carpy
Promax TV Explorer
I spoke to Promax a week ago and they informed me that this new TV meter was in full production and that many units were already being sold. There was a backlog of about 1 month before they could deliver a new unit.
I wondered if anyone has tried these yet? They look mighty fine from where I am standing.
Comments? I am in the UK by the way, and the retail price here is £1500 + 17.5% VAT
Any web links?
Technical specifications as distinct from glossy presentation?
Haven't been able to find them, but not for lack of looking. Like to see more than pretty pictures and highlights of some of the instrument's operating parameters.
(My spanish friend tells me noticias = the news. I want data from whence to derive my own interpretation of the facts.)
Didn't think there was any interest as kept getting referred to the glossy brochures - I have a thing about that. :blink:
Comments would be appreciated.
UNIVERSAL TV EXPLORER
PRODIG-5
1.1 Specifications
CONFIGURATION FOR MEASURING LEVEL AND POWER
TUNING Digital frequency synthesis. Continuous tuning from 45 to 865 MHz and from 950 to 2150 MHz
Tuning modes Chanel or frequency (IF or downlink at satellite band).
Channel plan configurable on demand
Resolution 45-865 MHz: 50 kHz
950-2150 MHz: < 200 kHz (span FULL-500-200-100-50-32-16 MHz).
Automatic search (Explorer) Threshold level selectable. DVB-T or DVB-C selection
Signal identification Analogue and digital. Automatic.
RF INPUT
Impedance 75 W
Connector Universal, with BNC or F adapter.
Maximum signal 130 dBµV
Maximum input voltage
DC to 100 Hz 50 Vrms (powered by the AL-103 power charger)
30 Vrms (not powered by the AL-103 power charger)
45 MHz to 2150 MHz 130 dBµV
DIGITAL SIGNALS MEASUREMENT
POWER RANGE
COFDM: 45 dBµV to 100 dBµV.
QAM: 45 dBµV to 110 dBµV.
QPSK: 44 dBµV to 114 dBµV.
MEASUREMENTS
DVB-T (COFDM): Power, CBER, VBER, MER, C/N
Presentation: Numeric and level bar.
DVB-C (QAM): Power, BER, MER, C/N
DVB-S (QPSK): Power, CBER, VBER, MER, C/N
COFDM SIGNAL PARAMETERS
Carriers 2k / 8k (Selected by the user).
Guard Interval 1/4, 1/8, 1/16, 1/32 (Selected by the user).
Code Rate 1/2, 2/3, 3/4, 5/6, 7/8.
Modulation QPSK, 16-QAM, 64-QAM.
Spectral inversion Selectable: ON, OFF.
Hierarchy Indicates hierarchy mode.
QAM SIGNAL PARAMETERS
Demodulation 16/32/64/128/256 QAM.
Symbol rate 1000 to 7000 kbauds.
Roll-off (a) factor
of Nyquist filter 0.15.
QPSK SIGNAL PARAMETERS
Symbol rate 2 to 45 Mbauds.
Roll-off (a) factor
of Nyquist filter 0.35.
Code Rate 1/2, 2/3, 3/4, 5/6, 7/8 and AUTO.
VIDEO
Format MPEG-2 / DVB (MP@ML).
Services decoding Service list and PIDs
ANALOGUE SIGNALS MEASUREMENT
LEVEL MEASUREMENT
Measurement range
Terrestrial TV & FM bands 10 dBµV to 120 dBµV (3.16 µV to 1 V)
Satellite TV band 30 dBµV to 120 dBµV (31.6 µV to 1 V)
Reading Auto-range, reading is displayed on an OSD window
Digital Absolute value calibrated in dBµV, dBmV or dBm.
Analogue Relative value through an analogue bar on the screen.
Measurement bandwidth 230 kHz (Terrestrial band) + 4 MHz (Satellite band) (maximum band ripple 1 dB).
Audible indicator LV audio. A tone with pitch proportional to signal strength.
Accuracy
Terrestrial bands ±1.5 dB (30-120 dBµV, 45-865 MHz) (22 °C±5 °C)
Satellite band ±2.5 dB (40-100 dBµV, 950-2050 MHz) (22 °C ± 5 °C)
Overrange indication ­, ¯
MEASUREMENTS MODE
Terrestrial bands
Analogue channels Level, Video-Audio ratio and Carrier-Noise ratio.
Digital channels Channel power, Carrier-Noise ratio and Channel identification.
Satellite band
Analogue channels Level and Carrier-Noise ratio.
