c2grh 0 Posted February 21, 2007 Share Posted February 21, 2007 Ticket was $1989 but the guy I know there said they average about $1700-1750 so I figure the $1600 (+10% Warrenty) figure isn't too hard to negotiate.might be worth also trying DES Powerhouse in Carnegie or Nudawading as they had ticketed specials on this TV of around $1650 a week or so back. Got it today for $1,699 at DSE Southland. Plus $160 to extend the warranty from 1 year to 5 years. Link to post Share on other sites
csteddy 0 Posted February 22, 2007 Share Posted February 22, 2007 Today I bought the TX-32LXD600A for $1622 inc GST. Location - WA @ Myaree JB-HI FI Link to post Share on other sites
gtpdspin 0 Posted February 24, 2007 Share Posted February 24, 2007 Bought the TX-32LXD600A for $1712 from Harvey Norman City Cross. That's the best price I could find in Adelaide. Link to post Share on other sites
madmax 0 Posted February 25, 2007 Share Posted February 25, 2007 Got it today for $1,699 at DSE Southland. Plus $160 to extend the warranty from 1 year to 5 years. Any progress on the wall mounting c2grh? It's the only thing stopping me from buying this tv. Or did that mount you linked on the previous page work out okay? Link to post Share on other sites
c2grh 0 Posted February 25, 2007 Share Posted February 25, 2007 Any progress on the wall mounting c2grh? It's the only thing stopping me from buying this tv. Or did that mount you linked on the previous page work out okay? Sorry about that link on the other page Madmax. After looking at it again you were right that the minimum height is 180mm, and therefore no good for the pana with it's 120mm height. Haven't bought a mount as yet as I am trialling a couple of positions in the room before I decide whether I need tilt and/or swivel options or just a flat wall mount. By the way the pana flat wall mount you mention on the previous page is useless to me as it can only be attached to a stud wall with 450mm centres. My stud centres are 600mm which seems to be fairly standard in Australian houses built in the last 20 years or so. Te following link http://www.qsphere.com.au/mounts.html could solve your mounting problem. A combination of mounts PBL18 and PBL20 will give you 180 degrees swivel and 15 degrees tilt as well as being able to be mounted to studs with 600mm centres (not sure of your wall construction). This would cost you $270 - not sure if that's what you're willing to pay. Link to post Share on other sites
madmax 0 Posted February 25, 2007 Share Posted February 25, 2007 Well this just gets better and better doesn't it...... will investigate the stud distance soon, but am expecting the worst, and those mounts from qsphere are no good to me unfortunately......the hunt continues! Price is no issue, I will pay anything to make it work! I don't want to have to buy the Samsung, but I think it's the only VESA compatible integrated screen out there! [edit] Okay, some googling on the Sony 32" (whose mounting holes I measured to be 200 x 150mm or 200 x 170mm ) and I found this: "VESA compatible (requires SU-WL31 mounting bracket)", so I had a closer look, and it seems you have to attach the flat wall mount to the back of the tv, and this wall mount has holes for the VESA 200 x 100mm! Coud it be the same for the Pana?? And if not, perhaps holes could be drilled in the wall mount?? Messy, but perhaps possible?? [edit2] I see the Pana wall mount has no VESA holes, and a large void in the middle just to make it more difficult.....but it could be done by drilling holes 200 x 200mm just outside the void, then this Vogels mount becomes a possibility: http://www.vogels.com/detail.asp?ISSAID=58...&ChildID=-1 by using the Vogels supplied converter rods to convert the vertical 200mm to 100mm.....as you can see, I really want this tv, and this Vogels mount is the nicest I've found...... Link to post Share on other sites
Steffche 0 Posted February 25, 2007 Share Posted February 25, 2007 [edit] Okay, some googling on the Sony 32" (whose mounting holes I measured to be 200 x 150mm or 200 x 170mm ) and I found this: "VESA compatible (requires SU-WL31 mounting bracket)", so I had a closer look, and it seems you have to attach the flat wall mount to the back of the tv, and this wall mount has holes for the VESA 200 x 100mm! Coud it be the same for the Pana?? And if not, perhaps holes could be drilled in the wall mount?? Messy, but perhaps possible?? I just swapped my 26lxd600a for the 32" Sony Bravia V' series...excellent TV I have to say. The sound is a little disappointing, but unbeatable for picture quality and black levels....if you adjust it properly that is... http://www.lyris-lite.net/kdl32v2000_review.html Link to post Share on other sites
