Steffche 0 Posted October 16, 2004 Share Posted October 16, 2004 Well, just got back from Megamart....and decided to swap the Philips for the Viera. They don't stock NEC so I was at a loss as to what to do. I compared the Viera to a fujitsu they had in there and didn't notice any difference. I get the feeling that there aren't too many Viera followers here? <{POST_SNAPBACK}> How long did you have the Philips for? <{POST_SNAPBACK}> Well its a long story....I first bought the 42PF9945 6 weeks ago. After 3 or so weeks I complained about and had it swapped for the newer version 42PF9946. It seemed ok for around 2 weeks and then started to look very grainy in the black areas. It also has developed a few other glitches were when turned on it has a spasm attack and has rows of colored lines scanning down the screen. I have to turn it off and on again to fix it. Anyway....I had a technician from Philips come out and said he agreed with me...so now It's panasonics turn to impress me. I hope I haven't made another mistake... Link to post Share on other sites
ijd 0 Posted October 16, 2004 Share Posted October 16, 2004 ...so now It's panasonics turn to impress me. I hope I haven't made another mistake... I personally don't think you have made a 'mistake' with the Viera. I was very impressed with it when I first saw it (only a couple of weeks ago). It's just that when auditioning you need to do it on your terms, not the retailer's - and this is when you can sort the wheat from the chaff. I was very disappointed when I first turned on the NEC at home with an s-video input [see my earlier post]. But ... I already knew what I would ultimately get out of it and started setting it up properly. The last link in the chain was earlier today when I finally got a DVI cable for my STB - and I can't see any necessary changes to the default settings from the factory! Cheers, Ian Link to post Share on other sites
Steffche 0 Posted October 16, 2004 Share Posted October 16, 2004 As long as it looks better than the Philips....thats my main concern at the moment. I would hate to have spent an extra $1000 for nothing! Link to post Share on other sites
Groover ! 0 Posted October 16, 2004 Share Posted October 16, 2004 With regards to the difference between the 50XR4 and 50XM4.The only online info I can find is about the US models, which may not be appropriate to the "w" australian models. However, 50XM4 and 50XR4 US models are identical, excepting frame colour. Compare US Plasma Models I too have heard that there is some other difference, but have not been able to find out what it is. It would seem pretty silly though to have such similar models with a very subtle difference, and the online retailers seem to think that the models are equivalent. With regards the 42XR3 and 42XM3 there DOES seem to be a difference (try the above web site). The price and FCC class (what ever that is) is different!. One is a "commercial" and one is a "home" use plasma. They seem to otherwise be equal in specs tho - so why the extra cost and alternate classification? J <{POST_SNAPBACK}> I spoke to NEC prior to hunting these plasma's down and was told point blank the only difference between the two was the colour of the front bezel <{POST_SNAPBACK}> The remote is different as indidacted in a earlier post On the XR3 the bottom part of the remote was taken up by a button for each input The menu is also a little differnt and the all white screen option not on this model To me this looks more like what a commercial model would be like <{POST_SNAPBACK}> So did your pixelation problems go away ? Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 With regards to the difference between the 50XR4 and 50XM4.The only online info I can find is about the US models, which may not be appropriate to the "w" australian models. However, 50XM4 and 50XR4 US models are identical, excepting frame colour. Compare US Plasma Models I too have heard that there is some other difference, but have not been able to find out what it is. It would seem pretty silly though to have such similar models with a very subtle difference, and the online retailers seem to think that the models are equivalent. With regards the 42XR3 and 42XM3 there DOES seem to be a difference (try the above web site). The price and FCC class (what ever that is) is different!. One is a "commercial" and one is a "home" use plasma. They seem to otherwise be equal in specs tho - so why the extra cost and alternate classification? J <{POST_SNAPBACK}> I spoke to NEC prior to hunting these plasma's down and was told point blank the only difference between the two was the colour of the front bezel <{POST_SNAPBACK}> The remote is different as indidacted in a earlier post On the XR3 the bottom