mcb
WITHDRAWN OR RELISTED: FS: Arion HS-500 Mono Block Power Ampliers
Item: Pair of Arion HS-500 Mono Block Amplifiers fitted with Duelund VSF capacitor each and upgraded valves.
Item Condition: Excellent
Reason for selling: Now running big valve mono blocks
Price: $3750  $3500, Pick-Up (freight can be arranged at purchaser’s expense)
Payment Method: Cash on Pickup
The HS-500’s are a Vacuum Tube / Class-D Hybrid Monoblock Power Amplifiers.  Further spec’s below.
I purchased these amps new from Lenehan Audio in February 2014, fitted with VSF Duelund capacitors.  I have since added a matched pair of Cryoset treated Electro Harmonix  6H30Pi EB Gold Pin valves in lieu of the standard valves.
These amps where purchased to replace a highly modified Mingda MC34AB amp and have been used to drive my Lenehan ML2’s. They would have continued to remain in my system, had I not taken up the opportunity to try a pair of 200 watt monster valve monoblock room heaters.
Includes original packing boxes and manuals.
The current replacement price is US$6295 + freight + 10% + other import costs.
Happy to demo in Perth metro area.
Comments from SNA members on HS-500’s - http://www.stereo.net.au/forums/topic/46896-arion-hs-500-amp/
External Review - http://www.enjoythemusic.com/magazine/equipment/1010/arion_audio_rs_500.htm
HS-500 Amplifier Specifications
Rated Power @ 8 Ohms : 500 Watts
Rated Power @ 4 Ohms : 1000 Watts
Sensitivity : 1.8 Vrms
Gain : High gain (approx. 29dB) and low gain (approx. 25dB) settings. Currently set on low gain.
Frequency Response: 20Hz – 20KHz +/-0.5dB
Input Impedance : 200K Ohms
Damping Factor : 900 Ref @ 8 Ohms
Maximum Output Current : 35 Amps
Tube : 6H30
Dimensions : 9.75 in W x 4.75 in H x 14 in D (24.8cm x 12.1cm x 35.6cm)
Weight : 22 Lbs (10kg) each
Edited by mcb
Price reduced to $3600.
Price now reduced to $3500.
As stated previously, happy to demo within the Perth metro area.
This item has been withdrawn from sale or relisted.
    • By Somethingclever
      Item: Pair of Duelund 3.3uf 630 vDc CAST Pure Copper Foil
      Price:  800 ono ( Happy to post at buyers expense )
      Item Condition: Very Good
      Reason for selling: Change
      Extra Info: To quote Benjet who sold something similar..."If you know what these are then you don’t need me telling you all about them. If you don’t know them you probably don’t need them."
      Currently in use, will demount them when sold.
      These top of the line Duelunds were worth about 600 to 700 each when new as far as I can tell.
    • By BigMac
      Item: Complete Lenehan Stereo System
      Price: $8000
      Item Condition: Perfect sonically and unblemished physically
      Reason for selling: I make my own music these days and generally use my studio monitors or headphones to listen to music.  Rarely do I sit down in front of the stereo now.
      The audio system includes:
      Lenehan/Geissler PDX Level 2 DAC A pair of Arion HS-500 500w monoblocks A pair of Lenehan ML2 Reference Speakers A pair of Lenehan Ribbontek speaker cables A pair of Curious interconnects A Curious USB cable A pair of Mike Lenehan speaker stands to suit the speakers Two of Mike's anti vibration "toppers" Two of Mike's 3 Hz isolation platforms, for the PDX and the amps The stand that it all sits on, purchased from Audio Junction in Newcastle  All that's missing is your music server
         The system was purchased new from Mike and I have the original invoice.
      Since purchase the following upgrades have been done:
      Dueland capacitors fitted to the PDX A JL Sounds card was fitted to replace the HiTech interface Dueland capacitors fitted to each Arion amp
      If you are reading this advertisement and know of Mike Lenehan's audio credentials, I do not need to extol the virtues of this system.  It is heavenly. If you do not know of Mike's gear then you can find out about just how highly it is regarded by searching on this forum.
      This is a good deal for a complete, highly advanced stereo system.
      I am willing to do the following:
      Split the system if you are interested in individual components Travel to where you are, within a reasonable distance from Coffs Harbour, to deliver and set the system up (if you buy the complete system and are willing to cover my travel costs).  We can talk about what is a "reasonable distance". Freight to you at your cost.  I have all the original packing that Mike used to send this equipment to me.
      There is an iMac computer that I use as music server, on which I run Audirvana as a player.  It has only ever been used exclusively as my music server, not for general computing needs.  This is not included in the deal, however, since I also have another iMac we could discuss this further.  The Oppo DVD player shown in the photos is not included.
    • By Benjet
      Item: Duelund VSF 2.2uf 400v Capacitors
      Price: $475 for the pair
      Reason for selling: Surplus
      Payment Method: Pickup - Cash, Paypal (buyer pays fees)
      Extra Info: If you know what these are then you don’t need me telling you all about them. If you don’t them you probably don’t need them.
    • By Bill125812
      Item:  Duelund twisted pair Speaker Cable 2.5m
      Price: free.  Nothing inc postage
      Item Condition: perfect
      Reason for selling: NLR
      Extra Info: I made these up just as trial.  Very good but not quite what I was looking for.  They have Straightwire bananas   I also sheathed then in tech flex
    • By mcb
      Price: $3500, Pick-Up (freight can be arranged at purchaser’s expense)
      Tube : 6H30
