Tasebass 2,621 Posted April 15, 2017 Share Posted April 15, 2017 10 hours ago, metal beat said: You will find in the majority of cases comparing like vintage DD tables and belt drive tables that the bass delivery will be different - the DD is faster better defined, the belt drive a little more luxurious perhaps a little softer. It's the overall package that will dictate what sounds better - and vintage imo will do it for a cheaper price if you choose the right combo's. ...dont forget the quality of the bearing.. having now fitted 2 mag lev upgrades to my Sondek's bearings including a third party affair consisting of a new bearing housing and inner platter the noise floor drop is very significant... So much so that last night when listening was hard to tell if the cart was playing the end of a record.....bit spooky really... TT reproduction starts and ends at the bearing IMO.... Tase 1 Link to post Share on other sites
Ian McP 5,415 Posted April 17, 2017 Share Posted April 17, 2017 thoughts on idler drive, hmm, so exactly why are Garrards 301/401, Lenco, Thorens TD 124 and especially the highly desirable and expensive EMT so highly regarded? a newcomer http://thomas-schick.com/en/produkte?cat=plattenspieler another newcomer and a case in their defence https://oswaldsmillaudio.com/turntable regards Ian Link to post Share on other sites
Warren M. 342 Posted April 17, 2017 Share Posted April 17, 2017 (edited) 1 hour ago, Ian McP said: thoughts on idler drive, hmm, so exactly why are Garrards 301/401, Lenco, Thorens TD 124 and especially the highly desirable and expensive EMT so highly regarded? a newcomer http://thomas-schick.com/en/produkte?cat=plattenspieler another newcomer and a case in their defence https://oswaldsmillaudio.com/turntable regards Ian A quick look at the three drive systems: A good belt drive is relatively easy to build, resulting in pretty good performance for a modest outlay. The downside is that belt drives inevitably have inconsistent speed and usually have low torque, resulting in considerable speed variation due to stylus drag. You can overcome these limitations to some degree by multiple motors, massive platters, etc, but the costs become huge. I have a belt drive turntable, a Once Analog, which is relatively light at about 20kg, and, with various minor tweaks, I have found it to be among the best turntables I've heard, and relatively inexpensive compared to the really big guns (but still $7000+ without arm). Direct drive has very low motor speeds, which exacerbate many of the noise transfer problems already inherent in connecting the motor directly to the platter. Overcoming these problems is very difficult and expensive. The simpler solutions include massive plinths, which allow the better cheap Japanese direct drive turntables of say the 1970s to sound remarkably good, but nowhere near as good as the best belt drive solutions. Massive decoupled direct drive turntables such as the Continuum come at tremendous cost, and do provide exceptional performance, but few companies have persevered this arduous route. Idler drives offer an entirely different, and mechanically simple, approach. They allow high speed motors (like belt drives do), but allow a large proportion of the torque, generated by the motor, to be transferred to the platter, virtually eliminating stylus drag, without (if well-enough engineered) transferring the noise of the motor (like you find with direct drives). As a result, many of the inherent problems of direct drive and belt drive are avoided in the idler drive approach. If you take an idler drive mechanism, ensure that each part of the mechanism is optimised for speed consistency and minimal noise, then you have (theoretically) a near perfect drive mechanism. It then becomes a matter of sinking it into the most inert massive plinth possible to eliminate every other source of noise from being picked up by the stylus. The very best reengineered Lenco L75 turntables, in massive plinths, are regarded by some vinyl gurus as the very best turntables available at ANY price, convincingly better than turntables costing upwards of $200,000. I've never had the pleasure of listening to one. Edited April 17, 2017 by Warren M. 6 Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 Great post, Warren. Thanks for the explanation. Andy Link to post Share on other sites
ochremoon 224 Posted April 17, 2017 Share Posted April 17, 2017 Very well written, Warren. I'm expecting delivery of a re-engineered Lenco in a massive plinth in the next fortnight. Link to post Share on other sites
