mrmaxwell1503559518 0 Posted January 6, 2004 Share Posted January 6, 2004 if I could get the two for $2400-$2500 on finance (don't they still make interest off me?) I would take it. $2400-$2500 with a STB (i'd recommend the Pana) would be a very good deal. That's a saving of a couple of hundred off an already very good RRP. If you can swing a deal like that interest free then do it. A credit card with a 6 month introductory low interest rate might also be worth a look at - don't forget 99% of interest free deals are through GE Finance which can have some nasty interest rates if you don't pay off in time. Good Luck, and post your thoughts if you end up getting one. Quote Link to post Share on other sites
patdman 0 Posted January 6, 2004 Share Posted January 6, 2004 Yeah, I know that it really needs to be paid off within the 12 month period, I would hope to pay at least 85%->90% of the price off within that timeframe, if not the whole lot. I still need to work out exactly which STB to couple with this TV, I'd prefer to pay the extra few $$'s and avoid any problems. I would really hope to pay no more than $2500 for the TV w/2000A, or maybe $2600 with one of the more reputable STB's. I'll do some chasing around this weekend, see how I go. Also, what are these companies like with providing finance? I know they want people to be able to pay (well derr!), but I currently have a personal loan and some Credit Card debt, I know my finances, and I know I can pay this off, but if I get rejected for finance, I would be unhappy after G'ing myself up for a new W/S TV...especially after having to deal with TV through a PC card on a 19" monitor for the last 2 months! Cheers, Pat. Quote Link to post Share on other sites
blairy1503559527 0 Posted January 6, 2004 Share Posted January 6, 2004 Got mine at Hardly Normal on AGC 15 months interest free (back in October). Palsonic and Dgtec2000a was $1950 + $699 (or thereabouts). good luck blairy Quote Link to post Share on other sites
AzzX 0 Posted January 6, 2004 Share Posted January 6, 2004 The two issues I have with set are:1. A banding rolling up and down the screen Tech believes banding is an issue with the digital broadcast. Banding is not evident on normal RF input fta analogue, nor is it apparent on AV in via composite for Foxtel satellite. I didn't test it while he was here but it's also not evident from DVD's (component SD input) or Xbox (AV via composite). During prior visit he hooked up his own STB (also a dgtec 2000a) and banding was also evident. He's going to s/w his manager and try to arrange to come out with a second set to confirm his view that banding is an issue with the digital broadcast and not the TV itself. Seems that some resolutions exhibit these problems. I use my PC for HD broadcasts with a resolution of 1280 x 768 and 1024 x 768 on this TV without the banding. Mind you, these are at 60hz. My Old DVD Player via VGA did produce banding from time to time but the image was inferior than that from the PC. What is 1080i via pc vga output? 540 x 384? 2. A noticeable bow or downward curve along the top of the screen image. This is especially obvious in HD mode when adjusting screen, but also (and to a lesser extent) in normal mode when watching a letterboxed image.After previous visit he was supposed to discuss with his technical area and revert. He had discussed and someone was meant to call back...Anyway, this is an issue he referred to as yoke and it cannot be fixed, not even back in the factory where set is made. All these sets have varying degrees of yoke, some more noticeable than others. He acknowledged that this will be an issue when watching letterboxed DVD's or foxtel. Can't you adjust the bow via the TV menu adjustments? Quote Link to post Share on other sites
apchoo 0 Posted January 6, 2004 Share Posted January 6, 2004 Just curious what DVD players people would recommend to go with this TV?I'm thinking at least PAL and NTSC progressive scan, such as the Sony DVPNS730 perhaps? Any other suggestions? I highly recommend the Harman Kardon DVD30. It does PAL & NTSC progressive scan and has no problems reading all manner of DVD-R, DVD-RW, DVD+RW, CD-R & CD-RW discs that I threw at it (various manufacturers, and incl. VCDs and SVCDs). It also does DVD-Audio which is a bonus but it wasn't one of my prerequisites. I've yet to find a DVD-A title that I like. The available DVD-A range isn't extensive ... well, not in Melb anyway. I bought mine from E&S Sound and Vision at High St, Ashburton VIC. You can find a list of retailers at: http://www.e-hifi.com.au/main.asp?page=products/harman.asp BTW, patdman, I paid by credit $2,400 for the 76WSHD, 2000A and a cabinet stand for the TV from Retravision Mt Waverley VIC. Didn't ask about finance though. Blairy, when playing PAL dvds in PS, the 76WSHD reports a resolution of 720x600P (31.2kHz/50Hz). I still haven't tried the HD2 setting on the 2000A---too lazy to unplug all the wires and take the unit out of the cabinet. However, I noticed that the banding is most obvious when initially switching to the 2000A (via XGA). It lessens over some minutes and most times disappears altogether. Cheers. Quote Link to post Share on other sites
