Shuguang Treasure series of Valves
  • Replies 175
Well my new Shuggy 845T's arrived this morning. Buying from Grant Fidelity so far has been quite a pleasure - prompt emails, regular updates, friendly service.
[ATTACH=CONFIG]25025[/ATTACH]
The valves come in a really nice box.
[ATTACH=CONFIG]25028[/ATTACH]
The 845T (left) is noticably larger than the standard 845 (right). As you would expect, the internal construction is also different. In use, the 845T's are noticably brighter than the 845's (which were itself a very bright valve!). The base has some kind of anodized copper or gold finish. This was rather poorly done - I have four valves, and the colour on each of the bases is different.
So consistent manufacturing is not their forte. However, I noticed this:
[ATTACH=CONFIG]25026[/ATTACH]
845T's installed in the right monoblock. Note how the plates are angled at 45 degrees.
[ATTACH=CONFIG]25027[/ATTACH]
845T's installed in the left monoblock. See the leftmost tube? It is angled at 30 degrees!
Despite the obvious manufacturing defect, there is no detectable difference between the left and right channel. But the soundstaging is so muddy right now that it is hard to tell.
I have sent an email to Grant Fidelity asking them to take the tubes back and send me a new set of four. Will see what happens.
Hi Keith,
Consulted with Shuguang about the tube angle you mentioned - it's not considered a manufacturer defect by the factory. By measuring the top angle, it is not conclusive because the tube socket could be misaligned in the circuit by certain degree. And I don't think aligning the tube sockets is considered matching parameter in stereo equipment manufacturing.
We offer matching for electronic parameter on tubes, but not for tube internal parts physical measurement. Tube is a handmade craft - no two tubes will be 100% identical and we never warrant the matching you are expecting.
We have sold hundreds of Treasure tubes and quite a bit of the new Pavane tubes - no customers have requested us to match the mica plate on top, or angle of the internal parts. And we cannot warrant it if manufacturer doesn't consider it as defect.
According to what you said, your quad of tubes operate fine in your amp as far as I understand.
Regarding bias, it is subject to many many factors including how closely your circuit parts (resistors, capacitors, wires etc) are matched between the two monoblocks and if your power input to two amps are identical. I am afraid that measuring the bias differently at two power mono amps cannot lead to the conclusion that tubes are not matched properly.
If you have question about our tube matching, you can send the tubes to someone who own Amplitrex AT1000 tube tester and let me know your official results. I have confidence in our electronic paramaters matching. But again, we don't match tube internal physical measurement. It's a tube - an electronic parts, not twins.
Best,
Rachel
Thanks for replying, Rachel. I accept that if the tube performs correctly on the tube tester, you have done your part in matching four tubes. I also accept that there are other variables involved when it comes to setting bias on the amplifier - including the possibility that the previous set of tubes I was using were mismatched, leading me to set a bias which were appropriate for that pair of tubes, but not the new pair.
It would have been nice to get a set of results though. As it happens, I do know someone with a tube tester so I might go and check for myself if the tubes are electronically matched.
In any case, my amps have not been switched off for 24 hours. They are now nice and hot and the valves have 24 hours of burn-in. The soundstage has expanded very nicely and the top end has improved by quite a lot. Nothing happening to the bass yet.
As far as we know, tube tester for 845 type of tubes can only be tested at up to 500 volts. This is the limit of the Amplitrex AT1000. We take factory test results (at 1250V) into consideration when do our matching. You are more than welcome to re-test the tubes on another tester and let us know the test condition and results.
Thank you.
Rachel
I have not been here for a while intersting to see tha activity in this thread.
I allready have the 12AU7 Pavanes and my KT88-Z are on thier way unfortunatly I wont be able to try them out for a while as the Amps are in storage and I am living in the Nurse Quaters at Monavale Hospital so no possiblity of squizing the amps in here.
