billybob_chider
Tropo- Friend or Foe?
WTF! :blink::P
OK. I was sitting in my car out on the farm in central Vic. This is a bit of a bomb of a car and AM only works on the radio. Start flicking around and hit 1350. Now my AM knowledge is very limited but I checked it up and can't find any VIC stations on that frequency. I heard lots of different ads and was wondering is this what 2LF (Young, NSW) broadcast on? :P
Also hit another one, this I am sure of, 1467. Roma/St. George Qld. Was fairly clear for AM and lasted for ages. This is the first time i've had tropo on AM so I'll check tomorrow and see what happens. :P
Note: It was about 35 degress all day. :ph34r:
Edited by billabong33
I noticed some good signal lastnight from Newcastle. I was on my way home, casually scanning stations. NX and NewFM belting in strong. I could even get 2NUR 103.7 in and out. Could also get KO however with 2ST there the stations continuously swapped between each other, making both unlistenable. KO was playing Gangajang - Sounds Of Then while 2ST had some crappy quality talkback sindication as usual. Rheema 99.7 was coming in strong, totally overpowering 2SSR.
Also noticed on Sunday afternoon when scanning that something was interfering with 2MCR Campbelltown, which I usually get OK. Again, as I drove along the radio would swap between two stations (2MCR and another station). MCR still had the better so I couldn't make out what was causing the swapping.
I hear also 100.5 is being used atm.
I can never get 103.7 2NUR, it's just too weak. 100.5 is the Islamic station again. I think 100.3 may have been Forster/Tuncurry's repeater of 2RE? But it's about 1 kW so again that's pretty impressive.
WTF! :blink::P
I don't think you can ever get tropo on AM. If you were listening at night, thats a common occurrence. Btw, 4ZR from Roma is 1476 khZ. Comes in strong over Country radio Penrith here at Oatley at night. 1350 would be 2LF from Young. Central Vic is a pretty good location for long distance dx, in Shepparton once i got 100.7 Sea FM Townsville and 101.9 4MK Mackay on a hot summer's day via Sporadic E.
Picking up 92.9 Breeze FM and 93.7 Rebel FM from Canungra in Oxford Park. The transmitters are only 50W and im getting a signal from 100kms away :blink:
Well thats all I can get down here. Might take a drive up a bit furthur to the top of the hill and see what I can get.
Ok well it looks as though that the tropo has been and gone from Brisbane - sadly :blink:
Overall these past couple of days i have received:
89.1 CFM Kingaroy
90.7 Crow FM Wondai
92.3 ABC Local Radio Grafton (!)
92.9 Breeze FM Canungra
93.7 Rebel FM Canungra
94.5 ABC Local Radio Lismore
95.3 ABC FM Lismore
96.1 Heat FM Noosa/JJJ FM Lismore
96.9 ABC RN Lismore
98.5 ABC FM Wide Bay
99.3 JJJ FM Wide Bay
100.1 Boonah Community FM/ABC Local Radio Wide Bay
100.7 C FM Toowoomba
100.9 ZZZ FM Lismore/ABC RN Wide Bay
then nothing as all the frequencies above this are full of Brisbane Freq's
Maybe 103.7 Newcastle has made some changes. I could get something on and off again lastnight. Never long enough to hear a station ID. I see there is HPON licenced in Nowra for 2K, perhaps thats what I can get instead. Up until now I've never heard anything on 103.7 either.
There is also a station at Yass licenced for 2K on 100.3, this is a possibility as the other stations I could get that day were also from the south. The only other possibilty would have been 10K from Armidale, although I think its just too far away to co-channel a local service, trying to get it on a blank freq during tropo would be difficult enough.
I'm getting NBN from Newcastle ATM near Campbelltown!
However, I could not get the UHF channels from Newcastle though.
I could get ABC on VHF-5A, so VHF channels from Newcastle (NBN & ABC) can be picked up.
Both NBN & ABC from Newcastle are pretty much unwatchable, but they were there! :blink:
I just checked my stereo & no FM stations from Newcastle (except for 102.1 & 106.1) can be received.
I was down around Campbelltown lastnight and got KO co-channeling 2ST in places again. Was not enough to make out what was on KO, but being able to get the other Newie stations, its obvious thats what it was
I know what you mean.