blairy1503559527 0 Posted January 6, 2004 Share Posted January 6, 2004 The two issues I have with set are:Seems that some resolutions exhibit these problems. I use my PC for HD broadcasts with a resolution of 1280 x 768 and 1024 x 768 on this TV without the banding. Mind you, these are at 60hz. My Old DVD Player via VGA did produce banding from time to time but the image was inferior than that from the PC. What is 1080i via pc vga output? 540 x 384? Can't you adjust the bow via the TV menu adjustments? AzzX, to achieve 1080i on the Palsonic, the resolution you need is 1920 X 1080. This can be done at frequencies of either 28.125Khz/50Hz or 33.75KHz/60Hz. The screen adjustments only work on the sides of the image, not the top and bottom. Mind you I went batty trying this but then so did the service tech on his first visit Quote Link to post Share on other sites
blairy1503559527 0 Posted January 6, 2004 Share Posted January 6, 2004 Just curious what DVD players people would recommend to go with this TV?I'm thinking at least PAL and NTSC progressive scan, such as the Sony DVPNS730 perhaps? Any other suggestions? I highly recommend the Harman Kardon DVD30. It does PAL & NTSC progressive scan and has no problems reading all manner of DVD-R, DVD-RW, DVD+RW, CD-R & CD-RW discs that I threw at it (various manufacturers, and incl. VCDs and SVCDs). It also does DVD-Audio which is a bonus but it wasn't one of my prerequisites. I've yet to find a DVD-A title that I like. The available DVD-A range isn't extensive ... well, not in Melb anyway. I bought mine from E&S Sound and Vision at High St, Ashburton VIC. You can find a list of retailers at: http://www.e-hifi.com.au/main.asp?page=products/harman.asp BTW, patdman, I paid by credit $2,400 for the 76WSHD, 2000A and a cabinet stand for the TV from Retravision Mt Waverley VIC. Didn't ask about finance though. Blairy, when playing PAL dvds in PS, the 76WSHD reports a resolution of 720x600P (31.2kHz/50Hz). I still haven't tried the HD2 setting on the 2000A---too lazy to unplug all the wires and take the unit out of the cabinet. However, I noticed that the banding is most obvious when initially switching to the 2000A (via XGA). It lessens over some minutes and most times disappears altogether. Cheers. Apchoo, does that mean that you're watching DVD's at a resolution of 720P? They must look incredible. Have you been able to verify that the player actually outputs at this resolution or is the TV upscaling? The banding issue is most frustrating because of the fact that it comes and goes. If it disappeared completely, great, but one minute it's there and then gone. I am able to reach the output switch on my stb quite easily and have been experimenting with HD1 and HD2. On SUnday, on HD1 no banding. After nearly an hour or so of watching, the banding was so bad I switched back to HD2...no banding. Later mild banding was back. Generally better on HD2 and I'll probably stick with that for the time being. Looking to get hold of a PS DVD player and see if that exhibits the same problem. If so, then problem is clearly with the set... blairy Quote Link to post Share on other sites
apchoo 0 Posted January 7, 2004 Share Posted January 7, 2004 Apchoo, does that mean that you're watching DVD's at a resolution of 720P? They must look incredible. Have you been able to verify that the player actually outputs at this resolution or is the TV upscaling? Well, dvds in PS from the HK DVD30 to the 76WSHD does look incredible but I don't think that they're displayed at 720P. Doesn't 720x600P mean 600 lines in progressive scan? The max. no. of lines with PAL is 625 lines but you never get the full lot, so I reckon my dvds in PS are displayed in 576 lines PS (pretty much like getting only 480 lines from NTSC's 525 lines) and the 76WSHD's setting when viewing 576P is 600P. But I may be wrong and if so, someone please correct me. Cheers. Quote Link to post Share on other sites
