Followers
0
EXPIRED: FS: Tube Headphone Amp w/ Pre-amp Gold match with LCD3/2
By
hakiu, in Classifieds - Audio
Recently Browsing 0 members
Similar Content
By Ewok209
Item: xDuoo TA-01
Price: $85 + $15 postage
Item Condition: Good used condition
I purchased this dac/amp to use with my Beyerdynamic DT990 but I'm heading back towards IEMs. The blue LED power light no longer works but fully functional otherwise. The sound is quite mature and detailed, has a nice vibe , separation, layering and soundstage are all impressive for its price point. You can tube roll if you like (included tube is Electro Harmonics) it uses dual Wolfson DACs, the RCA on the back doubles as an input/output when no USB cable is plugged in so you can use the unit as a DAC or stand alone headphone amp.
Included is the dac/amp, power supply and USB cable.
Specs:
Aluminum chassis Dual Wolfson WM8470 DAC chips XMOS USB chip Supports up to 192 kHz/24-bit playback Asynchronous USB 2.0 transmission 12AU7 tube Transistors for class-A buffer Supports ASIO, KS, and WASAPI modes Inputs: USB 2.0, RCA (L, R) Output: ¼ in (6.3 mm) headphone jack, RCA (L, R) Operating voltage: DC 12 V Frequency response: AMP 10 Hz – 100 kHz +/- 0.5 dB; USB 20 Hz – 20 kHz +/- 0.5 dB USB sample rate: 16 – 24 bit; 44.1, 48, 88.2, 96, 176.4, 192 kHz Distortion: 0.03% (1 kHz) Output power: 2100 mW (32-ohm load) Gain: +6 / +17 dB Crosstalk: 110 dB Impedance: 16 – 600 ohm Dimensions: 5.5 x 3.2 x 3.2 in (14 x 8 x 8.2 cm) Weight: 14.5 oz (410 g)
By Bengineer
Item: JDS Element Headphone DAC & Amp
Price: $300 pu/pp
Item Condition: Real good. 2 years old.
Reason for selling: Upgraded
Bought August 2017 direct from JDS. It has the Australian adapter, ring colour is red (thin part around the knob)
Has USB in. RCA in. RCA out. High/Low Gain toggle. Accepts 6.5mm single ended.
By hugomac
Item: Mark Levinson No.27 ***PRICE REDUCTION***
Price: $3600
Item Condition: Excellent
Extra Info: Recently spent over $2000 fully restoring this superb ML Amplifier, work carried out by Sydney Mark Levinson dealer, over 20 Capacitors replaced. Sounds absolutely sublime better than current ML Amps. Upgraded to BAT VK655SE.
By audiodyna
Item: (1) Purist Audio Maximus RCA interconnect, (2) Apogee Electronic A-110 XLR interconnect, (3) XLO Type 2 Reference XLR Interconnect
Price: (1) $400.00 , (2) $350.00, (3) $350.00.00 (Postage not included)
Item Condition: (1) 7/10, (2) 8/10, (3) 9/10
Reason for selling: NLR
Extra Info: All these cables are 1.5 meter in length, in good working condition as been shown in photos.
(1) Purist Audio Maximus interconnect cable was originally filled with oil/fluid inside the shielded tube when new, but has dried up now.
It will be sold as it is.
(2) Apogee Electronic is famous for its digital equipment like DAC and cables which are normally used in recording studio, not the same company as the one manufacturing speaker.
(3) XLO type 2 Reference Series XLR interconnect cable are very fast and dynamic, suitable for valve system.
All these cable do not have original packing box but will be packed with extra care if transportation to other states is required.
By auditec
Item: 1
Price: $ 150
Item Condition: Used in excellent condition.
Extra Info: 1.8 M long power cable with neutral sonic quality. Terminated with US power plug and IEC socket.
Can send to anywhere at buyer's expense.
$10 donation to SNA when sold.
