Samsung PS42P4H - Just Purchased
I have yet to have the fix applied. But I have had no issues for over a week.  I am using VGA, DVI, Component, S-VHS and composite ports with different video sources and all is running fine.  The only problem I have is that on low quality input the PQ is not what you would like (garbage in - garbage out) Overall I am very happy with the PDP and watching HD tv via Teac or HTPC is excellent.
Chris
Would second that. ABC and SBS seem to be the problem broadcasters.
On the other hand, I watched LOTR #2 on DVD (Directors extended version) over the weekend and the Samsung performed flawlessly! I was very impressed... as were my mates! :-) No solarisation. No judder. Battle scenes were fantastic with the surround sound!
Re: the fix... I don't even know if I need it. The Samsung's never played up once.
Deucer.
  • Replies 150
Chris
Is the fix aimed at the lock up problem only? Do people still have synch problems between audio and video, or has that been solved also? Finally, has anyone gone for the big brother of this unit? The 50" looks like a styling replica of the 42" model but I haven't seen any commentary on its performance.
Thanks all for you constructive discussion - really helps people focus on their options.
Well I have been researching and looking at 42" plasma screens for approx 3 months. learning as much as I can about these awesome displays before making the plunge.
Now I have finally done it - I purchased the Samsung 42" HD P-S42P4H1 with stand, speakers & 2 yr warranty on Friday for......
$4200 !!! :blink:
Also got a $100 4 point power board surge protector for $50
So if you want one of these then get down to Dick Smith electronics whitehorse Rd, Nunawading, Melbourne. In the last 2 weeks I have been working Harvey Norman, JB Hi Fi & Dick all off against each other. Eventually - I told the guy at Dicks that I wanted to leave his store that day with the screen and I bargained the price. JB were good but - they were a bit wrapt up in techo speak and were not listening to me 'the customer' as to what I wanted - kept trying to convince me that I should spend $6k on Hitachi.
Yes I agree with all the positives stated about this screen in this forum - the screen is the best Bang for a Buck you will get.
However......
I too have been struck by the 'Lock-up' problem. :P
Not the syncing problem though. I have had 3 lock-up's since having the screen (48hrs) and am very grateful for all the insightful comments on this forum about this issue. Will be definitely calling Samsung & hopefully the 'fix' that has been talked about is working and I can move forward (Glad this has happened to me now & not in a months time when I loose my option to return!)
I dont want to send this screen back - because after so much research - this is clearly the winner for me.
As for my setup - I am at the basics until I build the Home theatre setup that I want. I am currently using the inbuilt tuner and DVD player. I think the JBL speakers are fantastic - The Mrs loves the design of the screen and all the inputs make this screen a big winner for me.
As to my future acquisitions, they are......
- A home theatre surround sound speaker & amplifier package (No DVD player etc). Minimum of 500W power, 5.1 speaker system with the ability to add 2 additional speakers. I want to run 2 additional apeakers to other parts of the house for playing music and radio. I am looking at a Yamaha system at present which is $498 at Dicks but, Dicks tells me that this will be replaced in the next 2 months with a better system of the same price - so I will wait.
- Home Theatre Personal Computer (HTPC).
If you are making a Home Theatre then you should really go down this path. Throw out your DVD player, recorder, PVR, digtial set top box, personal computer as all seperate boxes and get it all in one neat package where you know it works - cause you aint mixing a TEAC with a IBM with Panasonic with a Pioneer!!
The HTPC I have researched and am looking for is:
P4 3Ghz processor
512MB DDRAM (min)
160GB hard disk (min)
2 (yes 2!) DNTV HD Digital Tuner cards and software (these are the best HD digital cards on the market and the software is awesome as it is designed to support multiple cards (watch 1 channel record 2 others!)
128Mb graphics card
multiple digital card reader 6 or 9
DVI, s-video, composite outputs
MS windows XP media Centre SW
16 x DVD & CD RW +/-
Price is about $1800 if you look around
A good example of a 'quality' HTPC is offered at www.dpanda.com.au
I have also recently seen the HP (Hewlett Packard) home theatre PC - this a nice unit but, (the idiots!!) HP put analog TV tuner cards into these machines!! Can you believe it - they build a really good package and then ruin it with rubbish TV tuner cards!