part of the remote was taken up by a button for each input The menu is also a little differnt and the all white screen option not on this model To me this looks more like what a commercial model would be like <{POST_SNAPBACK}> So did your pixelation problems go away ? <{POST_SNAPBACK}> I now have a toppy hooked up PQ looks great (Got me stuffed) time will tell Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 As long as it looks better than the Philips....thats my main concern at the moment. I would hate to have spent an extra $1000 for nothing! <{POST_SNAPBACK}> Dude The NEC is like a BMW 540 Sport compared to the Holden Barina Philips really!! The extra $ is well worth spent with out a doubt For myself i have seen all HD plasma's and with in reason $ is not a problem and the NEC is the go all the way. I had the unfortunate pleasure of seeing another Viera tonight at power House Preston and there is no way in this world i would take one home it was set up with the Teac HD box running via DVI and it really didnt look good at all Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 Well, just got back from Megamart....and decided to swap the Philips for the Viera. They don't stock NEC so I was at a loss as to what to do. I compared the Viera to a fujitsu they had in there and didn't notice any difference. I get the feeling that there aren't too many Viera followers here? <{POST_SNAPBACK}> How long did you have the Philips for? <{POST_SNAPBACK}> Well its a long story....I first bought the 42PF9945 6 weeks ago. After 3 or so weeks I complained about and had it swapped for the newer version 42PF9946. It seemed ok for around 2 weeks and then started to look very grainy in the black areas. It also has developed a few other glitches were when turned on it has a spasm attack and has rows of colored lines scanning down the screen. I have to turn it off and on again to fix it. Anyway....I had a technician from Philips come out and said he agreed with me...so now It's panasonics turn to impress me. I hope I haven't made another mistake... <{POST_SNAPBACK}> Do yourself a favour and demand a refund then go out and have a look at the NEC before you settle on a unit Link to post Share on other sites
Groover ! 0 Posted October 16, 2004 Share Posted October 16, 2004 With regards to the difference between the 50XR4 and 50XM4.The only online info I can find is about the US models, which may not be appropriate to the "w" australian models. However, 50XM4 and 50XR4 US models are identical, excepting frame colour. Compare US Plasma Models I too have heard that there is some other difference, but have not been able to find out what it is. It would seem pretty silly though to have such similar models with a very subtle difference, and the online retailers seem to think that the models are equivalent. With regards the 42XR3 and 42XM3 there DOES seem to be a difference (try the above web site). The price and FCC class (what ever that is) is different!. One is a "commercial" and one is a "home" use plasma. They seem to otherwise be equal in specs tho - so why the extra cost and alternate classification? J <{POST_SNAPBACK}> I spoke to NEC prior to hunting these plasma's down and was told point blank the only difference between the two was the colour of the front bezel <{POST_SNAPBACK}> The remote is different as indidacted in a earlier post On the XR3 the bottom part of the remote was taken up by a button for each input The menu is also a little differnt and the all white screen option not on this model To me this looks more like what a commercial model would be like <{POST_SNAPBACK}> So did your pixelation problems go away ? <{POST_SNAPBACK}> I now have a toppy hooked up PQ looks great (Got me stuffed) time will tell <{POST_SNAPBACK}> How have you got the toppy connected to the plasma and did the leads come with the Toppy ? Is it RGB to the Plasma ? Surely the toppies PQ isnt as good as the Teac. Glen can you please STOP BUYING THESE TOYS , as it keeps putting ideas into my head. Angelo Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 With regards to the difference between the 50XR4 and 50XM4.The only online info I can find is about the US models, which may not be appropriate to the "w" australian models. However, 50XM4 and 50XR4 US models are identical, excepting frame colour. Compare US Plasma Models I too have heard that there is some other difference, but have not been able to find out what it is. It would seem pretty silly though to have such similar models with a very subtle difference, and the online retailers seem to think that the models are equivalent. With regards the 42XR3 and 42XM3 there DOES seem to be a difference (try the above web site). The price and FCC class (what ever