Redemption 0 Posted July 5, 2006 Share Posted July 5, 2006 Has anyone got a ps2 hooked up to their 8800? How does it look? Does the scaler do a good enough job in scaling the ps2 signal to the screen's resolution? I want to get a big screen for ps2 so this is one of the options I'm looking at, but a bit hesitant because the screen res is quite different to the ps2's 640x480 (?) signal. Thanks Link to post Share on other sites
Chopstar 0 Posted July 5, 2006 Share Posted July 5, 2006 Has anyone got a ps2 hooked up to their 8800? How does it look? Does the scaler do a good enough job in scaling the ps2 signal to the screen's resolution?I want to get a big screen for ps2 so this is one of the options I'm looking at, but a bit hesitant because the screen res is quite different to the ps2's 640x480 (?) signal. Thanks I have a PS2 hooked into my Panasonic 500a 42 inch and it looks awesome. It trips the light fantastic at the highest resolution. Link to post Share on other sites
Ivalice. 0 Posted July 5, 2006 Author Share Posted July 5, 2006 I find the HDMI port to be excellent, but it really depends on the quality of the source material, scaling resolution and cables. I also have component (at 1080i) from my STB looking just as good as HDMI through Monster MV3CV cables. My HTPC screensaver kicks in at 1 minute - better safe than sorry. Yeah, I love it. It's an attention grabber. I'm hanging out for HDDVD and Blu-Ray too. But I have reservations as to how improved colour bit depth will be handled over the HDMI interface (v1.2 compliant in the 8800, I think). Not sure if the extra bits will make it through the interface or whether it will be limited to 8 bits per channel like DVI is at the moment - I'm still investigating that aspect. Still, the native HD resolution will be great. ATTENTION GRADDBER I SERIOUSLY CONCUR, as for the HDMI 1.2-1.3 issue, I wouldnt mind utilising just the Native interface through 1.2, seriously It would definitely still provide excellent visual quality, however I was curious on the fact if the HDMI port could be upgraded through software update by Hitachi Fingers crossed on that regard. The spec's as claimed by Hitachi is the simulataneous display of 68.6 Billions colours, hmmm perhaps only something beyond the current DVD could the panel receive its full potential. obviously something similar to Blu-Ray or HD-DVD can it only realize the panel's HD capabelibilties! Link to post Share on other sites
helldiver 0 Posted July 5, 2006 Share Posted July 5, 2006 simultaneous display of 68.6 Billions colours ... which is 12 bit per channel colour and HDMI 1.3 is supposed to offer up to 16 bits per channel. What I haven't yet figured out is whether the Hitachi 8800 (claiming 12 bits) uses 12 bits only internally in manipulation of colours (e.g. A/D conversion from component; arithmetic operations) which is finally output at 8 bits per channel for display, or whether they built in the ability (additional to the HDMI 1.1/1.2 spec) to handle and display 12 bit colour over the HDMI interface - i.e. a proprietry adaptation of HDMI. ATM I can't tell, because all my source devices are 8 bit per channel (STB, DVD, HTPC). Got to say, Ivalice, for the person who started this thread in the first place, you waited a LONG time to make your purchase. You have more patience than I. Link to post Share on other sites
Ivalice. 0 Posted July 5, 2006 Author Share Posted July 5, 2006 After watching numerous DVD's It has come to my attention that dispite the fact of 16:9 frames used by the 8800's. The infamous black boarders are apparent on the Top and Bottem directions of the screen. quiet annoying TBH. however there are on few occasions where I see full screen NATIVE (without adjusting any Zoom in functions through the TV) displays through some DVD's I.e The Trueman Show, Japaness Anime "Hell Sing" are all displayed to completely cover the screen without having to display the Black boarders on either sides (Top and Bottom). Could someone please clarify this strange phenomenal please? Cheers Link to post Share on other sites
helldiver 0 Posted July 5, 2006 Share Posted July 5, 2006 After watching numerous DVD's It has come to my attention that dispite the fact of 16:9 frames used by the 8800's. The infamous black boarders are apparent on the Top and Bottem directions of the screen. quiet annoying TBH. however there are on few occasions where I see full screen NATIVE (without adjusting any Zoom in functions through the TV) displays through some DVD's I.e The Trueman Show, Japaness Anime "Hell Sing" are all displayed to completely cover the screen without having to display the Black boarders on either sides (Top and Bottom). Could someone please clarify this strange phenomenal please? Cheers Sure - most cinema DVDs are recorded in 2.35:1 rather than the screen's native 1.78:1 (16:9), so you will correctly see black borders top and bottom. Check the back of the DVD case - it usually gives you the aspect ratio. Link to post Share on other sites
