Details on new panasonic 600A plasma
I contacted panasonic customer care today. The new panasonic 600A plasma will arrive in Australian stores sometime in April 2006. The RRP will be $4499 for 42 inch. It will have 2 HDMI inputs, and is lighter and thinner than current model.
What they can't tell me is whether the picture quality will be better than the current model.
Does anyone know?
I am wondering whether I should take advantage on getting a good deal with current model or wait till new one comes out.
Any advice would be appreciated.
Thankyou!
  • Replies 471
Does anyone know?
Thankyou!
Yeah its gonna be a fair amount better:
VIERA, 42inch/106cm Plasma TV, 1080p Digital Processing
Chipset, 1080p Digital Re-Mastering Processor, 9th Generation
Plasma Panel, Advanced Colour Management System, 3072
steps of Gradation, 28.9 billion viewable colors, Sub-Pixel
Coltroller, Max. 10,000:1 Contrast Ratio, Contrast
Management System, New Real Black Drive System with Deep
Black Filter, HD AVI, High Definition Panel, Resolution - 1024
x 768, 1080i/720p/576p Input, Multi Window - Picture And
Text, Analogue TV Tuner & Speakers, 2 x HDMI Inputs, PC
Input.
Input.
Lets be frank here...
Firstly these things should pop out around $3800 at a guess.
1080p digital processing chipset???? WTF... My guess its like putting aerofoils on a mini... marketing spin..
The current blacks on the 500A are superb... I dont think you will see a major improvement with the 600A.. could be another marketing ploy.
Analog tuner ??? You would have thought digital by now.
I dont like the full silver bezel.
Considering the current can be had for under $3000.. Im not sure the extra dollars are worth shelving out for.
Sometimes in life you notice that a particular model that has been a winner cant be replicated despite the manufacturer throwing a few add ons. I think the 500A is one of those models.
Time will tell I guess :blink:
New model is slightly cheaper than the current has been at a wholesale level.
1080p processing is not a function of gen8.
Yes gen8 was great, no-one is slagging them off so relax people. Gen9 is gonna be very nice.
We all agree not having dtv built in sux, but another hdmi input is also very welcome.
At 1024 x 768 the panel cant do native 720p so what chances is going to do 1080p ?
Its a marketing ploy...
An extra HDMI is useful to some admittedly but I have an extra one now on my 500A as im running HTPC :blink:
"New model is slightly cheaper than the current has been at a wholesale level"
So the 600A is going to be less than $3000 ?
They will be giving them away soon :P
if we get the 600A in April, i will be suprised.....apparently they wont be avaliable in the US and UK until June
i thought there would be a inbuilt digital tuner with this model but i guess i was wrong....anyway, technology marches on but i'm happy with my 500A :blink:
Check out the UK website http://shop.panasonic.co.uk/invt/th42px60ped
It appears available in the UK at the moment.
Thanks for all your help. I think I will wait until the new version comes out, even though I won't get as good a deal as the current model.
1080p, 2 x HDMI inputs I think is worth that bit extra.
Would you agree?
thats the 60 Model....the 600 model is the premium model
pics
maybe youve confused the 600 with 60.....Panasonic might decide to release the 60 down here instead of the 600.....
Edited by jey16
pics
Sorry jey16, I obviously had confused the 600 with the 60. Thanks for setting me straight.
I wonder what the differences are between the 2 and which one Panasonic will release in Australia. Does anyone know?
the differences between the as far as i know depend on the country, for example in the US...the advantages the 600 model has include a PC Input, PIP and better speakers
the UK 60 model does not have the better speakers, PIP and additionally it misses out on the SD card slot although it does have a PC input
so i'm not sure what we will get here
if Panasonic want to release it in April, then it would have to be the 60 model because as i said, apprently the 600 is not due until June although for a couple of days a week or two ago, there were a few flash presentations on the Panasonic.com.au website about Plasma's and it had information on the new model, the pics in the presentation were of the 600 model and said that it would include a digital tuner....the presentations were taken down though so maybe they changed their mind
unless you could get a really good price on the current model....i'd wait for the new ones :blink:
Edited by jey16
Actually, it has the potential to be far more beneficial than it sounds. Current Panasonic plasmas only apply bob de-interlacing (like the majority of other plasmas on the market) to ALL 1080i sources. In other words they convert 1440x540 interlaced fields from a 1080i broadcast directly to 768p. This means you're missing out on 228 lines of vertical resolution, as well as getting a major softening of the picture, and the introduction of interpolation and scaling artifacts such as jaggies and shimmer. They still look good using this method, but there is definitely room for improvement.