DaveMS
Are you happy with your KT88-Zs :)
Keith
I hope the valves live up to your expectations :D
That's too bad Keith. Unfortunately, not the first poor review of these valves. They seem to be coming thick and fast. Hopefully they will come good after a burn in
I can't find any poor reviews google searching, do you have any links?, we have nothing but excellent feedback so far and would like to know if anyone doesn't like them who actually has them or has actually heard them and for what reason, so that if someone has similar gear we can let them know. Thick and fast to me means a lot more than zero, maybe you have another definition down under :)
Thanks from up above,
Ian
Edited by iGrant
Hello Rachel, thanks for taking the time to clarify some of the mystery about China tube manufacturers.
What can you tell us about "GUI GUANG" tubes. I found that company's website which shows they have there own factory in FOSHAN?
Is this manufacturer still operating today. What can you tell us about their tube quality...especially interested in their 300B tubes...like the Gui Guang 4300B Gold Pin Ceramic Base tubes?
Cheers (ni hao...hello) ...Vanch
Hi Ian,
sorry for the late reply. I have been busy shopping for records lately so I wasn't watching this thread everyday.
To answer your questions about Chinese tube manufacturers, here is my attempt:
There were total 156 government projects in the 50-60's during the cold war period to establish new China's military and national defense system. Quite a few vacuum tube factories were born then in various parts of China. They are strategically located to service the Chinese army in all parts of China. The very first project of course was done in 1956 located in Beijing (of course just out of Beijing for secrecy reasons and it has to be Beijing as the new China's capital) - it is called 775 factory then. All Chinese military suppliers are numbered factory with soldiers guarding the entrance 24/7.
Later on in 1965 the Factory 775 (Beijing) sponsored the project in Hunan (Chairman Mao's home province, which is an important strategic location for Chinese government) - that project eventually becomes today's Shuguang.
Factory 775 has a subsidiary in Tianjin (where today's TJ Full Music is located) called 774 for a few years. But it has always been an integral part of Beijing so it never had its own brand.
Shanghai used to have a tube factory but it has been long gone and never been a major part of the Chinese tube scene.
Today there are only 2 active audio vacuum tube manufacturers in China - Shuguang in Hunan and TJ Full Music in Tianjin. Shuguang is still semi-government owned although it has joint venture with Korean giant Samsung. Vacuum tube production is just a small part of Shuguang's business, but it is a big deal for us audiophiles :P Shuguang's bread and butter is from TV LCD screen etc.., not audio tubes, unless the Treasure tubes start to become like hot cakes flying off the shelf day and night - it is still going to take years to overshadow the LCD business :)
TJ Full Music is a privately owned business - the owner bought out the old vacuum tube production equipment from Beijing with capital from Taiwan initially. Overtime TJ has become self capital sufficient and today it is solely owned by the Chinese owner - who used to a technology backbone of Beijing during the 50's.
Shuguang tube is solidly owned by the Shuguang Group - although many Chinese companies were publicized and listed on stock market, Shuguang is pretty much run like a state-owned enterprise (SOE). This is very different from TJ Full Music.
Beijing has been long gone as a tube manufacturer. It joint ventured with Panasonic in the 80s and now is a public company listed on Chinese stock exchange.
For the Chinese tubes you see on the market today, many of them is indeed NOS. Even when we order the generic clear glass tubes from Shuguang, sometimes we receive the NOS ones. The Chinese NOS tubes have never been pushed up in price very much - part of the reason is no one re-tests what is sold - good one and bad ones all come out together from all sorts of sellers, then overtime Chinese tubes are labelled all as 'crap' by buyers who got burnt in the tube hunting. If you see a Chinese tube marked "J" on the base, it is military grade; if it is marked "T", it is special military grade. However, it doesn't mean all Chinese tubes marked "J" and "T" are superb - if a tube has been on shelf for over 40 years, it should be tested before going into actual use.
Tubes made during the Red China era are often have a star symbol - the star symbolize Chinese party. The tube is likely made before the 80's. Shuguang changed its logo in the 80s and hi-fi tubes really only took off in the 90s when some Chinese get wealthy with China's open door policy starting in 80s. 1990's is the start of the whole Chinese hi-fi industry and only then the ancient vacuum tubes were dug out from history dust.
