brisbull 0 Posted November 16, 2006 Share Posted November 16, 2006 After the firmware upgrade, there is a definite visible difference between SD and HD channels. It is very clear, much more detail and colour depth on the HD chanel, for the same program (CH9 vs CH90). It may indeed be the case that the LG produces a very good SD picture, making the difference less obvious - I hooked up an exteral SD box, and the picture produced was of much lower quality than the internal LG tuner. Link to post Share on other sites
madent 0 Posted November 19, 2006 Share Posted November 19, 2006 Hi All.... I spent an hour at hardly normal today looking at the 42PC1DV ($1995) and the 42PC1DG ($2500) and, true to my form, decided to research it before buying...That's what brought me here... Firstly, the sales man pointed out immediately that the 42PC1DV output was standard definition and proceeded to show me the difference between the 2 models (the mesh screen effect was more visible on the 42PC1DV... I knew nothing of the issue with this until i read the posts on this forum... But I can tell you that the difference between the 2 models stuck out like the proverbial canine testicals.... But I have made several notes from the posts here and i will go back tomorrow morning armed with my clipboard and ready to grill the salesman.... But from what I saw today....I will be bringing one home... The bottom line to me is..I can't afford 4 to 5 Grand for a plasma and the 42PC1DG Craps all over what I'm watching now...and the price is definately affordable to me.... Let me know if theres anything you want me to ask him.... Cheers Link to post Share on other sites
mannie 0 Posted November 20, 2006 Share Posted November 20, 2006 Hi All....I spent an hour at hardly normal today looking at the 42PC1DV ($1995) and the 42PC1DG ($2500) and, true to my form, decided to research it before buying...That's what brought me here... Firstly, the sales man pointed out immediately that the 42PC1DV output was standard definition and proceeded to show me the difference between the 2 models (the mesh screen effect was more visible on the 42PC1DV... I knew nothing of the issue with this until i read the posts on this forum... But I can tell you that the difference between the 2 models stuck out like the proverbial canine testicals.... But I have made several notes from the posts here and i will go back tomorrow morning armed with my clipboard and ready to grill the salesman.... But from what I saw today....I will be bringing one home... The bottom line to me is..I can't afford 4 to 5 Grand for a plasma and the 42PC1DG Craps all over what I'm watching now...and the price is definately affordable to me.... Let me know if theres anything you want me to ask him.... Cheers I suppose the obvious question is if we buy an LG 42PC1DG today, has it already got the software upgrade done. I am starting to think they don't and we would still have to go through the hassle of finding a dealer to come out and do it. Link to post Share on other sites
CTT 0 Posted November 20, 2006 Share Posted November 20, 2006 I suppose the obvious question is if we buy an LG 42PC1DG today, has it already got the software upgrade done. I am starting to think they don't and we would still have to go through the hassle of finding a dealer to come out and do it. Absolutely agree - A good question to ask: Which firmware version is on the panels in store now? Link to post Share on other sites
modtec 0 Posted November 20, 2006 Share Posted November 20, 2006 I purchased a 42PC1DG in the first week of september and besides the SD/HD problem, also had issues with it freezing on Prime & Win intermitently (see previous posts). It had firmware V3.01.0 The store I bought it from has been very helpfull and replaced it with a brand new unit last week. There have been no freezing issues since, and on top of that, the new Firmware V3.03.0 has in my opinion fixed the HD issue as well. There is now a very noticable difference between SD and true HD programs. I had to wait 3 weeks for new stock to come in as there was a huge back-order with LG apparently......so I'd say that all new units now will also have the new firmware. Additionally, last week I got to see the 42PC1DG alongside the new Panasonic TH-42PX600A and I'm very satisfied that I didn't pay the extra $800 for the Pana. In my opinion there is bugger all difference that warrents the extra bucks. For $2500 the LG is a bargain. If you are going to look at one of these new LG's, get the salesman to find the remote and then you can check the firmware version on their display model yourself. (just press & hold menu on the remote and menu on the panel at the same time) If it's V3.03.0, that tells you that all their stock should be the same. Link to post Share on other sites