apchoo 0 Posted January 7, 2004 Share Posted January 7, 2004 My DH-2000A is connected to the 76WSHD via the XGA port and the TV displays all DTV channels in the "China HDTV interlace" standard in 1920x1080i resolution (28.125kHz/50Hz in 16:9). According to the 76WSHD user manual, there is another standard with 1920x1080i resolution---"American HDTV standard interlace"---which uses 33.75kHz/60Hz in 16:9. Pardon my ignorance please, but is it possible to force the 76WSHD to display DTV via XGA in 1920x1080i in 33.75kHz/60Hz? I'm assuming that the vertical frequency has nothing to do with the electrical frequency in Oz (50Hz) and changing it from 50Hz to 60Hz should result in a better and more stable image. If such is the case, then the change in setting should be done at the 2000A, right? Pretty much like changing the refresh rate on your video card? Any ideas? Quote Link to post Share on other sites
blairy1503559527 0 Posted January 8, 2004 Share Posted January 8, 2004 Apchoo, I've never done this and I suspect it voids your dgtec warranty. It's documented elsewhere on this forum...here's how to do it Force 1080i @ 60Hz and here's some additional comments on the benefit... Horizontal Rolling Bars blairy Quote Link to post Share on other sites
apchoo 0 Posted January 8, 2004 Share Posted January 8, 2004 Thanks for the info, blairy. Hmmm ... I think I'll hold back tinkering with the innards of the 2000A until I hear from Travis (originator of the 60Hz setting commands). I've sent him an email for more info ... I'll post his reply later. Cheers. Quote Link to post Share on other sites
burningmullet 0 Posted January 8, 2004 Share Posted January 8, 2004 I've had this set for just over a month now and its great but i've just one problem. I'm using a Hyundai HS635 progessive dvd player thru the HD component input which looks sweet but with 4:3 dvds the image is stretched to fit the whole screen. I've tried all 3 display settings on the dvd player (4:3, 4:3 letter box and widescreen) and the image still stays stretched across the entire screen. Non-Anamorphic widescreen dvds seem to suffer the same problem. I'm not sure what to do next, i don't have another PS DVD player to try with the set. Any info or advice would be much appreciated. Quote Link to post Share on other sites
blairy1503559527 0 Posted January 8, 2004 Share Posted January 8, 2004 I've had this set for just over a month now and its great but i've just one problem.I'm using a Hyundai HS635 progessive dvd player thru the HD component input which looks sweet but with 4:3 dvds the image is stretched to fit the whole screen. I've tried all 3 display settings on the dvd player (4:3, 4:3 letter box and widescreen) and the image still stays stretched across the entire screen. Non-Anamorphic widescreen dvds seem to suffer the same problem. I'm not sure what to do next, i don't have another PS DVD player to try with the set. Any info or advice would be much appreciated. Welcome to the forum and congrats on purchasing a great set. With the palsonic in hd mode you cannot adjust the aspect ratio. You'll need to do this on your dvd player. blairy Quote Link to post Share on other sites
ray888 0 Posted January 8, 2004 Share Posted January 8, 2004 Okay, guys, I'm a bit confused by all these DVD and STB input. I've downloaded the manual. The TV has YCbCr input for DVD and YPbPr for HDTV STB. From reading this extended thread, I'm led to believe to use progressive scanning for DVD, I'd have to use the HDTV input. So how can I then connect a HDTV STB? Can I use the VGA input for the STB and YPbPr for thr Prog. scan DVD? By the way, can anyone advise on these progressive scan DVD player: Yamaha DVD-S540, Sony 730P, Omni 3200P and Digitor S1606. The first 2 are going for a rrp of $299 while the last 2 are going for ~$120. Either the Digitor or the Omni has a VGA output. Are they both PAL and NTSC progressive scan? Appreciate the advice. Thanks. Quote Link to post Share on other sites