If some vendor telling you they have Chinese NOS tubes, don't pay premium just because it is called NOS. The tube has to be tested for its true value. A dying or failed NOS worth nothing, no matter how old it is :)
About the seller Beijing EVLT you have mentioned, it has nothing to do with the Beijing tube factory (775). It is merely a modern day vendor selling vacuum tubes out of Beijing. They get supply from many sources - always bear in mind that Chinese supply chain is a myth and a mess: you should only buy from a confirmed source to ensure quality and authenticity.
Are you more confused? Maybe - lots of things in the eastern world is not black and white. Many fall into the gray area and there is no clear lines for anyone to follow. For those buyers who got burnt by buying from China, they usually got burnt in the gray area. But the fun of audio is also in the process of hunting for treasures, isn't it? :)
Happy listening.
Rachel
p.s. feel free to ask me about anything of China even if it is listed on our website - I don't discuss politics as my family members are still there and I want to maintain good terms with government so that I can do my audio business :) Anything about audio is welcome - I will do my best to do research for you or tell you from my personal experience.
Gui Guang tube from China:
Gui Guang - it used to be a brand name of Liuzhou Tube Factory out of Guangxi province. Gui - is the shortform of the province Guangxi (like CA is the shortform for California). Guang - means 'light' and many Chinese tube brand has this character, such as ShuGuang.
Liuzhou Tube Factory was established in the 1960's and closed down at around 2000. In between, the factory had been making other electronic parts - not much of tubes in the 80's and 90's. Some audiophiles in China bought out the equipment of Liuzhou Tube factory in 2007 and move them to Nanhai, Guangzhou, and the factory name is also changed to be the same as the brand name - Gui Guang. On their new tubes, you will see a printed logo of NGG - it's short form of Nanhai Gui Guang.
Liuzhou Tube Factory (the old factory) used to make great tubes and mostly are sold outside of China. Not many available on the Chinese market and old stock has all been sold out long time ago. If you find some NOS Guiguang tubes (made by Liuzhou Tube Factory), they are keepers (well, if they tested good - don't just believe someone telling you the tubes are NOS - the test results will tell you everything).
New Guiguang tubes from NGG: since production only resumed in 2009 after the factory moved, I have to say that it appears that the factory still has sometime to go in order to get close to the quality from Shuguang (I am referring to the top quality high end tubes from Shuguang only. Shuguang makes lots of so-so tubes for mass market and those are not always impressive and reliable). I don't have first hand experience dealing with Guiguang and have never owned their tubes - but by reading the Chinese audio forums, it appears that the tubes still need some improvement on sound and reliability. Bear in mind that tube making is hand craft - it's take long time to train workers and conduct quality control. Having the right equipment doesn't mean the factory will pump out top quality tubes right away. As a business, we try not to be part of the learning curve of a tube factory, because if I get 2 good ones out of 10 tubes imported to North America, I basically have to throw away the 8 bad ones - shipping back to China is too pricey to worth the efforts to return and replace them. Factory do not pay for return freight - I need to pay both ways and God knows if I will get good ones on the 2nd round :P Same with consumers - if you get crappy ones on the first round, you will lose freight and can only hope you get better ones on the 2nd round.
My recommendation is: if you have the tube rolling itch and the Guiguang tube price is right for the risk you are taking, have fun and get a pair to try, but do not hold your breath hoping to score a big winner right away. Buying Chinese tubes is like treasure hunting - you may have to go through lots of crap to get to the good ones, if you don't work directly with the source. That's why I only deal with Shuguang on the proven good tubes and only buy the best :)
If you have further questions, feel free to let me know and I will do my best to answer.
Best,
Rachel @ Grant Fidelity
Hi Rachel,
again thank you for clarifying about the Gui Guang factory which is still in production.
I have taken the plunge and purchased a matched pair of 'Gui Guang 4300B Gold Pin Ceramic Base' tubes...at a cost of AUS$150.00 delivered for the pair...I thought it would be interesting to compare their product. I hope to get them within the next 7-14 days, run them in for a few hours first then will be happy to advise of my impressions.
