blybo Posted August 2, 2017 Author Share Posted August 2, 2017 28 minutes ago, al said: though wiht some clarification in the HT room you are pretty much with the ideal harman front back setup and with a bit of a leg up in eq and processing. We went with the 2 best averaged placements out of 14 or 16 (can't remember) potential positions that were measured in the room by Paul Spencer. It was not based on a theoretical setup. Link to comment Share on other sites More sharing options...
blybo Posted August 2, 2017 Author Share Posted August 2, 2017 Anybody forked out the $$$ for the Rel bassline cable? Could you notice a difference? Link to comment Share on other sites More sharing options...
betty boop Posted August 2, 2017 Share Posted August 2, 2017 31 minutes ago, blybo said: Anybody forked out the $$$ for the Rel bassline cable? Could you notice a difference? is that the rel speakon to speaker lead connector ? i would suggest getting it Link to comment Share on other sites More sharing options...
blybo Posted August 2, 2017 Author Share Posted August 2, 2017 18 minutes ago, al said: is that the rel speakon to speaker lead connector ? i would suggest getting it a 10m Speaktron lead comes included and is what I used to demo but there is a very $$$ blue cable which I doubt could give significant improvement, or couldn't be made better for less by someone like Geoff at Aurealis Cables. http://www.audiotrends.com.au/cables-accessories/analogue-cables/subwoofer-cables/rel-bassline-blue-3-metre.html Link to comment Share on other sites More sharing options...
betty boop Posted August 2, 2017 Share Posted August 2, 2017 12 minutes ago, blybo said: a 10m Speaktron lead comes included and is what I used to demo but there is a very $$$ blue cable which I doubt could give significant improvement, or couldn't be made better for less by someone like Geoff at Aurealis Cables. http://www.audiotrends.com.au/cables-accessories/analogue-cables/subwoofer-cables/rel-bassline-blue-3-metre.html i would probably just use the speakon lead included Link to comment Share on other sites More sharing options...
Happy Posted August 2, 2017 Share Posted August 2, 2017 or use the fund to buy a more expensive sub... Link to comment Share on other sites More sharing options...
blybo Posted August 2, 2017 Author Share Posted August 2, 2017 17 minutes ago, Happy said: or use the fund to buy a more expensive sub... That's why I'm considering a S3. Can always sneak a new cable in down the track... if the same colour 1 Link to comment Share on other sites More sharing options...
blybo Posted August 16, 2017 Author Share Posted August 16, 2017 Rel S3 order placed... 1 Link to comment Share on other sites More sharing options...
Happy Posted August 16, 2017 Share Posted August 16, 2017 1 1 Link to comment Share on other sites More sharing options...
blybo Posted August 16, 2017 Author Share Posted August 16, 2017 @Happy, well... it is a 7m x 12m room and I may just put off buying a new integrated for awhile to help ease the pain. Buy well, buy once. 2 Link to comment Share on other sites More sharing options...
Guest Sime Posted August 16, 2017 Share Posted August 16, 2017 Good buy Link to comment Share on other sites More sharing options...