smee2 0 Posted February 26, 2007 Share Posted February 26, 2007 Is it possible to connect the PC through DVI->HDMI ?? I will be trying this very soon. I have a new Myth box (linux based hard disk video recorder) I am building with a video card that has VGA, S-Video, and DVI outputs. Do you know of any cheap converters, or cables with DVI on one end and HDMI on the other? Do JB sell them? Link to post Share on other sites
madmax 0 Posted February 26, 2007 Share Posted February 26, 2007 Ok, turns out the studs are at 450mm so if Plan A fails for any reason, I can easily move to Plan B (flat wall mount). Link to post Share on other sites
coylum 2 Posted March 3, 2007 Share Posted March 3, 2007 Hi, After reading the whole of this thread and doing much walking, viewing and reading I am convinced that the 600A is the TV for me (My shortlist was Sony KDL32V2000, Samsung LA32R71BDX and the LG 32LC2D). Now I have to find the cheapest price in the South East suburbs of Melbourne. It seems that $1700 plus extended warranty charge is the current "best price" I understand JB have just ticketed the item at $1794 (so I'm sure they would drop a $100??) Would appreciate any recent prices achieved in the Southland/Chadstone/Moorabbin areas. Thanks Link to post Share on other sites
taksan 0 Posted March 3, 2007 Share Posted March 3, 2007 Hi, After reading the whole of this thread and doing much walking, viewing and reading I am convinced that the 600A is the TV for me (My shortlist was Sony KDL32V2000, Samsung LA32R71BDX and the LG 32LC2D).Now I have to find the cheapest price in the South East suburbs of Melbourne. It seems that $1700 plus extended warranty charge is the current "best price" I understand JB have just ticketed the item at $1794 (so I'm sure they would drop a $100??) Would appreciate any recent prices achieved in the Southland/Chadstone/Moorabbin areas. Thanks Try HN at Chaddy ...speak to Michael Parfiti (salesman) he got me one for $1700 Link to post Share on other sites
RabidWolve 0 Posted March 4, 2007 Share Posted March 4, 2007 New owners of this TV can you tell me what version system software/bios it is running? Also for the PIP function can you display a component 720P picture with another source? Either DTV or Foxtel? Link to post Share on other sites
smee2 0 Posted March 4, 2007 Share Posted March 4, 2007 I will be trying this very soon. I have a new Myth box (linux based hard disk video recorder) I am building with a video card that has VGA, S-Video, and DVI outputs.Do you know of any cheap converters, or cables with DVI on one end and HDMI on the other? Do JB sell them? Haven't tried DVI yet, but using the VGA input, I'm getting a really great picture. It's great having a tv guide based hard disk recorder with dual digital tuners (my new myth box), and a great display like this Panasonic on which to play them back. Link to post Share on other sites
auziegway 0 Posted March 4, 2007 Share Posted March 4, 2007 Gosh ... This TV is sure becoming hot fav. for 32" section Tried 4 stores .. no Stock (S.east melbourne) Finally Bought it from Harvey Norman Nunawading $1660 Cash Price Great PQ, Great HD Tuner, Perfect Sound ... Fits snugly in my bedroom Only disappointment no acc. in the box , just the remote ... I expected at least an A/V cable ... Link to post Share on other sites
smee2 0 Posted March 5, 2007 Share Posted March 5, 2007 Gosh ... This TV is sure becoming hot fav. for 32" sectionTried 4 stores .. no Stock (S.east melbourne) Finally Bought it from Harvey Norman Nunawading $1660 Cash Price Great PQ, Great HD Tuner, Perfect Sound ... Fits snugly in my bedroom Only disappointment no acc. in the box , just the remote ... I expected at least an A/V cable ... How many? The things got 4 AV inputs, as well as 2 HDMI and a VGA ! Good price btw. I snagged one for $1675 recently and thought I did well. I've had it a week and no disappointments at all. It's a great TV. Link to post Share on other sites
auziegway 0 Posted March 5, 2007 Share Posted March 5, 2007 (edited) How many? The things got 4 AV inputs, as well as 2 HDMI and a VGA ! Fair enough, probably an HDMI cable should be shipped with every LCD/Plasma TV Any ideas which is the best way to connect my laptop (has both VGA & DVI-D) to the Pana ? a) VGA - VGA (analogue) ? DVI-D - HDMI (should work ?) ... they are cheap now http://www.staticice.com.au/cgi-bin/search.cgi?q=dvi+hdmi Was fiddling around with the menu and stumbled upon a GNU agreement (72) pages .... Wow they probably used the GNU source code to build upon DVB-T Tuner application .. Cool ... Also, in the near future ... would Pana decide to upgrade firmware .. I hope it should be possible to ugrade firware using SD ? Nevertheless great TV Edited March 5, 2007 by auziegway Link to post Share on other sites
