Does any Panasonic Plasma owners here, hear the faint little sound that comes from the right hand side of the panel, it sounds like a Kettle whistling, even with the sound down to zero, there's a whistling sound very low, but can be heard when there no sound at all!
Only a little drama, but the picture on this set is outstanding and is a joy to watch!
Go the Pana Club!
Mc. :ph34r:
Yes, it is truly rewarding making attempts to silence the sucker because it does work and the fix doesn't have to be expensive or obtrusive.
Firstly, complain. Strongly.
Secondly, don't bother getting a replacement. Most are the same.
Thirdly, when you start to notice it a lot more, just tell yourself your going mad. It's easily the cheapest solution.
Lastly, welcome to the 'buzz club'. There's plenty of room. :blink: Hey, we all have to have a club, you know.
  • Replies 201
Either I'm lucky or deaf, but I can't hear the buzz when sitting back from the set.
When I lean over the back of the set, I can hear a faint buzz which is drowned out by the sound of the set's fan. Nothing extraordinarily loud, and again, nothing I can hear over ambient noise while watching TV, even with the volume down.
This is on a Pana PV500A.
I've had my 42inch 500A for 3 weeks and its only because you mentioned it I've noticed the noise. To do so I have to put my ear within half a metre of the top of the screen. As this is an awkward viewing position I don't think it would be an issue for me.
The real fix to this problem will take a couple of years. You need to buy an IPOD and use it for 3-4 hours/day. Make sure it is turned up REAL loud. After a while this will fix the problem with the Panasonic.
Very happy with my 50 inch PV500. It looked absolutely massive when we set it up. I almost admitted to my wife that the 42 inch would have been big enough.
Running a Topfield 5000 through s-video and an old pioneer dvd through component. Both look fantastic to me. No solarisation, colours look very natural, fast motion looks great, blacks and shadow detail are great. I really can't fault it so far. I haven't seen a fujitsu (nobody in Canberra stocks them) but even if they are slightly better, I think the panny is a bargain.
$5900 including extended warranty to 5 years and delivery. Also included Wallabies supporters pack and $400 worth of Caltex Star Cash.
George
QT007,
Can you possibly tell me where you got this set for this price.
I'm going to get this baby and was looking to see who is offering the best deal.
thanks.
I'm sorry you noticed it due to our discussion.
By the time i'm 50 and partly deaf i probably won't be able to hear it because it will be in the scrap yard.
The buzz really is one of the only negatives about plasma.
Did you end up getting some tiles shinrai or have you settled on the baffle solution?
I'll have some time tonight to finally put up the tiles that I've mounted on a backing board. I was surprised two nights ago when I finally unpacked the tiles to find 4 midnight blue and 4 burgundy coloured tiles in the bottom of the box. Instead of taking them back I decided to work with them and have a multi-coloured solution that doesn't look half bad to my eyes and goes with the carpet!
I'll try posting photos tonight.
I'm getting my tiles on Mon/Tues. It'll be interesting but i won't actually put them up till i get the single pedestal stand. I'll be making it to the same size as my other frame since i want a discrete solution.
Make sure you post the pics.
So colour didn't really matter I guess and you would have got the grey I assume? Would make sense. You should have asked for the flame spec ones which are fireproof being so close to the plasma.
I think this is the case with most plasmas I've seen. Certainly with mine as I've posted there is a faint hiss and thats when you put you ear around the back of it and place it close within a few cms of the back. Come around to the front and theres no audible noise. And my plasma does not have fans so perhaps no noise to be contributed from there. And mines a 37" as well so perhaps less/smaller power supplies etc to be making any noise.
Ofcourse if you can't hear the sound from your normal seating position then theres nothing of concern there.
Quote:
The standard FONIC range has been tested and passed the following flamability standard.
BS5852 - 1990 (section 4 12.2) British flammability standard.
Smouldering cigarette test: Ignition Source 0
Assessment of ignitability by smouldering ignition source
I have also thought of covering them will a fire resistant fabric rather than you std felt.
yes thats the std level... they have a higher level which resists naked flame.