With 1080p processing, the panel will properly de-interlace 1080i signals to 1080p, before down-scaling to the panel’s native 768p resolution. The result is you get the best possible resolution and a smoother picture with more detail and less artifacts.
Rumour has it they will also support 1080p input via HDMI, which means there will be no de-interlacing required from Blu-Ray players, and the panel will simply do a nice neat down-conversion from 1080p to 768p, also resulting in a much better picture.
You can read more about de-interlacing and scaling here.
I'll make my judgement when I compare the two sets side-by-side.
Unfortunately on 1024 x 768 set there is scaling and a loss of resolution.
Will the extra processing be that noticeable on a 42 inch er?
We have folks out there who cant tell the difference between SD and HD sets lets alone upscaling and downscaling.
On top of all that we have broadcasters transmitting a different signals.
Its going to end up in tears for some :blink:
If people cant tell the difference between SD and HD, then they need to see an optometrist
I cant beleive there is a new model coming out already. I only just got my 500a a month ago and I wish it has 2 HDMI inputs :blink: Damn good tv though!
I agree, two hdmi inputs would of been real handy. But i will have to stick with the 500a cant justify spending more money on another tv when the one i have looks fantastic.
So will I. I was simply pointing out that 1080p processing can have some very good real world benefits and is much more than “marketing hype” as you described it.
You’ll find the move to 1080p processing on digital displays is a very common thing over the next 2 years. It’s a way overdue development, as up until this point many people haven’t been getting the most out of their HD displays (which is why external video processors are so popular with top end HT enthusiasts).
If done well (using weave for film, and motion adaptive de-interlacing for 1080i video) then yes, definitely. You’ll effectively be getting over 200 lines of extra resolution and a sharper picture with less visible motion artifacts. Seating distance will factor into this, but they should look significantly better with a SD and HD sources.
That’s true, but they’re not the ones we are talking about. Using that argument we should all have stuck with 68cm 4x3 interlaced SD displays with composite input :blink:
Orders are already places for the new panels to arrive in april. This includes the 42 SD & HD, as well as the 50". Likewise a completely new range of Viera LCD's, these also will not be including DTV tuners, unfortunately, although they do look alot nicer, better specs etc.
If you want inbuilt HDTV tuner with panny LCD, then they will still be running with the current model that is out there.
Unfort it is crap compared to the viera LCD's.
BTW, who is actually getting the 500 for under $3k?? Thats one hell of a price.
Hello,
I'm just back from the UK & I used AVforums as my guide to all things HiFi & Home Cinema, I'm sure your all familar with it but if you don't know about it I suggest you should join. They have an entire section dedicated to the new 60 & 600 Pani's. I've ncluded the link below.
http://www.avforums.com/forums/showthread.php?t=317667
I also contacted Panasonic Australia about these models & they reluctantly told me the following:
We will launch the Viera Plasma V60 TVs which presumably are the
equivalent of the PX60 in April and May. Our website should be updated soon on these new models.
It sounds like it's had mixed reviews but I supposed we will all have to wait until they appear so we can demo it next to the PV500 or the Fuji HHA51as (my 2 fav's).
Matt
a mate of mine works are retravision and i got him to ask the panasonic rep if they knew anymore infor and when these new models were to be released, he told him May 9th is the release date. now the tough decision is whether to wait or grab a bargain now on the current model
Ok,
Here you can see the differences between Gen 8 and Gen 9.
Gen 8 Brochure:
http://panasonic.com.au/content/library/files/F001450.pdf
Gen 9 Brochure:
http://www.panasonic.it/_ftp/catalogs/VIERActlg_EU_06.pdf
The main differences I can see is that Gen 9 has something called "V-REAL", 29 billion colours instead of 8.6 billion colours (Gen 8) and a contrast ratio of 10,000:1 instead of 3,000:1 (Gen 8).
Edited by skinXBWAU
good find there skin. in the looks department the new 600 I think looks heaps better than the current one and also better than the 60 version as well. wonder which one makes it here and whether we get the built in digital tuner or not.
I don't actually mind the design of the 60 and don't really care about the better speakers (because who really uses TV speakers) or the SD Card slot.
The silver strip along the base with the black above means it matches both my Squeezebox 3 and my future HK AVR635.
I also like how the "Panasonic" brand name is less intrusive on the silver part of the 60 than it is on the black part of the 600. Although I guess the 600 looks bigger because of the larger black frame.
I reckon that TH-50PV60 looks the biz. :blink: BTW - What is the "IDTV" version? EDIT: Oh it has a built-in tuner.