Scatpac 0 Posted November 20, 2006 Share Posted November 20, 2006 Thanks for the info modtec, I have had this unit since September and am completely satisfied with it apart from the SD/HD issue. A technician is coming to my place tomorrow to upgrade the firmware so I'll keep you all posted. If HD is improved then this is definitely the unit to buy for the price. Looks like the problem has been solved!!!! John G. Link to post Share on other sites
nickelwater 0 Posted November 20, 2006 Share Posted November 20, 2006 I was an early purchaser of the LG 42PC1DG back in August. Mine came with firmware v3.01 and I subsequently had it upgraded to v3.03. After reading the posts of others it does now look as if v3.03 really is the latest and that reporting of v3.23 was a red herring that applied to the 50" version. A few weeks ago I purchased a Toppy 7000 HD STB. I needed an STB to record to my DV-R and got the Toppy because it is often quoted as being the best but also because it allows up to 25 pre-set timings, far more than any other STB. I hooked the Toppy up to the LG 42PC1DG with both the component cables supplied by Topfield and also an HDMI cable I bought for about $30. One of the problems in analysing this whole hi-def question is that there is so little native hi-def being broadcast. Firstly the ABC and SBS are not yet in the game and Seven is only partially in. That just leaves Nine and Ten who broadcast some programs in 1080i. And since American content and other movie content is somewhat suspect that really just leaves programs coming from Nine and Ten's studios. Even then they are often showing video clips or adverts that just aren't native HD. So with that narrow opportunity to judge by I have compared both the SD and the HD picture quality eminating from the Toppy via Component cable and HDMI cable and via the LG's own tuner. And guess what? The LG's own tuner (for me) comes out best for both SD and HD. Now it could be argued that my HDMI cable was too cheap but I've read that price doesn't make much difference and I'm buggered if I'll spend $200 to extend this experiment. Right now HD is in its infancy in Australia. One day all TV, including sporting events, will be in HD and then we will really know if the LG 42PC1DG is worth its salt. For now I'm prepared to believe that its SD is well above par and therefore harder to tell from its HD. Link to post Share on other sites
brisbull 0 Posted November 20, 2006 Share Posted November 20, 2006 Right now HD is in its infancy in Australia. One day all TV, including sporting events, will be in HD and then we will really know if the LG 42PC1DG is worth its salt. True, but by that day, the 42PC1DG will actually be salt, having slowly mineralised after millions of years of exposure to the elements... Link to post Share on other sites
Aircon 0 Posted November 20, 2006 Share Posted November 20, 2006 I have a 60PY2D. anyone know what the latest version is for that? I have:- CPU VER 3.18.0 and MICOM VER 03.00 Link to post Share on other sites
Ted1503559509 0 Posted November 25, 2006 Share Posted November 25, 2006 FYI I have the 50PC1D and has the 3.02 firmware. The device was delivered 16 Nov as a replacement for the MW60Z... Link to post Share on other sites
emmcee55 0 Posted November 30, 2006 Share Posted November 30, 2006 I've just had the firmware on my set upgraded to ver 3.03 and I can't say I can notice much difference yet. I realise now that there is very little true HD programming being broadcast in Australia at this stage - hopefully that will improve in time. At least I will have a decent display if and when I purchase a HD or Blueray DVD player. Link to post Share on other sites
mannie 0 Posted December 13, 2006 Share Posted December 13, 2006 Well went down to Hardly Normal at Taren Point today, told the salesman about this problem and got the usual no it can't be true as LG would have told them if it was. Anyway got him to get the remote and found the following: CPU Vers: 3.04.0 Micom Ver: 3.00 So I think this would be okay, it is the CPU Version that has to be 3.03.0 or above, the Micom version is irrelevant? Just hoping to confirm before handing over the cash $2468 I think it was on special for. Link to post Share on other sites
