Learning about HeadFi
I am currently trying to learn about HeadFi due to a new arrival into our household. Their room is right next to my listening space, and as such I may be forced to use a more personal method for enjoying my vinyl records.
So given this possible requirement, I am looking for advice... information or just plain old opinion about how to get the equivalent type of sound I have now, just in headphones?
The Headphone out on my Amp is spec'd as follows:
THD (20hz-20khz) - <0,005% at 1V out
SNR - >110dB (32ohms loads; A-WTD, ref. 2V out, unity gain
Frequency response - +/-0.3dB (20hz-20khz)
Channel separation - >60dB at 1kHz
Output impedance - 6 ohms
So I am not sure what this means, but the manual suggests it will drive any headphones..... but me thinks this is not quite true based?
Anyway, I am running a NAD C388 and paradigm signature S2, that are currently sounding pretty good, particularly with a GS Accession Phono Pre. The REL T9 has fixed the bass :)
What headphone options would give me a good start into this space?
Dan
Link to comment
Hahaha, I hadn't even considered the addition coming at the later age bracket. Fortunately it's the smaller [emoji3]
As for budget.... the current Amp speaker and cable setup is a 5-6k sort of system. I would love to maintain this level of quality when adding headphones. As for the headfi budget, I suspect I will have to be maxing out around $1k.
Music. Hmm eclectic describes it, but artists currently include Fleetwood Mac, Sam smith, joe cocker, foo fighters, Simon and garfungle, just Simon, Adele, some classical and some jazz. Pretty much trying all types at the moment :)
Link to comment
I have and have used many pairs of headphones, none of them provide a listening experience equivalent to my speaker system.
Headphones are, if anything, even more idiosyncratic than speakers and personal preferences regarding presentation very much come into play in choosing a headphone.
The ability of your amplifier headphone socket to drive a particular headphone may also be limited vis a vis a dedicated headphone amplifier, particularly in the case of the harder to drive headphones.
Relatively inexpensive and quite easy to drive are the Grado SR60, the ATH-M50X and the Shure SRH-940 although the latter is getting somewhat dearer @ $300.  The Shure, IME, will work quite happily from a smartphone - the other two I have no direct experience of, but they are often recommended.
It would definitely be best if you could try a few pairs of headphones for yourself before committing.
Finally, I do concur that often a baby will sleep better with music playing although some genres are less helpful :)
Link to comment
As with stereo systems - choose the headphones first. Different brands have their own unique house sound or Signature. Much like speakers.
I've owned Sennheisers from the HD650 to the HD800 along with some Grado made Alessandro MS Pro and then gradually moved to planar, ribbon designs.
On the entry level, the Oppo PM3s are hard to beat. It retains the speed of planar drivers but is closed back - so sound is contained - great if you don't want to disturb someone else in the same room and doesn't require too much oomph to drive. The soundstage and feel isn't as good as the open back ones.
Going to open back headphones the PM2 is one that punches above its price point. It is so close to the PM1 that I often have a hard time justifying to myself or others to step up their budget.
My experience with Audeze is that QC can be a little hit and miss. Because it is handmade. And because the frequency plots have a pretty large variance between batches. Had to send my LCD3 back to US and the replacement was different. And because they are always changing the specs. May not be great for resale. Imho.
My absolute favorite has to be the Hifiman. I have the HE6 and it's a great sound. But it is a beast to drive. So it will need a gutsy amp.
Ideally you want a dedicated headphone amp - not something that is added as an after thought in marketing literature and is just a few op amps to the circuits.
If you are looking for one that can be used for yr speakers, I suggest looking at the PrimaLuna Dialogue Premium HP. A flick of the switch sends all that Tube power (not an opamp) to the headphone jack. Or the PS Audio BHK Signature preamp which has a headphone amp that shares the same designer as Audeze's King headphone amp.
Or wait a bit longer and get the Chord Poly/Mojo combo. I can't reveal too much yet but that pricing is going to be sooo good you will be glad you waited. That combines an excellent headphone amp and portable DAC along with a Roon compatible streamer.
Link to comment
@DoggieHowser obviously knows his headphones.
I've been fascinated with headphones, headphones amps and dacs for almost 3 years now. I've owned beyer dt880 & T1, Sennheiser hd650 & hd800, Audeze lcd-2f and will be getting ZMF Eikon and Atticus soon.
As Doggie stated, most of these headphones sounds best with dedicated headphone amps. I use a tube amp and a solid state. Gear are in my signature.
The last point Doggie made has my interest. I have just pick up a Chord Mojo and boy, was I surprised that it drove my planar magnetic LCD-2f really well. Sounds really good too. I'm also keen on the Poly and intend to attend the launch at MiniDisc on the 21st Sep 2017 from 6pm to 8pm.
Link to comment
It's true, I am unsure how to describe my sound preference, but balanced sound is important, clear highs and mids, on the slightly warmer side of the gauge, and enough bass to round out the bottom, but not EDM style if you know what I mean.
Link to comment
I have twin new arrivals in the home and, like @GregWombald said, just play music like normal through your speakers - unless it's late at night, which is when I do my head-fi listening.  Usually after 10 P.M.
One of the first decisions you'll have to make is closed or open backs.  If the bub is in a different room then you should be able to get open backs, which I did because there's no comparison in sound stage, I much prefer open backs.
At $1000 I'd keep that for your headphones and then work towards a dedicated headphone amp.  I first decided upon a set of headphones and used an AVR, then moved to an entry level headphone amp and now run my dream amp (WA22 with upgraded tubes).
Some people who are into their stereo system don't actually like the headphone experience, even good quality head-fi.  At $1000 it's good to dip the toe and see if it's for you.  Personally, I love them both, so long as the quality in the gear is there...
Link to comment
I think LCD-2f will suit you. A Chord Mojo as dac/amp driving LCD-2f has captivated me for 2 days straight.
However you need to up your budget. LCD-2f is selling at Addicted To Audio for $1399. I just pick up a 'new' Mojo on this classified for $525. This is all you need ..... for now. :-)
A good bass track is 'Rock You Gently' by Jennifer Warnes of 'The Hunter' album. Sounds really good on this setup.
Link to comment
  • 2 weeks later...
Well the new bub has decided to wait in the comfort of her mums tummy for a little while longer... any day now I suspect.
I have only managed to have 1 listen to the headphones as yet, so hopefully Father's Day includes some alone time [emoji3]
Link to comment
I've been playing around with headphones and amplification for a year or too and have had a few sets come into and out of my head-fi chain during that time.
I've just settled on a pair of Sony MDR Z7 after some experimentation and I love them. They're closed back so I can listen without disturbing others in the house, have a sound signature I particularly like and the build quality is very high as they are made in Japan, which is becoming rare.
I also had a pair of AKG K702 until recently (sold them on SNA) which I liked but found the presentation to be a little bright for my taste. For me they were a great place to start though as my taste in cans has developed a lot over the past year or so.
For amplification I'm using a Schiit Vali 2 with a GE tube and it's great.
Good luck!
Link to comment
To Top