Tubes I will compare to in my J. Sound Lab SET 300B Mark II (made in Israel) are...Sophia Princess 300B...Sophia Mesh Plate 300B...Golden Dragon 4300B with pre valves...EH 6SN7GTB & vintage Sylvania 6SN7GTB.
I only use CD players (no turntable...oops!) such as ....Marantz CD 63 KI Signiature MkII....Musical Fidelity Elektra Class A Tube CD Player....Shanling CD-T80 (to name a few) so my comments will be based on these source components. Music mostly...modern Jazz, some Classical, instrumental etc.
Hope to chat again soon...Vanch
Edited by monaro8
DaveMS
Are you happy with your KT88-Zs :P
Very pleased. They sound great out of the box and have not taken a backward step during the burn in period. They may be expensive for new valves but a cheap way to significantly upgrade your amp.:)
After the unexpected F1 result I thought I would drown my sorrows with some music. Amps have been on for 36 hours now, with a total of >100 hours burn-in on the new valves. I decided to recheck the bias, and this time it was 90mA on the left and 95mA on the right. When i first got the valves i reset the bias to 100mA on both channels, so obviously as the valves settled in they required re-biasing. Don't ask me why!!
I re-biased both mono blocks and had another listen. They now sound really good, although only slightly better than the stock valves (a no-name 845). The most obvious difference at this point is a fatter midrange on the new valves, but it has always had that from new.
The top and bottom are now more extended, and the soundstage has dramatically expanded. It is not yet by any means good,but it is miles better compared to when it was new!
Hi Rachel,
Gui Guang 4300B's still not arrived, should get them this week.
Will advise my impressions....
Stay tuned...
Vanch...:nana
Stay tuned...
Vanch...:nana
Keep us informed .
I lent a friend a pair of EAT's to try in his amp as driver tubes, he liked the KR's I lent him .
Keep us informed .
Will inform in near future.
Looks like you're not getting your tubes back too soon from your mate then???
I hope the Gui Guang's are not crappy...will see.
Vanch...:)
Keep us informed .
Well they arrived safe and sound a couple of days ago. Well packed in good boxes. Good!
Have been running them in since then and, to be fair...they will need at least 100 hours on them before I could start to give any reasonable analysis on their performance.
First impressions, however, straight out of the box...into the J.Sound Labs 300B amp...Musical Fidelity Elektra Class A Tube CD Player(sorry no TT)...they display the characteristic 300B traits...but...sound is on the 'thin' side of the spectrum. Detail is there, image seems wide with good height. Material..Patricia Barber, Acoustic Alchemy, Fourplay, Andrea Bochelli, George Winston piano & various jazz etc.
I should not forget to mention that at present my current tubes for comparison are the Sophia Electric Princess 300Bn tubes (circa. 90-100 hours running time thus far)...worth approx. 3 times the price paid for the Gui Guang's.
After 2 days auditioning...about 15 hours running...the Gui Guang 4300B's do sound somewhat better than the first session.
TOO early yet...keep listening!!
Vanch...:P
Gui Guang 4300B tubes...
More hours on them now...must admit they are sounding better, more mellow than the first listen...not as thin sounding on top...bit fuller there now. No issues with functionality...no explosions...seem to be working fine.
Stay tuned...Vanch...:)
Well ...having listened to these for quiet a while now, I must say they are more pleasing with some more hours on them than the first listen.
As I had been mainly listening to the Sophia Princess 300B/n tubes prior to getting the 4300B NGG Gui Guang tubes, the Sophia's having a more fuller, richer sound but they did have a fair few more hours on them already.
The NGG tubes are ceratinly not in the same class as the Sophia's which cost about 3 times more.
I would comfortably say IMO that for the price, the NGG tubes are "pretty good"! For an outlay of only...$150.00 delivered I think they would easily satisfy most 300B amp owners who don't want to spend $400.00 to $600.00 for a matched pair of 300B tubes.
