thathifiguy
Iso Acoustics Gaia Speaker Isolation
I picked up a couple sets of the Gaia 3 units (support speakers up to 32kg) yesterday and set them up last night on my PSB Synchrony One towers (not without a few curse words along the way).
I'd been hearing a lot of good things about them, so decided to bite.
Early signs are very positive so far. Played a number of my regular tracks and all sounded more open and bigger than they ever have.
For those that aren't aware, Iso Acoustics have done speaker isolation for studio monitors for years, though I believe these Gaia units are their first real dip into the world of home hi-fi speakers.
The idea behind them:
“When a speaker is placed on a hard surface, secondary internal reflections result. Any artifacts of this smear that is similar in the two channels is perceived to be in the center, causing the sound stage to collapse. The GAIA series of isolators eliminates this smear resulting in a larger 3-dimensional sound stage.”
They seem to be spring loaded in some way/shape or form as upon initial installation, I was a little nervous about the 'wobble', but after some time toying with them  it appears that is how they are meant to be.
Will do more listening over the weekend, but so far pretty happy with the investment!
One word of caution, the base of the Gaia Isolators appear to be some sort of sorbothane/similar material and thus left some 'moisture' marks on my bluestone slabs that I sit the speakers on. Not an issue for me, but could be for someone putting on expensive floors.
More details about them can be found here.
I just started a thread about these and similar products for speakers and electronics here https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fwww%2Estereo%2Enet%2Eau%2Fforums%2Findex%2Ephp%3F%2Ftopic%2F124201-Electronics-and-Speaker-Tweaks%2FIsolation-etc&share_tid=124201&share_fid=46070&share_type=t
Electronics and Speaker Tweaks/Isolation etc
This is excellent timing thanks for posting. Have you also noticed if less sound is travelling into other areas of the house?
Sent from my JAZZ using Tapatalk
Can't say I have been that observant yet, but I'll be sure to keep my ear out!
I just ordered some Gaia 1's for my personal Amphion Krypton 3's. I'll let you know how they come up...
Won't they alter the level of the tweeter by some distance?
The Designers of speakers would be careful to get the level correct on their speakers for the seating position, so I would of thought.
Or is it all ok as the distance is not too bad.
Edited by rocky500
9 minutes ago, rocky500 said:
Won't they alter the level of the tweeter by quite a distance?
I can't imagine it having much of an effect.
My spikes already had the speakers sitting a few centimetres from the floor, at worst the Gaia 3's may add an extra centimetre.
You can always adjust for this by having the rear ones sit slightly higher to give a slight forward tilt should you need it.
Edited by thathifiguy
If you think it's that critical perhaps you should put some under your listening chair as well to match. :sarc:
It depends how tall you sit and the height of the chair anyhow.
I have the Gaia 3's under my subs and main speakers. I noticed a big improvement in bass and dynamics - really what their ad said it would do. The 'springs' resonate at an extreme low frequency so as not to be heard by the human ear. They are supposed be capable of tiny wobble from front to back and vice versa and in that horizontal plane i.e. same direction that the speaker cone moves - front/back direction
Bob
Edited by Heifetz
@Magenta how did the Gaia feet perform?
Gambled and tried them under my pair of Quad 57 ESL speakers on metal stands. I was not sure how they would go with non box speakers but was pleasantly suprised. The bass was cleaner and appeared a little deeper and there was a definite increase in the soundstage width and depth. One of my better tweaks.
I will try them with my stacked pair when my second set returns from being reconditioned  by John Hall.
Hi all. I've got a set of Gaia II's under my speakers.
My setup is highly modded Mac Mini with Liner Power Supply, Chord 2Qute Dac, OAD Pre and Power Amp, with all the pre-requsite 'hi-fi' cabling all plugged into a PS Audio P3. This is all playing through Dynaudio Focus 380 speakers, standing on a wooden floor.
With a bit of sweat, effort, and alot of swearing I managed to install the Gaia's.