Although the real nice thing abou the HP machines is
- Light scribe DVD burner - allows you to burn a picture and / or words of what you burnt onto your CD / DVD on the rear of the disk.
- the additional hard disk slot - you can simply slot into the PC box (just like a floppy disk or CD player) an additional Hard Disk of up to 160GB - thus you could end up with 320GB of hard disk - great for recording HD digital TV!!
Basically, when I set this machine up with my plasma I will be surfing the net through my Home cable connection, buring HD TV to hard disk or DVD, compiling an awesome music library both as mp3's or from broadcasts such as RAGE, recording 2 channels and watching another and the best part....
with the DNTV digital TV tuner - I can access the TV from the office or anywhere remotely and start recording a TV show etc.
Anyway - these are my thoughts - will let you know how I get on with the 'lockup' solution and my acquisitions as they come on board.
I thought I had solved my Home Theatre Audio Sync problems with my Samsung 42" HD PS-42P4H but as it turns out I had not been able to fully do so. It certainly improved it but became annoying again after a while. I have 'double adapters' on the audio out from the PDP, one going to the Home Theatre 'audio in' and the other to radio headphones. There was even a sync problem then with audio muted on the PDP and with sound via the headphones and the Home Theatre speakers.
I connected a stand alone DVD Player to the PDP via component and all sync audio problems are now solved. However I still need to disable the PDP speakers (via "Mute On" in the Audio Menu) and I need to run the 'audio in' to the Home Theatre from the PDP.
I have had my Samsung for a month now and have not had any PDP lock up problems. The remote did lock up a few times during setup but all is OK now.
As people have said elsewhere in this thread, this Samsung is certainly great value for money. I am delighted with my purchase.
My thoughts on this PDP, which i've owned for 7 weeks now.
Can't fault the HD PQ from the HD LG4100 (DVI) - its awesome, well at least the test signals are, as thats all i've seen so far, being from Wollongong.
However am none too happy with the SD PQ from the same LG unit nor from my toppy (component). It seems to suffer from bad solarisation ( well I assume thats what im seeing, given the descriptions i've read). At first I thought it may be the Toppy/Component PQ issue i've read about, but its also very noticable from the LG, although maybe not quite so bad.
I've tried all possible settings on the Samsung but its still quite ordinary. Thought i'd give the screen time to settle hoping it would improve, but nope.
A small amount I could live but this I can't.
DVD from a Pio 373 (Component). Animated dvds such as the Pixar flicks are brilliant, but other dvds also suffer from this solarisation.
not sure what if anything I am doing wrong re setup, but IMO I can't get a decent SD PQ & I dont think I'm too fussy, quite the opposite
Any help would be appreciated,
Is there a service menu for better setup?
Calibration possible/recommended for this PDP?
Can sitting too close exaggerate solarisation, & hence sitting further away reduce its effect? due to room limitations I'm about 3 meters away
bb671
bb671,
In my experience with this panel, the SD material, particularly from ABC and SBS is where you'll notice solarisation..... and more so on their older material. So if this type of solarisation problem is associated with the quality of the material being broadcast... you'll get it with any PDP I'd suspect. I regularly notice solarisation with 7 (My Restaurant Rules is usually pretty bad), but not with 9 or 10.
You really need to get the HD digital broadcasts. They're made for your setup and you'll then really see what it's capable of.
I also have a Pio DV373 and have no trouble with solarisation. Although I try not to, I still look closely for it. Mine is connected directly to the PDP with NeoTech component cables.
Deucer.
Hi all,
I bought this unit last week for $3800 with stand and speakers.
I've got it hooked up to the LG4100 stb via DVI and the quality is excellent
I've also got a Panasonic DMR-e50 Recorder connected via a set of Crest platinum component cables and the solarisation is very noticable.