Kensell21 832 Posted April 17, 2017 Share Posted April 17, 2017 Very well written, Warren. I'm expecting delivery of a re-engineered Lenco in a massive plinth in the next fortnight. Pictures definitely required when setup for a show and tell. Sent from my iPhone using Tapatalk Link to post Share on other sites
Guest guru Posted April 17, 2017 Share Posted April 17, 2017 (edited) 3 hours ago, Warren M. said: A quick look at the three drive systems: A good belt drive is relatively easy to build, resulting in pretty good performance for a modest outlay. The downside is that belt drives inevitably have inconsistent speed and usually have low torque, resulting in considerable speed variation due to stylus drag. You can overcome these limitations to some degree by multiple motors, massive platters, etc, but the costs become huge. I have a belt drive turntable, a Once Analog, which is relatively light at about 20kg, and, with various minor tweaks, I have found it to be among the best turntables I've heard, and relatively inexpensive compared to the really big guns (but still $7000+ without arm). Direct drive has very low motor speeds, which exacerbate many of the noise transfer problems already inherent in connecting the motor directly to the platter. Overcoming these problems is very difficult and expensive. The simpler solutions include massive plinths, which allow the better cheap Japanese direct drive turntables of say the 1970s to sound remarkably good, but nowhere near as good as the best belt drive solutions. Massive decoupled direct drive turntables such as the Continuum come at tremendous cost, and do provide exceptional performance, but few companies have persevered this arduous route. Idler drives offer an entirely different, and mechanically simple, approach. They allow high speed motors (like belt drives do), but allow a large proportion of the torque, generated by the motor, to be transferred to the platter, virtually eliminating stylus drag, without (if well-enough engineered) transferring the noise of the motor (like you find with direct drives). As a result, many of the inherent problems of direct drive and belt drive are avoided in the idler drive approach. If you take an idler drive mechanism, ensure that each part of the mechanism is optimised for speed consistency and minimal noise, then you have (theoretically) a near perfect drive mechanism. It then becomes a matter of sinking it into the most inert massive plinth possible to eliminate every other source of noise from being picked up by the stylus. The very best reengineered Lenco L75 turntables, in massive plinths, are regarded by some vinyl gurus as the very best turntables available at ANY price, convincingly better than turntables costing upwards of $200,000. I've never had the pleasure of listening to one. Continuum turntable are belt drive. What turntable costs $200k other that that German monstrosity. Edited April 17, 2017 by guru Link to post Share on other sites
Warren M. 342 Posted April 17, 2017 Share Posted April 17, 2017 1 hour ago, guru said: Continuum turntable are belt drive. What turntable costs $200k other that that German monstrosity. I accept your greater knowledge re the Continuum offerings There are a few tunrtables above $200K: - the Goldmund Reference and Transrotor Argos are both over US$200K, but there are a dozen or more which would cost well over AU$200K to bring in, such as the Clearaudio Statement and the La Platine Magnum Link to post Share on other sites
Citroen 6,327 Posted April 17, 2017 Share Posted April 17, 2017 US$349,000 Acoustical Systems Apolyt turntable 1 Link to post Share on other sites
mwhouston 4,891 Posted April 17, 2017 Share Posted April 17, 2017 I wonder how it compares with my new under $1K Rega RP3? Lol. 3 Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 40 minutes ago, Citroen said: US$349,000 Acoustical Systems Apolyt turntable UnF'ingBlievable (fugly! ). DD? Idler? Belt? Andy Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 33 minutes ago, mwhouston said: I wonder how it compares with my new under $1K Rega RP3? Lol. C'mon, Mark. I know there are a few here who would need a DBT with 100 people present before they could accept that it does sound better ... but I'm happy to believe it does ... based on its price alone. Andy Link to post Share on other sites