The sound is more than acceptable...good detail, clean, spacious and they have not missed a beat as far as their construction.
(PS: I am not a tech, I don't have a valve tester or such...just my "ears")
Vanch...:P
not sure if I ever mentioned my listening tests of all of our 300B tubes a few years ago in our old forum (closed), http://grantfidelity.com/forum/viewtopic.php?t=281
Should be of interest as we all look for great tubes. btw, we just opened a new showroom in our hometown and have had many in the past 2 months compare the Treasure 300B-Z to original WE 300B in either of our 300B SET amps on various speakers and sources. I will be selling my WE 300Bs by 1 cent auction very soon, perfectly matched at 98% on the Amplitrex.
Ian
Edited by iGrant
Ian
Hi Ian
Can you send me your bank details so I can buy the WE300B's ,I'll transfer $200.00 into your account so you won't have to settle on a low auction price.
What other 300B's have you tested against ,all I can see is TJ's in the link you posted .
Any chance of seeing an internal picture of the Treasure 300B construction .
have heard good things about these too. keen to know how you find them!
Tuyen
I have used this brand (Shuguang Valves). I tested them on arrival (AVO/4 valve tester) transconductance reading was 85, then again after a few weeks run in, transconductance was now 55. A big drop in two weeks. This tube brand can sound ok, not great but ok, but are very poor quality, and do not last long . The vintage new old stock tubes, 1920 -60s last 5-10 times as long and sound far better. In the long run Shuguang tubes are not good value for money. Stick to quality vintage NOS NIB tubes by GEC Mullard Telefunken Brimar RCA Amperex philips ect. They may be more expensive initially, but in the long run will end up far cheaper, and always worth more to resell, if ever, because the price of vintage quality tubes goes up, not down. Edited by stevenvalve
Hi Steve,
Please hook me up with some 45 and 2a3 matched pairs please. I've seen video footage of the boxes full of tubes you have lying around..
I have 2x 2A3/45 SET amps that need some good quality reliable tubes.
Thanks! :P
Please explain which and how many Treasure tubes you have tested and used and where you purchased them from. Our Treasure Grade A tubes have been in operation for over 2 years now without any failure, I have re-tested our Grade A Treasure tubes with over 2000 hours on them and the have only dropped on average 15%.
The only way you could get 2 tubes to test at 85 and then have both drop to 55 is if you have a pretty inaccurate tube tester that is completely out of calibration, or you have put them in a circuit not suitable for them. It is also extremely unlikely that you would get two tubes that both test at exactly the same transconductance and drop at exactly same rate. Our word for this up above here has the initials BS.
I have tested many so called NOS tubes of famous makes and inflated prices, when bought from a reputable dealer with a laboratory grade tester and who know how and when to calibrate them properly, our tests indicate they are great tubes. When they have been bought from pretenders, the results can be very ugly, especially looking at the persons face who just paid a lot of money for junk. Remember that once a tube has been used it is no longer NOS.
That said, we have yet to come across any vintage tube that has a higher price than the Treasures or Pavanes that actually sounds any better. For the price I'm expecting I will get for the WE 300Bs, you can almost get an Amplitrex tester and go into the tube business yourself, part time at least. There is a reason we visit this site (besides being well moderated and generally fun) and that is you guys are ordering from us and paying the extra price for service and shipping for quality tubes, someone down under should be doing it for your fellow tube lovers down under for both new and vintage tubes !.
Ian
Hi Ian
See post above, nice try :P. As soon as we get a dead one, I will do that, we just received a shipment of KT88-Z that didn't survive, lost about 20 tubes :), not so much the financial loss for me (Rachel worries about that), but to see 20 or so great tubes in pieces doesn't make my day. I will take a pic of the internals of those and post.
The review was only of the tubes we sold, which was the stock Shuguangs and the Treasures and the 3 TJ FullMusic (Sophia) offerings. I have left it for others to describe how they compared to other tubes, they have confirmed what I think. I try to avoid typical marketing hype of my toy is better than yours. My toys are a better value, I have no problems with.
