The Audio Experts
Rotel RMB-1095, 5 Channel Power Amp. $1800
Price: $1800
Producing a full kilowatt (1000 watts!) of output power, Rotel’s RMB-1095 is a stunning realization of Rotel’s capabilities in amplifier design. It is, for all intents and purposes, a multi-channel version of the RB-1080 stereo power amplifier, already recognized as one of the finest amplifiers available at any price. Rated at 200 watts per channel (all 5 channels driven into 8 ohms, 20 Hz – 20 kHz, less than 0.05% THD), the RMB-1095’s power supply is built around two Rotel made 1.2 kVa toroidal transformers. Eight British-made BHC Slit Foil capacitors each with over 15,000 μf of energy storage, combine with thirty 150 watt, 15 amp output devices for uncompressed reproduction of the most dynamic source material. A sophisticated “over current” protection circuit with front panel LED indicators guards against potentially harmful operating conditions. Special “current absorbers” minimize turn-on surges while gold plated balanced XLR and single-ended RCA inputs provide easy connection to a variety of controller / preamplifiers. Heavy rear casters assist in placing the amplifier. RMB 1095 High Current Five Channel Amplifier
Specifications:
Power Configurations:                                              5 x 200 watts
Watts/Channel all channels driven,
unbridged, 8 ohm load, 20 to 20k Hz,
0.06% THD        200 watts
THD (20-20,000Hz) cont. rated power                   0.03%, maximum
IM Distortion (at rated ower, 60Hz:7kHz = 4:1)     0.03%, maximum
Damping Factor (8 ohms)                                        400
Input Sens. / Impedance                                          1.5V / 33 kohms
Frequency Response                                                15-100 kHz (=0.5, -3dB)
S/N Ratio (IHF A)                                                       116dB
Power Consumption                                                 800 watts
Dimensions (W x H x D)                                           433 x 237 x 380mm 17 1/8 x 9 3/8 x 15"
Front Panel Height                                                    221 mm, 8.7"
Weight (net)                                                               34 kg / 75 lbs
Location: The Audio Experts, 03 9545 5152, 2065, Dandenong Road, Clayton, Vic 3168
Price: $1800
Item Condition: Used, in perfect condition slight mark on top see photos (customer trade in), Item can be demonstrated before purchase if desired located in Clayton.
Payment Method: Cash, Bank Deposit, Eftpos or Paypal
Extra Info: Full check done by Rotel Distributor Australia.
Delivery:  Pickup available in Clayton, Postage available at buyers expense.
IMG_0200.thumb.JPG.e6d267f3759a11c481c6ae08c5a2f5b7.JPGIMG_0202.thumb.JPG.a6dfbefa07299058c0074646e52507b3.JPGIMG_0201.thumb.JPG.5af5374a8f07d391b4b8ef1c237f3366.JPG
Edited by The Audio Experts
    • By Conrad
      Item: Relist : TRAM 2 DHT PREAMP
      Price: Reduced to $1800
      Item Condition: Very Good
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal, Bank deposit
      These preamps have a bit of a cult following.
      They present a very transparent and holographic soundstage.
      This preamp has been rebuilt by a very competent technician due to dodgy mods.
      I can supply a receipt for the work done $560 odd from memory.
      It is now fully functional and operating as it should.
      It comes with Limited edition globe 45 Emission Labs tubes which are now unobtainable.
      Also an Emission Labs 274B rectifier.
      These tubes are worth well over $1000
      But wait there's more...I will also throw in a spare pair of National Union  45s.
      There are three different gain level inputs so it can be tailored to match  your system.
      It also has a new Logitech Harmony remote that does volume only.
      Auditions are encouraged.
      A donation will be made upon sale.Thanks for looking.
    • By Yuh
      Item: Panasonic Plasma TV 55 inch TH-P55VT50A 55"
      Price: $400
      Item Condition: Excellent
      Reason for selling: No longer required
      Payment Method: Pickup - Cash only
      Excellent condition plasma TV. This is the premium VT series. Only selling due to upgrade.
      Includes remote, two pairs of 3D glasses, box.
      Due to size, this TV is for pick up only, from Condell Park NSW 2200 (near Bankstown).
      A few people have asked me for the hours on time - I have checked the service menu and it shows 3,053 hours on time, with a times turned on count of 1,775. This is a very low hours on time. These panels are rated for 100,000 hours.
    • By Lovesit
      Item: LUXMAN PD-350 Turntable with LUXMAN TA1 Tonearm made by Micro Seiki and VS 300 Vacuum Stabiliser
      Price: $3800
      Item Condition: Very Good 8/10
      Reason for selling: Regretful Sale, Newborn on the way
      Doesn't get better than this.... VINTAGE RARE ITEM...
      Still RATED the best LUXMAN by Micro Seiki Turntable ever made. Regretful sale have a newborn on the way.. have owned this turntable for 14 years now, second owner has been refurbished and serviced by AUDIO RESTORATIONS.. All CAPS have been changed, amps calibrated to AUS standards 240 Volts, serviced and tested.
      RARE opportunity last time item like this was advertised for sale was 7 years ago.
      DONT MISS OUT...
    • By chimchimster
      Item: Vinyl Records 70s Rock Orig US and Japanese
      Price:  See list
      Reason for selling: NLN
      Payment Method: Shipping or Pickup - Paypal, Bank Transfer or Cash
      Extra Info: Vinyl Records 70s, Rock mostly original 1970s US and some Japanese Vinyl.  If you need more info or pictures of a record, please let me know. I will combine shipping. And, I will of course make a donation to SNA. Cheers!