smee2 0 Posted March 6, 2007 Share Posted March 6, 2007 Fair enough, probably an HDMI cable should be shipped with every LCD/Plasma TV Any ideas which is the best way to connect my laptop (has both VGA & DVI-D) to the Pana ? a) VGA - VGA (analogue) ? DVI-D - HDMI (should work ?) ... they are cheap now http://www.staticice.com.au/cgi-bin/search.cgi?q=dvi+hdmi Was fiddling around with the menu and stumbled upon a GNU agreement (72) pages .... Wow they probably used the GNU source code to build upon DVB-T Tuner application .. Cool ... Also, in the near future ... would Pana decide to upgrade firmware .. I hope it should be possible to ugrade firware using SD ? Nevertheless great TV Option B is pure digital and therefore should be cleanest (best?). I find VGA works very well though. Where did you find the GNU agreement on the menu? (and I hope you are right about firmware updates via SD card. That would be very easy.) Link to post Share on other sites
Neon Kitten 0 Posted March 6, 2007 Share Posted March 6, 2007 On the other hand, I can't fit the 32" panny, but I CAN fit the 32" Sony (because its speakers are at the bottom of the screen rather than the sides...). Sounds like you have the same A/V system wall unit as I do (mine's a really, really shoddily-made one from NZ company Criterion, which cost way too much and started falling apart weeks after I got it... that said, it HAS lasted 15 years now ) I'd go the Sony 40" W series tomorrow if I could get one, and dump the furniture. However I refuse to buy the X series until they make it available in black WITHOUT paying another $600-700 for a $10 bit of black plastic Link to post Share on other sites
auziegway 0 Posted March 7, 2007 Share Posted March 7, 2007 Option B is pure digital and therefore should be cleanest (best?). I find VGA works very well though.Where did you find the GNU agreement on the menu? (and I hope you are right about firmware updates via SD card. That would be very easy.) Under Setup Menu ... System Update .. DVB System Update there's a software license .. have a look at that Link to post Share on other sites
batts1503560780 0 Posted March 7, 2007 Share Posted March 7, 2007 Also, in the near future ... would Pana decide to upgrade firmware .. I hope it should be possible to ugrade firware using SD ? (and I hope you are right about firmware updates via SD card. That would be very easy.) Even easier, upgrade is transmitted! Link to post Share on other sites
Neon Kitten 0 Posted March 8, 2007 Share Posted March 8, 2007 Even easier, upgrade is transmitted! By who, exactly? Not the networks, that's for sure. Link to post Share on other sites
ravenhard 0 Posted March 9, 2007 Share Posted March 9, 2007 I just put a deposit down on this LCD. Got it for $1600 cash price at JB. Even got a free LCD wipe probably only worth 3cent. I was wondering bout warranty tho. My feeling is never buy a extended warranty. I never had for any other appliance and I never really had a major 1 break down within a warranty or extended warranty period. JB were offrering the warranty for 5 years at $180 discounted price. 1 hour before DSE would have given me 5 years at $120 which is another reason I didnt get the warranty from JB. So is the warranty worth it. Has any of the owners had any issues and can you get a warranty direct from Panasonic for cheaper? Link to post Share on other sites
zorg1503559539 0 Posted March 9, 2007 Share Posted March 9, 2007 which jb and state raven hard? Link to post Share on other sites
komer 0 Posted March 9, 2007 Share Posted March 9, 2007 Just ordered one of these too for 1655 in brisbane. Went to 7 different places and only JB Macgregor had it in stock but wanted 1750 for it. Happy to wait until end of the month for delivery. Link to post Share on other sites
ravenhard 0 Posted March 9, 2007 Share Posted March 9, 2007 which jb and state raven hard? Castle Hill in NSW Link to post Share on other sites