alastair 0 Posted January 8, 2004 Share Posted January 8, 2004 The TV has YCbCr input for DVD and YPbPr for HDTV STB. From reading this extended thread, I'm led to believe to use progressive scanning for DVD, I'd have to use the HDTV input. So how can I then connect a HDTV STB? Can I use the VGA input for the STB and YPbPr for thr Prog. scan DVD? Correct, you need to use the YPbPr connection for progressive scan. And also correct you can use the VGA connector for your STB. By the way, can anyone advise on these progressive scan DVD player: Yamaha DVD-S540, Sony 730P, Omni 3200P and Digitor S1606. The first 2 are going for a rrp of $299 while the last 2 are going for ~$120. Either the Digitor or the Omni has a VGA output. Are they both PAL and NTSC progressive scan? I have the Sony 730P, bought it a few days ago from the Sony shop in Chatswood, where it was/is on special for $249. It is PAL and NTSC progressive and is excellent quality, I am very impressed so far. One complaint/question I have is the HDTV mode doesn't seem to support and of the aspect ratio changing controls of the regular mode. In other words, when connected through the HDTV inputs I can't switch it to 4:3 aspect ratio (with black bars on the sides), zoom, panorama, etc. This means the 4:3 format DVDs I have (R1 Buffy boxsets are flattened. Does anyone know if this can be fixed? Proposed workaround is to use the S-Video connection for these types of disks... (edit: just noticed this is the same problem burningmullet has...) Quote Link to post Share on other sites
ray888 0 Posted January 8, 2004 Share Posted January 8, 2004 Thanks alastair. Any STB with VGA output? I eventually search DSE website (not a very good search engine) and found that the Digitor S1606 is listed as having NTSC progressive scanning. No mention of Pal PS. Quote Link to post Share on other sites
apchoo 0 Posted January 8, 2004 Share Posted January 8, 2004 The TV has YCbCr input for DVD and YPbPr for HDTV STB. From reading this extended thread, I'm led to believe to use progressive scanning for DVD, I'd have to use the HDTV input. So how can I then connect a HDTV STB? Can I use the VGA input for the STB and YPbPr for thr Prog. scan DVD? Ray888, I don't know the technical details of YCbCr vs YPbPr but the situation with the 76WSHD from my experience is as follows. The 76WSHD has two HD inputs, XGA and YPbPr. It also has a set of YCbCr inputs labelled "DVD". I connect the 2000A STB via XGA and my HK DVD30 dvd player via YPbPr. The DVD30 has PAL & NTSC prog scan and the 76WSHD will only display a PAL/NTSC PS signal via YPbPr. According to some technical literature I've read on the net, some TV's component video inputs are YCbCr & YPbPr compliant and would switch acccordingly depending on the type of input signal. Not the 76WSHD. To watch my dvds in PS, I must connect the DVD30 to YPbPr which leaves the XGA for the STB which is fine with me. The annoying thing is the 76WSHD only has one set of audio input for both HD inputs. I use these audio inputs for the STB as TV spkrs are fine for 99% of DTV. However, when I'm watching a dvd, 99% of the time I'd listen thru my 5.1 surround system. I hope my comments answered some of your questions. I felt extremely lucky in buying the 76WSHD for the wealth of inputs and signal types that it has/can receive as I wasn't completely aware then of what I needed. My mate who bought the Samsung WS32A10 76cm widescreen TV now faces the dilemma of i) the TV not having an XGA input for the 2000A he is planning to buy, and ii) the TV not supporting PAL PS as it does not do 576p (only 1080i/576i/480p/480i) and he's also planning to buy a PS dvd player. So do as much research as you can before you part with your $$$. By the way, can anyone advise on these progressive scan DVD player: Yamaha DVD-S540, Sony 730P, Omni 3200P and Digitor S1606. The first 2 are going for a rrp of $299 while the last 2 are going for ~$120. Either the Digitor or the Omni has a VGA output. Are they both PAL and NTSC progressive scan? As for the PS players in your list, I have no firsthand experience with them. The only one I came across briefly is the Sony 730 in which another mate was looking at getting. He decided against it because it could not read all of the DVD-R/+R/-RW/+RW discs he brought to test with---that, however, may not be important to you. He ended up buying a non-PS JVC player. I haven't had a disc (any region, original or copied) that the DVD30 would not read (yet). If copied dvds aren't a concern, there's also the HK DVD25 which is identical to the DVD30 except it doesn't do DVD-Audio. I would have bought it if it hadn't failed to read one of my TDK DVD-RW discs---and at $200 cheaper too! Good luck! Quote Link to post Share on other sites
