Perth.hifi
RTI , T2X Remote , XP6 processor and oppo 105 losing connection
Hi everyone
I've got a RTI Remote fully programmed ad a oppo 105 connected via rs232, had it 2.5yrs and find I constantly looses connection between the two. So frustrating. Spent big dollars, and dissaponted. I don't have ash issues with my pre amp, projector, humax player, Apple tv, etc... it's only the oppo105... anyone had similar experience? Only solution is switch all of, wait a while and try again. Eventually works done times. That'll good for mobile phone oppo app.
Sure wish I could edit the remote control myself,  out really sucks that you spend so much money and you don't get given a mini version of the software to edit.. this point alone,  in ready to jump to another system.
Also anyone have really slow hdmi sync with a marantz av8001 and oppo 105. Gets slow switching between inputs.
Sent from my SM-G935F using Tapatalk
T
Edited by Perth.hifi
mistakes
A lot of devices have a 'network standby' option within the configuration menu.  It is allow them to disable circuitry to meet European standby power regs.
What this does is to turn off the network card (on which the rs232 circuitry VERY commonly resides) so that when the unit is turned off, after a period of time the rs232 and network control interface will switch off.  It is possible they have a wake on LAN function enabled by default so your phone app works ok.
Don't remember the detailed setup options on this Oppo so you may need to do some hunting around in the menu.
RTI licences authorised dealers to use the software to try and keep some quality control on the programming that is provided to the client.  Even though, I have still seen a fair bit of crap programming over the years.
Control 4 only allow dealers to have the software.
Ditto Savant
Ditto AMX
Ditto Crestron.
URC I am not sure about but I imagine for their higher spec products it will probably be the same.
What product are you considering jumping to?
Is your RTI programming locked with a security key?
If not, options are available to you depending on what control devices you use.
Have not experienced the slow switching except in one very specific situation.
Can you draw up a fully detailed schematic of the system showing every connection to AVR.
Might be some clues I can help out with.
Rawl
Do you have any other options apart from rs-232 to control the oppo 105?
I used a simple cable on a 103D from the infra-red pulse generator. I have an RTI T2x, with an older RP-1 (I think - it was with a T2-C which became tempermental after a decade of use).  The cable (?serial) just went from the RP-1 to the back of the OPPO 103D.
The 203 doesn't have that remote connection (pity) so I have gone back to a simple infra-red 'dot' stuck on the remote control spot just near the disc tray, cabled back to the RP-1.
Benje
edit - the OPPO 105 has an IR-IN connection on the back (next to the USB slots) - I used that on my 103D for a wired infra-red connection with my processor.  can you connect your xp6 to the 105 using such a simple cable? (I think I used a 3.5mm mono cable).
Edited by Benje
That should work I do believe as long as you have spare port on xp6.
The programming would obviously need to be altered to change from 232 to ir
RP1 or RP6 or xp6 can output the ir.
RP6 from memory I think needs the 200ishmm long adapter cable for the ir emitter to plug into.
XP6 ir emitter will plug straight into the port and stick on the front of the Oppo or 3.5 to 3.5 mono into the back like you suggested.
Edited by rawl99
Im a Control4 guy myself but I would think RTI should still work after 2.5 yrs. Have you pulled the rs232 plug apart at both ends and checked the connections? Also, if you can find an 'Eco mode' in any of the menus, turn that off.
    • By gazza80
      I recently bought a LG 4K B8 Oled TV and already had a Sonos play base. The remote for the LG TV does not seem to interact with the Sonos so I am left having to adjust sound through my phone which is not ideal.
      Is there a way around this. I believe I might need an infrared remote. Can anyone recommend.
    • By frankn
      Item: NEW ** Definitive Technology Supercube4000 / active sub-woofer
      Price: AUD 900.00  (RRP in Australia is $1795).
      Item Condition: Brand New, never been used - box opened and re-packed.
      Reason for selling:  Mistake - wrong voltage - will need transformer ($100).  Cannot fit transformer in to custom AV cabinet.
      Payment Method: Pickup - Cash, Paypal, or EFT
      Extra Info:  Prefer local pickup but can be shipped in original packaging - Shipping will be charged at cost (I anticipate no more than AUD 100.00) or buyer can organise.
      Key Features
      • 8" (203mm) High Excursion Active Subwoofer Driver
      • 2 x 8" (203mm) Planar Low Bass Radiators
      • 1200 Watts Class HD digital tracking Amplifier
      • Integrated 56 bit Digital Signal Processor (DSP) preamp stage
      • Rock Solid Cabinets Ensure Pure Low Distortion Response
      Pictures:  Using Stock pictures as product re-packed
        Definitive_technology_sc4000_subwoofer_review.pdfDefinitive_technology_sc4000_subwoofer_review.pdf
      Definitive_technology_sc4000_subwoofer_specs.pdf
    • By swingmanic
      Wanted to buy, Mitsubishi remote control handset in good working condition to work on a HC4000 DLP projector. I believe it's the same for several other models too.
      The projector is fully usable but a genuine remote would be nice rather than a clone from eBay, so if you have one then please message me with a price or I can do an exchange for an Optoma HD65 remote control in mint as new condition.
    • By bmwheath
      Hi guys, just after an oppo 95 player preferably region free, looking to spend around $650-$700, let us know what you have or if you want to upgrade to the newer 105. Thanks Heath.
    • By Matcat
      Item: OPPO 105D
      Price: 1000 +post
      Item Condition:99.999 out of 100
      Reason for selling:upgrading
      Extra Info: here for sale is my oppo 105d with hardware region free mod. only played a few blurays and cds in its lifetime. physical condition is perfect apart from 1 teeny dint in the paintwork on top cover. comes with used but perfect condition remote, box and all original unused accessories. pickup preferred but buyer may post at own cost and risk