Just noticed: I don't think any of them do 720p or 1080i at 60 Hz. Could be a problem for Xbox 360 use?
I reckon that TH-50PV60 looks the biz. :P BTW - What is the "IDTV" version? EDIT: Oh it has a built-in tuner.
The difference between the 8th gen and 9th gen panels..by all accounts from those who actually seen them in action.. absolutely nothing... accept at bit of Hi Ho silver around the edges.
You can only do so much with a limited space and the 42 inch plasma has done its dash.
We talked about this 6 months ago.. How can the 42 inch plasma's improve... Digital tuner,a couple of extra features like sd cards or extra connections.
We hear about 1080i upscaling to 1080p. PLEASE take your hand off it.
The 42 inch panel is limited because of the amount of pixels it can actually display.
Manufacturers have to keep the punter interested, so of course they will release a new model with hype.
Its called marketing and people get sucked in everyday.
Remember the difference between a SD panel and a HD panel is only a couple of feet.
Some people go to extraordinary lengths to justify those couple of extra feet.
Others go way over the top to breakdown those feet into inches.
The 42 inch plasma panel is a ****.Its a great size but geometrically speaking it doesnt gel with the technology.
Doesnt matter how much make-up you apply to it, underneath, its still a ****. :blink:
So what are your thoughts on the 50inch?
In the few years I have been looking at plasma screens they have improved incredibly in both picture quality and price. What makes you think this progress is going to stop? I don't know how much better next generation Panasonic will be but I have absolutely no doubt that we will see better and cheaper 42 inch panels from a number of manufacturers in the near future. Moore's law seems to hold pretty well for more than just PCs.
Faced with this rapid change all we can do is buy the best value for money equipment at the time when we need it and then enjoy it (which you are obviously doing with the excellent Panasonic panel).
I have been told that a new panasonic plasma will be in Australian stores April 26th. It will have 2 HDMI's but no inbuilt digital tuner. There will be a second (different) plasma sometime December 2006. The salesman couldn't tell me the exact names of them (ie. 60 or 600). My guess is 60 in April, 600 later.
Another thing he told me sounded a bit weird:
'Having inbuilt digital tuner is actually a disadvantage (compared with LG PVR) because you can't record in digital HD format.'
Maybe someone could confirm or refute this statement?
Everything about Japanese manufacturing and production is built around the design model of small gradual innovations. Small innovations result in less design and production costs. So yes the changes look small but what did you honestly expect, this is how they operate.
well it depends really, if you have a HD PVR then having a digital tuner built into the plasma wont make a difference since you will be using the PVR to watch and record TV
if you dont have one though...and just want to watch digital tv, then having a built in tuner would be an advantage, 1 less box in your setup and less cables....and it might be cheaper then buying a seperate set top box
December does seem a bit late for the 600...i was thinking july, late April sounds right for the 60 though
Actually most of the comments I have read at the AV forums indicate a big jump in picture quality, and that’s just with SD material.
You have to remember that UK viewers don’t have any free to air 1080i broadcasting yet, so unless they can see side by side comparisons of Euro1080 (satellite HD broadcast channel) in store, there’s no way anyone can do a side by side comparison of the difference in 1080i quality between the older 500A and the new 60A/600A panels with 1080p processing.
To suggest that a proper de-interlace of 1080i to 1080p before being downscaled to 768p wont look better than bobbing 540i directly to 768p (which is what the 500A does with 1080i) is pretty absurd. Of course it’s going to look better. Just how much better 1080p processing makes a 42” panel look remains to be seen in real world tests, but of course it will make a difference.
Then you have the jump in black levels from the new black filter and the greater amount of colours resulting in smoother colour gradation. These things will of course improve picture quality too.
It would seem very clear from all your comments Lasty that you made up your mind about these new Panasonic panels long ago, and they haven’t arrived in Australia yet! Maybe wait and see how they look for yourself?
I think Lasty has made some interesting comments in his above posts esp "The 50 incher is a different ball game."
This avforums link UK, gives comment in regard to difference between 42” & 50” 600 model and link to photo (from Cebit Germany) showing the two together.
(photo can be resized by clicking box in right hand corner)
I think it fair to say that down scaling to 720p is always going to give a worthwhile improvement over up scaling to 720p. Then there is the extra benefit of the better form of de-interlacing Darklord gave an excellent post on.
Improvements to what are already the best plasma blacks in the business must be something to see. However I'll wait and see re the extra colours. I'm not convinced that going beyond 1 billion colours gives a noticeable improvement. But give me 1 billion over 16.7 million any day.
