blackfox
Helpful Audio Technical Document Links
some links I've found very useful:
@Paul Spencer's Bass Integration Guides parts 1, 2 and 3
Part 1 linked here
http://www.hifizine.com/2011/06/bass-integration-guide-part-1/
Acoustic Frontiers "Acoustical Measurement  Standards for Stereo  Listening Rooms"
http://www.acousticfrontiers.com/wp-content/uploads/2011/10/acoustic_measurement_standards.pdf
Other Acoustic Frontiers white papers here:
http://www.acousticfrontiers.com/2013314acoustic-frontiers-white-papers-and-articles-6/
Data Bass has some good articles on sub design/measurements:
http://data-bass.com/articles
Design guide and tool on QRD diffusers - this is a fantastic tool for QRD diffuser design!
http://www.subwoofer-builder.com/qrdude.htm
Porous Absorber calculator
single layer + air gap version
http://www.acousticmodelling.com/porous.php
and the multi layer version
http://www.acousticmodelling.com/multi.php
and the Helmholtz calculator version
http://www.acousticmodelling.com/helmholtz.php
Rod Elliot's site was already mentioned above, but the Linkwitz Transform project on Rod's site has provided me with a very simple woofer box design tool in Excel that's been my first port of call for designing woofer and sub woofer boxes for years - only useful for sealed designs, but also calculates the EQ gain required to push the woofer lower
http://sound.whsites.net/project71.htm
Design guidelines on Limp Mass pressure bass traps from gearslutz
https://www.gearslutz.com/board/bass-traps-acoustic-panels-foam-etc/743040-tims-limp-mass-bass-absorbers.html
(edits)
Hornresp - the goto tool for designing horns, tapped horns etc
http://www.hornresp.net/
Not technical documents, but Tom Danley's recordings of fireworks, trains, Harleys - very high dynamic range and significant bass - careful with the volume knob!
https://www.danleysoundlabs.com/tom-danleys-mic-recordings/
@KenTripp's SBIR calculator
http://tripp.com.au/sbir.htm
Mike
Edited by almikel
Le 08/11/2006 à 02:04, Drizt a déclaré:
Ok les gars, le fil est épinglé.
Lorsque le temps le permet, nous pouvons le ranger en supprimant les messages une fois que leurs liens ont été modifiés dans le premier message.
À votre santé  Sarkari Result TurboTax Gogoanime
Cela semble être une bonne idée. Terry j a essayé d’obtenir quelque chose de similaire il n’ya pas si longtemps, mais n’a pas obtenu beaucoup d’aide des autres.
Si nous pouvons le faire et aller, je vais en faire un collant pour vous.
Edited by ojanichsiya
Hi, Im looking for schematics for a pye mc-6 stereo that Id like to restore. Do you have any ideas on where i can find them?
This is just a wonderful Blog, thanks for the great insight and tips. We really appreciate your effort! Keep up the awesome work!