that is) is different!. One is a "commercial" and one is a "home" use plasma. They seem to otherwise be equal in specs tho - so why the extra cost and alternate classification? J <{POST_SNAPBACK}> I spoke to NEC prior to hunting these plasma's down and was told point blank the only difference between the two was the colour of the front bezel <{POST_SNAPBACK}> The remote is different as indidacted in a earlier post On the XR3 the bottom part of the remote was taken up by a button for each input The menu is also a little differnt and the all white screen option not on this model To me this looks more like what a commercial model would be like <{POST_SNAPBACK}> So did your pixelation problems go away ? <{POST_SNAPBACK}> I now have a toppy hooked up PQ looks great (Got me stuffed) time will tell <{POST_SNAPBACK}> How have you got the toppy connected to the plasma and did the leads come with the Toppy ? Is it RGB to the Plasma ? Surely the toppies PQ isnt as good as the Teac. Glen can you please STOP BUYING THESE TOYS , as it keeps putting ideas into my head. Angelo <{POST_SNAPBACK}> Hey Angelo I cant help it i am addicted i have tried rehab over the years but i tried converting the muli-purpose room in to a Home Threatre and they kicked me out. At the moment until i can get a some BNC to RCA converters i have it hooked up by composite and DAMMMMNNN it looks bloody good. As a test i am going down either tuesday or wed to buy the Teac and test side by side Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 The official feedback that i have got about HD and SD (From a un-named source Highly reliable tho) Is that the HD servie we are being privided is crap and the stations know its crap. I have been told that the station are pumping more effort in to SD than HD as there is a 2 to1 amount of people using SD as well as analogue. From what i have heard channel 7 are trying to fight the requirement to provide a HD service at all and concentrate on multi-cast SD only. Link to post Share on other sites
Downunder1503559766 0 Posted October 16, 2004 Share Posted October 16, 2004 Just when you think it's safe ....... I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? Link to post Share on other sites
glenncol 0 Posted October 16, 2004 Author Share Posted October 16, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> I for one like the stand that comes with the NEC Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 (edited) Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> Hi Downunder, We're never safe!! I'm sure Toshiba or Hitachi will release something next week that will pip this week's winner - but I will have no regrets over the next few years that my money was wisely spent this week, which is when I needed something! Re 50": All my comments on the NEC are for the 42" compared to other 42" units - they cannot and do not apply to comparing a 50" NEC to other ~50" units. However, you can trust Angelo's eyes for objective comments: He has the NEC 50" and, believe me, if he found a better unit he would go for it. Re Stand*: I'm getting used to it (I have to anyway!). It's been built for practical usage rather than for a beauty contest, so it is just too 'pedestrian' when you compare it with [the much lighter] LCD stands or something like the Hitachi. I was probably over-reacting anyway (I'm prone to this - ask the guys in the Election forum!). Re Speakers: I [briefly] thought of the speakers as an elegant solution for the centre channel, too. My centre is currently sitting behind the panel in a kind of 'echo chamber' until I find a total mounting solution for the whole shebang. However, the panel speakers are only rated at about 8 watts, so my 100W/ch Onkyo might give them a bit of grief if things got hectic during an action movie! Hope this helps, Ian * I'll take a pic of the unit in place and post a link sometime today for you. Edited October 17, 2004 by ijd Link to post Share on other sites
Moderators betty boop 15,807 Posted October 17, 2004 Moderators Share Posted October 17, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> Hi Downunder, We're never safe!! I'm sure Hitachi will release something next week that will pip this week's winner - but I will have no regrets that my money was wisely spent this week - which is when I needed something! Re 50": All my comments on the NEC are for the 42" compared to other 42" units - they cannot and do not apply to comparing a 50" NEC to other ~50" units. However, you can trust Angelo's eyes for objective comments: Believe me, if he found a better unit next week he would go for it. Re Stand*: I'm getting used to it (I have to anyway!). It's been built for practical usage rather than for a beauty contest, so it is just too 