Today, on the way back home from my aunts' place, what I got on 102.9 was either KO-FM or 2ST. 2ST seemed more dominant to be picked up on 102.9 than KO-FM, even when tropo from Newcastle is occurring.
In some places, 105.3 New FM was interfered by Mac FM from Wollongong. NXFM seemed to be free of interference from stations down south. This was between Eschol Park & Minto.
I was just wondering, with my VHF antenna being compatible with an FM antenna, do you think I would get stronger FM reception from Newcastle during tropo with a VHF antenna?
As my VHF antenna is pointed towards Sydney, it would be logical that I would get the Newcastle FM stations whenever possible.
Edited by dtv_campbelltown
Yes that would be the case. I have a Hills Optimax400+ pointing towards Sydney. It rejects most signals from the south. At my location in Oatley I receive Power fm 94.9 with very little to no signal and the Wollongong stations. Wave and i98 with low signal as well. The illawarra national fm services come in clearly. With our antenna all tropo ducting comes in from the north. The central coast stations come in with 100% signal strength, and I can always receive Nxfm, from a slight sound under the static to 100% signal in extreme ducting. Wollongong never interferes with it ever. So yes if you have a good Vhf antenna witch has strong forward gain and signal reduction to the back you will get better tropo reception from Newcastle and further north and will most likely recieve Ko fm instead of 2st on 102.9Mhz. Our best tropo ducting is JJJ Grafton on 91.5 and before Vega started ABC Fm Lismore on 95.3Mhz
Thanks for the reply. :blink:
An indication to see whether I got Newcastle through my VHF antenna towards Sydney can be demonstrated by seeing some form of TV reception on NBN & also ABC-TV from Newcastle during tropo. So that means, with an FM antenna being built in with our VHF antenna, I could get KO-FM over 2ST during tropo. I would like it that way because music-wise, I would prefer to listen to KO-FM over 2ST anytime, whenever possible. :P
I'm not sure how it would affect C91.3's reception in my location (Minto) but with that setup (receiving FM through VHF antenna towards Sydney), I would not get Wave & i98 from Wollongong very well, in which both stations would not be missed by me. It would give me excellent reception on the Central Coast FM stations, which they have better music formats than the Wollongong FM stations anyway. :P
At least I've got another radio at my parents bedroom, if I want to listen to the Wollongong FM stations, particularly Wave & i98. But both stations are not really spectacular to listen to, music-wise.
The antenna will need to be good with more gain preferred. Some antennas have very poor front to back ratio making the rear rejection pretty poor. With the right antenna, you should be able to attenuate 2ST enough to clearly get KO.
Yes I have received both before. Infact the day I got ABC on 95.3 was the day the "Neil Diamond" Tests were to begin. I was tuning in to see if tesing had begun but got ABC instead. I left it tuned but when I came back Vegas tests had begun, so that was the end of that.
This morning, my father tried to connect our FM tuner with an VHF antenna, with mixed results.
Tried NXFM as a test station from Newcastle, the signal was poor-to-average with the FM antenna. When connected with the VHF antenna, the reception was much better. I looked at 102.9 and it seems to be a splatter of 2ST & KO-FM altogether that is common in the Campbelltown area during tropo.
This was around 10:45am when I tried the FM signals from Newcastle through the VHF antenna. I haven't checked C91.3's reception when connected through the VHF antenna.
However, we cannot keep our FM tuner being connected with our VHF antenna because we got a diplexer of VHF & UHF antenna being put together, which would affect our FM reception.
I'm still working on it by buying the 2-way indoor splitter (LT-3020) from Jaycar.
Link: http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=
I'll let you know what the end result is.
Here is a picture of my TV antenna, if that helps.
My TV antenna
My TV antenna
The VHF ant. is medium size. You would need something more directional to fully reject 2ST. Are you using an amp? Some amps actually filter out FM radio frequecnies. The UHF antenna you have is pretty high gain so you should be able to get a few good dx catches with it (UHF TV that is), depending on the local terrain.
Edited by matt86
By what do you mean 'more directional'? :blink:
No.
I've got good UHF dx with it.
Last night, I got Prime & SC Ten from Newcastle. With that VHF antenna, I could get NBN & ABC from Newcastle. :P