Peter D 0 Posted July 5, 2006 Share Posted July 5, 2006 What I haven't yet figured out is whether the Hitachi 8800 (claiming 12 bits) uses 12 bits only internally in manipulation of colours (e.g. A/D conversion from component; arithmetic operations) which is finally output at 8 bits per channel for display, or whether they built in the ability (additional to the HDMI 1.1/1.2 spec) to handle and display 12 bit colour over the HDMI interface - i.e. a proprietry adaptation of HDMI. If it converts down to 8 bits to get it to the display, it can't be showing 68billion colors as it claims. It must output 12 bits from it internal processor to the display. I expect that it is doing all its calculations at something greater than 12 bits e.g. 16 or 32. After all calculations are done, it is reduced to 12 bits for display. I doubt that it accepts anything other than 8 bit on the HDMI input. Link to post Share on other sites
Struggo 1 Posted July 5, 2006 Share Posted July 5, 2006 Hi All, 8800 @ JB Macarthur Square $3047 clearance sale. Time to go shopping tomorrow. I know Bing Lee, David Jones, HN & JB all have this model in stock around my way. I have yet to see a 8900 yet. Check out this ASPECT RATIO site, http://en.wikipedia.org/wiki/Aspect_ratio_(image) Cheers Struggo Link to post Share on other sites
Struggo 1 Posted July 5, 2006 Share Posted July 5, 2006 good on you for posting RB. I'm still waiting for my replacment hitachi from HN, was supposed to be a 8800 but if they keep drag it out too long I might even end up with a 8900. So good to read your impressions and think at this stage will be pretty happy with either, anyways good to hear the 8900 is not a backward step for hitachi Hi Alebonau, Got your new set yet? Cheers Struggo Link to post Share on other sites
Moderators betty boop 15,742 Posted July 5, 2006 Moderators Share Posted July 5, 2006 Hi Alebonau,Got your new set yet? Cheers Struggo no call from HN as yet, originally they did say they needed to order one in. And I'm not rinign them to check till I start seing 8900's around the place. I'm in no hurry the old plasma is still going albeit with the white stripes every now and then Link to post Share on other sites
Ivalice. 0 Posted July 5, 2006 Author Share Posted July 5, 2006 Got to say, Ivalice, for the person who started this thread in the first place, you waited a LONG time to make your purchase. You have more patience than I. LOL I sure did, didnt I, no remorse though, as I got mine for a descent price of $3.1K cash, Prices like this could not have been achieved merely six month ago. anyway we could finally indulge in the full HD experience offered by the panel! p.s and thx for clarifying the aspect ratio for me HDFAN! appreciated :D Link to post Share on other sites
schmick1503560689 0 Posted July 5, 2006 Share Posted July 5, 2006 Hey Peoples, Just got back from JB Hi-Fi at Kedron... Best price they could do on the 8800 Panel was $3,070... Anybody think we would be able to see anything lower than this? The big killer is the extended warranty, 5yrs for $599... He said he could do the Panel and the Extended Warranty for $3,500... Also, something that I found weird is that he didn't think that the Hitachi could be used to dispaly the upcoming PS3 Console? Something about not being able to accept the signal? Is this correct? Anbody in Brisbane who has any recommended retailers? What are peoples thoughts on the price given the model is now discontinued in anticipation of the 8900..?? Link to post Share on other sites
Ivalice. 0 Posted July 5, 2006 Author Share Posted July 5, 2006 Hey Peoples,Just got back from JB Hi-Fi at Kedron... Best price they could do on the 8800 Panel was $3,070... Anybody think we would be able to see anything lower than this? The big killer is the extended warranty, 5yrs for $599... He said he could do the Panel and the Extended Warranty for $3,500... Also, something that I found weird is that he didn't think that the Hitachi could be used to dispaly the upcoming PS3 Console? Something about not being able to accept the signal? Is this correct? Anbody in Brisbane who has any recommended retailers? What are peoples thoughts on the price given the model is now discontinued in anticipation of the 8900..?? OMG....Tell me this is just another marketing sales scam... the HDMI capabilities offered through the 8800's are nothing short of expectation. its not the latest version as its claimed by what Sony has endorsed over the Ps3's but I would still expect the 8800's to render Ps3 signal's through it's HDMI inputs flawlessly...otherwise there will be no market's for the Ps3 as the new HDMI 1.3 ports wont be available by early 07... :ph34r: Link to post Share on other sites