'pedestrian' when you compare it with LCD stands or something like the Hitachi. I was probably over-reacting anyway (I'm prone to this - ask the guys in the Election forum!). Re Speakers: I [briefly] thought of the speakers as an elegant solution for the centre channel, too. My centre is currently sitting behind the panel in a kind of 'echo chamber' until I find a total mounting solution for the whole shebang. However, the panel speakers are only rated at about 8 watts, so my 100W/ch Onkyo might give them a bit of grief if things got hectic during an action movie! Hope this helps, Ian * I'll take a pic of the unit in place and post a link sometime today for you. <{POST_SNAPBACK}> you cant put the the panel on top of the center or is the centre too small or can you put the centre under the panel or above it on a stand/shelf? edit WAF was one reason we got the hitachi Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 you cant put the the panel on top of the center or is the centre too small or can you put the centre under the panel or above it on a stand/shelf? Hey Al, My lease agreement states that the only thing I can use to attach anything to the plasterboard walls is a certain type of flimsy picture hook! However, if I renew the lease next month, then I will be ignoring this clause and dynabolting the panel and/or my centre into whatever is behind the plaster!! (I've already had to do this with the rear surrounds else they would be sitting on 5-foot sticks waving in the breeze!). Cheers, Ian Link to post Share on other sites
Champion_R 0 Posted October 17, 2004 Share Posted October 17, 2004 The official feedback that i have got about HD and SD (From a un-named source Highly reliable tho) Is that the HD servie we are being privided is crap and the stations know its crap.I have been told that the station are pumping more effort in to SD than HD as there is a 2 to1 amount of people using SD as well as analogue. <{POST_SNAPBACK}> Which station is this? I know Nine HD in Melbourne (1920x1088) is a joke. It' only 12.0mbits with 384kbit DD audio. Nine HD in Brisbane (1920x1088) is 12.8mbits with 384kbit DD audio. Nine HD Sydney (1440x1088) is 12.3mbits with 448kbit DD audio. Nine HD in Adelaide (1440x1088) is 14mbits with 448kbit DD audio and Nine HD in Perth (1920x1088) is 14mbits with 448kbit DD audio. As a guide Ten HD nationwide (1440x1088) is 12.8mbits with 256kbit AC3, Seven ED nationwide (720x576) is 9mbits with 384kbit DD audio and ABC HD nationwide (1440x1088) is 14mbits with 448kbit DD audio. Seven looks like it has a much lower compression ratio but it has the most compression artifacts I ever seen. I'm not really convinced 1440x1088 reduces compression artifacts much over 1920x1088 either and I think this because Ten HD (1440) @ 12.8mbits breaks up far more than Nine HD (1920) @ 14mbits. Link to post Share on other sites
Groover ! 0 Posted October 17, 2004 Share Posted October 17, 2004 Wow Champion_R Good point. Now do you want to explain that in English ? Angelo Link to post Share on other sites
Groover ! 0 Posted October 17, 2004 Share Posted October 17, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> Ive got the 50inch Nec (plasma that is ) and I really do like it. Though I will say that as with most 50inch Plasmas Ive seen motion jidderness takes a while to get used to. I see it really badly where as the wife and kids dont see it at all. Ive seen the Hitachi 55 next to the Nec at HN Marion and there is really only one thing that the Hitachi is better at and that is its a 55inch and not a 50inch screen Angelo Link to post Share on other sites
Champion_R 0 Posted October 17, 2004 Share Posted October 17, 2004 Wow Champion_R Good point.Now do you want to explain that in English ? Angelo <{POST_SNAPBACK}> Okay here's the simple version. Nine HD in Adelaide and Perth are easily the best HD channels in Australia. More megabits means less compression and that means less artifacts and more picture detail. Why do Adelaide and Perth have a higher bitrate? That's because we don't have a crappy Nine Guide channel. Nine Perth and Adelaide have a proper EPG (The Perth one is 4 days, I don't know about Adelaide's) so the bandwidth that Nine Guide would be wasting is added to the HD channel. Ten HD is overcompressed because they allocate too much bandwidth to SD and they have a stupid video guide channel. ABC HD is on par with Nine HD in Perth and Adelaide in terms of bitrate but they don't show any real HD content. If they did, it'd be easily the best HD channel for most Australians. Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 (edited) Wow Champion_R Good point.Now do you want to explain that in English ? Angelo <{POST_SNAPBACK}> Okay here's the simple version. Nine HD in Adelaide and Perth are easily the best HD channels in Australia. More megabits means less compression and that means less artifacts and more picture detail. Why do Adelaide and Perth have a higher bitrate? That's because we don't have a crappy Nine Guide channel. Nine Perth and Adelaide have a proper EPG (The Perth one is 4 days, I don't know about Adelaide's) so the bandwidth that Nine Guide would be wasting is added to the HD channel. Ten HD is overcompressed because they allocate too much bandwidth to SD and they have a stupid video guide channel. ABC HD is on par with Nine HD in Perth and Adelaide in terms of bitrate but they don't show any real HD content. If they did, it'd be easily the best HD channel for most Australians. <{POST_SNAPBACK}> Actually, I would be quite happy* if the ABC specialised in top quality HD (which I'm already sure they will do early next year) and left Ten/4+3/SBS to f around with low quality programming (SBS excepted on this point) pushed out over 5 -10 pay-per-view SD streams on their single channel! Under that circumstance (and assuming Nine lift their HD game just a little as well), the premium advertisers would either switch to Nine or pressure Ten and 4+3 to lift their game. The free market eventually sorts these things out - but legislation is a much quicker solution (if any politician has the balls - like Alston had - to forcibly push the envelope so that the public still has choices). One or two commercial stations would still be serving up B&W analogue if legislation hadn't forced them to move to colour, then stereo, then digital, then HD. What most seem to forget in this analogue v. SD v. HD debate is that the whole of North America (not just the US), most of East Asia (not just Japan) and ALL of Europe will have access to predominantly HD programming (the percentage of newly-recorded material, not the percentage of actual repeat re-broadcasts) via satellite and/or terrestrial receivers within the next 12 months. The electronics manufacturers are also pushing towards 4320p equipment over the next year or three - meaning that 576i will go the way of the Betamax, in not too many years at all, for the top end of the advertising, manufacturing and consumer markets. [edit]Oooops! I nearly forgot: If we also throw HD-DVD into the mix - with major studios releasing HD versions of all their movies to video outlets - then the HD pressure on 4+3 and Ten will be even greater. [/edit] 576i equipment will, by then, be sold only in supermarkets and discount retailers for those who can't afford, or see the need for, widescreen HD in their homes. <end rant/personal-opinion/forecast ... take ya pick> As always, I welcome alternative views for readers to compare with mine! Cheers, Ian * while waiting for Ten and 4+3 to come back to the real world - rather than the world as they alone would like to see it! Edited October 17, 2004 by ijd Link to post Share on other sites
Big AL 0 Posted October 17, 2004 Share Posted October 17, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> I have an NEC 50" plasma 50XM4W so read my lips this is a great plasma excellent PQ and plenty of inputs including DVI. There are plenty of fine tuning adjustments available if needed. I have the desktop stand and I think that it is good looking and better than a lot of other stands that I have seen. The NEC stb that I got is not the best and have had problems which I am still waiting to sort with NEC. Big AL Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 (edited) All, I am so confident that this plasma (the NEC 42" XM3W) cannot be faulted in any way with any segment of the NineHD loop ... <snip> [edit] <original text deleted ... offer closed> [/edit] Edited October 18, 2004 by ijd Link to post Share on other sites
glenncol 0 Posted October 17, 2004 Author Share Posted October 17, 2004 All,I am so confident that this plasma (the 42") cannot be faulted in any way with any segment of the NineHD loop that I am willing to make an offer to one lucky Brisbane (or interstate) resident to act on behalf of the whole forum: If you are prepared to truck your Sony KVHR36, or Fujitsu or Hitachi 42"+ plasma, or Toshiba 63cm+ LCD over to my place (New Farm) for a comparative audition with my setup AND report your honest opinion on this forum afterwards for the benefit of those who think we have been smoking something - whether your opinion be favourable or unfavourable - then you will be very welcome to do so. PM me if you are interested. I will pick just one winner* from requests received. Entries will close when (if) I receive what I consider* to be enough* valid* requests to choose from. I'm making this offer only because I would be equally interested in the results of such a controlled shootout!! Regards, Ian * My decision will be final on the interpretation of any/all of these words. No debate will be entered into on the merits or otherwise of this offer. The offer may be withdrawn at any time for any reason if I feel it necessary for my own protection. <{POST_SNAPBACK}> Do we have some doubters of the NEC faith? Link to post Share on other sites