apchoo 0 Posted January 8, 2004 Share Posted January 8, 2004 One complaint/question I have is the HDTV mode doesn't seem to support and of the aspect ratio changing controls of the regular mode. In other words, when connected through the HDTV inputs I can't switch it to 4:3 aspect ratio (with black bars on the sides), zoom, panorama, etc. This means the 4:3 format DVDs I have (R1 Buffy boxsets are flattened. Does anyone know if this can be fixed? Proposed workaround is to use the S-Video connection for these types of disks...(edit: just noticed this is the same problem burningmullet has...) Correct. I have the same problem with the HK DVD30 on 76WSHD via YPbPr. There are a number of posts that suggest changing the aspect ratio on the dvd player rather than the TV, but doing that has no effect with my DVD30. So I resort to S-Video for dvds like The Wiggles or Hi-5 but I don't think my 15 month old daughter is that fussed . Also dvds like "Eagles - Hell Freezes Over" music dvds are also in 4:3, and I have to be content with a flattened looking Don Henley. Quote Link to post Share on other sites
burningmullet 0 Posted January 8, 2004 Share Posted January 8, 2004 One complaint/question I have is the HDTV mode doesn't seem to support and of the aspect ratio changing controls of the regular mode. In other words, when connected through the HDTV inputs I can't switch it to 4:3 aspect ratio (with black bars on the sides), zoom, panorama, etc. This means the 4:3 format DVDs I have (R1 Buffy boxsets are flattened. Does anyone know if this can be fixed? Proposed workaround is to use the S-Video connection for these types of disks...(edit: just noticed this is the same problem burningmullet has...) Correct. I have the same problem with the HK DVD30 on 76WSHD via YPbPr. There are a number of posts that suggest changing the aspect ratio on the dvd player rather than the TV, but doing that has no effect with my DVD30. So I resort to S-Video for dvds like The Wiggles or Hi-5 but I don't think my 15 month old daughter is that fussed . Also dvds like "Eagles - Hell Freezes Over" music dvds are also in 4:3, and I have to be content with a flattened looking Don Henley. yup changing aspect ratio on the dvd doesnt help me either so im using svideo hookup for 4:3 dvds now, problem is i have to swap between the two outputs in the dvd player setup as it wont output to both connections at the same time. Its a small hassle but i can live with it. Thanks for the help guys Quote Link to post Share on other sites
blairy1503559527 0 Posted January 8, 2004 Share Posted January 8, 2004 HD inputs are either XGA or YPbPr with one set of stereo audio inputs. You can connect HD stb or a PS DVD to either of these. All HD STB and (as far as I know) PS DVD players have YPbPr outputs. However only some have XGA outputs. AFAIK, dgtec2000a and Panny HDstb are the only ones with XGA outputs. Some Omni and Digitor players have XGA outputs. It really is a case of mix and match. As for the difficulties with DVD aspect ratio, I would imagine most Palsonic purchasers would already have a (non ps) dvd player. Keep it for those dvd's that won't play as you require via the HD inputs. Alternatively, if you have a games console use it for this need. And a third option, buy a cheapie DVD player from ALDI (Tevion $59 and it does PS too, although I haven't seen it in action a decent tv). blairy Quote Link to post Share on other sites
Lickster 0 Posted January 9, 2004 Share Posted January 9, 2004 I get around the issue by having the composite output go through an AV input. If the kids or wife want to just watch a DVD without the fancy effects they watch it through there. I watch 4:3 DVDs through there with the surround sound still on. In alot of cases you don't really want the top quality for 4:3. I was recommending the Unimax 808 PS DVD player which is both PAL and NTSC progressive, costs $118 and has a VGA output. All was going well for a week till it died on Christmas Day !! I am awaiting a replacement from Strathfield - no stock after the sales.... Quote Link to post Share on other sites
mrmaxwell1503559518 0 Posted January 9, 2004 Share Posted January 9, 2004 the Unimax 808 PS DVD player which is both PAL and NTSC progressive, costs $118 and has a VGA output That sounds like a good deal...especially if you have VGA input on your HD set. What's the actual video quality like through the Palsonic from one of these? Quote Link to post Share on other sites
apchoo 0 Posted January 9, 2004 Share Posted January 9, 2004 What's the actual video quality like through the Palsonic from one of these? Look back at my posts in this topic from page 9 on 76WSHD quality via XGA & YPbPr. Quote Link to post Share on other sites