Would tuning reduce this or would I be better with a different DVD player?
Could someone please post up their settings for this screen as I had a quick look and saw that the contrast was all the way up to 100 (not good I presume?).
Thanks for any help offered,
Gavin
Hi all,
Gavin
Heh Gavsta,
That's a great price.....can you tell us where or who you got that price from ?
Also, is that the Pana DVD recorder with 80gb Hard drive ? Saw that yesterday at Dick Smith for $900.......is that a reasonable price ?
Would you recommend a DVD recorder with hard disk over a STB with Hard disk like the new Toshiba that everyone is trying to get their hands on ?
Well it's been a month since my first post and I couldn't be happier.
As a guest said whilst watching Hero the other night '..this picture is just beautiful, I have never seen anything like it...' I agree.
No more locks but will ring and get the fix soon.
Little solarisation but I spent a couple of weeks tweaking settings etc. Never from the DVD which is the benchmark for signal in my system. I don't watch My Grub Rules so cant comment on that. I actually think the display is a botox and makeup detector as this is the only time I notice any solorisation - no movement and all one colour. Might even watch the academy awards to see if this is true. LOL.
Am also building a PCTV HD receiver / recorder / MP3 player etc. and will post again when that is up and running. I am going the free option with MythTV which comes on a self installing disk - or you can just beet from the CD-Rom and see if you like it
http://mysettopbox.tv/knoppmyth.html
The deciding factor for this decision is that I plugged my Mac in the other night and it is AWESOME the games - the net etc. Not to mention a true 1024 x 768 deiplay signal for a change. It is another world altogether. I don't know about Windoze but OSX detects the display and produces a wide screen desktop to work on. Also in OSX you can do a display colour calibration for the Samsung P42 display and tweak it to perfection.
I would highly recommend this unit to anyone considering a purchase as once set up is is a thing of beauty and awe. Especially if you hope to plug a computer into your display.
$3800 Wow thats amazing - where did you get that price from? was it screen only or stand & speakers as well?
As for the 'Lock-up' Issue - I just had the service bloke from Samsung visit to apply the software patch to my Samsung. I spent 10 mins after he left changing channels and putting the screen through its paces - no problems - so far - will let you know if anything goes wrong but, I am very happy that this is done now.
The Service guy said that he has fixed a couple of these lately but, not a lot. He said the problem is with the software, the signal sent from the remote was conflicting with the panel software and when the conflict occurred the screen would just 'lock-up' and not read anymore input signals. Apparently, they flew an engineer out from Korea who looked at a screen in Sydney with the problem - spent 10mins on her PC creating a fix, applied the fix and went back to Korea. (Not a bad trip to the office!) They haven't had any problems with screens since the software patch has been applied.
So if anything, I recommend that you get the software patch applied to your screens as soon as possible - just to be safe.
Also - regarding the Lip sync problems - the Service guy said that for all these screens you should NOT use the audio out options from the screen to an external device. The screen needs to be set up as the sound receiver only. Thus, for your DVD player - you should have the sound outputted from the DVD into your Home Theatre Amplifier and then (optional) from the Amp into your Samsung screen. Not - DVD player to screen and then to Amplifier.
Just checked out the mythTV option - nice features but, you get most of the software features when you buy a HD TV tuner card and the mythTV option looks a little 'patchy' at present. Will be interested to see how you go with this.
Oh how I wish I had my HTPC set up now with digital reception - but soooonnn!!
:blink::P
Gavin
I also have this same DVD recorder and I find as a DVD player it is shocking compared to my Pioneer 355. With the Panasonic make sure any picture "enhancements" are turned off (ie NORMAL, not cinema etc) and I would try another player. I actually ended up buying the Pioneer after the Panasonic as I was so dissapointed with the playback functions on the Panasonic.
Thanks for the replies.
Looks like I'll be swapping the dvd player over as I have heard that it doesnt record in widescreen so thats a bit of a bummer.
I got for $3800 from the Good Guys in Prospect last tuesday including stand and speakers. They had just dropped the price to $3999 and it took me 2 minutes to get them down to $3800 for cash they also threw in the Lg 4100 for $450.