ozyozy123 0 Posted July 5, 2006 Share Posted July 5, 2006 Hi all, I'm a little angry at what has happened this evening. This morning I called up a particular retailer requesting a price for the Hitachi 8800. He wouldn't give me his best price over the phone, so I told him what my best price was (buy another retailer). I didn't want to go in only to find out he can't match or beat it. Anyway, the price I quoted him over the phone was $3250 including a 5 year warranty. He agreed to beat this price if I came in tonight. So, after work I make my way down there and after testing the unit out for a bit, I decide to buy. His best price which he had agreed to in person was $3200 (inc. 5yr warranty). I agreed and then made my way to the service desk to pay for the unit. He misteriously walked off and re-appeared 2 minutes later advising me that he can't do it for $3200 as it is too cheap. He said he can do it for $3250. I wasn't too fussed, so thought about it then questioned how he can quote me one price then change his mind 2 minutes later. Anyway, I then agree to purchase the unit for $3250 including the 5 year warranty. I was shocked by what he had to say next. "Sorry, but I can't do that price its too cheap. I can do $3250 for the unit alone, but warranty will be extra". What the?? Is this guy for real? I was so p*ssed off I asked him to call his manager. He then made some lame excuse, saying his manager had just left for the day. Arrrgghhhh. What a total waste of time! It just annoyed me going to all that trouble, then have him shaft me over like that. Talk about unethical sales! Is there anything I can do about this? It really has frustrated me. Regards, Ozy Link to post Share on other sites
schmick1503560689 0 Posted July 5, 2006 Share Posted July 5, 2006 OMG....Tell me this is just another marketing sales scam... the HDMI capabilities offered through the 8800's are nothing short of expectation. its not the latest version as its claimed by what Sony has endorsed over the Ps3's but I would still expect the 8800's to render Ps3 signal's through it's HDMI inputs flawlessly...otherwise there will be no market's for the Ps3 as the new HDMI 1.3 ports wont be available by early 07... :ph34r: Invalice, that's what I was thinking... The PS3 as you mentioned would have no market if you needed the latest and greatest TV to be even able to utilise the PS3... I figured that the Hitachi would accept the signal of the PS3 then I assume scale it down to the Unit's capabilities, am I correct? Link to post Share on other sites
Ivalice. 0 Posted July 5, 2006 Author Share Posted July 5, 2006 Invalice, that's what I was thinking... The PS3 as you mentioned would have no market if you needed the latest and greatest TV to be even able to utilise the PS3... I figured that the Hitachi would accept the signal of the PS3 then I assume scale it down to the Unit's capabilities, am I correct? Definitely, its out of logic to even assume Sony would lose 99% of their estimated market share by mandatory consumers to upgrade to HDMI 1.3...thats irrational and completly out of question coming from a respectable global manufacturer. Non the less I would regard the 8800 to handle "Ps3" successfully this is without doubt Link to post Share on other sites
schmick1503560689 0 Posted July 5, 2006 Share Posted July 5, 2006 Non the less I would regard the 8800 to handle "Ps3" successfully this is without doubt WOOOHOO! Link to post Share on other sites
Struggo 1 Posted July 5, 2006 Share Posted July 5, 2006 Hi all,I'm a little angry at what has happened this evening. This morning I called up a particular retailer requesting a price for the Hitachi 8800. He wouldn't give me his best price over the phone, so I told him what my best price was (buy another retailer). I didn't want to go in only to find out he can't match or beat it. Anyway, the price I quoted him over the phone was $3250 including a 5 year warranty. He agreed to beat this price if I came in tonight. So, after work I make my way down there and after testing the unit out for a bit, I decide to buy. His best price which he had agreed to in person was $3200 (inc. 5yr warranty). I agreed and then made my way to the service