Mr_Gadget Posted April 24, 2017 Share Posted April 24, 2017 Hi all, I recently bought a Sony Z9D tv and will buy a 4k blu ray play at some stage this year. My AVR is a non 4K Denon 4311 and I understand that I can use one HDMI from player to denon for the audio and the other HDMI straight to tv for the video. What happens to the info that normally gets displayed from the AVR (eg volume changes, settings menu etc)? Will I not be able to see this if when using the blu ray player? Link to comment Share on other sites More sharing options...
betty boop Posted April 24, 2017 Share Posted April 24, 2017 9 minutes ago, Mr_Gadget said: Hi all, I recently bought a Sony Z9D tv and will buy a 4k blu ray play at some stage this year. My AVR is a non 4K Denon 4311 and I understand that I can use one HDMI from player to denon for the audio and the other HDMI straight to tv for the video. What happens to the info that normally gets displayed from the AVR (eg volume changes, settings menu etc)? Will I not be able to see this if when using the blu ray player? no wont see it as the avr is not feeding video to the display so will have to rely on the display on the denon one option people take is using the dual screen out the denon and feed a small monitor. it should give the osd overlay.... but something want to check ! given the wierd things hdmi can do... Link to comment Share on other sites More sharing options...
KiZ Posted June 8, 2017 Share Posted June 8, 2017 What about using the ARC on the TV, assuming it has one? I use that and PIP on the TV if I ever need the OSD from my amp... Sent from my SM-G930F using Tapatalk Link to comment Share on other sites More sharing options...
betty boop Posted June 8, 2017 Share Posted June 8, 2017 32 minutes ago, KiZ said: What about using the ARC on the TV, assuming it has one? I use that and PIP on the TV if I ever need the OSD from my amp... Sent from my SM-G930F using Tapatalk arc basically will mean you will miss out on HD audio. let alone 3D audio if passing to an avr. also wont get onscreen display from the avr on your display. all maybe not a major issue. and if using a player for instance with dual outs ...then something can also work around the audio aspects. Link to comment Share on other sites More sharing options...
Mr_Gadget Posted June 9, 2017 Author Share Posted June 9, 2017 I don't have any source players hooked up to my tv or AVR yet, but I found that by using ARC I can control the volume of the AVR and (see the numbers increasing/decreasing) with the TV remote. This is all the information on screen you'll be able to get though. Link to comment Share on other sites More sharing options...