Gavin
I just bought this PDP last week and I must say it is a sexy unit.
However I am not happy with it at all nor am I happy with Samsung.
I got the lockup, I got the audio sync problem but far and away the biggest problem is the solarisation.
I try to ignore it but it is so obvious that its irritating especially when I see my friends TV's and they rarely have the problem.
The solarisation is evident every time the camera pans or someone moves quickly- for example watch My restaturant rules and you'll see it is almost unwatchable.
The service guys came around and did the firmware upgrade but said theres nothing they can do about the solarisation. I rang Samsung and they said that they won't replace it because the service guy hasn't said it's a repair problem.
Now I get a line of pixels down the middle of the screen that go from grey to red and hold onto the colour around them for a few seconds. I'm at my wits end and don't know what to do.
Surely I didn't just throw $4000 away.
My PDP is connected to a HD set top box, and an LG HDD DVD Recorder I've tried these on other PDP's and they work perfectly.
Anyone have any tips on what I can do?
Also when I spoke to Samsung they said they've never had a problem with the TV and have never had one returned, I then mentioned that there are plenty of reports of problems on this forum and the girl on the phone denied it.
By the way there is a service menu you can get into if need be to do this put the TV on standby and then point the remote at the TV and press INFO then MENU then MUTE then Power On and you will get the service menu to adjust settings on the TV.
:blink:
bb671,
Deucer.
G'day Deucer
thanks for your thoughts. I get solarisation on all channels and DVD. i.e whenever there is skin its there, some shows are that bad its unwatchable others just bareable. Seems tabz 0000 is experiencing the same problem with his. I understand with this type of unit some solarisation is to be expected, but definately not to this extent :P
I will have a look at the service menu tonight & see what i can do, surely cant make it any worse!.
bb671
Samsung called back and they said they now have a fix for the lock up problem. I am awaiting a call from the local service centre to come out and do a the "5 min fix". Will keep you posted on the progress.
1bigtv,
It's a bit hard to know if there's really a problem or not. :blink: After Chrisr_aus had Megamart come out to set up his gear properly, he's reported having no lock-ups. But.... if Samsung says thay have a fix for the problem, you can only assume there is one. But the question is.... What is it?
So... while Samsung's installing the fix for you, would you mind getting some details for us?
For example:
- What exactly is the problem?
- What circumstances or combinations of circumstances cause the problem?
- What production batches are affected? (Batches or dates will do). EDIT 22/04/05.
- What is the fix?
- Is it a hardware change or firmware fix?
- Are there any other ways to avoid the problem other than by Samsungs fix?
As an consumer of their product, you've got a right to know this so don't let them fob you off.
Having said all that... I still haven't had one complaint about my Samsung panel.
Thanks for following up with this.
Regards,
Deucer.
Deucer,
- What exactly is the problem? Control of the PDP is lost via remote and front buttons on the PDP.
- What circumstances or combinations of circumstances cause the problem? Nothing specific.
- What production batches are affected? (Batches or dates will do). Was told Feb onwards. I geuss ones coming out of factory now are fixed.
- Is it a hardware change or firmware fix? Yes a firmware fix.
- Are there any other ways to avoid the problem other than by Samsungs fix? No.
Firmware took about 10mins to upload. Was something like NPL42PLEAT-1131
Does anyone know how to check the firmware version?
Regards,
1bigtv
Well that sounds like a warranty problem. Suggest you get the service technician back on site.
One tip to help you with solarisation is to watch the show.... not the solarisation. Might sound silly but it's true! Every PDP out there at the moment has some operational disfunction.... just read through this forum. The way you describe it, your solarisation sounds pretty bad.... but the extent of it depends on so many factors. In the end, the PDPs just the messenger that gets shot.
Deucer.
Deucer.