My first response was 'whoa'. Everything was better defined... infact the sound coming out of my speakers displayed increased resolution, more focused imaging and improved soundstage. I thought what a huge improvement. But after some time listening I found the sound hard and dry, and I began to worry I've spent a not inconsiderable amount on an expensive tweak that didn't work well with my system. I'd lost the beautiful midrange and smoothness my system used to have.
So I sat down and tried to work out what was going on. I've read that Nordost design their cables to introduce 'distortion' (I'm probably quoting what I read wrong), and we know that many Valve amps in the past quiet easily introduced distortion into the sound that many find pleasing. I was wondering, maybe the distortion I had was more appealing, maybe I need to re-introduce distortion into my system some how... after sitting and listening to my system and thinking about my problem, I luckily stopped my silly thoughts and decided to take another approach. I came up with another hypothesis that because I had moved recently and hadnt set up my equipment racks, and all of my equipment was sitting on hard heavy cabinets that was storing vibrations from the sound coming from the speakers, and in-turn was introducing distortion into my components in a feedback loop. This created a kind of smearing, which wasnt unpleasant - maybe similar in effect what happens to valve amps when distortion is introduced and colours the sound with a 'warm' glow.
So I set about pulling out all my isolation platforms and accessories, got my Mac Mini, dac and amplifiers isolated and bang, the sound smoothed out. Now all the gains I perceived - increased resolution, more focused imaging and improved soundstage - was emphasised and the smoothness and warmth returned to my system. As an added benefit the bass sounds clearer, more controlled and more extended. I couldnt go back to living without the Gaia II's now that I have heard such a big improvement to my system. I can highly recommend them.
So to sum up I'm extremely impressed and happy with the obvious and sizeable improvements to my system. I'd highly recommend the Gaia's to people who have already gone beyond mid-fi, have a system that is revealing of component changes, and looking to tweak out improvement gains in their systems. I'd suggest this might be an expensive tweak for people who have only spent a couple of grand on their system as it costs around $850 for a set of 8 feet. It would still work but I'd spend my money on getting better equipment first.  And before installing the Gaia's you need to ensure your components, cabling, isolation etc is all sorted as the sound could become revealing of distortion and noise in your equipment.
I added the Gaia II under my Whatmough P33 signature speakers sitting on a floating wood floor. I found they opened up the soundstage resulting in a perceived improvement in the clarity of vocals that normally sit centre stage.
They do have a suction cup type effect which sticks the speaker to the floor and allows some alarming movement left to right. This makes it harder to move the speakers around but also makes it far less likely that anyone can ever accidentally knock them over. A definite bonus for tall, narrow speakers like these.
@Max HeadroomThanks for that post. Very informative. My speakers require the Gaia 1 which as far as I can see will cost AUD2,000. Where did you get yours from? I thought 8 Gaia 2 feet cost a lot more than $850.
Edited by amdan
Alert origina poster
I bought mine from Sydney HiFi Castle Hill. Just looking at their website, they’re still selling 8 Gaia II feet for $806. There’s a big jump in price to the Gaia I though at $1899.
I’ve been living with the Gaia 3’s for more than 6 months now. Sitting under a pair of Elac 407’s.
Pretty well same results as mentioned above - better defined transients, especially in the lower frequency range, imaging less ‘fuzzy’, soundstage overall a little bit cleaner with the sound appearing a little bit more lively.
The other thing I will add is that the speakers have disappeared that little bit more with the Gaia’s.
They are certainly staying in my system.
I'll need adapter plates to which brings my cost to over$2000. Not sure it will be worth that much! Shame I can't try before buying.
Sounds like you'll be better off with townshend podiums.
I bought a set of Gaia 2s at the hifi show last year. The standard bolts don't fit my speakers and I'm only just now getting it sorted. Got a call today from convoy saying that isoacoustics will have to special make bolts for me.
Hopefully one day soon I'll get them on
I got a set for my Spatial M3's for my birthday last week. Everything you have is what I have found. My speakers were always pretty good at disappearing, now they are awesome. I'm getting better micro detail and more nuances to every note
After a fellow forum member @Happy Sacks sang high praises about the Gaias, and after seeing positive feedback on this thread and also from my AV dealer I've decided to go for it as well. Gaias II is what I will need, just waiting for stock.