Digital channels Channel power and Carrier-Noise ratio.
SPECTRUM ANALYSER MODE
Satellite band 30 dBµV to 120 dBµV (31.6 µV to 1 V)
Terrestrial bands 10 dBµV to 120 dBµV (3.16 µV to 1 V)
Terrestrial 230 kHz
Satellite 4 MHz
Span
Terrestrial Full span (full band) - 500 - 200 - 100 - 50 - 32 - 16 - 8 MHz selectable.
Satellite Full span (full band) - 500 - 200 - 100 - 50 - 32 - 16 MHz selectable.
Markers 1 with Frequency and level indications.
Measurements
Terrestrial bands
Analogue channels Level.
Digital channels Channel power.
Satellite band
MONITOR DISPLAY
Monitor TFT colour 5 inches.
Colour system PAL, SECAM and NTSC
TV standard M, N, B, G, I, D, K and L
Spectrum mode Variable span, dynamic range and reference level by means of arrow cursors.
Sensibility 40 dBµV for correct synchronism.
BASE BAND SIGNAL
VIDEO
External video input Scart.
Sensibility 1 Vpp (75 W) positive video
Video output Scart (75 W)
SOUND
Input Scart
Outputs Built in speaker, Scart.
Demodulation TV PAL, SECAM, NTSC system according to DVB-T, DVB-C, DVB-S and MPEG standards.
De-emphasis 50 µs
Subcarrier Digital frequency synthesis according to the TV standard.
RS-232C INTERFACE For service and calibration.
EXTERNAL UNITS POWER
SUPPLY Through the RF input connector.
Terrestrial and Satellite External or 5/13/15/18/24 V
22 kHz signal Selectable in satellite band.
Voltage 0.6 V ± 0.2 V
Frequency 22 kHz ± 4 kHz
Maximum power 5 W
DiSEqC GENERATOR According to DiSEqC 1.2 standard.
POWER SUPPLY
Internal
Batteries 7.2 V 11 Ah Li-Ion battery.
Autonomy > 3.5 hours in continuous mode.
Recharging time 3 hours up to 80% (instrument off)
External
Voltage 12 V
Consumption 35 W
Auto power off Programmable. After the selected amount of minutes without operating on any control. Deactivable.
OPERATING ENVIRONMENTAL CONDITIONS
Altitude Up to 2000 m
Temperature range From 5 to 40 °C (Automatic disconnection by excess of temperature).
Max. relative humidity 80 % (up to 31°C),
decreasing lineally up to 50% at 40 °C.
MECHANICAL FEATURES
Dimensions 230 (W) x 161 (H) x 76 (D) mm
(Total size: 2.814 cm3)
Weight 1.9 kg (without holster)
INCLUDED ACCESSORIES
1x CB-044 Rechargeable Li+ battery 7,2 V 11 Ah
1x AD-055 "F"/F-BNC/F adapter
1x AD-056 "F"/F-"DIN"/F adapter
1x AD-057 "F"/F-"F"/F adapter
1x AL-103 External DC charger
1x DC-261 Carrying bag.
1x AA-103 Car lighter charger.
1x CA-005 Mains cord.
OPTIONAL ACCESSORIES
DC-299 Transport suitcase.
PRODIG-5
1.1 Specifications
RF INPUT
Impedance 75 W
POWER RANGE
MEASUREMENTS
Roll-off (a) factor
Roll-off (a) factor
VIDEO
LEVEL MEASUREMENT
Measurement range
Accuracy
MEASUREMENTS MODE
Terrestrial bands
Satellite band
Terrestrial 230 kHz
Satellite 4 MHz
Span
Measurements
Terrestrial bands
Satellite band
MONITOR DISPLAY
BASE BAND SIGNAL
VIDEO
SOUND
Input  Scart
De-emphasis 50 µs
Maximum power 5 W
POWER SUPPLY
Internal
External
Voltage 12 V
Consumption 35 W
MECHANICAL FEATURES
Thanks a lot, if you can and have it, can you give me a contact person (name and email) at Promax.
As far as specs go, it seems to me as an excellent meter, it's got the accuracy (on paper), its got the spectrum, BER/MER, MPEG-2 and it weights 1.9 Kg.
I'm really looking forward to see it working, if it is half as good as they say, I'm seeing bad selling times for the Unaohms as, personally, I prefer one meter for all than one meter for each modulation, specially with this weight.
Just got a price and demo from Electrocraft for 4.2K + GST, and what can I say, the meter really does the job.