desk to pay for the unit. He misteriously walked off and re-appeared 2 minutes later advising me that he can't do it for $3200 as it is too cheap. He said he can do it for $3250. I wasn't too fussed, so thought about it then questioned how he can quote me one price then change his mind 2 minutes later. Anyway, I then agree to purchase the unit for $3250 including the 5 year warranty. I was shocked by what he had to say next. "Sorry, but I can't do that price its too cheap. I can do $3250 for the unit alone, but warranty will be extra". What the?? Is this guy for real? I was so p*ssed off I asked him to call his manager. He then made some lame excuse, saying his manager had just left for the day. Arrrgghhhh. What a total waste of time! It just annoyed me going to all that trouble, then have him shaft me over like that. Talk about unethical sales! Is there anything I can do about this? It really has frustrated me. Regards, Ozy Report the PR%#K to fair trading! Call his manager and give him a mouth full also. Link to post Share on other sites
pjc 0 Posted July 5, 2006 Share Posted July 5, 2006 Arrrgghhhh. What a total waste of time! It just annoyed me going to all that trouble, then have him shaft me over like that. Talk about unethical sales! Is there anything I can do about this? It really has frustrated me. Regards, Ozy After all your research and build up it must have been dissapointing. Hope you get the 8800 somewhere else at a reasonable price. Philip Link to post Share on other sites
llan 0 Posted July 6, 2006 Share Posted July 6, 2006 Hi, My 8800 arrived yesterday, set it up with component, entered suggested settings from earlier in this thread, sat back last night with a slightly awed feeling while watching, well worth the purchase. I might add that this is with a cheap sd stb, I'll try to wait until a decent hd pvr hits the market. All of this purchase was based upon information from these forums, long may they live!!!! Regards and thanks to all, Bill Link to post Share on other sites
simonactive 0 Posted July 6, 2006 Share Posted July 6, 2006 no call from HN as yet, originally they did say they needed to order one in. And I'm not rinign them to check till I start seing 8900's around the place. I'm in no hurry the old plasma is still going albeit with the white stripes every now and then Just rang Hitachi Australia because JB HiFi are taking to long to get back to me. There are no more 8800's left at the wharehouse and there are also no more 8900's in the Hitachi wharehouse either. They have all been ordered and shipped to the stores. Hitachi are ordering more 8900's as we speak. But i have asked around at JB,David Jones and Harvey Norman and none of the sales reps have even heard of the 8900 let alone when it will be in stock. It seems we know more than the stores. What the hell is going on ? Has anyone seen a 8900 in a store in Melbourne and where ? Link to post Share on other sites
Moderators betty boop 15,742 Posted July 6, 2006 Moderators Share Posted July 6, 2006 Just rang Hitachi Australia because JB HiFi are taking to long to get back to me. There are no more 8800's left at the wharehouse and there are also no more 8900's in the Hitachi wharehouse either. They have all been ordered and shipped to the stores. Hitachi are ordering more 8900's as we speak. But i have asked around at JB,David Jones and Harvey Norman and none of the sales reps have even heard of the 8900 let alone when it will be in stock. It seems we know more than the stores. What the hell is going on ? Has anyone seen a 8900 in a store in Melbourne and where ? not sure on the 8900 but got a call from HN sayign they had my name on a 8800. Apparently that was the last actually coming from the chadstone store. The store I was talkign too itself said they had anotehr waiting for pickup fro ma customer and another 2 on order with no ideas or further mention of the 8900. Somone mentioned someplace that theyre using this opportunity to clear the 580TA model which is same price with the built in tuner but with an older gen screen. The 5900 is as asia market panel maybe the stocks jsut havent come yet. The hitachi rep I spoke to at a HN store week or so ago said the 8900 they wouldnt be selling for atleast another month Link to post Share on other sites
