djOS Posted February 11, 2007 Share Posted February 11, 2007 Unfortunately, I have no way of knowing which Seven 576p programs will be DD5.1 or not. Bummer, thanks anyway mate. Link to comment Share on other sites More sharing options...
desmonc Posted February 14, 2007 Share Posted February 14, 2007 Ten HD is 1080i - a true HD resolution.Star Wars will be in HD, according to the guide! Hi Anthony, Check out the Ch 10 HD pic in this post it shows 1440x1088@25 so its not true 1080i only Ch 9 has that. http://www.dtvforum.info/index.php?showtop...mp;#entry540797 Chris Link to comment Share on other sites More sharing options...
sold Posted February 14, 2007 Share Posted February 14, 2007 Hi Anthony,Check out the Ch 10 HD pic in this post it shows 1440x1088@25 so its not true 1080i only Ch 9 has that. http://www.dtvforum.info/index.php?showtop...mp;#entry540797 Chris Ten HD switched to 1920*1080i@50Hz recently. Nine HD is either 1920*1080i@50Hz or 1440*1080i@50Hz depending on which city you are in (both of which would be classed by the majority of people as HD). Link to comment Share on other sites More sharing options...
djOS Posted February 14, 2007 Share Posted February 14, 2007 Hi Anthony,Check out the Ch 10 HD pic in this post it shows 1440x1088@25 so its not true 1080i only Ch 9 has that. http://www.dtvforum.info/index.php?showtop...mp;#entry540797 Chris 10HD in Melbourne is most definitely 1920x1080i as reported to me via DNTV Live; it was previously 1440x1080i. Link to comment Share on other sites More sharing options...
abdelrm Posted February 15, 2007 Share Posted February 15, 2007 Saving Babies was presented in High Definition and double checked on the TEN website also. Thursdays 8.00pm - Saving Babies - Network TEN Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 15, 2007 Author Share Posted February 15, 2007 Good to know, TEN is really putting a lot of effort into HD programming! Link to comment Share on other sites More sharing options...
spanky123 Posted February 16, 2007 Share Posted February 16, 2007 Doh. I would've thought Bourne Identity tonight would've been HD. Are you guys sure it isn't ? The picture is extremely good, but then again I'm only watching on a 19" LCD, so I can't really tell if it's HD oh. . . and i'm not sure if I've said this before, but thanks anthony for your work =) Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 16, 2007 Author Share Posted February 16, 2007 It's not, and it hasn't been when it was previously shown unfortunately. Definitely a movie that would be great on the big screen in HD. Link to comment Share on other sites More sharing options...
LBM Posted February 16, 2007 Share Posted February 16, 2007 Watermark = Not HD. Just like last time (and the sequel), Ten didn't show it in HD. I too agree that it would be a movie that would benefit but the Blu-Ray (or whatever format) version should do fine. Link to comment Share on other sites More sharing options...
stazi Posted February 17, 2007 Share Posted February 17, 2007 wow! thanks for all your work on this. i was wondering where you compile the info from regarding the programming Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 17, 2007 Author Share Posted February 17, 2007 wow! thanks for all your work on this. i was wondering where you compile the info from regarding the programming I compile it all manually from a number of sources. Examples of some freely available television guides on the internet that include HD information include: www.ebroadcast.com.au www.yourtv.com.au Thanks for using the guide. Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 17, 2007 Author Share Posted February 17, 2007 Update An updated guide, covering 18/02/07 to 23/02/07 has been posted. Link to comment Share on other sites More sharing options...
straycat Posted February 18, 2007 Share Posted February 18, 2007 (edited) What's In High Definition This Week Since joining the HDTV club 6 mnths ago at the bargain basement level (Acer AT3201W LCD display through Legend LHD2) I have been frustrated at the lack of info available re which FTA progs are in HD or widescreen. Like many noobs, I suspect, I will often watch a program that I wouldn't normally bother with just because it's in HD. I registered as a member today mainly so I can thank you, Tony, for providing this very useful guide which I have frequently referred to and regularly print out and keep handy. Still can't understand why the TV guides in the newspapers, or the weekly TV guide mags, don't include this essential information. Thankyou then, for your good work in compiling the guide on a weekly basis. btw: for those who are known to say "If you can't tell the difference between SD & HD then why bother with HD?"..... As those unfortunates who, like myself, purchased the LHD2, will appreciate, this box gives no indication of the source definition, & to change between HD formats requires about 20 keystrokes to navigate a clumsy menu (including PIN code). With the 2 different HD formats in use by 9/10 & ABC, and the 576P used by 7, it becomes tiresome and impractical to attempt an A/B test for each channel change. Edit: OK, I exaggerated. Just counted the keystrokes. At least 13, not 20. Still tiresome though. Edited February 18, 2007 by straycat Link to comment Share on other sites More sharing options...