blontic 0 Posted December 13, 2006 Share Posted December 13, 2006 Right now HD is in its infancy in Australia. One day all TV, including sporting events, will be in HD and then we will really know if the LG 42PC1DG is worth its salt. They are broadcasting AFL in HD next year. I think it's just a trial but they are doing it. Link to post Share on other sites
mannie 0 Posted December 16, 2006 Share Posted December 16, 2006 Domayne - Taren Point have the 42PX5D on sale for $2387, I got one with the 5yr warranty for $2570 Gave up on the 42PC1DG. Nearly fell over when I saw the 42PX5D on sale in the local paper, was down there first thing next day to get one. Link to post Share on other sites
snugmuffin 0 Posted December 20, 2006 Share Posted December 20, 2006 CPU Vers: 3.04.0Micom Ver: 3.00 So I think this would be okay, it is the CPU Version that has to be 3.03.0 or above, the Micom version is irrelevant? Hi, I bought this TV two days ago and I am very happy with it. I did just want to check on the firmware version however....I have the same details as the above guy and was also wondering whether it is the CPU or mircom version that counts? Can somebody who has had the upgrade please advise both of us on this matter! Thanks. Link to post Share on other sites
CTT 0 Posted December 20, 2006 Share Posted December 20, 2006 Hi all, Has anyone had a serious go at optimising the PQ on this unit yet? I am just starting to fiddle with the contrast etc to see what is best and I would be interested in anything that others have found. I've found that the most straightforward improvement to PQ is had by just turning the brightness down by 1 to 2 notches. This dramatically improves rendering of black. Anyone got any tips to share? Cheers, Colin. Link to post Share on other sites
SteveBuscemi 0 Posted December 24, 2006 Share Posted December 24, 2006 I have the 42" LCD version of this display (the manual covers both the 42PC1DG Plasma and 42LC2D LCD models) and the salesman at the time mentioned that he had noticed the HD/SD problem with the Plasma but not the LCD. Whether or not thats due to the Plasma being the older firmware revision I don't know, but I can definitely see a substantial difference between SD and HD on my LG. Link to post Share on other sites
phez 0 Posted December 25, 2006 Share Posted December 25, 2006 Anynews on the best price for these ? I have seen $2479 from SmartPrice online. Have cash. Link to post Share on other sites
skitzzza 0 Posted January 8, 2007 Share Posted January 8, 2007 So what video settings (brightness, contrast, sharpness, etc) has everyone decided on with this TV? Link to post Share on other sites
Walshey1503560392 0 Posted January 8, 2007 Share Posted January 8, 2007 hi I am writing this on behalf of a friend who has just bought one of these, he has been quite happy with his however spoted a few times while using it that every now and then the speakers on the tv would clip and crackle (at normal volume) and at the same time a black line would flash across the screen this was very intermitent but seing that it was only a week old he rang to get it replaced under waranty. However now the new tv has been recieved it appears it could be a slightly different revision it is labeled as a 42PC1DG-AA does anyone else know if this is a newer version or if it is older and if it is newer what has been revised? I will go have a look tomorrow and see what exactly is different from what he told me the stand and also button placement seems to be altered. Will update you all tomorow. Link to post Share on other sites
JimiD 0 Posted January 15, 2007 Share Posted January 15, 2007 Im new to this forum but thought you guys would like to know that i recently purchased the 42PC1DG for $2300 delivered with a component cable thrown in. just a quick question to see if anybody knows how to get the epg to display all channels rather than just the associated channels that you are currently viewing. I saw that this was raised earlier in the topic but there does not seem to be any replies to the query. Thanks for all your help in advance. Link to post Share on other sites
JimiD 0 Posted January 18, 2007 Share Posted January 18, 2007 Anybody??? Any help with the EPG or user settings for bedding in would be appreciated. Cheers Link to post Share on other sites