Ivalice. 0 Posted July 6, 2006 Author Share Posted July 6, 2006 Hi,My 8800 arrived yesterday, set it up with component, entered suggested settings from earlier in this thread, sat back last night with a slightly awed feeling while watching, well worth the purchase. I might add that this is with a cheap sd stb, I'll try to wait until a decent hd pvr hits the market. All of this purchase was based upon information from these forums, long may they live!!!! Regards and thanks to all, Bill Im still running mine through factory defaults I.e Contrast 0 Brightness 0 Colour 0, I was hoping to fine tune the babe in another couple of weeks , after the initial running in period as stated by numerous forumers. Happy Joy with your 8800 as I was totally blown away by the DVD quality (via component Progressive). without doubt image quality would increase eventually as more fine tunes takes place. Cheers Iva Link to post Share on other sites
schmick1503560689 0 Posted July 6, 2006 Share Posted July 6, 2006 Hey Peoples, Well I put a deposit down on my 8800TA today at Clive Peters at Aspley... Got the panel for $2,900 + $460 for 5 yr warranty, bringing the total to $3,360... That was the cheapest price I could get! JB Hi-Fi, Videopro, Harvey Normal were all around the $3,500 mark still.... Can't wait to get the thing home and setup, though that will be a couple of weeks away as I'm still awaiting other goodies to be put into our new home! Now, can anbody point me in the right direction for a good STB and also DVD player to utilise the awesome 8800? Any help appreciated... Link to post Share on other sites
Smocky 0 Posted July 6, 2006 Share Posted July 6, 2006 If it helps anyone, I've got a receipt from Bing Lee Castle Hill here for the 8800 at $2,850. I mentioned it on this thread when I bought it 3 weeks or so ago. If it helps, I can fax the receipt for price matching. BTW, this thing is stunning. I'm sure the 8900 will be great too, but get yourself a bargain while their clearing them. Sub $3,000 for this quality panel is simply outstanding. Jason. Link to post Share on other sites
Struggo 1 Posted July 6, 2006 Share Posted July 6, 2006 If it helps anyone, I've got a receipt from Bing Lee Castle Hill here for the 8800 at $2,850. I mentioned it on this thread when I bought it 3 weeks or so ago. If it helps, I can fax the receipt for price matching.BTW, this thing is stunning. I'm sure the 8900 will be great too, but get yourself a bargain while their clearing them. Sub $3,000 for this quality panel is simply outstanding. Jason. That's a great price Smocky. Did that include an extened warranty? If not how much where you quoted if you don't mind. I may pay a visit to my local Bing Lee today. Cheers Link to post Share on other sites
schmick1503560689 0 Posted July 6, 2006 Share Posted July 6, 2006 If it helps anyone, I've got a receipt from Bing Lee Castle Hill here for the 8800 at $2,850. I mentioned it on this thread when I bought it 3 weeks or so ago. If it helps, I can fax the receipt for price matching.BTW, this thing is stunning. I'm sure the 8900 will be great too, but get yourself a bargain while their clearing them. Sub $3,000 for this quality panel is simply outstanding. Jason. Now how come Brisbane doesn't have any Bing Lee Stores! Link to post Share on other sites
Black Dawg Down 0 Posted July 6, 2006 Share Posted July 6, 2006 Now how come Brisbane doesn't have any Bing Lee Stores! But NSW doesn't have Clive Peters either! Link to post Share on other sites
Arushan12 0 Posted July 6, 2006 Share Posted July 6, 2006 If it helps anyone, I've got a receipt from Bing Lee Castle Hill here for the 8800 at $2,850. I mentioned it on this thread when I bought it 3 weeks or so ago. If it helps, I can fax the receipt for price matching.BTW, this thing is stunning. I'm sure the 8900 will be great too, but get yourself a bargain while their clearing them. Sub $3,000 for this quality panel is simply outstanding. Jason. wow thats an awesome price for a 42 inch hd plasma, i was about to buy a 32in ch samsung lcd, but this has me thinking twice.. i will be using it primarily for xbox 360, do you guys think i'm running a risk of burn in if take this road, or just stick with the 32inch samsung?? Link to post Share on other sites
Struggo 1 Posted July 7, 2006 Share Posted July 7, 2006 But NSW doesn't have Clive Peters either! A Clive Peters is due to open at Auburn July/August 06. Link to post Share on other sites
samps 0 Posted July 7, 2006 Share Posted July 7, 2006 i will be using it primarily for xbox 360, do you guys think i'm running a risk of burn in if take this road, or just stick with the 32inch samsung?? You'll get burn in if you pause a game screen and go to bed for the night, but in reality it's not a problem. I've got the 360 running into my 8800 over component and its simply fantastic. There's an inbuilt screen saver timer in the menu and the xbox 360 itself will dim the screen after a while, so you'll be safe. I've played countless hours of PGR3 and no sign of speedo/kudos images burning in. This screen is awesome with the 360, I assure you. Much more 'natural' looking than any LCD. Link to post Share on other sites
