Tony Cox Posted June 12, 2017 Share Posted June 12, 2017 SOLD Item: CAMBRIDGE AUDIO CXU universal disc playerLocation: South Yarra, VicPrice: $800Item Condition: Excellent - has had only very light useReason for selling: surplus to requirementsPayment Method: Pickup - COD OnlyExtra Info: Disc types: Blu-ray (BD) including BD-3D, DVD, DVD-A, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD+-R/RW, DVD+-R DL, BD-R/RE The CXU is the pinnacle in high-end home cinema. Designed for the ultimate performance and playback of movies and music, the CXU has unrivalled connectivity making it a complete home cinema hub, whatever your source. Incredible audio performance from 5 separate Wolfson DACs and ATF upsamplingVivid, detailed video from DARBEE Visual Presence technologyWide variety of inputs to handle any audio-visual source NETWORK PLAYBACK CXU also has a wired or wireless network connection. This means it can connect to your home network and play back audio, video or photo files from UPnP and DLNA servers and from NAS drives. TWIN OUTPUTS Separately configurable, twin HDMI outputs, send high quality video to multiple displays or 3D video to a display and separate HDMI audio to a non-3D AV receiver. An Audio Return Channel (ARC) is built in too, allowing the audio signal from a connected TV to be sent to the CXU with no need for a separate audio output from the TV. DARBEE VISUAL PRESENCE DARBEE Visual Presence technology can be adjusted for any digital content. DARBEE Visual Presence technology can be adjusted for any digital content. Processing is adjustable, allowing you to customise the visual enhancement to suit your needs. And for ultimate flexibility, you can set your preferred DARBEE mode individually for each of the different video inputs. EASY TO USE An intuitive on-screen colour display and simple, user-friendly controls, plus an easy to use backlit remote, mean all of CXU’s features are easy to use, even in the dark. The remote control for the CXU will also control the matching Cambridge Audio AVR or hi-fi amplifier. ANALOGUE SUPERIORITY Make the most of the Wolfson DACs and audio upsampling on-board, by connecting the multichannel analogue audio outputs to the multichannel inputs of the perfectly matched CXR200 AV Receiver, for the highest quality digital to analogue conversion and 24-bit/192kHz audio upsampling. DIGITAL VOLUME CONTROL The CXU can be connected directly to a power amplifier or active speakers for a simple and highly versatile system, with no worries about volume control. Whether using digital or analogue outputs, you can control volume (even on 7.1 and 2.0) set ups direct from the CXU remote. Video outputs:2 x HDMI 1.4a with ARC Audio outputs:7.1 multichannel analogue RCA/Phono output, 1 x S/PDIF, 1 x TOSLINK, Dedicated 2 channel stereo analogue RCA/Phono output HDMI inputs:2 x 1.4a (one with MHL compatibility via the front panel) Audio inputs:1 x S/PDIF, 1 x TOSLINK D/A converters:5 x Wolfson WM8740 24-bit/192kHz DACs Decoder:Mediatek MTK8580 Audio Up-SamplerAnalog Devices DSP running Anagram Technologies (TM) Q5 up-sampling to 24 bit/192kHz (All 10 channels) Video processor:DARBEE Visual Presence (on primary output) External storage:3 x USB 2.0 Network:Ethernet: 100BASE-T, Wi-fi: 802.11 b/g/n via supplied dongle. 2.4GHz Maximum power consumption:35W Standby power consumption: <0.5W Dimensions (H x W x D) 82 x 430 x 312mm (3.2 x 16.9 x 12.3’’) with feet Weight:5.0kg (11.0lbs) Pictures: 1 Link to comment Share on other sites More sharing options...
AMCNAD Posted June 13, 2017 Share Posted June 13, 2017 a shame this was released just as 4K was coming out, great little spinner, GLWS Link to comment Share on other sites More sharing options...
Special K Posted June 23, 2017 Share Posted June 23, 2017 PM sent re price. Sent from Tapatalk Link to comment Share on other sites More sharing options...
Tony Cox Posted September 4, 2017 Author Share Posted September 4, 2017 Sold on eBay 04/09/2017. Link to comment Share on other sites More sharing options...
