CollisCollis
FS: Naim Audio Stageline Phonostage
Item: Naim Audio Stageline Phonostage for Moving Magnet(N)
Price: $425
Item Condition:Mint
Reason for selling:Now using an MC cartridge
Payment Method: Pickup - Cash, Paypal or Direct Deposit
Extra Info:This is a fabulous Phonostage that will bring your vinyl to life.Comes with original box, manual ,receipts etc. Mint condition..unmarked.Current retail is $800
Edited by CollisCollis
Hey I don’t suppose this is still available ??
    • By Famo
      Item: Transmission line cabinets 8-inch 2-way
      Price: $25
      Item Condition: Very good
      Reason for selling: NLR
      Extra Info: 8-inch 2-way Transmission line cabinets. Very Solid. About 1-metre tall
    • By Famo
      Item: jamo sub for repair or spares
      Price: $25
      Item Condition: Jamo sub needs a new plate amp
      Reason for selling:
      Extra Info: jamo sub, box in very god condition. Plate amp needs repair or replacement
      Photos
    • By caleb
      Item: Mad Scientist Audio BlackPod Mini Tungsten Carbide Audio Footers 3pcs set
      Price: $100 plus $10 post
      Item Condition:7/10(has some scratches and wears on one of the tc ball but works fine)
      Reason for selling:no longer required
      Mad blackpod mini tungsten Carbide for sale in great working condition.I found it great  under sources.
      Exactly the same quality built compared to the standard tc version but in smaller fraction.
      Here's more info and reviews
      http://www.madscientist-audio.com/blackpodmini.html
      http://www.hifi-advice.com/blog/review/accessories-reviews/mad-scientist-audio-blackpods/
    • By SoundGuy
      Price: $12,000 $10,500 $9700
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By mtan002
      Item: Music Appreciation Appreciation 8th Edition + Multimedia Companion V4.5
      Price: $40 + Actual postage
      Item Condition: Used
      Payment Method: Paypal or cash on pickup
      This book is in fair condition with cover and all pages intact.
      The Multimedia Companion is in good condition.
      You pay actual postage based on your location.