Deucer,
Believe me I try to watch the show and ignore the solarisation but it just gets so darn frustrating especially when you consider the amount of money spent.
tabz_0000,
What STB, cables and connections are you using? I'm certainly no expert on this stuff but I don't find much solarisation at all. I really only notice solarisation for about 20% of my viewing time (when I'm looking for it). It's only really ever on 7, ABC and SBS... and then it depends on the program. MRR on 7 is the worst I've seen. I also find that ABC and SBS are better viewed on SD than their HD channels.
I wonder if your other components are contributing to it. I'm using an LG LST4100 HD STB and standard DVI cable to the PDP. All other cables are premium Neotech and I don't get solarisation at all from DVD over component.
If you're not happy, you should discuss this with your store and send it back. But it would be a shame to throw the baby out with the bath water. You've got a good PDP there for the money you've spent. It'll never be perfect, but there might be something you can do to improve it to your satisfaction.
Deucer.
Hello tabz_0000
First of all, don't worry. It seems that unless you pay a great deal to get a top brand, every plasma has pros and cons, especially the lower price as manufacturer use less processing to cut cost. For the lockup problem, see how some people got it fixed. As I mentioned before in this forum, Samsung plasmas have been known (see Cnet reviews in Aust and US) for noticeable solarisation. This is more visible with moving pictures when the original souce is not HD (note that the broadcaster may scale up the souce to HD before transmission). If you watch true HD source such as Get Away, you'll see that this is very negligible. By the way, this solarisation happens only with Component /S-Video/DVI inputs. What I suspect is that the green signal is abit delayed compared to other color signals (Red,Blue) as a result of filtering inside the TV. However, if you watch DVDs from a computer via VGA input @1024x768 resolution, I'm sure this won't happen. This is because the PDP won't need to do any conversion as the input signal matches the native resolution of the panel.
If you are very a cricial viewer, a possibe solution is to consider a HTPC (home theatre PC) which can allow you to watch HDTV with brilliant pictures with no more motion artifacts. A HTPC also allows you to schedule TV recording, skip commercials, a versatile DVD recorder, ... and so much more. Just do a Google search on HTPC and you will see. At the moment, the cost of a commercial HTPC starts from 1.5k (see http://www.edutechnology.com.au/home/produ..._home/index.php ) for an example. However, you can also build one and depending on what you need, probably $800 might be enough. Note that, with a HTPC, you will no longer need a HD STB and DVD recorder. Some other people in this forum also mentioned about this.
The bottom line is: there may be some trade-off for the low price of the HD plasma if you are too cricial. However, the saving allows you to buy a HTPC box that gives you amazing viewing experience, which I bet will be equivalent to top-brand plasmas.
Hello tabz_0000
Guys thanks for all your replies.
I've decided though that I'm gonna contact Megamart and get them to exchange it for another panel.
I've tried so hard to ignore the Solarisation but it is so prominent on so many shows that I actually hate the TV.
On question though with my HD STB I select the format as 1080i is this correct, or do I have to change depending on the channel, and how do I know what format to use?
I leave mine on 1080i. Find the PQ is best when left there. The STB should provide info on the video and audio protocols the broadcaster is using for each channel. You'll likely have an info button or similar on your remote for this.
Sorry to hear you're not happy with the PDP. Hope you find something that meets all your requirements. The upside is those prices keep coming down.
Deucer.
Deucer.
Guys
Thanks for all the advice...Samsung have screwed me around so much on this I refuse to buy another Samsung product.
I did speak to Megamart and they have agreed to exchange the PDP for another one...I'm thinking of going for the LG DT42PY10x it's a nice looking unit with a HD Tuner built in does anyone know much about it? It's ticket price is $5499 but I can get it for $4450.
Hi
Be careful and check it out first,new LG HD Plasma due out June/July at RRP of $3999.
Regards
Basil
Hi All,
I have recently bought the Samsung PS42P4H, and have had it for about 2 days now.
Seems to be not to bad....However have read a lot of reviews/posts in regards to the screen locking up, and colour solarising issues.
I am still waiting on the HD box to come, as they had to order the unit I am chasing, however in the meantime am not 100% happy with the PDP.
