RabidWolve
Bravia X To Launch Soon?
Made a call to Sony Central in Sydney today. They confirmed on the phone that the X SERIES will be in stock and on display FRIDAY 8th September. I put my name down for a call when it arrives. They said City and Chatswood would be recieving 40 and 46" sizes,
Price - they would not confirm - - all they said was they will be in stock and they had a list of customer waiting. Stock apparently was limited to a handfull of pieces they said.
Anyway - I will await the phone call and then maybe go have a look
The Sony Chatswood (Sydney) store (like the other Sydney Sony outlets I presume) have the X series up and running if anyone is interested. They also have stock for sale.
J.
J.
Yep, just rang them and they confirmed, I know where I will be tomorrow morning !!
2dr4u
I don't know if you will get this in time, but I am going to head down to Chatswood tomorrow morning as well. If you are interested in doing a group buy and try and knock the price down then put a post up and let me know.
Cheers mate
Got to see the x series in action today and boy was it impressive. It was only displaying 720p but still gave an even clearer picture than the V series. 1080p could only be mind blowing....
Sony Central at Chatswood would only knock $200 off the price, I am going to wait until it drops a little more. If anyone out there wants to do a group buy on the 46x2000 in the Sydney area then put up a post.
This is definitely the tv I have been waiting for!
If someone has asked this before sorry
Can you access the native resolution of the Bravia X with a HTPC ?
Via DVI I hope ?
If so it would be a killer monitor for the HTPC.
Via DVI I hope ?
Yep, using a DVI --> HDMI adapter.
So no overscan when connecting PC via DVI-HDMI? You can see the full screen, including the task bar? Can you please confirm?
Did anyone who checked out the X series take a look at the inputs for the display. I would really like to know what type and number of inputs the AU X series has.
Also does it have digital audio out for the HD tuner?
From what I have read on the UK & US AV forums, there is no overscan at all. It's a pure 1:1 pixel mapping.
Wow, This could be the thing that finally changes my mind from buying a Panasonic HD Plasma.
This is a killer application for the Bravia X series.
Bravia X-Series
Model#: KDL52X2000 KDL46X2000 KDL40X2000
SRP: $9999 $6999 $5499
Features
  • Full HD Resolution (1920 x 1080)
  • Integrated HD Digital Tuner
  • Sony S-PVA Panel
  • BRAVIA Engine (EX)
  • 2nd Generation Wide Colour Gamut CCFL (WCG-CCFL)
  • Wide Viewing Angle(178 Degrees)
  • HDMI Input
  • PC Input
  • Changeable Bezel colours
  • Floating Glass Design
  • Power Saving Mode
  • Multi Picture
  • Clock
  • On / Sleep Timer
  • Teletext
  • Light Sensor
  • Cinema Drive
Terminal
HDMI Input x2
Component In x3
S-Video in x2
Composite in x3
Headphone Out x1
HD15 / PC Audio Input x1
Specifications
Model KDL52X2000 KDL46X2000 KDL40X2000
Power Consumption [330W] [260W] [220W]
Dimensions (WxHxD mm)
With Stand [1415 × 890 × 384] [1262 × 795 × 322] [1111 × 717 × 322]
W/O Stand [1415 × 827 × 123] [1262 × 734 × 121] [1111 × 657 × 121]
Weight (Kg)
With Stand [54.5] [41] [35]
W/O Stand [47] [36] [30]
Any scart on the AU version of the X series ??
I've just posted the complete specifications of the AU Version X-Series Bravia. So the answer to your question, NO there's no SCART connection on the X-Series. :blink:
Is Harvey norman stocking these? I just checked out Myer and still only the new S but had some good bargins on the older Vs. I think if I can pick up a X 46inch for low 6s then that would be sweat... :blink:
Thanks for the info. :D
Thanks for the info. :P
That's ok :blink:
Scart is no good anyway, HDMI is the way to go now. :D
That's ok :blink:
Scart only carried other signals in a "all in one" analogue connector (eg Component / s-video / composite). So if the prior poster was looking to connect a scart device, then an adaptor would do the job. They should also be aware that scart connectors are not always bi-directional (ie make sure that the adaptor works with the direction the signal is going).
Given that scart can carry component, it really is still a good alternative to a digital connection.
J.
BTW - I have been hunting for some info on the 1:1 pixel mapping - anyone have any links to some information (perhaps buried deep within one of the large UK forums?)
That's ok :blink:
Currently have a pana dvd recorder using RGB via scart. I'll have to use S video into the X series untill I can invest in a new dvd player.
Yes, I agree with Scalpel regarding the SCART connection (just couldn't be bothered explaining it :blink: ). Like what he said SCART is an all-in-one connection, so you have to check the specs and see what kind of signal the device output.
When u say "RGB"? Do you mean component or the actual RGB connection? Cause RGB connection is not very common in devices as well as TVs. People sometimes gets confused and called a component connection as RGB because they use a red, green and blue cable. Anyway, for you 'lizclinton', I recommend you using component rather than S-video, you will get a better picture.
Most Scart devices do not support component through Scart. :blink:
There is not many Scart 2 Component adapters out there if it does support it.
My advise would be use S-video in short term until Blue-Ray or HD-DVD are released as current DVD's are
standard definition so not a huge difference between S-video and component.
Or you could buy a cheapish DVD player for short term use.
The Pana DVD recorders AV1 output menu gives three options, RGB, S Video & Video. I'm using the RGB option and assuming this is being carried over my Scart to Scart cable to the display.
I rang sony central perth for those wondering, it should be on display by Friday next week. No pricing yet :blink:
We've got the 40" and 46" X-Series on display already in the Sony Central World Square in the Sydney City. But I've seen them last month at SEM (Sony Experience More) a Sony only event in the Fox Studio. :D
