billabong33 Posted October 30, 2005 Share Posted October 30, 2005 Hi Guys. Just Wondering My mate sent me a .ts file and Nero Media player won't play it and nither will anything else. Is thier some out there on the Internet i can download and install for free or will i have to buy something? Thanks for your comments in advance! Link to comment Share on other sites More sharing options...
jasonwea Posted October 30, 2005 Share Posted October 30, 2005 When stuck in Windows I use Media Player Classic when I want to play a TS recording from my MythTV server. Link to comment Share on other sites More sharing options...
billabong33 Posted October 30, 2005 Author Share Posted October 30, 2005 Yes I have windows media player classic and it will NOT play it. It says cannot playback format. Are thier any specialised programs designed just for this format or a Codec for Media player? Link to comment Share on other sites More sharing options...
algarve7 Posted October 30, 2005 Share Posted October 30, 2005 Yes I have windows media player classic and it will NOT play it. It says cannot playback format. Are thier any specialised programs designed just for this format or a Codec for Media player? <{POST_SNAPBACK}> Are you sure you have Media Player Classic (MPC) v6.4.8.4? It's not the same as Windows Media Player (Microsoft). MPC has a lot of extra specialised features that WMP doesn't have. Here's an easy place to get it: http://www.afterdawn.com/software/video_so...yer_classic.cfm Another great player is VLC Media Player. It can play just about anything under the sun. Even half downloaded video files. http://www.videolan.org/vlc/ Make sure you have FFDSHOW video filter installed. If you do have the right player, and it doesn't work it may just need a good codec. FFDSHOW decodes most streams. http://www.afterdawn.com/software/video_so...ers/ffdshow.cfm What I'm interested in is a player that has built in DxVA (Direct X Video Acceleration). It directs most of the processing of the video to the hardware -- basically the video card (if the video card supports DxVA that is, which most new ones do) rather than letting the CPU do all the work. When I use Media Player Classic it plays the .tp files, but not so well (a bit jerky) because it doesn't have DxVA (I think) so my CPU sits on 100%. Is it any different if you have a digital TV tuner card in the computer? Anyway, I hope that helps. Comments welcome... Link to comment Share on other sites More sharing options...
tw1965 Posted October 30, 2005 Share Posted October 30, 2005 DVBPortal HDTV Pump Filter: http://www.dvbportal.de/projects/hdtvpump/ TSFileSource : http://nate.dynalias.net/TSFileSource/TSFileSource.html Elecard/MoonLight Player Link to comment Share on other sites More sharing options...
renura Posted October 30, 2005 Share Posted October 30, 2005 Hi Guys.Just Wondering My mate sent me a .ts file and Nero Media player won't play it and nither will anything else. Is thier some out there on the Internet i can download and install for free or will i have to buy something? Thanks for your comments in advance! <{POST_SNAPBACK}> You can try this Link to comment Share on other sites More sharing options...
hoolaparara Posted October 31, 2005 Share Posted October 31, 2005 Or an Mplayer windows build from http://www.mplayerhq.hu/ Link to comment Share on other sites More sharing options...
billabong33 Posted October 31, 2005 Author Share Posted October 31, 2005 Downloaded VLC Player. Works a treat. Thanks While im at it does anyone know a player that plays .Amr files?? Its for my Mobile phone it has a few sound clips on it as .Amr files. Cheers Link to comment Share on other sites More sharing options...