Many reviews and people are talking about 16.7million colours v's XX Billion colour screens, however im not 100% sure if this makes a 500% (to say) difference???
Understanding of the fact that more colours 'should' give a better/true® match to the original image, however I am noticing that this Samsung screen appears to have a lot of solarisation when watching all analogue broadcasts, and DVD even when the signal is received via Video in RCA, RGB-3xRCA Component Video, and S-Video as well.
Is this normal from such source signals, and once the HD box comes, it is likely to disappear?
I have noticed that the screen has only locked up once so far, so hoping for this note to happen again.
Other then the 1 Lock up, and the current solarisation issue, I am otherwise very happy. If the solarisation issue will be eliminated by the HD box, then im sure I will be holding on to this one.
Any feedback would be appreciated.
Cheers.... :blink:
  • 3 weeks later...
Ive been reading this topic regarding the PS42P4H and THought I would mention that I have this unit and the TEAC HD STB (connected via DVI)
I have the following issues with the panel.
1. Buzzing sound (intermittant). Sounds like its comming from a torroid transformer at the back of the panel. Gets louder with brighter colours on the screen (white, blue etc). UNACCEPTABLE and IF NOT FIXED WILL BE DEMANDING A REFUND.
2. When I first turn the set on I get random blue dots throughout the picture.. Its almost like a light static. THis seems to dissapear as the set gets 'warm'.
3. SOLARISATION. Clay faces.. At first I thought I was going mad.. But after reading this forum it sounds to be a real problem.
I disagree however with those of you who say it doesnt happen with HD.. I watch getaway etc and when the faces pan around the screen the solarisation is unacceptable... I would rather watch a Nokia Mobile phone. When the faces are stationary however the picture is perfect.
Firmware: My version is 16 September 2004. (thanks for the codes to get into the service menu)
Can people please list the date of their firmware here... If I dont have the latest I will request that when they fix points 1 & 2.
P.S I purchased this unit with speakers & the TEAC STB (HD) for 1400 on AGC about 2 months ago from Good Guys Erina..
THanks
David
slimf-
How much did u say you paid for the unit? 1400? Thats extreamly cheap. I have a freind (business client), that is infact a Samsung disty, and that is way way below even his buy price from Samsung, this might be the reason you unit was so cheap, and/or not all that good- ie. buzzing issua, blue dots... etc...
This is not a problem I had with my unit, I have since returned it and have recieved a refund, however the clay face issue was a big issue for me.
I infact noticed a colour streaming issue watching HD as well, (Samsund HD 550 STB), and it wasn't good at all on DVI/or any other connection. It looks like a rainbow behind the face/head/object.
The big issue I had was that the Samsung was the only screen that I looked at, where i was able to see extra pixals/dots to try to fill in colour in flat colour areas.
As mentioned it has since gone back and money back in my bank... ;-)
Im now looking at waiting for the new Fujitsu 50" or 55", yes its a lot more $$$, but hey 50" and Fujitsu... well what more can i say.....
The only down side to the Fujitsu other then the $$$ I have noticed, is that the screen is based on a red contrast, where in bright white images/colours the white actually seems to have a redish tinge to it... I have look at the current model screen, all over sydney and it seems to vary depending on how its setup... However in all the screens i have seen it still remains to some degree....
I also have friends who work at Fujitsu, and after speaking to them im assured that its still a very good screen, and I believe it..... The new version is reported to be very much the same, however it will have HDMI instead of DVI... ;-)
Best of luck with the Sammy, and its a waste of time calling Samsung about this screen, they are bloody hopeless! I called 3 times and got a "there is nothing wrong with your screen, nore our product".... I told them it was bullshit, and to read forums across the internet... they just told me that they don't lock up, and the colour/clay face effect is nothing at all, just watch HD.... blah blah blah....
Oh btw my screen was built in Feb 2005, if i remember correctly! Could have even been later, but i think it was either Feb 2005 or March 2005...
THanks
David
Mine was built in Dec 04.
