Jone5y
FOUND: Entry Level Turntable
Item: Turntable (and possible amp or phono stage)
Price Range: up to $350
Item Condition: Used
Extra Info: Looking to piece together system for my parents. Budget dictates it will be very entry level. They would be happy with something that just spun the black discs and made some noise. We all know that attitude simply won't do and, with mum threatening to buy a record player from Kmart or BigW, something needs to be done. I don't know what they played vinyl on back in the day but i know it played ALL the time. The last setup they had was an all in one 'hifi' system made by Sony that was purchased at a big box store.
I've searched far and wide on this site to try and educate myself and realise that used is the way to go. However, the water gets very murky from there. Every opinion on Rega/Pro-ject/Audio Technica has an equally strong opponent and the same goes for belt vs DD etc, etc. Not having a vinyl rig myself i don't have any experience of my own to draw on and don't know why i should or shouldn't choose a denon pl30 over a technics 212 or a Rega RP1 and so on. I'm hoping the wise folk here can help me out. My experience thus far has been: find option available for sale, see what google says, search for stereonet results, discover it's junk or is good but out of budget, go back to drawing board. I'm hoping by posting this WTB i can end that loop.
Basically the requirements are (in rough order of priority)
  • Cost. One constant in turntable threads is the call to increase ones budget. Mine is pretty fixed.
  • Reliability/Automation. The olds, whilst very technically minded in some areas, don't tolerate unreliable tech (the sony unit mentioned earlier is now at the tip, speakers and all). I don't know if full or semi auto tables were the norm back in the 80's but if they aren't fraught with issues i'd probably lean that way
  • Looks. minimalist or classic (think wooden plinth as opposed to plastic DJ style) preferred
  • Phono. I have an unused Cambridge Audio 340a integrated amp that will accompany the turntable. As such an external phono stage will be required. Whether a cheap new one is better than an old built in unit I don't know, you probably will. If the difference between inbuilt and outboard isn't much I'll go with inbuilt as it is one less box. Another option is to sell the cambridge and source an amp with inbuilt phono. I've been looking at these on Ebay for a while and.....
  • Ability to modify. If it is able to be or benefits from a new plinth or some other kind of woodwork oriented DIY I'd love to put my own stamp on it
  • Sound quality and upgrade potential. This unit will not be upgraded until it dies so that's not a factor. Obviously i want the system to sound as good as possible but for the users "good" sound quality will be good enough
I think that covers it (a lot of words for a couple of hundred bucks i know!). Let me know what you've got squirreled away in a cupboard somewhere or are looking to upgrade from and lets see if we can do a deal.
At that budget you're just going to have to trawl the classifieds and take what you can get I think.
Hard to be fussy with such a strict budget, but I understand the limitations you face.
In the Rega/Pro-Ject/Audio Technica category there is also Music Hall - but again, being fairly new to market it's unlikely you'll find something second hand.
Best bet, I think is a cheapy Rega and an AVR with in-built MM phono stage. $500 would likely yield a slightly larger cast net.
Here's one to look at:
Thanks Marc, it's now on the list.
I realise my ask is a big one and beggers can't be choosers.
If I manage to sell off something i don't need I'll revise the budget to cast a wider net
What about a Denon DP-30Lii or Pro-Ject Debut III for about the same money, are either of those worthwhile pursuing?
Edited by Jone5y
Just to clarify, is the budget for just the turntable $350, then the amp or phono stage on top of that?
Or $350 for the lot?
Looking to get turntable and phono for around $350. Amp is excluded from the budget, i have that already. If i find a decent amp with phono for under $200 i will sell existing amp and use all $350 for TT
ah OK that makes sense. I was going to post the link to my gumtree advert (that I PM'd you about) here to let others comment on whether it is any good for your requirements, but if you bought the amp, then you'd be better off buying a better turntable.
I see, i see. I did have a look at your ad and had the same thought
Guest Hensa
This is a respectable turntable:
http://www.ebay.com.au/itm/Vintage-Yamaha-Turntable-/252790949451?hash=item3adb83c64b:g:TTkAAOSwTM5YtROG
I set up one of these for a friend's parents - pretty basic but they love it:
http://www.ebay.com.au/itm/Vintage-Pioneer-Turntable-SPL-100-Japan-/182428937217?hash=item2a799cac01:g:7xYAAOSw-0xYQe0R
For ultimate simplicity (full auto, p-mount cartridge) look for a Technics SL-7 though may be hard to find under $350 but they do come up occasionally.
Thanks @Hensa , i hadn't considered Yamaha.
I probably should have split reliability and automation in my original post - reliability is weighted much higher. Auto would be nice but not essential. "P mount" yet another thing I'm clueless on. You've now given me something else to research.
I can see what is going to end up happening.....all of this googlin, learning and ogling at nice looking TT's is going to get me interested in the dark side. Who knows what will happen when i purchase something and give it a spin in my system
is a lightly used Audio Technica LP120 USB @ $200 a decent buy? It's not the prettiest and the USB wont be required but is it worth a look?
Hi
Current new ones are about $450, so depending on cartridge may be OK....