ray888 0 Posted January 10, 2004 Share Posted January 10, 2004 I finally purchased this TV. So far I'm very impressed with the PQ with DVD connected via YCbCr. Now more incentive to put up a new aerial for analogue BC. The only problem so far is that when viewing in 16:9, the set seems to lose some picture on either side, more on the left. I tried adjusting the set with "The Ultimate DVD" and it confirmed that some of the picture is missing on the left. Unfortunately, I couldn't get into the OSD menu as shown in chapter 14, page 34 of the manual. so I cannot get to H-Phase or H-Size or indeed any of the option shown on that page. Is this menu option only available for HDTV mode? Please advise. There was a rotation up on the top RHS which I was able to correct using the rotation menu. I'm holding out for a HD STB till there are more content broadcasted and more models. Should I get a SD STB for the time being? By the way, maybe someone should start a thread about which SD/HD STB they bought and/or recommend. Including failure. What do you think? Thanks. Quote Link to post Share on other sites
blairy1503559527 0 Posted January 11, 2004 Share Posted January 11, 2004 I finally purchased this TV. So far I'm very impressed with the PQ with DVD connected via YCbCr. Now more incentive to put up a new aerial for analogue BC.The only problem so far is that when viewing in 16:9, the set seems to lose some picture on either side, more on the left. I tried adjusting the set with "The Ultimate DVD" and it confirmed that some of the picture is missing on the left. Unfortunately, I couldn't get into the OSD menu as shown in chapter 14, page 34 of the manual. so I cannot get to H-Phase or H-Size or indeed any of the option shown on that page. Is this menu option only available for HDTV mode? Please advise. There was a rotation up on the top RHS which I was able to correct using the rotation menu. I'm holding out for a HD STB till there are more content broadcasted and more models. Should I get a SD STB for the time being? By the way, maybe someone should start a thread about which SD/HD STB they bought and/or recommend. Including failure. What do you think? Thanks. If you're getting a new aerial make sure it's good for digital reception too...no point getting a new one now and again later on. H-Phase and H-Size are only available in HD mode. Have you got the dvd player set up correctly (EG set to ouput WS)? With this set I've got an HD STB. Personally I wouldn't bother with an SD box. (Of course, if you have a use for hte SD box on another set after you later upgrade to HD that might be worthwhile). There are currently two threads for STB...one HD and the other SD. blairy Quote Link to post Share on other sites
keeno 0 Posted January 15, 2004 Share Posted January 15, 2004 This may already have been answered, but does it upscale 720 to 1080 - or does it natively do this res? That could also be a stupidly worded question! Quote Link to post Share on other sites
apchoo 0 Posted January 15, 2004 Share Posted January 15, 2004 This may already have been answered, but does it upscale 720 to 1080 - or does it natively do this res? According to the user manual, the 76WSHD does 1080i/720p/576p/576i/480p/480i, so I believe it does 720 natively. I have nothing to test this---the only resolutions I've verified are 1080i, 576p & 480p. Cheers. Quote Link to post Share on other sites
ray888 0 Posted January 15, 2004 Share Posted January 15, 2004 Hi, everyone. Can anyone help, please? Can anyone recomend the optimal setting for contrast, brightness etc? Can you actually access thevarious buttons on the remote when in HDTV mode, ie YPbPr? I cannot seem to be able to access such buttons as the Panorama, P.Scan, Photo etc. Can onyone help with the OSD menu when in HDTV mode? Eg H-Size, H-Phase, V-Sizeand V-Phase. Quote Link to post Share on other sites
AzzX 0 Posted January 16, 2004 Share Posted January 16, 2004 Greetz ray888 You cannot access the same buttons when in HDTV mode, the TV acts more like a PC monitor. The menu button gives you most of the controls. If you have a device that utilizes the VGA or RGB (ypp) connections then that device will be better suited for changing things like aspect ratios and resolutions, be it a PC or set top box. Just square up the picture via the menu using A 16x9 DVD so there are no gaps and you will be fine. contrast and brightness is usually down to personal taste. - set the contrast all the way up and work from there until you get the best pic. Cheers Quote Link to post Share on other sites