What are people's view of the carpet spikes? My carpet is just regular thin loop carpet. Do you think the spikes are necessary?
Edited by Ed Sky
I am really happy with my 2s and same experiences as above.
I think I have similar carpet to you and it's fine. I spoke with Convoy about this and they said the spikes are more for very thick carpet and or underlay.
Thanks for the feedback. I'll get them without the spikes then. @Happy Sacks recommended coasters from Bunnings as an alternative to spikes as well.
You will get better results using the dedicated carpet spikes, but you can use 60mm clear spiked castor cups if you can't afford them as a temporary solution. GAIAs work best whey they have a suitable surface to adhere to.
Thanks @Happy Sacks, that's a great hack! I assume this is the product you're referring to: https://www.bunnings.com.au/surface-gard-60mm-round-spike-castor-cups-clear_p4050163.
Hi Guys,
I keep looking at these but my speakers are 32kgs which should mean, according to Isoacoustics the Gaia II’s but that would cost just under $1k....I can’t do that, considering my speakers cost me $3,300!
But, if I can use Gaia III’s, which are rated to 30kg’s then I could afford them, has anyone used the III’s on 30+ kg speakers?
Matt
    • By Assisi
      I can appreciate the intention of some SNA members who have over recent times minimised and simplified their respective systems.  Less can be better.  I have gone in the opposite direction.  I like to tweak and try things to see what may happen and if there is a beneficial outcome.  There are consequences to my direction.  Stuff and more stuff.
      My system has expanded, developed and evolved over the past 10 years.  It is a bit like the kitchen pantry with packets of stuff in the back out of sight that are about to become museum pieces.  Things are put in there that get forgotten about.  With the help of my system curator (he did most of the work) my entire audio system was dismantled, cleaned, dusted and vacuumed at the weekend.  Then just the integral components and cables were put back.  Nothing else.  Turned all the components on and fortunately there was music.  All the accessories, tweaks and whatever where all left out!
      The photo below shows all the accessories etc on a table that were left over at this time.  There are few more things than I expected.  I have a tendency to collect.  Not included in the photo are two largish power supplies that are used to power network converters and Synergistic cables and Tranquility bases. Over time most of what is on the table will be reintroduced, one piece or set at a time so that I can evaluate the benefits or otherwise.
      Are there other members out there whose systems have developed as mine has?  I have never had a specific objective or plan to get to where I have.  Things just happened.  I tend to follow my intuition.  It will be interesting as the accessories are reintroduced to hear whether they are a benefit or not.
      John
    • By jason101
      Item: Isoacoustics Gaia footers model I or II
      Price Range: less than RRP
      Item Condition: Anywhere from very good upwards
      Looking for a set of Gaia footers to try with my Sopra N2. They weigh 55kg each, right on the spec difference between the I and II models (latter for speakers up to 54kg).
      I need two sets (one for each speaker), and to have them posted to NZ.
      Greatly appreciate any assistance from the SNA community
      Thanks!
    • By harmo_hammer
      Hi All,
      I've owned many cameras, and occasionally, I find a new feature, trick, hidden setting, from merely navigating the menus, updating firmware, or installing software onto the SD Card. I just had another one, so I thought I'd start a this little topic.
      Canon Powershot Users:
      If you happen to own a Canon PowerShot compact, or hybrid camera (basically anything other than a DSLR) then I highly recommend that you look at http://chdk.wikia.com/wiki/CHDK. Even if your camera is old, (I used it on an old Canon PowerShot S5IS that I bought back in 2007) they support a number of models (see the CHDK site for a list). Basically, you copy some software to your memory card, and this enables a variety of features that your camera may not have. Features include the addition of raw photo capability, extending shutter options (think 1/100 000th of a second), and the software also gives you the ability to make your own cheap USB port shutter release, amongst others.
