surprisetech
New 3-way Speaker Build has finally started.
I've been planning to build a new 3-way pair from scratch for some time and it's finally happening.
The last upgrade I did on my main speakers was to increase the box size from 70 to 118 litres by adding plinths to the bottom of the existing enclosures, replacing the 10" bass drivers with 12" Peerless 830669's, fitting appropriate ports and rebuilding the crossovers.  I've been really happy with the results, but always planned to upgrade the aging mids & tweeters and build new enclosures from scratch with better materials and a really nice finish.
I've been really happy with the Peerless woofers, so they are being re-used.
Did quite a bit of research into mids & tweeters that would match with the 830669s and with each other, and finally settled on SB Acoustics SB15NRXC30-4 5" Mid-Bass drivers and SB26ADC-C000-4 Tweeters.
They're both a very good match for the woofer in efficiency and both have really good off-axis response in the bands they will be operating in.
I also picked the SB15NRXC30-4 because it has an Fs of 41 Hz.  This allows me to have a fairly low woofer-mid crossover of 350Hz, so that each of the 3 drivers will only be responsible for about 3 to 4 octaves.  I'm looking at a mid-tweeter crossover of 2800Hz, so all 3 drivers will only be operating well within their comfort zone.
The new enclosure will be 130L front-ported and the midrange driver will have its own 3L chamber behind it that I'm making up out of heavily damped poly pipe.
I don't really have the time or tools to build the boxes as well as I would like, so have got a custom furniture builder doing it for me.  Should be picking up the semi-assembled boxes soon to do the internal treatments.
Do you have any illustrations as to what the final speaker will look like?
Yes. I had to do very detailed drawings for the cabinet maker.
Material is 18mm furniture grade birch ply.
Photo is from the maker when the basic assembly was done and before he started on rounding the edges, bracing, etc.
Crossovers (Mark 1) were built a couple of months ago.
I've chosen to go with 2nd order slopes all round to start with and have included Zobel networks for the woofer & mid.
(It's OK, the solitary bi-polar electro is only in a zobel network)
No doubt there will be some changes when I can start testing.
Once I'd chosen to go with the 350Hz bass-mid crossover, sourcing the choke for the woofer was an interesting exercise.  The Jantzen C-Coil finished up being my best option to keep the DCR to an absolute minimum and eliminate any chance of saturation without breaking the bank.  I can see why so few commercial 3-way designs crossover this low!
The plan is to embed this enclosure into the back of the speaker box so that the crossover components will be accessible for mods by just taking its lid off.  i.e. without needing to open up the speaker box.  This should make fine-tuning the crossover and doing measurements much easier.
The midrange chambers are ready.  I had a few different ideas of how to approach this and although the technique I settled on might be amusing, I think it should be effective.  It's a little over 3 litres which according to WinISD would give me a flat response to more than an octave below my crossover frequency. So plenty of margin there.
Due to the close proximity of the chamber walls to the driver in a midrange enclosure, and the chamber itself being inside a speaker box, I wanted rounded surfaces throughout.
So I used a length of 150mm diameter stormwater pipe, a melamine bowl and a 75mm end cap all glued together with polyurethane adhesive after preparing the mating surfaces with coarse sandpaper.
Outside is covered in Car Builders Sound Deadener to make it non-resonant and the inside is lined with thick felt at the rear and thinner felt around the sides to kill off internal reflections.  I'll add some polyester fill when doing the final assembly.
I'm planning to use liquid nails or the polyurethane adhesive to attach them to the back of the baffle and provide a complete seal, in conjunction with a couple of small L brackets to make sure they are centred over the midrange cutouts.
Creative and/or comic comments all welcome!
Ha, very good! Just don't try taking them on a plane.
Can you see the colour coding from outside the speaker? Oh, and is red for driver +, or crossover +?
I'd be flattered to be one of your mids.
I'm more worried about the thickness of your panels, especially the baffle. Hope you use lots of bracing.
Thanks Brian.  All good points.
I'll be wiring the mids with care and will be treating the terminals on the back of the chamber as the speaker terminals (red for driver +).
As for panel thickness/stiffness.  I'm fairly confident I have this covered, but I do have a contingency plan.
The choice (and extra expense) of the birch ply gives me the stiffness of 25mm MDF, but without the weight. (And a nicer finish)
All the panels are biscuit-jointed and also have battens on all the insides of the joints.  The panel shapes and the narrower widths at the top should also help.
Yes, there will be lots of bracing done with more of the 18mm birch ply and I've still got 10 sheets of the Sound Deadener to install on the insides of the panels as well as a thick dense felt.
The contingency plan is that the design allows me to glue an additional layer of the ply to the back of the baffle if necessary.
Was able to make some progress on the weekend.
The crossover enclosures are now embedded into the removable section of the rear panel with PU glue, so no chance of air gaps.
Inside surfaces of these panels including the back of the crossover box have the adhesive bitumen pads and 10mm felt.