dclayw 0 Posted March 12, 2007 Share Posted March 12, 2007 There was some discussion earlier in this thread about the recording via SD card and how poor the quality was. Well, I have to agree, but if anyone is interested I recently bought an iPAQ pocket pc, basically a runout model and got it cheap. It's an iPAQ rx1950. I installed TCPMP on it, (a freeware media player for the pocket pc). TCPMP is one of the few players that can read ASF files, which is what the Panasonic TV records on the SD card. Bottom line is you can record on the SD card on the TV then plug the SD card straight into the iPAQ and play it back. Quality is ofcourse not an issue on a screen this size. Now I can record may favourite shows/movies or whatever and watch them on my iPAQ. I'm using 2GB SD cards by the way, purchased on ebay for $20. Link to post Share on other sites
smithcorp 0 Posted March 13, 2007 Share Posted March 13, 2007 There was some discussion earlier in this thread about the recording via SD card and how poor the quality was. Well, I have to agree, but if anyone is interested I recently bought an iPAQ pocket pc, basically a runout model and got it cheap. It's an iPAQ rx1950. I installed TCPMP on it, (a freeware media player for the pocket pc). TCPMP is one of the few players that can read ASF files, which is what the Panasonic TV records on the SD card.Bottom line is you can record on the SD card on the TV then plug the SD card straight into the iPAQ and play it back. Quality is ofcourse not an issue on a screen this size. Now I can record may favourite shows/movies or whatever and watch them on my iPAQ. I'm using 2GB SD cards by the way, purchased on ebay for $20. This is why i also think the SD card recording is a great idea with this TV! Link to post Share on other sites
-Anthony- 0 Posted March 13, 2007 Share Posted March 13, 2007 Where is the cheapest place to pick up this TV at the moment? Cheapest I was able to find was $1600 at DSE Powerhouse. Link to post Share on other sites
ttn 0 Posted March 18, 2007 Share Posted March 18, 2007 FYI, if anyone is interested, just bought a TX-32LX60A for $1100 by M/C from Bing Lee. It is advertised for $1199. Link to post Share on other sites
DigitalHT 0 Posted March 19, 2007 Share Posted March 19, 2007 Thinking of getting this panel but am not sure about the backlighting control. Have noticed that many have said they had problems with the auto backlighting feature. From what i've read the backlighting control can only be adjusted from the service menu otherwise your stuck with the presets. Is this right? Has anyone actually adjusted the backlighting from the service menu and have seen any benefits? Also considering the Sony KDL32V2000 and the Hitachi 32LD960DTA as they both have backlighting control on the OSD. The Sony is pricier and had limited inputs (esp. only 1 HDMI). The Hitachi is evenly priced as the Panasonic and uses the same technology but has the advantage of having 2 components rather then 1. The only thing that is missing from the Hitachi is no SPDIF out. I believe both the Panasonics and Sony are made in Japan, not too sure about Hitachi. Any feedback would be appreciated. Thanks. Link to post Share on other sites
dixitr 0 Posted March 21, 2007 Share Posted March 21, 2007 I have put down deposit for this unit. purchase price $1600 + $150 for 4 years addtitional warranty. but i have to wait till next week, as nobody seems to have any stock. i have called binglee bankstown, good guys bankstown, DSE powerhouse bankstown but no one has stock. and if you do not have stock, how do you negotiate. as for worth of warranty, i had a small power supply glitch in my fujitsu hd-plasma which costs me cool $500. they admitted it was only a $2 capacitor, but the diagnostic time & testing time etc meant they slugged me with $500. so i would rather pay $150 than risk a heft bill later. also, i had to take back my 20" CRT Samsung after exactly one year due to screen sizing issue. thank god i was under warranty - because the repair bill (charged to samsung) was $320 - for a TV which i got for $290 !!!!! apparently they had to replace the entire main PCB. would be interesting to hear other members opinions on this issue. Link to post Share on other sites
madmax 0 Posted March 23, 2007 Share Posted March 23, 2007 Anyone know the price of the wall mount (TY-WK32LX20W)? Was it negotiable? Link to post Share on other sites