      The great thing about CHDK is that there's practically no risk to your camera. If you don't like what it does, simply remove your memory card and you're back to normal settings. Please note that the raw images (if your camera doesn't already have raw capability) may need to be converted before you can process (or view) your images. See the CHDK site for more details.
      Canon 5D Mk III Users:
      AEB Expansion:
      Firstly, when I bought my 5D, the Auto Exposure Bracketing  (AEB) used in High Dynamic Range (HDR) shots could only do 3 shots per bracket. By updating the firmware for the 5D, I could suddenly choose between 3, 5, and 7 shots per bracket. So it's worth updating your firmware to see what has been improved.
      ISO Range Expansion (Specifically, ISO 50 on a 5D Mk III):
      Canon cameras have often started at an ISO 100 and gone up to 3200, 6400 and beyond (depending on model). While I rarely have any need whatsoever to go beyond the default upper limits of ISO, I occasionally wish I could lower ISO for long exposures at night to reduce noise. Great news, you can set the minimum ISO to 50 on a 5D mkIII by simply following these instructions:
      1. Enter the menu.
      2. In the camera section (red), go to the second tab, and select "ISO Speed Settings" (This lets you to configure the max and minimum range).
      3. Select the 100, and dial it down to 50. (I found that the option to lower this is not obvious, I thought it'd already be at the bottom).
      4. Exit the menu.
      5. Dial your iso to 50. On the camera, it will display "L" for low, not 50, so don't stress if you don't see the number as expected.
      DSLR Users (In General):
      Back Button Focusing:
      By default, most DSLRs and many not-quite-DSLR cameras use the shutter button as both the focus and shutter control. However, if you're taking multiple shots of the same thing and just changing composition each time, the default configuration will tell the camera to re-focus for each shot. This can lead to lost moments, and missed photo opportunities especially in dark, low-contrast environments, or for compositions that you just can't put a focus point over your desired subject.
      Separating the two focus/shutter features means you can shoot multiple shots with different compositions, while going through the focusing process only once. Of course, this only works if the distance stays constant, but in many circumstances, this is a good thing. However, there are many cases where this will not be helpful...
      If you're using macro lenses (or just close to your subject), really long telephoto lenses, narrow depth of fields (wide apertures), or doing anything involving a mix thereof, then recomposing is likely to change the focus distance, and this technique will probably do more harm than good.
      Obviously the method to enable back button focusing varies from one camera to another, so look into your camera manual on how to do this or look online, there's a lot of sites to explain all this.
      Canon 1.4x Extender, restoring autofocus on F5.6 lenses (or slower):
      If you are like me with a F5.6 telephoto lens, adding a 1.4x extender drops the widest effective aperture one "stop" to F8.  Most Canon DSLRs (other than the 1D series which will autofocus at F8) will not autofocus with anything higher than 5.6. So you need to manually focus absolutely everything.. which get's very tiresome.
      However, if you want to re-enable your auto focus on the 1.4x extender (apparently this doesn't work with the 2x extender) you simply put tape over the 3 left-most pins on the lens side (not the camera side) of the extender. For more details, see http://www.michaelfurtman.com/taping_the_pins.htm
      I have used this technique with good effect on bright sunny days. But I imagine that it would be unusable in poor light. Obviously, the focus won't work as quickly, and it'll miss the mark more (afterall, it has less light to work with), but it will work for slow moving subjects in relatively bright conditions.
      Anyway, if you have any tips or tricks, please feel free to add them here. All the best!
      Hamish
    • By Primare Knob
      I do not have a clear idea of where to go, starting this thread, since similar threads already exsist. But I like it to become an exchange of things tried and compared. A bit of a technical know how hub and a try before you buy gathering.
      I currently have 2 identical PC hardware systems (non hardware optimizations) and 5 operating systems, tweaked and non tweaked.