Craig M Posted February 18, 2007 Share Posted February 18, 2007 8:30pm - MOVIE: Charlie's Angels: Full Throttle will be DD5.1 audio on Nine HD, Friday 23 Feb. Craig. Link to comment Share on other sites More sharing options...
desmonc Posted February 19, 2007 Share Posted February 19, 2007 10HD in Melbourne is most definitely 1920x1080i as reported to me via DNTV Live; it was previously 1440x1080i. Absolutely right but its only changed in the last couple of months (in Perth), I updated the resolutions post, it now shows 1920x1080. http://www.dtvforum.info/index.php?s=&...st&p=598292 Chris Link to comment Share on other sites More sharing options...
digitalj Posted February 19, 2007 Share Posted February 19, 2007 Ugly Betty, even though it was only ED, it had DD 5.1. Is it worth adding this just for the DD 5.1? Link to comment Share on other sites More sharing options...
LBM Posted February 19, 2007 Share Posted February 19, 2007 The thread is "What's In HD this week", not "What's has a 5.1 track this week". I say no, Seven don't deserve mention at all when it comes to HD content. Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 24, 2007 Author Share Posted February 24, 2007 Update An updated guide, covering 24/02/07 to 3/03/07 has been posted. Link to comment Share on other sites More sharing options...
digitalj Posted February 24, 2007 Share Posted February 24, 2007 I'm not so sure where you got the info for MIB2 from, but we've been watching it since 6:30pm. Link to comment Share on other sites More sharing options...
Craig M Posted February 24, 2007 Share Posted February 24, 2007 And Nine HD Movies with DD 5.1 listed here... http://www.dba.org.au/index.asp?sectionID=126 Craig. Link to comment Share on other sites More sharing options...
digitalj Posted February 24, 2007 Share Posted February 24, 2007 And Nine HD Movies with DD 5.1 listed here...http://www.dba.org.au/index.asp?sectionID=126 Craig. Those movies are widescreen SD, there's nothing in there that's listed as HD. Link to comment Share on other sites More sharing options...
anthonysimilion Posted February 24, 2007 Author Share Posted February 24, 2007 I'm not so sure where you got the info for MIB2 from, but we've been watching it since 6:30pm. It's shown at different times in different states, due to the NAB Cup. In Perth it is being broadcast at 8:00pm. Link to comment Share on other sites More sharing options...
anonymez Posted February 24, 2007 Share Posted February 24, 2007 MIB II is SD, at least here in Brisbane-- Yourtv and TEN's guide agrees It was HD the last few times it was broadcast, however. Link to comment Share on other sites More sharing options...
digitalj Posted February 24, 2007 Share Posted February 24, 2007 MIB II is SD, at least here in Brisbane-- Yourtv and TEN's guide agrees Was also SD in Sydney. Link to comment Share on other sites More sharing options...
Craig M Posted February 24, 2007 Share Posted February 24, 2007 Those movies are widescreen SD, there's nothing in there that's listed as HD. Ahem...Yes there is.. Nine's High Definition Movies: Charlie's Angels, Full Throttle [+ DD 5.1 audio] (Friday 23 February) Murder At 1600 (Friday 23 February) Daddy Day Care [+ DD 5.1 audio] (Saturday 24 February, Sydney & Brisbane only) Just Cause (Sunday 25 February) Black Out (Sunday 25 February) Murder By Numbers [+DD 5.1 audio] (Friday 2 March) Chicken Run (Saturday 3 March, Sydney & Brisbane only) Richie Rich (Saturday 3 March, Melbourne, Adelaide & Perth only) The Witches of Eastwick (Saturday 3 March) The Punisher [+DD 5.1 audio] (Sunday 4 March) Ocean's Twelve [+DD 5.1 audio] (Friday 9 March) A Cinderella Story [+DD 5.1 audio] (Saturday 10 March) What Women Want (Saturday 10 March) Link to comment Share on other sites More sharing options...