Wiring from the crossover to the inside of the box will go via the IP68 rated cable gland.  Might add a little silicone just to be sure before I tighten the gland.
Having found the odd insect or spider inside speaker boxes over the years, I also vermin-proofed the Port tubes with some grille cloth.
The midrange chambers and ports are installed (PU glue again) and I did add another layer of ply on the back of the baffle around the woofer.
Picture of the midrange chamber installed in the box.
Edited by surprisetech
    • By Bree K
      These are a fantastic pair of speakers, with excellent sound quality. If you are looking at them, you should know them
      We just got some B&Ws, but these will give any speaker in this price range a run for their money. Sadly, we don't have room to keep them as a second system.
      Happy to audition on pick up from Camperdown, Sydney. Comes with front grills. Price is relatively firm at $850.
      PM me if interested. Thanks!
    • By HTFan
      As new pair of KRIX Neuphonix speakers in Black veneer. These are seriously as new and I have not used them for over a year.
      These speakers RRP for around $3500. I have the box/manual for the speakers ready to go.
      More info can be found at http://krix.com.au/P....aspx?p=44&id=1
      Price I'm after is $1500
    • By m1ttens
      Hey guys,
      I've got a bunch of things to get rid of as I may be leaving the country for work in a few months!
      That and I need a bit of a shift in my system due to the way I use it.
      If you guys see issues with my prices please let me know! I'd prefer pick up, however postage can be arranged as I have almost all of the boxes.
      (Will post pictures tomorrow evening!)
      1- Sonique Diamond 550 SE's in Jarrah $1900.00 ($2799.00 retail!)
      http://www.sonique.com.au/hifi/diamond.htm
      2- Rega P3 Yellow (P3 not Planar 3 or RP3 or P3/24) with Bias 2 cartidge $450.00
      http://www.drhifi.net.au/Reviews/Rega%20P3%20Review/Rega%20P3%20Review.htm
      3- Creek OBH-21 with OBH-2 PSU $200.00
      http://www.head-fi.org/t/25578/info-on-creek-obh-21-and-obh-21-se-amps
      4- Energy ESW-C8 $250.00
      http://www.energy-speakers.com/subwoofers/?sku=ESW-C8
      Incredible sub for small rooms! Great reviews!
      5- Sennheiser RS-120 $120.00
      http://www.sennheiser.com.au/au/home_en.nsf/root/private_headphones_hifi_wireless-headphones_504779
      It's some great gear! With the speakers I'll include a pair of 5m (?) Tara Labs Omni speaker cable with Banana plugs for convenience!
      With the sub I'll include my 5m Tara Labs coax lead (I think it's a higher end video one, but can't remember)
      Anyways, would prefer pick up, you can also come and have a listen providing we set up a time!
      As I have sold my amp, you'd probably have to bring yours.
      Cheers!
      -Andrew
    • By twwen2
      Item: ProAc Response 1SC in cherry
      Price: $1250 including postage to Australia
      Item Condition: 7/10 - see below for details.
      Reason for selling: Making space
      Payment Method: Pickup - Cash, Paypal, Direct Deposit
      Extra Info: The venerable ProAc 1SC. I purchased these last year from a forum member on SNA. They are in reasonably good condition, but do have some minor marks scratches on sides and top of both speakers (only visible up close). These are a very capable standmount speaker with a sound that is enticing.
      The speakers do not have their original box, but will come safely packed. Shipping within Australia is included in the asking price.
      Review: http://www.stereophi...oudspeakers/386
      Pics:
    • By Oldknees2
      Looking at Selling the following speakers (currently on ebay as well). Looking for offer above $3950?
      Focal- JM Lab Electra Be 937
      Extremely rare - 25th ANNIVERSARY-LIMITED EDITION.
      Just 300 pairs in the WORLD!
      Electra BERYLLIUM LINE.
      UTOPIA finish,drivers and parts.
      Most audiophiles prefer them to UTOPIA DIVA due to sound and design with front loaded double 8" Bass drivers.
      Frequency response (-3dB) 35Hz - 37kHz
      Efficiency (2,83 V/1 m) 92dB
      Nominale impedance 8 ohms
      Minimum impedance 3.3 ohms
      Crossover frequency OPC(Optimum Phase Crossover) 300Hz/2800 Hz
      Drivers: Two 8" W cone woofer
      6" W cone midrange
      1" TCE Be pure Beryllium inverted dome tweeter(same used in UTOPIA Line)
      Maximum power 250 Watts
      46Hx11Wx19D
      Heavy-95Lbs each
      Classic Light Gold Burr Ash Finish
      Excellent reviews. Look and sound fantastic
      In excellent condition - cabinets mint. Removable grills good.
      No boxes
      These retailed in Australia for $14,000 / pair.
      Only selling due to downsizing. These have been rarely used and driven extremely lightly. Currently in a home theatre application.
      Pick up preferred. You can arrange a courier at your own cost, or I may be able to transport these to say Sydney if you twist my arm.
      ebay link : http://www.ebay.com.au/itm/271171388909?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_638wt_966
