alanh
Indoor Antennas For Digital Tv
This post has been removed by the author and saved by him
Edited by alanh
What's the best indoor antenna for HD digital signals ? in the Pakenham Victoria region ? I want to try this more simple approach first, before going into the Mr Antenna scenario and getting external antenna installation approval from the building management etc....
:blink:
LMagic007,
It does not matter whether it is HD or SD the both signals are combined into a single signal on the channel shown in the Geographic Viewers' Forum shown below.
AlanH
LMagic007,
Please put location specific posts in their Geographic Forums and keep this post for general detail on Indoor antennas.
AlanH
davidok1,
Please ask you question in the appropriate Geographic Viewers' forum with your town/suburb. I cannot answer otherwise. The Geographic Forums are near the bottom of the main forum home page.
AlanH
for some strange reason, when im near the rabbit ears, quality is up at about 50% but when I move away the quality drops to about 35% wats going on there? strength stays the same at about 70% :blink:
If your antenna is between you and the transmitter; its possible that you are playing "reflector" duty!
If, instead, you are between the transmitter and your antenna- you'd be acting as a "director".
A good indoor antenna I use is one from Dick Smith. It has the rabbit ears but also a small UHF antenna built-in. If you wrap the cable from the base to the UHF antenna around the little pole then plug it in to the set top box, it seems to work well. I recieve the ABC at 91% and SBS at 95%, signal strength wise on my computer. Hope this manages to help someone.
mjstokesy,
Reception with indoor antennas depends on the strength of the signal around the antenna, the number and strength of reflections, the channel being received, the polarisation of the signal. This is why I wrote the pinned post. This is why a properly installed outside antenna is always better. In digital this means a more reliable signal.
AlanH
Does anyone have any success stories using only an indoor antenna.
After reading this topic I am tempted to give it a go as I receive fantastic analogue reception.
I backed off after I was told by an A/V salesman that it flatly would NOT work at all.
MattP
MatthewP,
It really depends on your exact location, including in the room. Also which real channels you wish to pick up.
Also if the channels you are trying to receive are in bands 4 and or 5 the indoor antenna which looks like a mini outdoor antenna are better.
AlanH
MattP
I live in Wagga Wagga and had good results with a Tandy/Dick Smith indoor tv antenna with built-in amplifier. The transmitter is pretty close, but with the amp off the signal breaks up and/or drops out, however with the amp turned on the picture is excellent with no drop outs. This applies to the digital HD transmissions too.
So I am happy with digital tv reception with an indoor antenna but found I did need the amplifier turned on otherwise the drop outs are to annoying.
im looking to buy dtv100t for my PC... though my only option at the moment is to use an indoor antenna... are there any tips anybody would like to give?
I seem to have picked up that my rabbit ears will work best wen its horizontally presented and the length it is spread out has some effect too.
I am in the South of Brisbane...and we get ok analogue reception on our TV's, but as soon as the PC is on, the quality is dramatically effected... because I'll be getting a PC dtv tuner.. will my reception be always effected?