dclayw 0 Posted March 23, 2007 Share Posted March 23, 2007 Thinking of getting this panel but am not sure about the backlighting control. Have noticed that many have said they had problems with the auto backlighting feature. From what i've read the backlighting control can only be adjusted from the service menu otherwise your stuck with the presets. Is this right? Has anyone actually adjusted the backlighting from the service menu and have seen any benefits? Also considering the Sony KDL32V2000 and the Hitachi 32LD960DTA as they both have backlighting control on the OSD. The Sony is pricier and had limited inputs (esp. only 1 HDMI). The Hitachi is evenly priced as the Panasonic and uses the same technology but has the advantage of having 2 components rather then 1. The only thing that is missing from the Hitachi is no SPDIF out. I believe both the Panasonics and Sony are made in Japan, not too sure about Hitachi. Any feedback would be appreciated. Thanks. There was some talk a while back about adjusting the backlight from the service menu but I don't think anyone ever did it sucessfully. You might want to check on the AV forums in the UK, there is a lot of info in there on this TV. I can't remember what settings I have on the TV right now but once I set it up I have not changed it (I've had the TV about 3-4 months now). The inability to adjust the backlight has not been a problem. I guess you get used to what you have but it's not an issue for me. The only thing I notice occasionally is when you get an add or something that has an almost totally white background. That is quite bright but it's not really a problem. For most viewing conditions the backlight is fine. My TV is in a very bright room (lots of sunlight), so viewing conditions are from very bright sunlit room to totally dark and the TV pretty much handles it all without adjusting any settings (once you do the initial setup). I'm not tring to plug the the TV but I think this backlight issue is highly overstated, if it is a problem at all then it is only a very minor one. The other benefits of the TV like better inputs and IMHO better PQ then any of it's competitors far outweigh the inability to adjust the backlight. Link to post Share on other sites
B9force 0 Posted March 23, 2007 Share Posted March 23, 2007 can you get a warranty direct from Panasonic for cheaper? When I bought my Panasonic home theatre receiver last year, included inside the box amongst the paperwork was an order form for an extended warranty that could be purchased from Panasonic Australia. (I had already bought an extended warranty from the retailer, and would have preferred to buy from Panasonic.) Can any owners of the 32LXD600A advise whether there was a Panasonic extended warranty offer in the box? Cheers Link to post Share on other sites
DigitalHT 0 Posted March 23, 2007 Share Posted March 23, 2007 There was some talk a while back about adjusting the backlight from the service menu but I don't think anyone ever did it sucessfully. You might want to check on the AV forums in the UK, there is a lot of info in there on this TV.I can't remember what settings I have on the TV right now but once I set it up I have not changed it (I've had the TV about 3-4 months now). The inability to adjust the backlight has not been a problem. I guess you get used to what you have but it's not an issue for me. The only thing I notice occasionally is when you get an add or something that has an almost totally white background. That is quite bright but it's not really a problem. For most viewing conditions the backlight is fine. My TV is in a very bright room (lots of sunlight), so viewing conditions are from very bright sunlit room to totally dark and the TV pretty much handles it all without adjusting any settings (once you do the initial setup). I'm not tring to plug the the TV but I think this backlight issue is highly overstated, if it is a problem at all then it is only a very minor one. The other benefits of the TV like better inputs and IMHO better PQ then any of it's competitors far outweigh the inability to adjust the backlight. Thanks for the reply dclayw. Had a looked at the Sony compared to the Panasonic today at Myers Melbourne CBD store. The Sony picture did look slightly better then the Panasonic. Not sure if this was whether to the enhanced settings that may be adjusted on the Sony or not though. The color on the Sony did look more vibrant and looked good on scenes with colourful backdrops. The Panasonic had a more natural colour. The Sony's colour maybe was to enhanced but it did look good to the eye at first glance. Noticed that the black level on the Sony was also slightly better. The viewing angle on both sets were pretty much the same as I couldn't determine a difference. The Sony is $500 more but is limited in inputs. The Panasonic can be had for $1600 as others have reported but is currently out of stock everywhere. Maybe the Hitachi 32LD960DTA which is similar to the Panasonic in both technology and price is the go? Link to post Share on other sites
