Serpeant
Can an old Onkyo 875 Integrated Amp be use as a Power Amp?
I have an Onkyo 875 and was hoping to upgrade to a Dolby Atmos pre-amp.
If I get a Dolby Atmos pre-amp, can I then use the Onkyo 875 as the Power Amp to power the speakers but not do any of the processing?
This way I can save a few dollars until I am ready to purchase a proper Power Amp?
I might be wrong, but I don't think so. I was thinking the same thing for my Onkyo TX-NR906 as the amp stage has great output, but the digital/pre is now somewhat outdated.
I've actually heard people doing this by using the 7.1 analogue inputs on the receiver and setting the volume to suit but not sure of the results.
Edited by Hi-Fi Whipped
Yes you can. Page 32 of the user manual is a good place to start.
Jason.
    • By MattyW
      Ok, now that I've had my Wavebourn Edelweiss-3 for a few months and it's nicely burned in it's time for me to prepare writing my review of it which I'll post here over the coming month. I'll post my impressions and experience purchasing this wonderful amp from Anatoliy Lisovskiy, who will be releasing the production series of the Edelweiss-3 power amp, an integrated amp and separate preamp over the course of this year.
      As I understand it the current production version of the power amp and integrated will all be EL34 though allow and pin compatible tube to be used right through to KT120, possibly even KT150. My own amp on the other hand uses WW2 vintage CV1127 radar sweep tubes.
      More to come.
    • By SoundGuy
      Price: $12,000 $10,500 $9300
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By mlw
      Item: Concert Fidelity ZL200 monoblocks (price reduced)
      Price: $8500
      Item Condition: Excellent 8/10 on Audiogon scale
      Reason for selling: Reconfiguration of system (for balanced operation)
      Extra Info: purchased second hand around 5 years ago. Rarely used and always used with PS Audio conditioner. New price for these were $48,000 US ($70,000 AUD!) - very expensive (and heavy) mono blocks. You will not find any power amps of this quality near this price. This amp received the Absolute Sound 2012 Editor's Choice Award.
      The unique sound of the ZL-200 is aptly described by Mr. Harry Pearson: "These monoblocks are the first solid-state amps I've heard that sound like a tubed unit, and by that I mean a very good tubed unit, on the order of say, the best conrad-johnson amp (vide, the ART III) but lacking the golden glow of the CJ sound, thus rather more uncolored than most, if not all, of the transistorized competition. It has the dynamics of good tubed unit, the focus on instruments and the sense of an ambient field that is characteristic of the old William Z. Johnson design for Audio Research.
    • By GroovyGuru
      Item:   AVM Ovation MA 8.2 Monobloc pwr amps
      Price:  $16,000
      Reason for selling:  Upgraded to valves.
      Payment Method: Pickup - Cash, Paypal, COD, Bank Cheque, electronic transfer.  If Paypal, buyer to pay all fees.
      These were Marc Rushton's power amps.  I bought them in Oct 2017.  I said I was never going to have valve power amps again but I changed my mind after I heard the AR Ref 160M which I bought.  But I would've happily stayed with the AVM MA 8.2.
      The AVM monobloc runs the AR pwr amp close.  At $16k the AVM MA 8.2 is an affordable end game power amp.  RRP was $44,000 for both ($22,000 each).  It is rated at 600 watts RMS.  It will drive anything with finesse.  It is a low noise, low distortion design.
      This is a very good price for these amps.  If you want to spend less, there is the Holton monobloc listed on this site for $15,000.
      It is Germanic black as you can see by the pictures.  It is so black even the white parts are black.
       If not pickup, buyer to arrange courier.  Gross shipping weigh each at about 45kg.  W58cm x H38cm x L57cm.  Shipped in haulage case as pictured.
    • By Mpr_65
      Item: Nord One SE Power Amplifier (class D)
      Price: $2200
      Item Condition:  Excellent.
      Reason for selling:  Gone to Valve amplification. Can’t afford to have this one sitting around.
                Dual mono design
                400W pc  / 8ohm
                Latest Rev D buffer boards fitted ($950 upgrade)
                Sonic Imagery op amp fitted (can be changed DIY)
                12v trigger fitted
                Excellent condition, no marks, no scratches, dents, as new.
                Original box and receipt
                Functioning perfectly
                Balanced input.
      Nord info.
                https://www.nordacoustics.co.uk/product-page/nord-one-se-nc500dm-mkii-dual- mono-stereo-amp
      Reviews.
      https://6moons.com/audioreviews2/nord/2.html
      https://hifipig.com/nord-one-up-nc500-dmst-power-amplifier/
                 Purchased this amp new with Hulgich Ella II speakers. Same amp was used with Hulgich speakers to win best sound in show at 2017 Melbourne Hi Fi Show (minus the new Rev D buffer upgrade which provides even better bass response and other goodness)   Handmade in the UK it’s not a cheap class D. Great attention to detail in all aspects of its production.
                  Very clean sounding amplification with 400 watts / 8omh it will drive any speaker.
                  Ever wondered how good class D can be? This is a good place to start!
                  Current model (same) will set you back $3800+
                  Demo available.