blairy1503559527 0 Posted January 16, 2004 Share Posted January 16, 2004 Useful link for setting brightness and contrast on any tv Brightness and Contrast settings I actually have this printed out and keep it wiht the tv manual. The settings available via the remote depend on whether you are in 'normal' mode or 'high definition' mode. The manual is infact broken down into specific sections to reflect this. Settins such as Panorama, P.Scan, Photo etc. are only available in normal mode. In HD mode you have H-Size, H-Phase, V-Sizeand V-Phase etc etc. Changes made in one mode do not reflect in the other (in the main). In HD mode this is generally a case of trial and error...there is limited guidance in the manual and no you won't get it perfect first go...it will take a bit of effort. good luck blairy Quote Link to post Share on other sites
ray888 0 Posted January 17, 2004 Share Posted January 17, 2004 PS DVD and HDSTB connection: How to on this TV? At present I'm connecting the Sony 730P PS DVD via YPbPr. I have searched for HDSTB with VGA output and found none. So how can I connect the HDSTB when I've already used the YPbPr input on this TV? Cna I use a double adapter? Are there any on the market and who sells them. Thanks Quote Link to post Share on other sites
captaineos 37 Posted January 17, 2004 Share Posted January 17, 2004 DGTEC 2000A has VGA output, works very well on the Palsonic, also the Panasonic HD STB has VGA output, but I havnt tested it. Im sure there are a few more outhere that have VGA out. Do a better search! jeremy barr Quote Link to post Share on other sites
tnt015 0 Posted January 19, 2004 Share Posted January 19, 2004 Is there anyone using this TV with HTPC? I am interested to know if this TV can accept 1280X768 60 Hz via VGA connector? Quote Link to post Share on other sites
Dogbert 8 Posted January 20, 2004 Share Posted January 20, 2004 I second that tnt015. I am going to build my first HTPC with the bits left over from my planned PC upgrade in the next month. I am also interested in resolutions and refresh rates etc that I should use with my Palsonic TV. I am thinking of connecting via the xVGA, I might need a xVGA switch box (are they available?) to swap between the QTR2140 and the HTPC signals to the TV. I am finding it hard to adjust when I have to watch the video now, I am looking forward to a HDD recorder. Cheers Andrew Quote Link to post Share on other sites
blairy1503559527 0 Posted January 20, 2004 Share Posted January 20, 2004 Link to Palsonic web site for this tv. Palsonic 76WSHD At the bottom of the page is the link to the instruction manual. This details the display mode settings in HD mode. Yes it accepts 1024 X 768P with H- frequency of 48.4KHz and V-frequency of 60Hz. In fact it takes about 13 different 'displaying patterns' and can support and store another eight. Also have a look elsewhere in this forum...there's heaps of info on HTPC and resolutions etc. With the right software you should be able to set the HTPC output to meet the TV's inputs. good luck blairy Quote Link to post Share on other sites
Philby 4 Posted January 22, 2004 Share Posted January 22, 2004 Hi Guys, I have some questions regarding the Palsonic that the local sales drone could not answer. 1) If I run either a 480p/576p/720p/1080i signal to the HD inputs does it automatically sync, or does it have to be done manually? 2) Could you run Y-connectors on the HD input to connect both a STB and a DVD player? 3) Can the unit do 576p/720p/1080i @ 50Hz and 480p/720p/1080i @ 60Hz ? 4) I am thinking about using a Momitsu DVD-V880 player with the Palsonic, does this seem to be a good combo? Thanks Philby Quote Link to post Share on other sites
michaelf 0 Posted January 23, 2004 Share Posted January 23, 2004 philby, I have done alot of research on this TV and I now have one myself, so I beleive I can answer your questions. 1) Yes the TV does automatically sync to the signal its receiving and it converts it to the screens native resolution of 1024x768 (its basically a computer monitor). Sometimes, some resolutions do not sync perfectly so you need to play around with the geomitry settings of the screen. 2) No you would need a switch box to run two devices into the same input and just switch them when you use them. However the TV does actually have 2 HD imputs anyway. A HD component input and a RGBHV 15pin input. Both will accept a HD input from devices such as a DVD player or a STB. The RGBHV input is the best through, so you may want to use this input for both to get the best picture quality, therefore you would need a VGA switch box which can be obtained from most computer stores. 