      I have the following comparison in mind:
      OS vs OS: Win 8.1 vs Win 8.1 CAD optimized
      Win 8.1 vs Server 2012 R2
      Win 8.1 CAD optimized vs Server 2012 R2 Core
      Win 8.1 CAD optimized vs Server 2012 R2 AO
      Server 2012 R2 vs Server 2012 R2 Core
      Server 2012 R2 Core vs Server 2012 R2 Core AO
      If people are living near Sydney, they are welcome to message me for a meet up. I don't mind to organize a listen session for comparing OS systems or to have a chat about how things work or to try something new.
      I am only short on Phills AO script and hope to find a trial/temp or borrowed version to be able to include it in the listen session.
      The players I use are JRiver and JPlay (local and remote) Kernel Streaming via USB
      After finding the optimal OS and tweaks I like to start tweaking the bios and do another comparision.
      The step after that, would be hardware optimizations and comparison.
      All in all, a multi session comparison learning path, which I will use this thread for, to keep track and inform you guys. I hope to get more people to join in, so this does not becomes a one guy opinion.
      More to come on this.
      Update:
      I am going to place a couple of links and information that has been gathered in this topic here at the top and also some of my findings in tweaking down the PC.
      I have updated the Excel sheet about Windows services with my new findings. There a 4 Running services vital for Windows Server, and there are 4 services vital to run and control JRiver.
      This list is based on the list made by Black Viper. This minial of services is based on a PC with no Wifi
      http://www.blackviper.com/service-configurations/black-vipers-windows-8-1-service-configurations/
      Here is a link with a free script to optimize Windows 8 and 8.1 and also disable the GUI during playback. You can find the scripts if you scroll down the window inside the page.
      http://www.computeraudiodesign.com/computer-setup/
      Here is another free script with an Audiophile Server option posted by PXK
      http://www.windowsxlive.net/livetuner-2-0-improved-optimizations-with-more-features/
      Version 3 posted by nothing 1
      http://www.windowsxlive.net/livetuner/
      Here is a link for another Audiophile player which also does a lot of tweaks to your PC mentioned by acg.
      http://www.phasure.com/index.php?board=1.0
      The interesting aspect of people using this player is that they have under clocked their CPU for the best result. Something I like to try out.
      Here is a link for another Audiophile player mentioned by nik.d
      http://oryaaaaa.world.coocan.jp/bughead/index.html
      Here is a link to another Audiophile player mentioned by 24bit, and one that I can recommend as well.
      http://www.daphile.com
      Here is the link for JPlay.
      http://jplay.eu/
      Here is the link for JRiver
      http://www.jriver.com/download.html
      Here is the link for the Audiophile Optimizer
      http://www.highend-audiopc.com/optimizer.html
      The following links are all computer related
      Turn on Auto Logon: http://support.microsoft.com/kb/324737
      The Difference between Server GUi and Server Core: http://technet.microsoft.com/en-us/library/hh831786.aspx
      Changing IRQ priorities: http://www.petri.co.il/optimize-windows-8-audio-setup-jriver-media-center.htm#
      Turn on Wifi on Windows Server: http://blogs.technet.com/b/blainbar/archive/2012/09/14/getting-your-windows-server-2012-to-use-wireless-not-best-practice-but.aspx
      Turn on/off Server Features using Comands: http://blogs.technet.com/b/yungchou/archive/2013/12/19/windows-server-2012-r2-installation-options-and-features-on-demand-part-2-of-5.aspx
      List of Packages that come with Windows Server: http://technet.microsoft.com/en-us/library/dn452400.aspx
      Using command to tweak Services: http://technet.microsoft.com/en-us/library/hh849849.aspx
      Using PowerShell to tweak Services: http://4sysops.com/archives/managing-services-the-powershell-way-part-3/
      The following links are worth to read if you are planning to tweak things yourself. Using a dual boot System is highly recommended and if you screw up your registry the ability to fix it from within another OS is a feast.
      Installing a dual boot system:http://windows.microsoft.com/en-au/windows/install-multiple-operating-system-multiboot#1TC=windows-7
      Fix your Registry from a dual boot system: http://superuser.com/questions/145493/how-to-edit-registry-from-another-os-boot-up
      You have to change C: for D: because in a Dual Boot you current OS will always be C:, and you try to fix the registry on D:
