  • Replies 108
SC HD is ~12.64Mb/s
------AC3 Audio: 447.51Kb/s
TS information says 13Mb/s (FOR AUDIO: AC3: Bitrate 448 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 2/0 L, R)
SC10 SD is ~ 5.87Mb/s
------MPEG 2Audio: 257.67Kb/s
TS information says 6Mb/s (FOR AUDIO: Elementary Stream PID 354 (0x0162) MPEG-1 Audio
MPEG1 Audio: Bitrate 96 Kbps Sample Rate 32 KHz
MPEG1 Audio: Layer I Mode Stereo
Screen Capture: http://img173.exs.cx/img173/1634/tenhd7os.jpg (resized from 1440x1080 to 1920x1080)
Edited by kenneth
Link to comment
There is a possiblity that a VPG may come on the SC10 network later (of course this was just an email from an anonymous person at SCB (using the email form on their site to contact them about it)).
They may just be copying Ten (or Ten told them not to go higher due to people like you Winston that pick up SC10 from non-licensed areas).
Link to comment
Heheheh :P So I'd be the scapegoat for PRiME being 576p (if they choose to go down that path) too? :blink: I stay on the Sydney channels most of the time anyways though. How about the Canadians? They can get American OTA/FTA stations and they're also relayed on cable.
Link to comment
Sure : Click Here
I have never done one of these exports so I did the ALL option.
Thanks.
Looks like SCTen HD is 200kbits better off than Ten HD but there is a hell of a lot of null packets. Either they are planning to put up a VPG or they don't know how or are unwilling to optimise the mux.
They are also the only 1080i broadcaster using h x 1080 instead of h x 1088.
Link to comment
I just got the test channel here in Ballarat!!!!!
> video basics: 1440*1080 @ 25fps @ 0.7031 (16:9) @ 13000000bps, vbvBuffer 444
-> starting export of video data @ GOP# 0
!> dropping useless B-Frames @ GOP# 0 / new Timecode 00:00:00.000
packs: 36888 100% 6938328
-> Video: fr/ ct/ 1p/ cg/ og/ dg -> 82/ 1/ 0/ 7/ 0/ 0
-> Video length: 82 frames @ 00:00:03.280
-> GOP summary: min. 20, max. 24 fields; contains interlaced frames
-> avg. nom. bitrate 12981395bps (min/max: 12970000/13055200)
-> set first sequenceheader bitrate to 9800000bps
---> new File: D:\Video\2005-03-31(Thu)PM0329-CHD40.m2v
--> Teletext on PID 0x113 (SubID 0x10)
--> AC-3/DTS Audio on PID 0x4BC
Audio PTS: first packet 03:04:14.262, last packet 03:04:17.846
Video PTS: start 1.GOP 03:04:14.883, end last GOP 03:04:18.163
-> adjusting audio at video-timeline
-> src_audio: AC-3, CM, 2/0(2.0), 48000Hz, 448kbps @ 00:00:00.000
!> 1 frame(s) (32ms) added @ 00:00:03.232
audio frames: wri/pre/skip/ins/add 102/0/0/0/1 @ 00:00:03.264 done...
---> new File: D:\Video\2005-03-31(Thu)PM0329-CHD40.ac3
Link to comment
Yeap I'm picking up SC HD Channel here is Wagga Wagga NSW. Just a Colour Bar Test but it's a start. Prime HD is still SD. However we still don't have the WIN HD Channel. :blink:
Link to comment
Why is anyone worrying about bit rates being higher on the regionals than the Metro channels? The video quality is only going to be as good as its original source bit rate provided on the HD feeds from Metros. Also there's no point in hoping Prime are going to magically broadcast in 1080i when all of 7's 'HD' content is garbage 576p...If they did upconvert it would be like using a scaler on your DVD but not even as good..
Link to comment
Guest Tim H
Hello DTV addicts in Canberra
SCTEN HD. The teac is picking up station 50 but alas no pic or sound as at 7:15pm Friday 1 April. Is this a B/C issue - ie no signal or is it a STB problem?
WIN HD test loop and PRIME test screen are both very good.
Thanx Tim
Link to comment
To Top