Got out the black felt and 2 matches. Mostly it just melted. After 5-6 seconds with a good flame it caught a little. Not much though.
I can't see a consistent flame coming from the plasma. A spark yes. Smoke yes but burning flame. Doubt it.
Ah, Phreek these guys from the pana clug aren't going to like the buzz club for hijacking the thread.
hehehe
yes take your buzzing fuji probs back to your buzzing threads - you had two threads for that didn't you - them not enough :blink:
Just bought me a ticket to Pana Paradise.. 50'' :blink:
it cost me a lousy $6100 and i depart next Friday if all goes well :P
as big Kev would say.. Im excited
You should be excited mate, the picture quality when I watch 1080i from the HD STB is literally like looking at a picture or through a window. It is absolutely flawless! Good Standard Def source material like DVDs also look incredibly crisp and yet not jagged or harsh. It reminds me of a beautiful big-screen CRT without the visible scanlines or screendooring :blink:
As for the buzz, I did notice it today when the room was dead quiet and with the sound switched off. It seems to peak with bright scenes and dull with dark scenes, so it is the transformers.
However at any other time with even a slight volume and/or any ambient noise the buzz is not perceptible. I can comfortably live with that - not an issue for me. I do feel sorry for those who do feel this is a major issue, it's always hard when something sours an otherwise good viewing experience.
How true, bright to dark screen, makes it louder,
i'll live with it too!
"I love my Pana" :ph34r:
Funny thing is, late last night in almost total silence, I muted the volume and I couldn't hear anything at all. Only a slight sound from the fan, but no buzzing. Maybe it depends on how hot the set gets?
Anyway let's not let the pana thread get hijacked by the buzzers :blink: I had another thread talking about calibration advice, maybe we could share calibrated settings in this thread?
QT007,
thanks.
Bought fom Domayne, Canberra. (yes Canberra, where prices never seem very competitive)
I got quotes from Havey Norman and Bing Lee. I probably could have got it a bit cheaper but I couldn't be bothered running around too much. In the end I thought it was a fair price and didn't chase another price from good guys etc. Turned out well in the end because I got the $400 caltex vouchers from Domayne which I didn't realise at the time of purchase.
If you want extended warranty I suggest negotiating on a package price. Don't agree on a panel price and then let them whack on a full priced extended warranty. Realistically you could start at $5600 for panel only or $5800 with extended warranty.
On the buzz issue- I can can hear a slight whirr or buzz when my head is behind the panel and within a few inches. My Toppy hard disc and light dimmer switch make more noise than the PV500A. A real non-issue for me.
Still very happy with the purchase. If a fujitsu is more than 5-10% better I would be very surprised.
George
Wow. I've bought furniture from Domayne canberra, but I've never given their hifi gear a second look because I always thought it was inflated beyond even Harvey Norman prices. You got a good deal!
BTW, I've got into the Service Menu 1 on my set, but I can't get into Service Menu 2 for the life of me, either by following the instructions here or here. Anyone have any tips for getting it to work on the PV500?
I have just purchased the new 42 HD Pana and I am very happy with the purchase. Thanks to all the information in this forum helped me come to my decision.
The problem that I am finding hard to overcome or find a solution to is the restriction of one HDMI input. I currently have the LG STB with a DVI to HDMI cable using the input. I want to buy a DVD player with HDMI upcaling but have no more inputs.
I am sure that a lot of people have this same problem, does anyone have an easy solution? I thought that there may have been a 1 to 2 HDMI cable adapter but this does not seem to be the case.
Easy, sure. http://www.ramelectronics.net/html/hdmi-2x1-switch.htm
I gather you don't want to pay anything though. :blink:
Rowey_X,
Best and cheapest option is to choose which will benefit the most from the digital connection, DVD player or STB. My opinion would be to use the HDMI for the DVD player if you are getting one that upscales.
Best see first how your STB goes using both options before getting the DVD player.
Other choices such as scalers or switchers (from o/s) would be unnecessarily expensive IMO.