      Artist                  Album     Year     Cover    Album            Price    Country    Notes
      Big Brother & The Holding Company    Cheap Thrills    1970    VG    VG+    Columbia    KCS9700    $15.00    USA    GateFold Split bottom cover
      Charles Mingus    The Greatest Concert of    1972    VG+    VG+    Prestige    PRST34001    $50.00    USA    3XLP TriFold
      Creedence Clearwater Revival    Bayou Country    1969    GD    VG     Fantasy    8387    $10.00    USA    (Marks on record) Cover splits on bottom and spine
      Emerson, Lake & Palmer    Welcome Back My Friends    1974    EX-    EX    Manticore    P5140~2M    $30.00    Japan    3XLP
      Faces    Long Player    1971    VG    VG+    Warner Brothers    WS1892    $15.00    USA    (Marks on record)
      Greatful Dead    Live / Dead    1970    VG+    VG+    Warner Brothers    2WS1830    $40.00    USA
      Greatful Dead    Anthem Of The Sun    1971    VG    EX-    Warner Brothers    WS1749    $35.00    USA
      Greatful Dead    From The Mars Hotel    1974    EX-    EX-    Greatfull Dead Records    GD102    $25.00    USA
      Greatful Dead    Vitage Dead    1970    VG+    VG+    Sunflower    SUN-5001    $20.00    USA
      Humble Pie    Thunderbox    1974    EX-    VG+    A&M    SP3611    $20.00    USA    Die Cut marks on record
      James Gang    Rides Again    1970    VG+    VG    ABC Records    ABC S-711    $10.00    USA    GateFold marks on record
      Jefferson Airplane    Surrealistic Pillow    1967    VG+    VG     RCA    LPM-3766    $10.00    USA    (Marks on records) Writing on cover
      John Harrison    Creepshow OST    1982    EX-    EX-    Varèse Sarabande    STV81160    $60.00    USA
      Maria Muldaur    Maria Muldaur    1973    EX-    VG+    Warner Brothers    MS2148    $5.00    USA    GateFold (Marks on record)
      Pentangle, The    Sweet Child    1968    VG     VG+    Reprise    6334    $20.00    USA    2XLP GateFold (Top cover 6" seam splits)
      Pink Floyd    Atom Heart Mother    1970    VG+    VG     Harvest    SKAO-382    $35.00    USA
      Pink Floyd    Meddle    1971    VG+    VG+    Harvest    SMAS-832    $40.00    USA
      Rolling Stones    Your Poll Winners    1967    EX-    EX-    London    SLC184    $25.00    Japan    Booklet GateFold Japan Only
      Traffic    Mr Fantasy    1967    VG+    VG+    Island    ILP961    $55.00    UK    GateFold Writing on cover Pink Island Mono
      SOLD
      Beatles    Rubber Soul    1970    EX-    EX+    Apple    AP8156    $15.00    Japan
      Charles Mingus    At The Bohemia    1956    VG    VG    Debut Records    DEB123    $15.00    USA    Marks on Record Pops
      Cream    Wheels Of Fire    1968    VG    VG    Atco    SD2-700    $15.00    USA    2XLP GateFold (Marks on Records) Bottom cover edge 4" split Original stereo pressing on tan/purple ATCO labels, with a reflective silver gatefold cover.
      Pink Floyd    The Dark Side Of The Moon    1973    VG+    VG+    Harvest    SMAS-11163    $35.00    USA
      Yes    Close To The Edge    1972    EX-    VG+    Atlantic    SD7244    $15.00    USA    GateFold Marks on record
      Mountain    Nantucket Sleighrude    1971    VG+    VG+    Windfall    5500    $20.00    USA    2XLP GateFold (4" split bottom) 12 page coloring book and 2 band photos
      Pink Floyd    Wish You Were Here    1975    VG+    VG+    Columbia    PC33453    $35.00    USA
      Yes    Yessong    1973    VG+    EX-    Atlantic    P-5087/89    $40.00    Japan    3XLP
    • By Class A Audio
      Item: PS Audio PerfectWave P10 Power Plant
      Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, Melbourne, VIC, 3168
      Price: $4900 plus shipping
      Item Condition: Excellent, includes original packaging
      Reason for selling: Ex-demo clearance
      Extra Info: From the PS Audio website..."The PerfectWave P10 is the largest and most advanced high-end personal power generating station in the world. Capable of powering any size system with pure sine wave power, generated internally with a fully analog power amplifier, the P10 brings forth all that’s possible from your system and ensures you get the same great performance every time you listen.
      The P10 is our biggest and best Power Plant yet. With 5 separate regenerated zones and 1500 watts of pure regenerated power, the P10 can handle any size system you want to power. From medium to large power amplifiers to the smallest pieces of source equipment, the P10 will work magic on your system’s performance. Only the very finest high-end system around the world use the P10 Power Plant and this is the piece to strive for.
      With your system powered directly from the output of the P10, dynamics and openness are breathtaking. New voices, new harmonics and a renewed sense of musicality are yours the moment the P10 starts up. This is one of the most important pieces of audio equipment you can own, building a firm and reliable foundation for your system that will serve you for years to come.