Warren M. 342 Posted April 17, 2017 Share Posted April 17, 2017 1 minute ago, andyr said: C'mon, Mark. I know there are a few here who would need a DBT with 100 people present before they could accept that it does sound better ... but I'm happy to believe it does ... based on its price alone. Andy Nah, I reckon they'd be about the same (as long as they are switched off and in another room). Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 1 minute ago, Warren M. said: Nah, I reckon they'd be about the same (as long as they are switched off and in another room). Haha - yes, good one, Warren! Andy Link to post Share on other sites
Wimbo 2,368 Posted April 17, 2017 Share Posted April 17, 2017 Is there a Turntable there? Link to post Share on other sites
Citroen 6,327 Posted April 17, 2017 Share Posted April 17, 2017 11 minutes ago, andyr said: UnF'ingBlievable (fugly! ). DD? Idler? Belt? Andy "drive: unique balanced shaft transmission drive with dynamic torque management" Belt? Link to post Share on other sites
Citroen 6,327 Posted April 17, 2017 Share Posted April 17, 2017 They supply two people for three days to set it up 1 Link to post Share on other sites
ochremoon 224 Posted April 17, 2017 Share Posted April 17, 2017 3 hours ago, Kensell21 said: Pictures definitely required when setup for a show and tell. Sent from my iPhone using Tapatalk Yeah, I'll do so when I have it up and running. Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 9 minutes ago, Citroen said: "drive: unique balanced shaft transmission drive with dynamic torque management" Belt? Nah - shirley DD? Andy Link to post Share on other sites
metal beat 19,351 Posted April 17, 2017 Author Share Posted April 17, 2017 20 minutes ago, andyr said: UnF'ingBlievable (fugly! ). DD? Idler? Belt? Andy Yes Belt drive. Its a very impressive turntable in person and you can see a lot of $$ has been spent in building it. I saw it last year at the HK show. The top layer of the platter is vinyl. 2 Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 6 minutes ago, metal beat said: Yes Belt drive. Its a very impressive turntable in person and you can see a lot of $$ has been spent in building it. I saw it last year at the HK show. The top layer of the platter is vinyl. Thanks, Shane - and Cliff. Andy Link to post Share on other sites
stevoz 5,429 Posted April 17, 2017 Share Posted April 17, 2017 51 minutes ago, Citroen said: Ha ha! It's amazing that little, albeit solid, belt turns a 58kg platter! This one's definitely for the Bugatti owners! 1 Link to post Share on other sites
djb 3,196 Posted April 17, 2017 Share Posted April 17, 2017 A bit strong @andyr the TTs you design and build are highly functional There are no adornments frill or fringes. many ppl would consider them ugly. 1 Link to post Share on other sites
Tasebass 2,621 Posted April 17, 2017 Share Posted April 17, 2017 5 minutes ago, djb said: A bit strong @andyr the TTs you design and build are highly functional There are no adornments frill or fringes. many ppl would consider them ugly. Meccano.... 1 Link to post Share on other sites
mwhouston 4,891 Posted April 17, 2017 Share Posted April 17, 2017 (edited) Let's keep it in perspective, it only goes around and around. How hard can it be? Edited April 17, 2017 by mwhouston Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 29 minutes ago, djb said: A bit strong @andyr the TTs you design and build are highly functional There are no adornments frill or fringes. many ppl would consider them ugly. Sure, David! But brass motor pods & spring bases instead of black ... I consider to be a 'frill'. 23 minutes ago, Tasebass said: Meccano.... But Meccano sounds good, Tase! Andy Link to post Share on other sites
Full Range 5,644 Posted April 17, 2017 Share Posted April 17, 2017 Today my daughter dragged me into IKEA Not my favourite place in its shopping design because once in you travel ONE WAY and you can't get out until you see the whole store Anyway as she went off into a buying frenzy I stopped and had a look at lamps specifically for the turntable Out of the 2 designs I shortlisted this one was best suited Item - IKEA - HARTE light @ $19.99 Its not to bright and has a strip of lights that is better than a spot light Took a few photos - last one is with my room lights off 6 Link to post Share on other sites
Moderators proftournesol 8,432 Posted April 17, 2017 Moderators Share Posted April 17, 2017 How on earth do you reach the platter and arm on that turntable? Perhaps a crane and a harness to winch you over the top? Link to post Share on other sites