Has 16 Sept. Firmware
Had a local serviceman out last week to look at very poor solarisation issue. Agreed it was bad. He is going to install latest firmware soon, and reckons that will fix it, but i'm not so sure
bb671
  • 2 weeks later...
Hi Guys
Sorry for the delay in replying
I paid 4000 for the unit from Good Guys Erina (4400 with TEAC box) - not 1400. :-)
I had the tech out from Vickory Sound (nice bloke) and he is replacing the input boards and the power supply boards.. Parts on order..
The blue dot issue happens when the unit is cold.. I notice it more on cold days when I first switch the set on :-( Tech reckens the two new boards will fix the issues.
I saw another post here regarding the solarization and that a firmware update might fix it.. I doubt it to! Will keep you posted on if/when the parts arrive and get fitted.
Dave
slimf-
ive owned my ps4p4h for about two weeks now and love it. solarization issue does suck but i deal with it. i paid 3500 from good guys.
whats the code to get the service menu?
Ooops. Posted in the wrong spot. Here's where it should have gone.
Having just bought a Samsung PS42P4H last week, I rang Samsung regarding the firmware upgrade. They said that a service agent would visit on-site to do the firmware upgrade within 48 hours.
What was interesting was that they said the upgrade would fix both the LOCKUP and SOLARISATION problems.
Has anyone had any experience with this? Does the upgrade fix the solarisation?
Dunno. I suspect the firmware upgrade won't fix the solarisation. But I've got no information to support this suspicion. I'll tell you though..... I've found the solarisation with my unit has substantially reduced over time! It was only ever bad on low quality broadcasts and noticeable on quality broadcasts if you looked hard for it. Never seen it on 1080i broadcasts. But it's reduced now.
I think one of the following two things, or the combination of them has reduced the solarisation:
(1) Panel has run-in. I've had mine 4 months now and it's had a good workout.
(2) I did the THX optimiser on the DVD (component) input and replicated the settings (according to my eye) for the HDSTB input (DVI). This resulted in the contrast setting being reduced quite substantially (to a setting of about 60 to 70 from memory). I suspect this had a big impact in reducing solarisation. The THX optimiser is on the Star Wars and Incredibles DVD, amongst others (and any George Lucas produced DVD I'd suspect).
I was accidentally watching FTA via the analogue signal fed through my VCR (which is rarely used now) as opposed to via the STB and the panel locked up on me for the first time. So your post reminded me to log the service call for the firmware upgrade. When it comes, I'll look for any change in solarisation.
Deucer.
This is what I wrote down on my Owner's Instruction Manual.
In Standby mode.
On the remote hit in turn:
Info
Menu
Mute
and then Power On
Uhmmm, ok I am about to ask a really dumb question. I have just skimmed thru alot of the site so please dont flame me for asking a question that has probably been asked a zillion times before, but I honestly have not been able to find an explanation of this. Ok so here goes, "what is solarisation" ??.
I was really interested in one of these panels until I started seeing people commenting on solarisation and I have held off asking the question incase I could find the answer. I think I know but am not 100 percent sure.
If someone could explain this to me I would really appreciate it.
Again, sorry if its been asked before. Im kinda an newbie/not so newbie to these forums.
I bought this plasma a week ago and have no idea whether it was sold with the firmware upgrade or not. Either way, it has performed flawlessly - no lockups whatsoever. Maybe there's a little solarisation, but it's minimal at best. It's more noticeable if you're standing 2 feet away from the screen. When you're sitting a few metres back (the correct distance), it's nothing.
I am interested in this too as I am seriously considering this panel as well.
I take solarisation to mean where shades of a color (usally face skin color) don't blend normally but appear as a big area of the one color tone. For my understanding of solarisation I have only noticed it with facial skin color.
I have a PS42P4H and find I only get what I call solarisation from lower quality video. I had a minimal amount of this (like about 10 secs) when watching the one dayer from England (via Austar) this morning during a close up of a batsman's face. Not worth worrying about really! Older programs such as Golden Girls on Austar have some solarisation too.
I don't recall any solarisation when watching live sport via the STB on free to air Hi Def