skitzzza 0 Posted January 18, 2007 Share Posted January 18, 2007 There is no EPG for viewing all the channels. Only the now and next information is available for whatever channel your on. Link to post Share on other sites
citykid_2000 0 Posted February 4, 2007 Share Posted February 4, 2007 Has anyone tried different picture settings and found one they liked? eg: standard,cool etc Link to post Share on other sites
citykid_2000 0 Posted February 6, 2007 Share Posted February 6, 2007 anyone guess not then Link to post Share on other sites
graf 0 Posted February 11, 2007 Share Posted February 11, 2007 how can i find out the version of firmware of my LG ? Link to post Share on other sites
citykid_2000 0 Posted February 11, 2007 Share Posted February 11, 2007 how can i find out the version of firmware of my LG ? Press menu on the remote nad menu on the tv and a hidden menu will pop up,you can go to version menu 7. Link to post Share on other sites
graf 0 Posted February 11, 2007 Share Posted February 11, 2007 Press menu on the remote nad menu on the tv and a hidden menu will pop up,you can go to version menu 7. THanks mate. How should I go about with getting LG to come out and upgrade my firmware ? Link to post Share on other sites
citykid_2000 0 Posted February 12, 2007 Share Posted February 12, 2007 THanks mate.How should I go about with getting LG to come out and upgrade my firmware ? Give them a ring explain situation,see what they say and go from there,my experience with lg is not to give up,just got this plasma as a replacement after 3 years, after buying the biggest dud technolgy DLP and still today they are crap.This tv seems to be ok,picture can be pixelated at times.So I going to upgrade my antenna using RG6 cable and see how I go from there. Link to post Share on other sites
spf1977 0 Posted February 13, 2007 Share Posted February 13, 2007 Hi All, New to this forum. I am currently looking for a plasma. I was thinking of purchasing the Panasonic TH-42PA60A but was in the Good Guys at Fyshwick today and the sales person thought I was better off purchasing the LG 42PC1DV. Not sure I need to spend the extra money to get the 42PC1DG. Price listed was $1788 before I did any haggling. Anyone with any thoughts? thanks. Link to post Share on other sites
simon5574 0 Posted March 3, 2007 Share Posted March 3, 2007 Hi All,New to this forum. I am currently looking for a plasma. I was thinking of purchasing the Panasonic TH-42PA60A but was in the Good Guys at Fyshwick today and the sales person thought I was better off purchasing the LG 42PC1DV. Not sure I need to spend the extra money to get the 42PC1DG. Price listed was $1788 before I did any haggling. Anyone with any thoughts? thanks. My parents just bought the LG PC1DG yesterday and i have the PC1DV (bought about 6 months ago). Good question, what are the key differences? Apart from one being black and about $700 more Re Firmware upgrade, is there a national number or something i can ring, i spent ages look through this thread. I have version 3.00 and HD is the same as SD picture Link to post Share on other sites
skitzzza 0 Posted March 3, 2007 Share Posted March 3, 2007 My parents just bought the LG PC1DG yesterday and i have the PC1DV (bought about 6 months ago).Good question, what are the key differences? Apart from one being black and about $700 more Re Firmware upgrade, is there a national number or something i can ring, i spent ages look through this thread. I have version 3.00 and HD is the same as SD picture PC1DG is a HD screen, and PC1DV is a SD screen. Link to post Share on other sites
simon5574 0 Posted March 3, 2007 Share Posted March 3, 2007 PC1DG is a HD screen, and PC1DV is a SD screen. Thanks for the quick reply, Both have HD tuners but only one has a HD screen, why bother with an inbuilt HD tuner then?. LG are weird Link to post Share on other sites
nis200979 0 Posted March 4, 2007 Share Posted March 4, 2007 Thanks for the quick reply,Both have HD tuners but only one has a HD screen, why bother with an inbuilt HD tuner then?. LG are weird Progressive Scan versus Interlaced. It makes a small difference but is great marketing. The Th42PA60 has a better picture than LG but requires a sepearate STB (+ sep remote) and doesnt have PC input. Instead, the new Samsung 42" HD plasma with HD tuner is down to $2349 at Myer now and I know someone in Vic that can do very close to the price you had on the SD LG. Also, 2yr warranty standard. Link to post Share on other sites
