can i make a vga to rca composite video lead if so what do i need can you buy vga to rca composite video leads as well as vga to component leads if so how much are they what is the absolute cheapest vga to compsite and vga to component adaptors seperate vga to rca composite video and vga to component adaptor prices please
Here is a Crest lead not sure on price but you could ring Bing Lee/ HN with the product code.
Crest VGA to Component
The item in the link is a VGA to RGB cable, not VGA to composite or component.
There is no such thing as a VGA to composite cable, or VGA to component cable.
They are different video processing standards which require conversion first, before any adaptor cable can be used.
VGA - Component - S-Video - Composite Converter
Depending upon what you are trying to do, there are D_sub to component (or RGB) cables as pointed out above. Clearly, you need a componenet signal being put out the d-sub connection. But as Col points out, if you have an rgbhv signal from the d-sub connector, it needs to be converted to component before connecting it to a component input.
Fusion
  • 2 weeks later...