Many amps will be coming over the next year with HDMI inputs that should be able to solve this problem
New Yamaha amps, with I believe 2 HDMI inputs are arriving soon (how soon I don’t know) should be able to do the job
No TV that I am aware of in this country ATM has 2 HDMIs.
This is true, but a few such as the Hitachi and the Fujitsu have HDMI and DVI.
If you haven't yet bought your DVD player, I would just make sure that I bought one with good quality component output. This would be your least expensive option until the HDMI switching stuff becomes more affordable.
So, would it then be possible, for example, to connect the following:
a - DVD player to Fuji 50" via HDMI
b - PVR (Brand I haven't decided on) to Fuji 50" via DVI.
I know "a" is possible, but I am not sure about "b" because of the HDCP (or whatever) of the DVI port.
Can anyone answer this?
Thanks.
Thanks.
"b" is possible if the PVR (or any source device) is not HDCP compliant.
There is no reason for a STB or PVR to be HDCP compliant, and there has been some discussion on the Toshiba J35 threads about asking Toshiba/Castel to remove this setting.
I used to run the Teac DV-B800 STB via DVI into my Fujitsu, and the Pioneer 969 DVD player via HDMI.
Thanks Foghorn.
Rowey_X,
I believe the upcoming pio plamsa's will have 2 hdmi's.
Foggy, since the dvi reports 60hz even though your stb may say 50, is this a problem?
I thought it would be shinrai, but I didn't notice any juddering. I asked glenncol to confirm this too with his LG STB and he didn't have any judder via the supposedly 60Hz DVI input.
The processing of the fuji makes the diff here. There is clearly a difference in smoothness between the 50" pio model i had and the fuji.
Even running movies at 60hz through my pc reduced the judder on the fuji more than the pioneer. Excatlt same software. Don't get me wrong, the judder is still there for pal on the htpc at 60hz but reduced.
Thanks.
Better check out this post right now
http://www.dtvforum.info/index.php?showtop...ndpost&p=264128
:blink: I should be a footy commentator.... as soon as I say the Fuji can do it, they pull it from the market! :P
...and the Hitachi 7800TA is also being run out in favour of a new cheaper model which I believe is also lacking the DVI input.
  • 2 weeks later...
I'm a newbie, so pls forgive me for any silly questions.
Anyway, reading these posts convinced me to buy a 42" HD Pana 500A. Could you happy pana owners pls give me a some ideas on which HD STB box I should get with this plasma & how much?
Thanks in advance.
Note that RRP from $5499 to $4999 effective today so street prices should move accordingly. My 42pv500a was delivered this morning. I am very pleased to have cancelled my Hitachi 42pd7800ta at the last moment due to supply issues. Let the good times roll on in Pana Paradise :blink:
Was at good guys today (picking up Toppy MPS, but that's another story) - 500a for $3999 on the ticket, and very ready to deal.
Love the Fuji, but starting to agree with salesperson - is it worth and extra $1000?
But am I the only one who hates the Pana bezel - Pana price and PQ with NEC bezel would be my pref.
Kent
Kent
the pana is absolutely incredible value at $3999 !
bloody amazing really keeping in mind the SD pana were ticked only a year or so ago for 4k. Now you can get a beaut HD plasma for the same money.
the bezel is a bit wide and theres slimemr out there but the pana does include the speakers so overall ends up slimmer if considering a plasma with speakers.
i picked up the DSE DTR 800 HD stb for $350 from Dick Smith..
works a treat. I believe it is a rebadged Homecast HT 5000 which sell for $453.
It has the ATI Xellion chip in the STB
for more info about the STB check
http://www.dtvforum.info/index.php?showtopic=23152
http://www.dtvforum.info/index.php?showtopic=23550
someone posted about a bad box.. i have mine for a week left on 24/7 and
no problem.. House, LO SVU and CSI miami looked stunning last week.
I was going to get the Strong 5400 but i think ill keep this one and save the extra
$250. I mean there is not a lot of HD content and this will keep me happy until
the HD pvrs come out