jewfish 0 Posted October 17, 2004 Share Posted October 17, 2004 Glenncol, I'm interested in the Charcol model 42XM3, is there any reason spec wise I should go for the 42XR3 ? If not, I'll pull the trigger this week. Rob. Link to post Share on other sites
glenncol 0 Posted October 17, 2004 Author Share Posted October 17, 2004 Glenncol, I'm interested in the Charcol model 42XM3, is there any reason spec wise I should go for the 42XR3 ? If not, I'll pull the trigger this week. Rob. <{POST_SNAPBACK}> No the Specs are the same there is a differnce in the menu and the remote due to the charcol model being a commercial. Link to post Share on other sites
Groover ! 0 Posted October 17, 2004 Share Posted October 17, 2004 Glenncol, I'm interested in the Charcol model 42XM3, is there any reason spec wise I should go for the 42XR3 ? If not, I'll pull the trigger this week. Rob. <{POST_SNAPBACK}> No the Specs are the same there is a differnce in the menu and the remote due to the charcol model being a commercial. <{POST_SNAPBACK}> Sorry to be pain here, but Glen would you not say the silver model be better as it has 2 more features ? Angelo Link to post Share on other sites
Groover ! 0 Posted October 17, 2004 Share Posted October 17, 2004 All,I am so confident that this plasma (the NEC 42" XM3W) cannot be faulted in any way with any segment of the NineHD loop that I am willing to make an offer to one lucky Brisbane (or interstate) resident to act on behalf of the whole forum: If you are prepared to truck your Sony KVHR36, or Fujitsu or Hitachi 42"+ plasma, or Toshiba 63cm+ LCD to and from my place (New Farm) for a comparative audition with my setup AND report your honest opinion on this forum afterwards for the benefit of those who think we have been smoking something - whether your opinion be favourable or unfavourable - then you will be very welcome to do so. PM me if you are interested. I will pick just one winner* from requests received. Entries will close when/if I receive what I consider* to be enough* valid* requests to choose from. I'm making this offer only because I would be equally interested in the results of such a controlled shootout!! Regards, Ian * My decision will be final on the interpretation of any/all of these words. No debate will be entered into on the merits or otherwise of this offer or any aspect of the selection. The offer may be withdrawn at any time for any reason if I feel it necessary for my own protection. <{POST_SNAPBACK}> Ian if I didnt know any better , Id say your starting to sound a bit like DAFFY DUCK !!! Angelo Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 Ian if I didnt know any better , Id say your starting to sound a bit like DAFFY DUCK !!! Angelo Actually, a couple of friends have now seen my panel and asked how it compares with the mentioned 'contenders' - since I had previously suggested those as the best of type (CRT, PDP and LCD) for them to look at. Now I'm inquisitive also on how the XM3 stacks up for the purpose of future recommendations, if a friend (or newbie to the forum) finds a good deal on one of the contenders. Since I know how each contender performs when driven by good RF, STB and interconnects - and the only place I know I can set up a valid comparison is at home! - I decided to risk the inevitable flames and tyre-kickers by making a very specific offer that might also benefit someone considering a swap or upgrade to the NEC. Then we both win by finding out for sure how they compare! BTW, how did you find your old HR36's performance with the Loop? I'm sure Daffy would be equally devious, so thanks for the compliment! Cheers, Ian Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 The blacks are very good, there is a control which allows deep or light blacks. Hey Angelo, I just noticed this in one of your earlier posts. Does the 42" have this option and, if so, which one is it? My only issue with the 42XM3W so far is that I was expecting deeper 'below black' performance with the THX Optimiser from my new Pioneer 676A player ie. expected the 'Brightness' test to look exactly like the logo drop-shadow on the sample in the intro to the test. Any other comments? Ta, Ian Link to post Share on other sites