Guest guru Posted April 17, 2017 Share Posted April 17, 2017 40 minutes ago, mwhouston said: Let's keep it in perspective, it only goes around and around. How hard can it be? Only experience with a REALLY good turntable would show you how hard it can be and if I answer honestly, a $13000 txt/ arm combination sounds great but a $60000 txt/ arm combination sounds a whole world better so maybe $200k pushes the boat out again. Link to post Share on other sites
Guest Misterioso Posted April 17, 2017 Share Posted April 17, 2017 12 minutes ago, proftournesol said: How on earth do you reach the platter and arm on that turntable? Perhaps a crane and a harness to winch you over the top? The Apolyt is 128cm high. Unless you are a toddler, you should have no problems reaching the platter :-) Link to post Share on other sites
ABG 2,540 Posted April 17, 2017 Share Posted April 17, 2017 On 4/12/2017 at 8:26 PM, metal beat said: Technics SL-1000MK3D has arrived. Coupled with my EPC-P100C-MK4 cartridge, the combo is sounding superb. thanks @MarkT. I'm a bit late to the party having only just read this post right now. Congratulations Shane. That is one awesome looking and extremely drool worthy piece of kit. I shall have to wrangle another visa and pay homage some time. 6 Link to post Share on other sites
ABG 2,540 Posted April 17, 2017 Share Posted April 17, 2017 On 4/13/2017 at 7:54 PM, metal beat said: Thanks Chill. It is amazing that two tables 35 years old sound so great but no more tables for me. seriously thou, I have 6 bloody turntables and only physically enough room for 4 of them. Pioneer PLX-1000 I am going to set up in daughters room. but, Pioneer Exclusive P10 will probably need to be sold and go to good home that can enjoy this wonderful table. cheers LOL. I looked into the tea leaves and I see a GT2000x in your future. It may be a few years away, but you'll find room for it eventually. Link to post Share on other sites
analog brother 2,074 Posted April 17, 2017 Share Posted April 17, 2017 shane needs af-0 first 2 Link to post Share on other sites
djb 3,196 Posted April 17, 2017 Share Posted April 17, 2017 @andyr I haven't trimmed my TT mat to she off the gold sub platter bearing the way s o m e ppl have . or is that an appropriate ergonomic adjustment like removing a tone arm lift making a damaged cart/stylus more likely Link to post Share on other sites
andyr 5,760 Posted April 17, 2017 Share Posted April 17, 2017 2 minutes ago, djb said: @andyr I haven't trimmed my TT mat to show off the gold sub platter bearing the way s o m e ppl have . or is that an appropriate ergonomic adjustment I did that B4 I got the beautiful brass/ss inner platter, David. Cutting the centre out of the mat (around where the label goes to) makes the TT sound better. 2 minutes ago, djb said: like removing a tone arm lift making a damaged cart/stylus more likely I don't get this part? Andy Link to post Share on other sites
aussievintage 3,618 Posted April 17, 2017 Share Posted April 17, 2017 10 hours ago, guru said: Only experience with a REALLY good turntable would show you how hard it can be and if I answer honestly, a $13000 txt/ arm combination sounds great but a $60000 txt/ arm combination sounds a whole world better so maybe $200k pushes the boat out again. Then again, the law of diminishing returns usually applies. I wonder what the last $50k in that $350k table actually buys you 1 Link to post Share on other sites
mwhouston 4,891 Posted April 18, 2017 Share Posted April 18, 2017 2 hours ago, aussievintage said: Then again, the law of diminishing returns usually applies. I wonder what the last $50k in that $350k table actually buys you Then you have to think cart to match? 1 Link to post Share on other sites
mwhouston 4,891 Posted April 18, 2017 Share Posted April 18, 2017 14 hours ago, Citroen said: They supply two people for three days to set it up Is it true this guy first owned a JH Formula 4 and one day thought "how can I improve this"? 2 Link to post Share on other sites
Moderators alistairm 3,198 Posted April 18, 2017 Moderators Share Posted April 18, 2017 I have been umming and ahhing about what to do with my second SL-10... even contemplating selling it, although it's been refurbished by Chris Kimil and they're so user friendly so I decided to keep it. Strung it up today with a modest pair of Focal actives fed by a modest Lehmann Black Cube... surprisingly enjoyable. I wonder if the wife will notice if I wall mount it somewhere? 8 Link to post Share on other sites
