anthonysimilion
What's In Hd This Week
I'll have to make a new thread every week for this, as after a few days I am unable to edit the first post (to update the information). It'll be weekly from now on. Do you think it should be every three or four days to keep it fresh in people's minds - or should I stick to weekly?
Isn't there something called a "sticky thread" - whatever that is?? I assume it is some sort of editable thread?
Or you could ask Coral to give you permission to edit this thread on a more regular basis.
Yes progressive does give you an improvement in PQ at SD resolutions but it's hardly Hi-Def, merely a more stable image!
Stable? Seven use BOB deinterlacing to get a Progressive signal. You'll see logos and text "bob" up and down to verify this.
very true, but I was trying to keep it simple and avoid the "which de-interlacing system is teh l33t" debate. :blink:
I understand this but Seven's HD seems to be at a higher bitrate (not sure about this). As beyond what improvements can be made from making it a progressive image, the image quality seems to be better in colour and probably most importantly better in detail (lacking fewer digital artifacts) than the same SD image. So while I agree the resolution is slack, it's still a fair bit better than just changing an 'i' to a 'p'.
Keen
The bitrate Seven uses is still far too low even for 576p. You should see PRiME's 576p, whose bitrate is over 12.57mbps as opposed to Seven's 9.00mbps. This means PRiME's picture will be less pixelated than Seven's and also less compression artifacts.
Either way, both Seven SD AND 576p show way too many artifacts and pixelation to begin with, and neither are as apparent on PRiME's 576p.
Finally, calling 576p "HD" is a joke.
7 ED Forum No. 163 :P:blink::P
I agree Prime 's ED is much better than 7 poo.
It's still No better than SD.It's still No better than SD.It's still No better than SD.It's still No better than SD.It's still No better than SD.It's still No better than SD.It's still No better than SD.It's still No better than SD
im sorry, but im not sure what point it is, that you are trying to make? :blink:
Edited by djos
His point is that seven's 'HD' is no better than its SD and I disagree completely.
ITS WORSE!!!
Stones
ITS WORSE!!!
Stones
Are you american, if you are then my above attempt at humour, comes under the heading of irony. :blink:
What's In High Definition This Week
My vote would be update weekly.
Update
An updated guide, covering 8/01/06 to 15/01/06 has been posted. This thread can now be bookmarked, for easier access.
Love your work Anthony :blink:
