rsbj Posted April 20, 2005 Share Posted April 20, 2005 GuysI just call Big W in Forest Hill in Victoria. They tell me that it will on sale 8:30 tomorrow morning and there is no way that you can put one on hold. Ren <{POST_SNAPBACK}> Same at my local. Not putting them out until the morning and no way I can purchase one today. Link to comment Share on other sites More sharing options...
chrissara Posted April 20, 2005 Author Share Posted April 20, 2005 I will post piccies tonight but be aware of a few things. 1. I will be wall mounting mine. The bloke is coming tomorrow to do a proper installation. 2. As a result the TV will be on the floor, at night. The pictures therefore may not do justice to the screen. It is just that I am envisaging the camera flash may pose problems and show up on the screen. I will connect it to a Teac 800 via DVI and a Samung HD937 via DVI. Any other inputs eg component, composite or computer let me know. Link to comment Share on other sites More sharing options...
Guest gbm Posted April 20, 2005 Share Posted April 20, 2005 Got mine today from Winston Hills. Picture quality is great and i only set up with S-Video for DVD. Am yet to connect for normal TV. ALthough i will be getting a Set Top Box HD propably Teac. Some one mentioned buying one for $350. Where From ? Went and got DVI cables and have connected to PC. Just pluged in and screen came up great. Looks very good possibly stretching screen but have not tryed changed setings to the higher resolution. Currently set at 1024 x 768. Just tryed 1280 x 768 which is says is the highest resolution but the screen went a bit funny and seemed to shift sideways. Will try more later. It detects the screen as a LG DT-3003X. Link to comment Share on other sites More sharing options...
mrplou Posted April 20, 2005 Share Posted April 20, 2005 Just came back from QV (Melb city) and they have one setup via composite (of course!) playing The Incredibles dvd - impressive pq - quite a good looking unit also. They are available and in stock for sale now. Link to comment Share on other sites More sharing options...
Fritz Posted April 20, 2005 Share Posted April 20, 2005 Got mine today from Winston Hills.Picture quality is great and i only set up with S-Video for DVD. Am yet to connect for normal TV. ALthough i will be getting a Set Top Box HD propably Teac. Some one mentioned buying one for $350. Where From ? Went and got DVI cables and have connected to PC. Just pluged in and screen came up great. Looks very good possibly stretching screen but have not tryed changed setings to the higher resolution. Currently set at 1024 x 768. Just tryed 1280 x 768 which is says is the highest resolution but the screen went a bit funny and seemed to shift sideways. Will try more later. It detects the screen as a LG DT-3003X. <{POST_SNAPBACK}> Sorry guy's hit the wrong button, gmb, could you please advise what the insruction book says is the screen size and res? Because this looks like the 26 or 30 inch model not 32" @ 1366x768 Thanks Fritz Link to comment Share on other sites More sharing options...
chrissara Posted April 20, 2005 Author Share Posted April 20, 2005 Got mine today from Winston Hills.Picture quality is great and i only set up with S-Video for DVD. Am yet to connect for normal TV. ALthough i will be getting a Set Top Box HD propably Teac. Some one mentioned buying one for $350. Where From ? Went and got DVI cables and have connected to PC. Just pluged in and screen came up great. Looks very good possibly stretching screen but have not tryed changed setings to the higher resolution. Currently set at 1024 x 768. Just tryed 1280 x 768 which is says is the highest resolution but the screen went a bit funny and seemed to shift sideways. Will try more later. It detects the screen as a LG DT-3003X. <{POST_SNAPBACK}> Sorry guy's hit the wrong button, gmb, could you please advise what the insruction book says is the screen size and res? Because this looks like the 26 or 30 inch model not 32" @ 1366x768 Thanks Fritz <{POST_SNAPBACK}> Valid point - there may have been an assumption here on the boards 9including myself) that this was a second gen panel. Maybe it isn't. Link to comment Share on other sites More sharing options...
Zedric Posted April 20, 2005 Share Posted April 20, 2005 Got mine today from Winston Hills.Picture quality is great and i only set up with S-Video for DVD. Am yet to connect for normal TV. ALthough i will be getting a Set Top Box HD propably Teac. Some one mentioned buying one for $350. Where From ? Went and got DVI cables and have connected to PC. Just pluged in and screen came up great. Looks very good possibly stretching screen but have not tryed changed setings to the higher resolution. Currently set at 1024 x 768. Just tryed 1280 x 768 which is says is the highest resolution but the screen went a bit funny and seemed to shift sideways. Will try more later. It detects the screen as a LG DT-3003X. <{POST_SNAPBACK}> Sorry guy's hit the wrong button, gmb, could you please advise what the insruction book says is the screen size and res? Because this looks like the 26 or 30 inch model not 32" @ 1366x768 Thanks Fritz <{POST_SNAPBACK}> Valid point - there may have been an assumption here on the boards 9including myself) that this was a second gen panel. Maybe it isn't. <{POST_SNAPBACK}> In-store info says 1366x768, for what that's worth Cheers Zed Link to comment Share on other sites More sharing options...
chrissara Posted April 20, 2005 Author Share Posted April 20, 2005 Thats what my literature says too, but issues like this have arisen before. The AR panel was a noticeable one. Link to comment Share on other sites More sharing options...
Nevyn72 Posted April 20, 2005 Share Posted April 20, 2005 Valid point - there may have been an assumption here on the boards (including myself) that this was a second gen panel. Maybe it isn't. <{POST_SNAPBACK}> The panel is definitely second generation........ it just seems to be using the same processor board as the 26" which is first generation Perhaps the firmware isn't able to fully compensate for this screen's differences in PC mode? Cheers, Peter Link to comment Share on other sites More sharing options...
mrhatken Posted April 20, 2005 Share Posted April 20, 2005 The panel is definitely second generation........ it just seems to be using the same processor board as the 26" which is first generation Is it possible to confirm this? Perhaps by checking the version of the firmware or even just the interface menus? I guess with a generation change in processor board would probably come a change in the and firmware and interface menus etc. It would be good to know. Thanks, Ashley. Link to comment Share on other sites More sharing options...
mrhatken Posted April 20, 2005 Share Posted April 20, 2005 Also, what cables does it come with? If any ... Cheers, Ashley. Link to comment Share on other sites More sharing options...
JimPuchai Posted April 20, 2005 Share Posted April 20, 2005 Also, what cables does it come with? If any ...Cheers, Ashley. <{POST_SNAPBACK}> Just the regular mains cable and a double ended component cable with RCA RGB plugs. Link to comment Share on other sites More sharing options...
CVonV Posted April 20, 2005 Share Posted April 20, 2005 so it's a second gen panel simply cos it's native res is 1366x768 but a first gen since it can't display 1280x768 and above correctly (ie it's shifted to the right) using DVI? and lemme ask again... is the input switching still slow as? are there discrete input buttons on the remote? Link to comment Share on other sites More sharing options...
sixpennycarp Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Link to comment Share on other sites More sharing options...
offshore Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Just do the honest thing and sell it on Ebay, then buy the one you want. If you do a frauduent return, it doesn't exactly encourage BigW to provide similar product offers in future. Link to comment Share on other sites More sharing options...
markg1503559880 Posted April 20, 2005 Share Posted April 20, 2005 Went and got DVI cables and have connected to PC. Just pluged in and screen came up great. Looks very good possibly stretching screen but have not tryed changed setings to the higher resolution. Currently set at 1024 x 768. Just tryed 1280 x 768 which is says is the highest resolution but the screen went a bit funny and seemed to shift sideways. Will try more later. <{POST_SNAPBACK}> Have you had more of a chance to try it at higher resolutions on DVI? How far did it shift sideways for you? Link to comment Share on other sites More sharing options...
retro Posted April 20, 2005 Share Posted April 20, 2005 Can some one give me the width of this LCD - I need to see if it fits my wall units. Just dreaming here - do the speakers come off?? Link to comment Share on other sites More sharing options...
digitaladvisor Posted April 20, 2005 Share Posted April 20, 2005 For those having with vertical shift see this article and those wanting independent review on how these perform with computers (Media Box orientation). I think this maybe the same LCD under the 'skin' Picture shots and full orientated computer review use: http://www.trustedreviews.com/article.aspx?art=1253 It would be only be a matter of time before other import "brandings" hit our shores. DA Link to comment Share on other sites More sharing options...
markg1503559880 Posted April 20, 2005 Share Posted April 20, 2005 Can some one give me the width of this LCD - I need to see if it fits my wall units. The manual gives a distance of 925mm - I've already checked this for someone else and it is correct. Just dreaming here - do the speakers come off?? <{POST_SNAPBACK}> Sorry, no - they aren't removable. Link to comment Share on other sites More sharing options...
retro Posted April 20, 2005 Share Posted April 20, 2005 Thanks mate. Link to comment Share on other sites More sharing options...
sixpennycarp Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Just do the honest thing and sell it on Ebay, then buy the one you want. If you do a frauduent return, it doesn't exactly encourage BigW to provide similar product offers in future. <{POST_SNAPBACK}> I would lose a few hundred dollars then Link to comment Share on other sites More sharing options...
MadDog1503559593 Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Just do the honest thing and sell it on Ebay, then buy the one you want. If you do a frauduent return, it doesn't exactly encourage BigW to provide similar product offers in future. <{POST_SNAPBACK}> I would lose a few hundred dollars then <{POST_SNAPBACK}> Such is life! Link to comment Share on other sites More sharing options...
xtractdigit Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Just do the honest thing and sell it on Ebay, then buy the one you want. If you do a frauduent return, it doesn't exactly encourage BigW to provide similar product offers in future. <{POST_SNAPBACK}> I would lose a few hundred dollars then <{POST_SNAPBACK}> How long have u had the 66 if only for a short time. Take it back and tell them its interfereing with your phone <cordless> try another 66 then go back and say its the same and u contacted the service dept and they said to pay xtra for 81 as it has a better tuner. Presto new 81 telly Link to comment Share on other sites More sharing options...
Tony M Posted April 20, 2005 Share Posted April 20, 2005 I bought the 66cm AWA and want to get this one, I still have the box/receipt but the return desk at my store is pretty tight to the policy, what excuse could I use? Just do the honest thing and sell it on Ebay, then buy the one you want. If you do a frauduent return, it doesn't exactly encourage BigW to provide similar product offers in future. <{POST_SNAPBACK}> I would lose a few hundred dollars then <{POST_SNAPBACK}> How long have u had the 66 if only for a short time. Take it back and tell them its interfereing with your phone <cordless> try another 66 then go back and say its the same and u contacted the service dept and they said to pay xtra for 81 as it has a better tuner. Presto new 81 telly <{POST_SNAPBACK}> If you're serious, I'm pissed off. We all pay in the long run for this sort of BS. I don't like getting crappy service from retailers, but it's not hard to see why they dish it out if they get this sort of garbage from customers! 6pennycarp, do the right thing and accept that you changed your mind when a new model came out. AFAIK, Big W don't trade-in, but there should be no difficulty off-loading an almost-new 66" for a fair price. I've considered asking Angelo if he's still got his as an 81cm is too big for the wall unit in which I've got a 3rd TV that's overdue for replacement. Unfortunately, I don't think even the 66" will fit, but I'm looking at the possibilities. The advice given by digit is the sort of thing I'd expect from the **** that just left a large door ding in my car. (Might help to explain my current frame of mind!) Link to comment Share on other sites More sharing options...
zorg1503559539 Posted April 20, 2005 Share Posted April 20, 2005 catalog with pics here http://www.bigw.com.au/catalogue%2021-04-0.../pages/05/b.jpg http://www.bigw.com.au/catalogue%2021-04-0...te/index01.html on page 5 looks good.. so whois is rushing down to their local big w tommorrow with the readies or credit card in hand.... Link to comment Share on other sites More sharing options...