Ian
Keep us informed .
G'day 56oval,
lots more hours on the NGG Gui Guang 4300B tubes now....
am enjoying them much more with extra time on them.
Sound is smooth, clear, good air, good soundstaging...depth & height.
Absolutely not a problem with quality...no sparks, pops, buzzing, banging etc.;)
IMO...for this price they are a VERY GOOD 300B matched pair...I am happy to listen to these...then swap with the Sophia Princess 300B/n tubes...then back to the NGG's.
Again, I confirm the Sophia's are richer...better tubes...but are they 3 times better??? IMO...No.
At a budget price the NGG's are a no brainer.
Cheers...Vanch...:D
Hi Gav,
btw, and interesting sidenote, much better sounding tubes can be built than what is on the market, the problem is they don't survive leaving the factory door, the true art of tube design is the trade-off between sound and shippabilty (if that is a word ;). The 75 year old tube wizard at TJ FullMusic showed me some of his, 'if only I could ship these' 300B, 845, 2A3, etc, they were stunning.
Ian
are you saying great sounding tubes cant be shipped?
i have no problems with ecc32 mullards from the 50's being shipped across the world.(great sounding tube)
how do you think treasure series premium would go against the great ecc32 mullard from the 50's?(6sn7)
Edited by kajak12
kajak, I have the Mullard 6SN7. What do you like about them?
Mullard ECC32 ST shape (around 1950-60s) are considered the best 6SN7 version. Mullard ECC33 are also a highly regarded 6SN7, another very good 6SN7 is the RCA 5692 very rich and warm. But what do i know, as iGrant said ( Our word for this up above here has the initials BS).
i dont have any eecc32 but i have heard them on a system and really liked them but they cost around $800 nos(new in box)
they are on my wish list
what 6sn7 mullards do you have? pics would be nice
Have read similar on other forums in discussions on valve design and construction. Apparently there have been experimental valves constructed that sound absolutely magical.
Trouble is, they are so mechanically fragile they would not withstand the rigours of being freighted to a customer.
Hi Kajak, i'll go get a pics of the Mullards later. I did not realize there was a "common" Mullard and a rare one. FWIW - I do not necessarily buy into the NOS=better. I think valves sound different, but which one is best for you is personal taste. I don't like the Mullards. I much prefer the GE 6SN7 - and mine is very much a minority opinion. Good for me, keeps prices of replacements down!
Vintage Mullard 6SN7-ECC33 tubes 1950-60 have about 4 versions, 2 types are very good, some are ordinary, you may have the poor sounding one. I have 6 of these NOS NIB GE 6SN7 coin base tubes if you need them, some say they are excellent, but i have not heard them. Edited by stevenvalve
if a valve cant get sent to my house then its nfg no matter how it sounds
That seems bazaar as the finest sounding tubes I have are mostly heavy duty rugged-ized military grade tubes. IMO the finest sounding 6SN7 is the Sylvania JAN CHS 6SN7W
[ATTACH=CONFIG]26065[/ATTACH]
Followed closely by the early 1952 Sylvania 6SN7GT
[ATTACH=CONFIG]26066[/ATTACH]
Though, IMO, the best sounding current production 6SN7 is the TJ Full Music unit (also "re-badged" as Sophia and Jardis)
[ATTACH=CONFIG]26067[/ATTACH]
Cheers, Earle.
Hehe, Send em over an I will let you know which ones I like.
MD
PS how are them there amps sounding
its just one amp with a tube rectification power supply on the left i bet its awesome as its a carbon copy of my amp
Cheers, Earle.
tj full music i must try one day or the treasure series just to hear how far they are behind the good old stuff.
if we get a few people in we can buy some treasure series and split the cost and share between share holders of the tube that way we can all have a listen and sell if its nfg to us.
Hrmm.. which one to use??
GE/RCA 5691 red base wins ;)
Look like you have a very seroius amp there Tuyen.
some NOS EL34 will complete the package I reckon .:)
Lovetube