katmar 0 Posted July 7, 2006 Share Posted July 7, 2006 If it helps anyone, I've got a receipt from Bing Lee Castle Hill here for the 8800 at $2,850. I mentioned it on this thread when I bought it 3 weeks or so ago. If it helps, I can fax the receipt for price matching.BTW, this thing is stunning. I'm sure the 8900 will be great too, but get yourself a bargain while their clearing them. Sub $3,000 for this quality panel is simply outstanding. Jason. Jason, I would REALLY appreciate it if you could please fax me a copy of your receipt: it helps a lot when I try to bargain with sales reps to actually show them that I didn't make up the quote. Thanks Link to post Share on other sites
Struggo 1 Posted July 7, 2006 Share Posted July 7, 2006 Hi All, Just picked up my 8800 from Bing Lee Campbelltown. Paid $2750 for the 8800 + $399 for the extened warranty. I now have to set it up ASAP because the little buggers are stoked and can't wait. I also received a free family movie pass as I was pushing for $3100. Thanks again to all those who helped. Cheers Struggo Link to post Share on other sites
Arushan12 0 Posted July 7, 2006 Share Posted July 7, 2006 You'll get burn in if you pause a game screen and go to bed for the night, but in reality it's not a problem. I've got the 360 running into my 8800 over component and its simply fantastic. There's an inbuilt screen saver timer in the menu and the xbox 360 itself will dim the screen after a while, so you'll be safe.I've played countless hours of PGR3 and no sign of speedo/kudos images burning in. This screen is awesome with the 360, I assure you. Much more 'natural' looking than any LCD. cool thanks alot mate, well its either going to be a Sony 32inch bravia, or the hitachi, atm i'm leaning towards the hitachi plasma, i live like 2mins drive around bing lee casula, and hopefully they can price match.., the, they have a big hitachi 42pd880ta box outside with 3499 marked on it..., it will kinda be hard for them price match to 2850 if they can... Link to post Share on other sites
Moderators betty boop 15,742 Posted July 7, 2006 Moderators Share Posted July 7, 2006 cool thanks alot mate, well its either going to be a Sony 32inch bravia, or the hitachi, atm i'm leaning towards the hitachi plasma, i live like 2mins drive around bing lee casula, and hopefully they can price match.., the, they have a big hitachi 42pd880ta box outside with 3499 marked on it..., it will kinda be hard for them price match to 2850 if they can... grab the 42" hitachi arushan the gain in screen realestate over a 32" it self is well worth it ! Delivery for my 8800 is still being organised, hopefully will have it tommorow, thrilled to bits cant wait to have and all set up. if you can get for the $3k mark I think your doing pretty well on this one. And grab an extended warranty which at $300-$400 is really worth the money. Link to post Share on other sites
pjc 0 Posted July 7, 2006 Share Posted July 7, 2006 The 5900 is as asia market panel maybe the stocks jsut havent come yet. The hitachi rep I spoke to at a HN store week or so ago said the 8900 they wouldnt be selling for atleast another month Saw the 8900 today at my local supplier so they are about Philip Link to post Share on other sites
Arushan12 0 Posted July 7, 2006 Share Posted July 7, 2006 grab the 42" hitachi arushan the gain in screen realestate over a 32" it self is well worth it !Delivery for my 8800 is still being organised, hopefully will have it tommorow, thrilled to bits cant wait to have and all set up. if you can get for the $3k mark I think your doing pretty well on this one. And grab an extended warranty which at $300-$400 is really worth the money. yeah i think i just sealed the deal in my mind, glad to see the hitachi is such crowd fav in the forums.. Link to post Share on other sites
simonactive 0 Posted July 7, 2006 Share Posted July 7, 2006 Saw the 8900 today at my local supplier so they are aboutPhilip Was that in Melbourne and if so where ? Link to post Share on other sites
pjc 0 Posted July 7, 2006 Share Posted July 7, 2006 Was that in Melbourne and if so where ? Sorry, no not Melbourne but Toowoomba. Philip Link to post Share on other sites
simonactive 0 Posted July 7, 2006 Share Posted July 7, 2006 Sorry, no not Melbourne but Toowoomba.Philip I am looking to buy a 8800 or 8900 this weekend has anyone seen the 8900 in stores in Melbourne and where so i can compare them. Link to post Share on other sites