3) The TV via the component video HD inputs can do 576i/576p/1080i @ 50Hz, and 480i/480p/1080i @60Hz. Via the RGBHV HD input, it can do 576p/1080i @50Hz and 480p/720p/1080i @ 60Hz. RGBHV doesn't seem to properly handle 576i @ 50Hz or 480i @ 60Hz . It also accepts various computer standard resolutions up to 1024x768@60Hz. 4) As you have probably seen on another thread on this forum, we are the Australian distributor of the Momitsu DVD player you mentioned. Of course I personally have a V880 at home and have it hooked up to the Palsonic via RGBHV using a DVI-VGA adaptor (which we also sell) going through a VGA switch box, along with my Xbox with a HD VGA kit, and a DGTEC 2000a HD STB that has VGA output. It all works great and the picture from the Momitsu is very impressive on this TV. It is a great TV and great value. I picked mine up for under $1900 so its fantastic value. You won't be disappointed. Same goes for the Momitsu. When you are ready for the momitsu, email me and I will provide you will full details. Thanks Quote Link to post Share on other sites
keeno 0 Posted January 23, 2004 Share Posted January 23, 2004 Hey all, Firstly, great thread and thankyou. Made my decision based on most info here! Here are my initial questions and problems I thought I should share. Maybe some of you could help me out? • When I hook up the PS2 through the HD Components, the screen is out of sync. I guess this is because the port doesn’t accept 480i(?). Still, it looks bloody nice through the normal component. • Xbox through composite. Well, it is big, but not as clear as it could be. I am going to get it ‘converted’ (;-)) to be able to be an NTSC version, and probably buy a VGA converter (from www.x2vga.com – anyone else have this set up – please comment!). The reason is that the Palsonic doesn’t accept 720p/480p at 60Hz through anything but the VGA connection(?) • Normal RF varies between acceptable and annoying. This is due to the aerial and reception though. I get the three/two vertical bars down the middle of the screen on crappy reception, good reception they aren’t there. Guess I should get a set-top box…! • Screen is slightly set up wrong, missing some of the left side. I fix this. • I cannot get the VGA working with my computer. I change the res on Windows to 800/600 @ 60hz, and I can see the image, but it is badly out of sync (scrolling up and to the left really fast). I am probably doing something really stupid – but what? • Image warping on widescreen. There is definitely something up here – the image about 10cm in from either side is quite badly warping. You can really notice it on scrolling text and panning images in movies. It is highly annoying for me, as I am quite prone to seeing this stuff. I think this will require me to call Palsonic… If you watch a 16:9 movie in ‘Panorama’ – you will see what I mean (even though this is an exaggerated view). I know some people have had this problem (PaulInMelbourne), and some haven’t at all! • Settings. I know some people have already asked for a posting of everyones settings – so how about it guys! The link to the setting up a TV on this page was excellent reading - you should all look. • Image blurring. When you are watching anything, you can kind of see the movement is kinda lagging (if someone turns their head, rather than being a smooth ‘real’ looking movement, there seems to be some kind of dragging of the image – really bad description I know!). It looks like there is some DNR (?) on, even though I have it turned off. So, can anyone help? Otherwise, it is a ****in’ TV for the price!! Just some set up problems for me! -pk- Quote Link to post Share on other sites
Philby 4 Posted January 23, 2004 Share Posted January 23, 2004 Thanks for the Info Guys, So where can I get a good price on one of these (Palsonic 76WSHD)? I'm in Adelaide and the be$t price here seems to be from HN @ $$2200. Seems a little $teep when I see ppl getting them for around $1900. Thanks Philby Quote Link to post Share on other sites
blairy1503559527 0 Posted January 25, 2004 Share Posted January 25, 2004 keeno PS2 outputs in SD and can't be synched using HD inputs. There's various threads in the forum about modifying the XBOX for use with HD inputs RF analogue TV is generally acceptable, although obviously depends on your aerial. I have the dgtec 2000a and pq is vastly superior to analogue Set the res on your pc to one of the resolutions listed in the tv's manual...that should get you started. (I've never connected PC. Using vga input for stb.) Image warping is a call to palsonic I'd suggest. Depending where you are they might even arrange to call out to your place. I don't get the image blurring you mention, in either HD mode or the standard AV inputs. Is this related to the warping you mention above? Quote Link to post Share on other sites