simon5574 0 Posted March 4, 2007 Share Posted March 4, 2007 PC1DG is a HD screen, and PC1DV is a SD screen. So saying DG is about $700 more Which set is better value for money? PC1DG is a HD screen, and PC1DV is a SD screen. So saying DG is about $700 more Which set is better value for money? Link to post Share on other sites
TC11503561154 0 Posted March 15, 2007 Share Posted March 15, 2007 Hi new here. I just bought my LG 42PC1DG from the good guys castle hill for 2000(the 1080p must be really close now). When I press both menu buttons I don't get the menu to show me the firmware?? Is there more to it or have LG changed the button codes to reveal the hidden menu?? Thanks TC1 Press menu on the remote nad menu on the tv and a hidden menu will pop up,you can go to version menu 7. Link to post Share on other sites
Scatpac 0 Posted March 16, 2007 Share Posted March 16, 2007 Hi new here. I just bought my LG 42PC1DG from the good guys castle hill for 2000(the 1080p must be really close now). When I press both menu buttons I don't get the menu to show me the firmware?? Is there more to it or have LG changed the button codes to reveal the hidden menu?? Thanks TC1 I tried it yesterday and it worked ok. Try pressing the TV menu button slightly before the remote and just wait a few seconds. It dosen't appear straight away. Cheers. Link to post Share on other sites
latino 0 Posted March 17, 2007 Share Posted March 17, 2007 my 42PC1DG recently froze on me when turning it to channel 9. I looked through this forum and have a few questions My TV is the following verison CPU ver: 3.12.0 Micom V: V3.02 Is it old? or recent? I got my TV from Jb Hifi in Nov. 06. Can I take it back to them if its old or do I have to bug LG to upgrade me. It takes like 10seconds from when I hit the power button to display the channel on the screen. Does anyone else have this problem? Link to post Share on other sites
automan 0 Posted March 17, 2007 Share Posted March 17, 2007 my 42PC1DG recently froze on me when turning it to channel 9.I looked through this forum and have a few questions My TV is the following verison CPU ver: 3.12.0 Micom V: V3.02 Is it old? or recent? I got my TV from Jb Hifi in Nov. 06. Can I take it back to them if its old or do I have to bug LG to upgrade me. It takes like 10seconds from when I hit the power button to display the channel on the screen. Does anyone else have this problem? I heard that Channel 9 has been transmitting unusual and infrequent surges through their HD digital transmissions and that that has been causing freezing on LG integrated tuners. They say the problem can be fixed by unplugging the tv from the wall for five minutes before switching the tv back on. If that does not work then go back into the menu and re-tune in the digital channels. Hope this helps. So saying DG is about $700 moreWhich set is better value for money? So saying DG is about $700 more Which set is better value for money? For anyone interested my local good guys(hoppers crossing) have the 42PC1DG model for $2300. I heard the salesman talking to a customer and said the lowest he could do it for was $2200. Hope this helps. Link to post Share on other sites
mickyt71 0 Posted March 18, 2007 Share Posted March 18, 2007 (edited) Over the weekend I had a return of my LG 42PC1DG freezing on channel 9 both Saturday afternoon and Sunday evening (during the last couple of minutes of 20 to 1). I called Penisula TV who I have had service my panel before. They told me it is channel 9 doing some upgrade on their digital service and errors are being received in the stream that the tuner doesn't like. They told me to unplug the unit for an hour and plug it back in. I said that is simply not good enough and asked about a firmware upgrade. They said they are working on one but one is not yet available. I bought a TV to watch not switch off for 1 hour and stare at a blank screen! Seriously unimpressed I decided to give LG a call. Thier Customer Service 1800 number was engaged for the first few minutes. After getting through I had a very lengthy queue wait. Once through I was told there techs were working with channel 9 to resolve the issue but at the moment there is no fix. He also stated they had received 200+ calls this morning from customers. Edited March 18, 2007 by mickyt71 Link to post Share on other sites
