mcb
FS: Arion HS-500 Mono Block Amplifiers
Item: Pair of Arion HS-500 Mono Block Amplifiers fitted with Duelund VSF capacitor each and upgraded valves.
Item Condition: Excellent
Reason for selling: Now running big valve mono blocks
Price: $3500, Pick-Up (freight can be arranged at purchaser’s expense)
Payment Method: Cash on Pickup
The HS-500’s are a Vacuum Tube / Class-D Hybrid Monoblock Power Amplifiers.  Further spec’s below.
I purchased these amps new from Lenehan Audio in February 2014, fitted with VSF Duelund capacitors.  I have since added a matched pair of Cryoset treated Electro Harmonix  6H30Pi EB Gold Pin valves in lieu of the standard valves.
These amps where purchased to replace a highly modified Mingda MC34AB amp and have been used to drive my Lenehan ML2’s. They would have continued to remain in my system, had I not taken up the opportunity to try a pair of 200 watt monster valve monoblock room heaters.
Includes original packing boxes and manuals.
The current replacement price is US$6295 + freight + 10% + other import costs.
Happy to demo in Perth metro area.
Comments from SNA members on HS-500’s - http://www.stereo.net.au/forums/topic/46896-arion-hs-500-amp/
External Review - http://www.enjoythemusic.com/magazine/equipment/1010/arion_audio_rs_500.htm
HS-500 Amplifier Specifications
Rated Power @ 8 Ohms : 500 Watts
Rated Power @ 4 Ohms : 1000 Watts
Sensitivity : 1.8 Vrms
Gain : High gain (approx. 29dB) and low gain (approx. 25dB) settings. Currently set on low gain.
Frequency Response: 20Hz – 20KHz +/-0.5dB
Input Impedance : 200K Ohms
Damping Factor : 900 Ref @ 8 Ohms
Maximum Output Current : 35 Amps
Tube : 6H30
Dimensions : 9.75 in W x 4.75 in H x 14 in D (24.8cm x 12.1cm x 35.6cm)
Weight : 22 Lbs (10kg) each
2 hours ago, Vqya23N4086e said:
@mcb PM sent.
Thanks, response sent.
Now Sold.
    • By Somethingclever
      Item: Pair of Duelund 3.3uf 630 vDc CAST Pure Copper Foil
      Price:  800 ono ( Happy to post at buyers expense )
      Item Condition: Very Good
      Reason for selling: Change
      Extra Info: To quote Benjet who sold something similar..."If you know what these are then you don’t need me telling you all about them. If you don’t know them you probably don’t need them."
      Currently in use, will demount them when sold.
      These top of the line Duelunds were worth about 600 to 700 each when new as far as I can tell.
    • By Benjet
      Item: Duelund VSF 2.2uf 400v Capacitors
      Price: $475 for the pair
      Reason for selling: Surplus
      Payment Method: Pickup - Cash, Paypal (buyer pays fees)
      Extra Info: If you know what these are then you don’t need me telling you all about them. If you don’t them you probably don’t need them.
    • By Bill125812
      Item:  Duelund twisted pair Speaker Cable 2.5m
      Price: free.  Nothing inc postage
      Item Condition: perfect
      Reason for selling: NLR
      Extra Info: I made these up just as trial.  Very good but not quite what I was looking for.  They have Straightwire bananas   I also sheathed then in tech flex
    • By mcb
      Price: $3750  $3500, Pick-Up (freight can be arranged at purchaser’s expense)
      Tube : 6H30
    • By Tax
      Has anyone had a play with the Duelund RS capacitors?
      I am going to install a couple of these in the first stage of the Lamm LP2. I already have VSF's in the second stage.
      Can they be installed upside down on on their side, will this cause any leakage issues?
      Is there a preferred orientation with the leads to signal/impedance etc?
      t
