andthen01 Posted September 8, 2005 Share Posted September 8, 2005 The LG LST-5100 has been reccommended to me by a couple of stores to go with a new Panasonic HD Viera 42in. I was close to getting the Toshiba J35!! (one store recommended it to me) Thanks to user reviews on a well known review website, (which 65% slammed it), I was put onto dba, and hello J35! I don't think I'll go there!. This is a good forum. So... my other option is the LG LST-5100. Not much has been said about this unit, but a few stores have described it as a solid unit, and seems to be good value for $499. The only thing I'll need is a DVI-HDMI adapter, but I think that is ok. I'm still interested in the Dual HD tuner with Hard Drive that Toshiba offered, but can't seem to find an alternate on the market. Anyone have any opinions on the LG, or suggestions on alternatives? (I think I'll stay away from the Toshiba and Panasonic) Cheers Link to comment Share on other sites More sharing options...
david_h Posted September 8, 2005 Share Posted September 8, 2005 I had the Samsung for a week - don't touch it. It's way too flakey. I have replaced it with the HUMAX HD 7000 which is an excellant unit. I also understand from others here that the Strong is a good box Link to comment Share on other sites More sharing options...
markus_42 Posted September 8, 2005 Share Posted September 8, 2005 I also have the Panasonic 42PV500 and am very happy with my Strong 5400 HD STB. A little more expensive than the HUMAX which was also on my shortlist. You can get an adapter, but DVI-HDMI cables are available also. Good luck! Link to comment Share on other sites More sharing options...
AMY Posted September 8, 2005 Share Posted September 8, 2005 I have used the Humax 7000 for over 6 months, & it has not given me 1 iota of trouble. It is reliable, pq is very sharp with excellent colour rendition, no lag, no drop outs, no pixelization, & a 2 yr warranty. It also does not have macrovision( which I think the LG5100 does) which enables you to record direct from the stb to a dvd recorder( which I am doing with excellent results.). The box also has an on /off timer. Amy Link to comment Share on other sites More sharing options...
wildcat Posted September 9, 2005 Share Posted September 9, 2005 I'm using an AUSID with the 42PV500. Very happy with the picture but I'm looking to trial the new Teac 820 sometime over the next few weeks. My only gripes about the AUSID are the RF remote making it more expensive to integrate with a universal remote, no DVI/HDMI which means I have a spare HDMI port on my panel and no spare component for my PS2, and no optical audio out so I need to buy a converter to get digital audio into my amp. So really, there is no problem with the AUSID, it's just that it doesn't integrate into my existing equipment that well. I'm guessing I'll go through the trouble of getting the Teac and find out that the picture quality is not as good (am having no solarisation type issues watching the footy ATM). Link to comment Share on other sites More sharing options...
dtp Posted September 9, 2005 Share Posted September 9, 2005 I have the combination between Panasonic TH42PV500A and TOSHIBA J35, in this forum I am the lucky one with the J35, I have no problem at all!!!! and love every minute of it..... Link to comment Share on other sites More sharing options...
