  • Replies 1.5k
Another feature of this panel is the amount of inputs its got.
Ive got a DVD player on component,Foxtel on s-video ( which for some reason gives me the same PQ as RGB convertered to component!)Video and free to air Sat on composite, HD TV on DVI WHICH STILL LEAVES A COMPONENT AND XGA FREE !!
Angelo
With regards to being scared of having a grainy effect if sitting to close I was in HN at Noarlunga when they were setting up the NEC. I was stood very close to it & noticed that it was still very clear even up close. That was actually my first impression of it.
The Pioneers however did look grainy at the same distance although they were running component as apposed to DVI on the NEC which may have made some sort of difference.
When the NEC was set up the sales staff got every other sales staff over to have a look at it. The general consensus was that it was the best display that they had all seen!
Thats the one, wow they want $150 for the same thing.
That's what I thought Angelo it's getting to the stage accessories are costing heaps I had to change my print cartidges the other day and when I found out the price I just got a new printer instead :blink:
cheers laurie
Well it had to happen or else my name would not be Angelo.
The fan noise did seem very loud last night, so I check out the display model in the shop and you guessed it.
Mine is 3 times louder..... Nec has come out and said it does seem louder than normal.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHH
HHHHHHHHHHHHHHHHHHHHHHHHH !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Angelo :blink:
Angelo :blink:
Relax dude its only the fan remember the PQ
How warm is your room angelo? The fans may be temperature controlled so if your room or the area is too warm the unit may run the fans faster to help cool the unit. Remember that the display unit you saw probably was in an air conditioned environment. I used to notice the fans would speed up on my older unit if the temperature was very hot.
I had thr Marantz which is a rebadged NEC and even when the misses had the ducted heating up to Hell on earth temp i could not hear the fans so if Angelo can hear them to a point of being annoying there is something wrong
Hearing the fans is relative the amount of the noise, if you watch tv at a loud volume it will drown out the noise, display showrooms are noising so a lot of the nosie is drowned out. So I guess it all depends on when he's watching the thing and at what times, ie I used to notice the fan noise was very annoying late at night when I had the volume down very low. But otherwise at higher volumes it wasn't noticable. So I guess that needs to be taken into account.
When i got the Marantz home i tested for fan noise the very first night and with everything off in the house i could just bearly hear it sitting 3 meters away
Quite true, another thing is the size of the room and reflective surfaces etc.
Whenever I buy a new computer, and put it in my study, the thing sounds so loud, due to the shape of the room and the reflective surfaces. Usualy changing the stock fan is the first thing I do.
Might be a similar issue here.... perhaps the room might be amplifying the noise, and also the fan might be running faster once the temperate is above certain limit (as was suggested earlier in this thread...)
Anyway, would be interesting to see how you go Angelo...
cheers,
Ritesh
I purchased an NEC PC-50XM4W plasma 2 weeks ago including stand and NEC HD stb for $8,030 including delivery. This was a limited special deal. The XM4W is the Black model. The picture is stunning and I watch from about 3m away and have no problems with viewing distance. Watching HD pictures takes your breath away. I have my STB and DVD player connected via component cables and my satellite box via S cable. The satellite pq is excellent as good as dvd. Only problem I can find is the fan noise can be heard during low sound output. I was going to buy the Panasonic 50" Viera series but changed my mind and now glad I did as this NEC has DVI input. I was told HDCP (high definition content protection) compliancy allows you to view HDTV signals through the DVi connection that are copyright protected. If you do not have HDCP compliancy, you will just see snow on the screen. But it's ok when using component cable.
Hope that helps.
  • Moderators
And thats why I made sure the plasma I bought didn't have a fan in it - nothing more anoying than a fan going off or switching speeds during the quiet scenes of a movie. With a fan inside the panel thers no guarantees even if its reasonably quiet now that it doesn't start making some noises further down the track. Even my HT amp does not have a fan.
The HDCP thing is pretty confusing. My Hitachi plasma's dvi connection is HDCP compliant and my TEAC HD stbs dvi connection is not - yet while hooked up via dvi they work perfectly together.
Perhaps HDCP compliance is more of an issue if you source(stb or dvd player) is HDCP compliant and your panel isn't?
Well eventually it will be a requirement for sources to check for HDCP compliance on digital outputs (Which display devices will have, but recording devices will not, the idea being you will be able to display Protected content but NOT record it digitally). If your source is not HDCP compliant, then you are laughing anyway....
Well one is to assume the fan plays an important part in some displays then having a lot of experience with equipement that has fans to control temperature,if it totally fails then there should be a shut down of the display but that depends on the fan circuit I just hope they have a pulse counter rather than detect loss of voltage! I've seen computer board destroyed because of the voltage sensor method and it dosen't help when they don't use ball bearings on the fan unlike the cheap brushless type
cheers laurie
HEy Angelo you are very quiet on the NEC front
No Im just going through what this plasma can do.
Far out I,ve just found out that if I can find the right cable I can go direct from Foxtel RGB Scart to the BNC connectors on the plasma.
The picture processing done by the plasma on s-video really is fantastic.
I,ve also found that the PQ on component to be better and alot brighter than DVI so far which has surprised me.
Nec has agreed to swap my plasma over for a new one as they also found my plasmas fans to be very noise as well. I could really ask for my money back but the term "what the hell for" springs to mind.
YES THERE IS A FIRST FOR EVERY THING !!!!!
Angelo :blink:
Angelo :blink:
What about going the 42"
Angelo :blink:
Once youve lived with a 50inch you just cant go back to a 42inch it just seems too small.
Angelo :blink:
Still feel your sitting to close?
What are you noticing or not likeing sitting that close?
Isn’t that funny, at first you thought a 50” was going to be too big but you got used to it quickly, as I thought you might.
Soon you will want a 60”. :blink:
Regards,
Owen
Angelo :blink:
This is what Ive found out so far about what was making me giddy, its the motion gitterness which all 50 inch plasmas suffer from ( when you stand 3 meters or more away it tends not to be as bad).
Tonight I tried using component and I can switch back and forth from DVI and component and have found that its not as bad on component.
Angelo
Soon you will want a 60”. :P
Regards,
Owen
Funny you should say that because when they offered me my money back that was the first thing which jumped to my mind ahh a 60inch !!!
Angelo :blink:
Angelo :blink:
Angelo
When i looked at the 50 i was standing between 3 and 3.7 meters from the screen and noticed a little noise whochi thougght would annoy me after a while at those distances
Angelo :P
Angelo
As I said before Im starting to prefer the component connection for this very reason(sh#t should not have sold the Toshi stb after all :blink: )
Angelo :P
Angelo
Funny you should say that because when looking at the 50 it was with the NEC HD box via component
Angelo :P
Angelo
Far out lucky you didnt see it on DVI.
I,ll catch you tomorrow when you get yours and see what you think of it .
Cheers Angelo
hmmm.. that's the point I was making a few pages back SIZE do really count as a visual impact! now a 60" is one mother of a display
cheers laurie
cheers laurie
Now I know Ive heard that quote before but it wasnt about a display............. :blink:
Angelo
That was possible on the X1 too you know Angelo, a lot of panels can take RGB with sync on green which is what scart is. All you need though is a special cable to take the scart rgb pins into a bnc or vga cable and just link the Red/Green/blue pins to the vga/bnc RGB pins.
No I didnt know that.I wonder where you could find such a cable ?
Interesting note that the Sony 50inch X1 is made in Japan and not Korea and has no issues with DVI HDTV.
Angelo