madmax 0 Posted March 23, 2007 Share Posted March 23, 2007 There was some talk a while back about adjusting the backlight from the service menu but I don't think anyone ever did it sucessfully. You might want to check on the AV forums in the UK, there is a lot of info in there on this TV. Here is the info from the UK forum (took me freakin' ages to find it!): _ _ _ _ _ _ _ _ _ _ Press V/- on TV while holding the index button on remote, if it doesn't come try pressing them at the same time. (the index button is located directly below the yellow button on the remote, not the 'I' next to the '0', pressing this will bring up the self check menu and do a factory reset!) Now you can see service menu 1 with all sorts of options for adjusting rgb and backlight stuff Navigation: Keep pressing green button and watch throuh the options. pressing red will cycle backwards. Pressing the yellow and blue button will adjust the values for each option up and down resp. you will reach one point where you cannot go further (ie. the same display though you press green button) Press hold button on remote (next to index button) Now you se can see service menu 2 Again browse through various options by pressing the red/green button. The options in Service menu 2 are more cryptic now idea what these are. Lat option will show the amount of hours the set has been running though. press exit to exit the service menu. In service menu 1 for some options you will see 'normal' in the top right corner. This refers to the selected colour balance in the normal picture menu. If you want to adjust the warm colour balance, select this first form the normal picture menu then go into the service menu. I think you can adjust settings per input. So swicth to the HDMI input if you want to adjust those settings. _ _ _ _ _ _ _ _ _ _ Can someone please confirm that this procedure works for our local model? [edit] Came upon this a bit further along: "you need to set the bass to max and treble to minimum in the sound menu before pressing the index button and the volume down button. Didn't mention that in the post you quoted." So if the first procedure doesn't work, try this as well. If someone can confirm which is correct, I'll edit this post accordingly. Link to post Share on other sites
Madelaide 0 Posted March 24, 2007 Share Posted March 24, 2007 Here is the info from the UK forum (took me freakin' ages to find it!):_ _ _ _ _ _ _ _ _ _ Press V/- on TV while holding the index button on remote, if it doesn't come try pressing them at the same time. (the index button is located directly below the yellow button on the remote, not the 'I' next to the '0', pressing this will bring up the self check menu and do a ... settings per input. So swicth to the HDMI input if you want to adjust those settings. _ _ _ _ _ _ _ _ _ _ Can someone please confirm that this procedure works for our local model? [edit] Came upon this a bit further along: "you need to set the bass to max and treble to minimum in the sound menu before pressing the index button and the volume down button. Didn't mention that in the post you quoted." So if the first procedure doesn't work, try this as well. If someone can confirm which is correct, I'll edit this post accordingly. I'm not sure about those instructions, but these http://www.dtvforum.info/index.php?s=&...st&p=268934 do work (post #4 if the url doesn't show the right item) for my LX500A panasonic. Setting the channel to 99 is essential; I got to service menu 2, but I cannot find documentation on the service menu 2 settings. Good luck! M. Link to post Share on other sites
auziegway 0 Posted March 27, 2007 Share Posted March 27, 2007 When I bought my Panasonic home theatre receiver last year, included inside the box amongst the paperwork was an order form for an extended warranty that could be purchased from Panasonic Australia. (I had already bought an extended warranty from the retailer, and would have preferred to buy from Panasonic.)Can any owners of the 32LXD600A advise whether there was a Panasonic extended warranty offer in the box? Cheers Yes there is a form included. BUT Its highly overpriced ... about $300 for 2 extra years .. What a rip off !! Link to post Share on other sites
-Anthony- 0 Posted March 31, 2007 Share Posted March 31, 2007 Hey all, Just wondering how this TV compares with the Philips 32PF9631D. Thanks. Link to post Share on other sites
Grunter1503560097 0 Posted March 31, 2007 Share Posted March 31, 2007 Hey all,Just wondering how this TV compares with the Philips 32PF9631D. Thanks. Based off the comparisons I did, both PQ and features, I went for the Panasonic. And now days it's very well priced. Here's a link to another thread with some info on comparisons. Click Here Link to post Share on other sites