JJ
Thanks JJ, Just went to check and the ad has been removed.  FWIW I'm pretty sure it was Ortofon and green in colour
A couple of "DUAL" models have popped up in recent searches and some seem to meet most requirements. I knew nothing of their existence before this morning. From what i can tell they were a mid level offering when new and there a couple of models to leave well alone due to well documented faults. Does anyone have any experience with Dual TT's that are worth keeping an eye out for or opinions on them in general?
I have a Dual 603.  It's pretty basic, but it sounds good.  The Dual 601 and 701 are reasonably well regarded, certainly better than my 603.  The big weakness with the Dual TT's is their arm.  That is what holds them back sonically from what I understand.  I'm only familiar with the 600 and 700 series - I can't offer anything constructive about other models.  The 600's and 700's are pretty much bullet proof and many models are automatic or semi automatic.  Any of them would keep your folks happy.  I'm not too sure how well they respond to custom upgrades as I've never bothered - I've since bought another TT.
@Zaphod Beeblebrox has serviced hundreds of Dual TT's over the years and may be able to offer more specific advice.
I have a Pro-Ject Debut Carbon in blue and a Pro-Ject Tube Box S that I will be looking to sell soon. Let me know if you're interested :)
Definitely interested. Currently tossing up between a vintage denon (pl30ii) and another Project debut carbon I've found. feel free to send me a PM with details
Quick update on this, after being comprehensively outbid on numerous TT's I snagged a Denon DP30L-ii for a tick over $100. It runs, is semi auto and keeps a constant speed.  It will feed into a cambridge audio 340A via a sub $100 used phono of some sort, probably Pro-ject or NAD.
    • By Anton70
      Item Condition: Excellent Shipping Options: Shipping is included in price. Suburb or Town: Brighton State: Victoria Payment Method: PayPal Reason for selling: Upgrade Further information:
      Excellent condition phono stage. Great little phono stage.
      Dip switched so you can adjust to suit your cartridge (this is great).
      Black model, all like new in original box with paperwork, power supply etc.
      Sorry pickup not available with lockdown so post is included in price
      PLEASE READ
    • By hugo_wilco
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal EFT cash on pickup Reason for selling: Funds required Further information: This is the latest version and one of the first in the country. It is less then 2 months old.
      One thing I have learnt is that it doesn’t matter how good your arm TT or cartridge is, if you’re phono stage isn’t up to the task you are wasting money and forever chopping and changing.
      This was already a great phono stage but this version has a much more natural and warm presentation. It bested my valve phono stages by a considerable amount.
      It has XLR out too!
      I am actually really reluctant to sell this out of all the items I listed. It can get the most out of ANY cartridge hooked up to it.
      I have all boxes etc.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2-mkii
    • By haygeebaby
      Item Condition: Perfect - used Shipping Options: Pickup available and you can audition. Suburb or Town: Perth State: Western Australia Payment Method: EFT, Cash on Pickup Reason for selling: Upgrading
      Re-post - price is negotiable / offers welcome.
      Purchased new from local supplier just over 3 years ago.
      Still using stock tubes with total hour count of 1,625 hours over 3 years.
      Unit is in perfect working condition and is pristine in appearance.
      Unit is complete with manual, QC sheets, power cable, screw driver, remote control, and original box. Remote control has hardly been used at all.
      Also have a full set of spare tubes for the unit which are brand new – Sovtek 1 x 6550WE, and 4 x 6H30.
      Really loved this unit. Very good user interface. Impedance changing on the fly, auto shut off, display dimming, new/current ARC styling, solid metal remote control.
      Fixed gain of 55db. Have used with several cartridges with wonderful sounding results – including Benz Micro Wood S L (0.4mv) and EMT JSD P6.0 (1.05mv).
      Loading range 47k, 1000, 500, 200, 100 Ohms.
    • By tachi
      Item Condition: Good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Huntingdale State: Western Australia Payment Method: Paypal, EFT Reason for selling: Moving on Further information: This is a MMF 9.1, bought in Singapore. The main difference between this model and the Australia model is the motor. It uses a 16V ac motor. I  have been using it for the past 6 years' without any issue.
      Specifications
      Triple Plinth
      Drive method: belt drive
      Motor: 16 V ac motor
      Platter: 1" Acrylic
      Speeds: 33 and 45rpm
      Tonearm: Project 9cc (carbon fibre)
      Price includes a fully functionable turntable with dust cover and please note that no cartridge is included. For a detail review, please refer to:
      http://www.stereomojo.com/MusicHallMMF9.1Turntable Review/MusicHallMMF9.1TurntableReview.htm
    • By hugo_wilco
      Item Condition: Excellent just a bit of dust Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Eft Paypal Cash on pickup Reason for selling: Funds required Further information:
      Unfortunately due to Pandemic I am forced to sell my gear. This is my favourite TT and has been the longest I’ve had. This TT is phenomenal and I don’t  I want to let this go but don’t have a choice.
      The Ref2 is the latest with the updated power supply.
      Purchased from the wonderful guys at Sonic Purity.
      Will be selling  Phono stage separately
      Your chance to get an endgame TT package at nearly Half  price!!!!
      RRP: $14,900
      Buyer to pay out of pocket Paypal fees.
      Will be boxed so can arrange freight to interstate.
      TURNTABLE ONLY FOR SALE
      Have all boxes and packaging. Will be boxing them in the next few days Nd will post photos.
