Full Range
SOLD: Starting Point Systems 'Battery DAC' TDA1543
Item: Battery DAC, TDA1543, Non Over Sampling (NOS)
Price: SOLD
Item Condition: As new, unmarked - also will ship in the packaging it cam in
Reason for selling: Surplus and have upgraded to new model
Payment Method: EFT, PayPal as friend, Cash
Extra Info: Highly regarded DAC, sweet and detailed sound with great imaging and tone.
NOTE - This is the upgraded dual Battery model
Pictures: Of actual unit
From the website -
What are the main features of this DAC ?
And what are the main goals of its design ?
  • Extract the pure performance of the last built non-oversampling true 16-bit TDA1543 DAC from Philips
  • Optical & Coaxial inputs (leftmost switch on the photo)
  • DIR9001 96 kHz SPDIF Receiver (lowest-jitter on the market - 50ps)
  • Supports sampling frequencies from 28kHz to 108kHz (continuous range, including non-standard frequencies)
  • TDA1543 16-bit DAC - the original from Philips®
  • Passive I/V conversion
  • No Op-Amp - direct output with 2Vpp (will drive any power amp well)
  • Huuuge capacitors on the output path provides sub-Hertz cutoff frequency (<0.3Hz on a 10kOhms input)
  • Dual Stage power supply regulation (for a super low background noise level)
  • Separate voltage regulator for the DAC and the Digital SPDIF receiver (same reason as above)
  • Battery-powered with a single 9V NiMH battery (optional - but without it you must provide a clean 12V - 15V power supply)
  • Smart battery charger on-board (quickly charges the battery when depleted, keeps it charged at low current when idle)
  • When both power switches are on, the battery is recharged, and is also used to buffer the external power, completely removing hum.
  • Will Directly drive any power amplifier
  • Easy to carry around and use it at your friends home
  • 2+ hours of listening on the battery alone
     Thread -      http://www.stereo.net.au/forums/topic/71210-“the-battery-dac-“-impressions/
Edited by Full Range
What have you upgraded to? Is it the DAC3?
Yes I have the DAC 3
Its more a side grade - but I like the sound of both of these little DAC's
I've been considering grabbing the DAC3 for some time now. The fact you've side graded, i assume its worth its asking price.
This version is a touch easier to operate with the toggle switches
The new version has an added USB
I would be happy with either
This item is on hold
Pending payment it's SOLD
    • By StereoInOz
      Price: $550 Item Condition: Impeccable Shipping Options: Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: WORONORA HEIGHTS State: New South Wales Payment Method: EFT, Cash on Pickup Reason for selling: Moved to separates Further information:
      Impeccable Vincent SV-400 Integrated amplifier.  Have original box, packing and remote control.  Great amp, lots of grunt for the money  and super quiet -- and sounds great too.  RRP is $999:  https://www.selby.com.au/vincent-sv-400-integrated-amplifier-black-sv400b.html
      Can post at buyer's expense.
      https://www.vincent-tac.de/en/product-types/integrated-amplifiers/sv-400.html
      https://www.youtube.com/watch?v=wAtA2LbYDdw
      The weight alone shows that a solid power unit has been integrated, capable of guaranteeing stability. The 6800uF filter capacitors, a ring core transformer and electronic volume control all make a clear statement. The SV-400 is also equipped with a D/A converter in order to playback music formats offered by a PC or music server. A USB socket acts as the input here.
      Technical Specifications
      Frequency Response: 20 Hz - 20 KHz +/- 0.5 dB Nominal Output Power
RMS / 8 Ohm: 2 x 50 Watt Nominal Output Power
RMS / 4 Ohm: 2 x 80 Watt Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 200 mV Signal-Noise Ratio: < 90 dB Input Impedance: 47 kOhm Max. Power Consumption: 214 Watt Inputs: 5 x Stereo RCA, 1 x USB Outputs: 1 x Stereo RCA Pre Out, 1 x Stereo RCA Rec Out, 2 x 2 Speaker Terminal, 2 x 3.5 mm Jack (Power Control) Colour: Black / Silver, Weight: 9.5 kg Dimensions (WxHxD): 430 x 98 x 345 mm
    • By peppy
      Item: Denafrips ARES II DAC
      Price Range: Unsure
      Item Condition: New or Used
      Extra Info: Based in Sydney, happy to cover postage if need be.
    • By peppy
      Item: Oppo HA-1
      Price Range: IN LINE with previous sales here
      Extra Info: Based in Sydney, but happy to cover postage if need be.
    • By afie
      So currently I have nothing setup, but have narrowed down on speakers and am looking for what avr/power amp/dac are required to make work everything I desire.
      Id like to be able to have a 2ch setup for a main tv/kitchen/living area, with speakers to play:
      - music currently on a hard drive (internal and external);
      - tv/movies through streaming apps like Netflix through a Fetch box or a Xbox1 or a Chromecast;
      - streaming apps/Youtube through casting from an iphone.
      Sound quality of music is the priority, but I do find it much easier to hear spoken words on tv with separate speakers.
      I have been looking at Ascension speakers from Adelaide and talked to the guy there last year.  The likely model will be around 150 wrms at 8 ohms. I will call him again to discuss, but if I remember correctly from what he recommended last time, an AVR to drive such speakers is expensive relative to the speakers just to offer extra channels that I don't need. Would a suitable alternative be a 2ch power amp plus a second device to hand all the digital inputs?
      Emotiva BASX A-300 or AMC: 2N100MKII-2 are both 150w 8ohm power amps for about $800, but an AVR that can do 150w at 8 ohms are about $5k - what am I missing here? Ive looked into this several times over the last year and I feel like I am just going round in circles.
      Any help would be appreciated. Cheers.
    • By Batty
      Price: $100 Item Condition: Used, so 8/10 Shipping Options: Pickup is available,I can ship this item Suburb or Town: Parafield Gardens State: South Australia Payment Method: Cash or Paypal. Reason for selling: Ares II and D10 DACs Further information: Prefer to Audition (utmost care taken) for a local sale, but I can post at buyer's expense. I think this DAC is well enough known to be a great DAC for the price new and an absolute bargain at this price point.
      I am willing to consider swapping with just about anything audio related in the price range with financial adjustments either way.
      This is the non USB version, and does not come with a power supply.
