Sceeta
Rega Tonearm wiring configuration
Hi all,
Just swapping out the cart on my Rega P25 and as the rca cables are not marked as L and R or color coded I though I would meter out the cables and mark them. This is where the problem starts. The cart indicates that Red and Green are the Right channel pair and White and Blue are the Left channel pair which I assume is an industry standard. When I meter out the the cables they don't seem to match. The red wire at the cartridge end goes to the centre pin of one lead with 1.2 ohms resistance, The green wire goes to the outer of the opposite rca (I assume the outer is the negative) with a resistance of 1.2 ohms. The white wire goes to the centre pin of the other rca with 1.2 ohms resistance and the blue wire goes to the opposite outer with 1.2 ohms resistance. Not sure if those resistances are high or not but it would appear as though the left and right channels are not matched to the same rca connector. Obviously I can change them on the cart when i connect it up but I guess my main question is, is this the way it is supposed to be or would i be better to swap the green and blue so that the channels are paired on the on rca?
Your assistance will be greatly appreciated.
Cheers Matt.
36 minutes ago, Sceeta said:
Hi all,
Cheers Matt.
Hi Matt.
look like your wiring have been mixed up some how . just use the blue /red for right ch and the green/ white for left ch.
Duc
Edited by lovetube
typo
I'd change the RCAs to match the cart outputs.
So if I just match red/blue and white/green that should correct the issue shouldn't it? This is obviously a stuff up from Rega's factory as I am the 2nd owner of this TT and all the wiring is factory fitted. The previous owner hasn't altered anything.
do as i said above. you can't correct the RCA end on this cable . just swap at the cartridge end.
18 minutes ago, lovetube said:
Hi Matt.
look like your wiring have been mixed up some how . just use the green /red for right ch and the blue / white for left ch.
Duc
No worries Duc. You just confused me a bit because your suggestion above is matching the same connections and not swapping them but I thought that is what you meant. Red/Blue Right channel, White/Green Left Channel at cartridge end. Cheers.
sorry my typo . what i wrote is a standard how they should be wired . your case is just wrap the green and the blue at the cartridge end and all will be fix .
Duc
No worries, thanks for the advice, cheers Matt.
Just an update on this one. I contacted Synergy Audio in Vic just to see if I could find out if this may have been done for a reason. Since you can't contact Rega directly I went to them as they are the Victorian authorised Rega distributor. They were very prompt in getting back to me and had already contacted Rega with the issue. Rega have asked for some photos, I guess to see if it has been altered, which I have supplied today so I guess it will be sometime next week now before I get an answer. Watch this space.
So after 3 weeks of going back and forth, Rega weren't particularly prompt in getting back to Synergy but at least Synergy kept me informed, it turns out that all Rega tonearms have a soldered termination block in the base of the arm so that is where the connection error must be. I was of the belief that these arms as well as the RB900 had one piece cables but this has definitely been confirmed by Rega that it is not the case. I have now ordered an incognito silver cardas wiring kit and will just give it a full rewire with one piece cables. That will be the next challenge. Drawing as supplied by Rega.
For anyone who is interested, I got an incognito silver cardas rewire kit and finally got around to rewiring the arm. It was a bit of a challenge but only took about an hour to do it. After having done this myself I've gotta say that the factory wiring is less than impressive. I was really happy to be pulling out the factory shite and installing the incognito kit. The difference to the sound quality that the mod made was incredible. I was very sceptical beforehand but it was a major improvement. The bass is no longer muddy and the mids and highs are fantastic. If you want to improve your Rega arm, I can't recommend this upgrade enough. If anyone wants advice on how to do it I'd be more than happy to share my experience. It is pretty straight forward really. All the best. Oh and here's a pic of the business end.
Edited by Sceeta
added photo
So you're saying that cables do make a difference?  :ohmy:   :cool:
Certainly this mod made a difference. I've never gone down the path of changing interconnect cables for some of the over priced ones that are out there but it certainly poses the question. I can't justify the cost of them though to experiment and am happy with what I have got.
How did you go with the little rubber grommet that apparently gets pulled out and cant be replace?
Which ones, there's 3 in there. Two in the bearing end, they were easy enough and there's one at the headshell. The kit comes with a new one but it's a bit loose so when I pushed it in it went right into the arm tube so I ended up using the original one. If you've never seen one apart there are solder joints behind that plug as well as the ones that terminate on the brass plug. As soon as I started pulling wires all those connections just broke off so it's good just to get rid of those solder joints and have a single run of wires from headshell to phono plugs. I think that probably contributes greatly to the signal/sound improvement.
    • By Teksiis
      Howdy all, not sure if this should be here or in the "Beginners & Purchasing Advice" section, please feel free to move if it is more suitable there.
      Roughly four and a half months ago I purchased Betty the SL120 :
      Betty and I have shared some amazing moments together in our short time, as such I feel she deserves a special treat.
      All silliness aside, I have just purchased an Ortofon 2M Blue to replace the cart that came with the TT and I am now considering upgrading the tonearm.
      I am wondering if this is a worthwhile investment and if so where a good starting point would be, and I suppose as a secondary question would I be better off spending the money somewhere else in the system?
      I am not sure how relevant all the other info is but here is the system as it stands:
       - SL120 Fitted with an SL1200 MK II arm
      - Ortofon OM ProS (About to be replaced with the OM2 Blue)
      - Yamaha AX-497 Amplifier (Using the amps built in phono stage)
      - Dali Concept 6 and B&W DM602 S3s (Currently having a shoot out between the speakers to decide which stays)
      I understand that with the new cart, a tonearm would see me spending well over what the TT cost me to begin with however there is something about the old Technics TTs that appeals to me.
      Any suggestions and/or advice appreciated.
      Terry
    • By stib
      I have aquired a Grace g-707 that has been trashed and I'm restoring it. The metal parts of the arm are in good condition, part of the anti-skating assembly was cracked, but repairable, but the headshell is completely missing.
      So what I want to do is 3D print a replacement headshell. Using images on the internet I can get a pretty good idea of the geometry, but for accuracy I need actual measurements. Is there a g-707 owner out there who can get a ruler, or better yet some calipers and give me the dimensions? Only need the headshell, not the arm. Here are the measurements I need (in rough order of priority):
      width length max depth (at the back) min depth (at the front) outside diameter of the arm mounting tube length of the arm mounting tube distance from front to start of screw holes length of screw holes width of screw holes spacing of screw holes (should be 1/2", yes?) thickness of the plastic lastly, if you can measure the angle between the arm and the headshell that would be great.
      You can refer to the image to see what I'm talking about. If you can't be bothered doing them all then just the length, width and depth would be a great help.
    • By gzman71
      Item: Rega P1 ( new version)
      Price: $400 with free postage
      Item Condition: As New....1 month old with receipt
      Reason for selling: So impressed with the sound that iv'e ordered the P3
      Extra Info: Glowing reviews from around the world.....Fantasic Deck!
      Performance pack is available for $199 from Rega outlets
      Comes complete with all original packaging etc
      Comes with standard cartridge so it's ready to plug and play!
      https://www.whathifi.com/rega/planar-1/review
      https://www.stereophile.com/turntables/507rega/index.html
      https://theaudiophileman.com/planar-1/
    • By hugo_wilco
      Item:  Linn 3b Akito tonearm
      Price: $1800
      Item Condition: mint
      Reason for selling: upgrade.
      Extra Info: Bought New from Tivoli Hi-Fi. Has box etc. Comes with T-Cable. Has a new RRP of $3195. Works well with MC cartridge. I have a Dynavector 20xL with low hours that works beautifully together. PM of interested in both.