Groover ! 0 Posted October 17, 2004 Share Posted October 17, 2004 The blacks are very good, there is a control which allows deep or light blacks. Hey Angelo, I just noticed this in one of your earlier posts. Does the 42" have this option and, if so, which one is it? My only issue with the 42XM3W so far is that I was expecting deeper 'below black' performance with the THX Optimiser from my new Pioneer 676A player ie. expected the 'Brightness' test to look exactly like the logo drop-shadow on the sample in the intro to the test. Any other comments? Ta, Ian <{POST_SNAPBACK}> GO under menu, , setup, dvi setup and push menu and there it is. Angelo Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 GO under menu, , setup, dvi setup and push menu and there it is.Angelo Thanks mate - also for reminding me to do the DVI setup! Forgot to read that section. Link to post Share on other sites
Downunder1503559766 0 Posted October 17, 2004 Share Posted October 17, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> Ive got the 50inch Nec (plasma that is ) and I really do like it. Though I will say that as with most 50inch Plasmas Ive seen motion jidderness takes a while to get used to. I see it really badly where as the wife and kids dont see it at all. Ive seen the Hitachi 55 next to the Nec at HN Marion and there is really only one thing that the Hitachi is better at and that is its a 55inch and not a 50inch screen Angelo <{POST_SNAPBACK}> Angelo, Now that surprises me that the Hitachi would have been as good as the NEC, as I would have thought the increase in colours/greyscales would have reduced the artifacts and jidder in the NEC over the Hitachi ! ( please don't confuse this comment with any real knowledge ! ) Does the NEC still suffer from face blurring etc. during sport type action, or is that more of a signal compression issue ? Trolled the usual suspects in Brisbane over the weekend, but could not find an NEC, where is Marion ? Ian, Good point thankyou re-the speaker capacity, as I will be attaching them to a Yam RXV2400, it would be of concern !! Thankyou for your feedback Link to post Share on other sites
Downunder1503559766 0 Posted October 17, 2004 Share Posted October 17, 2004 Just when you think it's safe .......I thought I had finally made up my mind on which plasma .. a Hitachi 55" ... then I read these posts ! The NEC 50XR4W sounds like a real option, based on everyones experiances. Does anyone have any comments or views between the two ? The viewing distance will be just on 4 meters Ian, is the NEC stand that bad ? what was the option Geoff at e-home offered ? What about the speakers, has anyone heard them ? .....was considering getting the speakers and using them both for the centre channel only. Anyone seen one in Brisbane ? <{POST_SNAPBACK}> I have an NEC 50" plasma 50XM4W so read my lips this is a great plasma excellent PQ and plenty of inputs including DVI. There are plenty of fine tuning adjustments available if needed. I have the desktop stand and I think that it is good looking and better than a lot of other stands that I have seen. The NEC stb that I got is not the best and have had problems which I am still waiting to sort with NEC. Big AL <{POST_SNAPBACK}> Big Al, Did you consider the Hitachi 55 in your evaluation ? if so what swung it the NEC way (other than price) ? Regards Link to post Share on other sites
glenncol 0 Posted October 17, 2004 Author Share Posted October 17, 2004 Glenncol, I'm interested in the Charcol model 42XM3, is there any reason spec wise I should go for the 42XR3 ? If not, I'll pull the trigger this week. Rob. <{POST_SNAPBACK}> No the Specs are the same there is a differnce in the menu and the remote due to the charcol model being a commercial. <{POST_SNAPBACK}> Sorry to be pain here, but Glen would you not say the silver model be better as it has 2 more features ? Angelo <{POST_SNAPBACK}> Really dont know if the two missing features play a big part in the panel performance there seems to be only one menu option missing and the remote is different. Link to post Share on other sites
Steffche 0 Posted October 17, 2004 Share Posted October 17, 2004 As long as it looks better than the Philips....thats my main concern at the moment. I would hate to have spent an extra $1000 for nothing! <{POST_SNAPBACK}> Dude The NEC is like a BMW 540 Sport compared to the Holden Barina Philips really!! The extra $ is well worth spent with out a doubt For myself i have seen all HD plasma's and with in reason $ is not a problem and the NEC is the go all the way. I had the unfortunate pleasure of seeing another Viera tonight at power House Preston and there is no way in this world i would take one home it was set up with the Teac HD box running via DVI and it really didnt look good at all <{POST_SNAPBACK}> I don't think the Viera has DVI input.... I think there's a bit of hot air blowing around here. I have heard this type of commentary going around before, and upon inspection it proves to be just that...HOT AIR!!! I had a look at a Fujitsu 42" and compared it with teh Viera....I'd say the viera had better blacks....and both suffered from pixelation on skin tones...so I think a bit more honesty and less boasting needs to be had around here! Link to post Share on other sites
glenncol 0 Posted October 17, 2004 Author Share Posted October 17, 2004 As long as it looks better than the Philips....thats my main concern at the moment. I would hate to have spent an extra $1000 for nothing! <{POST_SNAPBACK}> Dude The NEC is like a BMW 540 Sport compared to the Holden Barina Philips really!! The extra $ is well worth spent with out a doubt For myself i have seen all HD plasma's and with in reason $ is not a problem and the NEC is the go all the way. I had the unfortunate pleasure of seeing another Viera tonight at power House Preston and there is no way in this world i would take one home it was set up with the Teac HD box running via DVI and it really didnt look good at all <{POST_SNAPBACK}> I don't think the Viera has DVI input.... I think there's a bit of hot air blowing around here. I have heard this type of commentary going around before, and upon inspection it proves to be just that...HOT AIR!!! I had a look at a Fujitsu 42" and compared it with teh Viera....I'd say the viera had better blacks....and both suffered from pixelation on skin tones...so I think a bit more honesty and less boasting needs to be had around here! <{POST_SNAPBACK}> What inparticular are you refering to? Link to post Share on other sites
Steffche 0 Posted October 17, 2004 Share Posted October 17, 2004 The bit about "I would never take one of those home..... I find it hard to believe the Viera could be that bad. Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 * I'll take a pic of the unit in place and post a link sometime today for you. Here is the promised photo of the 42" in action at home. Note: Don't judge the PQ from this quick'n'nasty 640x480 .jpg snap of the newsreader! Link to post Share on other sites
glenncol 0 Posted October 17, 2004 Author Share Posted October 17, 2004 The bit about "I would never take one of those home..... I find it hard to believe the Viera could be that bad. <{POST_SNAPBACK}> Pal That was my opinion you dont like stiff . I have done alot of auditioning of plasmas over the last few months and IMHO i would not take a Viera home due to solarisation , Pixelisation ,not DVI input that fact that the stand is way over priced and the fact that it only carries a 12 month warranty and for less money we have got the best plasma on the market bar none. People are on here to give and read opinions and that my friend is my opinion i am sorry if it doesn’t match yours but after all it is MINE!! Do me a hugh favour and audition the NEC and pana and tell me what you would take home and what you wouldn’t . I assume you own a Viera with your comments. Link to post Share on other sites
ijd 0 Posted October 17, 2004 Share Posted October 17, 2004 (edited) I don't think the Viera has DVI input.... I think there's a bit of hot air blowing around here. I have heard this type of commentary going around before, and upon inspection it proves to be just that...HOT AIR!!! Then buy the 'Norwegian Blue' (ie. Viera)!! If it looks better to you, then isn't it what you should be buying? Sheeesh!!! The Viera doesn't have DVI (Glen probably saw it via XGA?) - otherwise I might have hastily bought it about 10 days ago on looks alone! (though check back through my posts to see my PQ comments on the Viera at the time - before I had even heard about the NEC)! Now that I have seen the NEC properly set up (at home!) - thanks entirely to my knowledge of Glenncol and Angelo on this forum over the past 6 months* - there is absolutely no way that I would now recommend a Viera to anybody on the basis of PQ! I would suggest that you start a Norwegian Blue thread - where you can all discuss how to solve the Viera's PQ issues among yourselves. Oh ... and btw ... good luck with trying to obtain any useful help from Panasonic! The usual 2i cents, Ian * FWIW ... it has indeed taken me 6 months to decide on an upgrade from a 76cm LG POS - mainly because of a very tight budget and a number of issues with each possible upgrade alternative. The NEC cost me double my budget and I don't regret one single cent of the extra money - its performance brings tears to my eyes every time I turn it on! I wouldn't say it was better than the Fujitsu 42" - but it sure thumps everything else, including the Pioneer, and costs a heck of a lot less than these! Edited October 18, 2004 by ijd Link to post Share on other sites
