Rho Beta 19 Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, Luc said: @Rho Beta"Oils aint oils Sol." And going by your avatar your old enough to remember that spiel. haha! Yeah, that's me. A few years ago in fact. And yes I do remember that, "Oils ain't oils" Link to post Share on other sites
GregWormald 1,706 Posted November 9, 2020 Share Posted November 9, 2020 I've heard of all sorts of substitutes but can only really recommend that you contact the manufacturer. Most OEM oils are fairly cheap as only small amounts are used. 1 Link to post Share on other sites
cafe latte 148 Posted November 9, 2020 Share Posted November 9, 2020 49 minutes ago, GregWormald said: I've heard of all sorts of substitutes but can only really recommend that you contact the manufacturer. Most OEM oils are fairly cheap as only small amounts are used. Not all manufactures get it right, many smaller companies who build great turntables are not oil experts. Michell is a good example the recommend Mobile one car engine oil. A turntable does not need a multi grade (cold running) and an open bearing does not want emulsifying agents in the oil nor detergents keeping crud suspended as turntable bearings dont have an oil filter. It would have been far better if they suggested a similar weight machine oil . I emailed them a few times asking this question and they just ignored me emails. 1 litre of a decent compressor oil will cost about the same as 20mls so you will have enough for ever and even to use for other stuff. Chris Link to post Share on other sites
Rho Beta 19 Posted November 9, 2020 Share Posted November 9, 2020 56 minutes ago, GregWormald said: I've heard of all sorts of substitutes but can only really recommend that you contact the manufacturer. Most OEM oils are fairly cheap as only small amounts are used. Yup. And I've done that today. Visited the Pro-ject Audio Australia web site and dropped them an email. I'll post here what I find out. Link to post Share on other sites
Rho Beta 19 Posted November 27, 2020 Share Posted November 27, 2020 On 09/11/2020 at 8:01 PM, Rho Beta said: Yup. And I've done that today. Visited the Pro-ject Audio Australia web site and dropped them an email. I'll post here what I find out. …And they kindly replied. I also contacted Sound Station HiFi in Toowoomba, where I bought the turntable and asked for advice. Pro-Ject Audio told me the bearing already comes lubricated (as you'd expect) and that should last for years. They also sell a product in a syringe applicator specifically for their inverted bearing turntable range (called Grease IT) and recommend this if you somehow need to re-apply lubrication to the bearing. A little goes a long way and one application should last years. Blair McCosker, the Sound Station proprietor suggested the best way to buy the product would be to buy it on line direct from the OEM. I agree. Link to post Share on other sites
