EOI: Someone to enhance my Sansui TU-X711 supertuner and get another as payment !
The exceedingly rare Sansui TU-X711 was Sansui's last venture into high-end FM, 12 years after the TU-X1 (Sansui's top-of-line fully analogue AM/FM statement tuner). The TU-X711's circuit-identical precursor, the TU-X701, placed 15th out of 84 highly regarded tuners in FMTunerInfo's famed sound quality shootout (beating the superb Sansui TU-717 by two places). In stock form this is the quietest tuner I have ever heard: stereo noise on a good wide/local signal is about -90 dB ...incredible !
Image result for tu-x711
As good as the TU-X711 is, in stock form, it can be substantially improved to bring it near the very top in sound quality.
When these tuners very occasionally surface on eBay (usually in Germany) they are typically about €300 plus shipping to Oz.
Here is my offer:
Enhance my personal TU-X711, and get one FREE to enhance for yourself!
I have two Sansui TU-X711s ! Both waiting to be enhanced, but I have neither the experience nor dexterity for such a task.
I handed these tuners over to someone who, unfortunately for me (but not for him) has been phenomenally busy since then and will be for the foreseeable future. So I've retrieved them and I'm offering again.
I do have excellently clear instructions, by FMTunerInfo contributor JohnC in the US, who has made these changes to a TU-X701 with apparently stunning results, and I have the full service manual and circuit diagram. The motherboard and daughterboards (power, MPX) are well laid out and easy to access above and below.
Here is the list of suggested modifications and a few post-mod photos of JohnC's TU-X701:
TU-X701 DIY
Unless noted all caps are Panasonic FR, Panasonic FM, Nichicon HE, or Panasonic FC as available and in this order of preference.
Power Supply
13 & 29 Volt Rails
mC1  220/35 > 470/35
mC4  220/63 > 470/63
mC5  100/50 > 220/50
mC8  100/50 > 120/50
mC11  2200/50 > 2700/50
mC14  47/10 > 120/16
mC16  1000/25 > 2200/25
mD3  Assemble FW Bridge using 11DQ10 Schottky Doides
mD1/2  200V or larger Schottky or Epitaxial Diode
5.6, 18.5, -28 V Rails
mC19  330/35 > 560/35
mC20  470/25 > 470/35
mC21  100/10 > 220/25
mC25  100/35 > 220/50
mC26/28/29  47/50 > 120/50
mC27  330/63 > 470/63
Front End
dC7  470/16 > 1000/25
Composite
dC52  10/50 > 22/50
dC58  47/50 > 100/50
dC63  47/50 > 47/50 Nichicon Muse KZ + 0.1 polypropylene film bypass
dC64  100/25 > 220/35
dC68  47/50 > 100/50
dC69  470/16 > 1000/25
dC70  100/16 > 100/25 Nichicon Muse KZ + 0.1 polypropylene film bypass
dC91  100/16 > 220/25
dC77R-dC100R & dC77L-dC100L  > 10 or 22/50 Nichicon Muse ES Non-Polar
Replace the polarized cap pair with a single non-polar Nichicon Muse ES series cap.  Orient the new cap with the long lead in the negative side of the 77 cap hole and the short lead in the negative side of the 100 cap.
Desolder the 2043 JRC 6504 op-amp and replace with an op-amp socket and OPA2604 (for now)
Replace the power cable (internal and external) by audio grade cable. I'd much prefer to see the external power cable replaced by an IEC socket, which would require some (neat) metalwork. If you can't do this, it is not a deal-breaker.
Post-enhancement photos, courtesy of JohnC and FMTunerInfo.com:
If you are interested in taking up the challenge, please contact me privately.
Warren
Edited by Warren M.
If only i had the skill, fantastic offer for the right person. I'd love a great tuner like this.
Sent from my SM-G930F using Tapatalk
The parts and servicing time would probably cost more than the 300euro these are going for in Germany. Unless you are paying for parts and the Techs time is paid for with spare tuner? What condition is the spare in?
€300 plus shipping is about AU$600 and that's assuming you can get one. Assuming that audio electronics is your pastime and not your profession, cost of modification time is not really relevant.
My guess is you would be up for about $300 for the components for both tuners, but could be less.
If you were to modify a TU-9900 or TU-919, the tuner alone would cost you maybe $1000 or more, and the mods required are much more extensive, probably costing about $500 in components per tuner. In the end you would have a tuner which may have very marginally better sound quality than the modified TU-X701, but costing you several times more.
Condition of both my TU-X711 tuners is excellent: 8.5-9/10.
Warren
Edited by Warren M.
From your description, it's a matter of replacing all those caps, some diodes, op amp socket, IEC power socket and running some good quality wire - is that a fair summary?
If so, it seems just a tedious job of upgrading the bits, provided there's a clear manual to follow and doesn't require complicated programming or exotic test gear
So you are saying I should do it myself. You've obviously never seen my soldering technique.
Besides, I expect that, changing capacitance values in the front end and the composite circuitry, a realignment of the tuning varactor will be required.
Warren.
Do the upgrading notes include what's required to do the re-alignment?  The rest of it seems quite manageable - how come you haven't sent this off to Joe?
1 hour ago, jrhill said:
How come you haven't sent this off to Joe?
Joe has three itty bitty projects which seem to have taken up a lot of his time:
  1. The Elsinore "current compatible" DIY speaker which looks like this EL-6_SoundRoom.jpg and performs like this EL-6_Family.gif
  2. The JLTi (currently level 4.2 + ACB) Oppo BDP105 (and soon UDP205), which has implemented one after another completely new or rethought technologies
  3. The JLTi family of amplifiers, again involving serious revision of amplifier orthodoxy
Given his tendency to reinvent whatever he touches (my EE MiniMax phono for instance, which went from good to phenomenal, after mapping and redesigning the circuit) it should have been no surprise that he would not get around to working on these tuners, as he could not have stopped at simply doing component swaps.
Which is why I am getting it done by someone else.
Warren
Aah, you do need a tech's workshop for setting the unit up, as I expected - unfortunately, I can't do this for you - sorry
    • By Prana69
      Item Condition: Very Good Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Mordialloc State: Victoria Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR Further information:
      This is a really nice tuner from Pioneer's 1979-1982 fluoroscan series.  It is super sensitive, picking up FM signals with just speaker wire. There are a few minor marks on the faceplate, but the pictures make them look worse than they are.  The AM antenna is intact.
      If you own a 508, 608 or 708 amp, this tuner looks great alongside them.  I've included a net picture as an example.
      Note: The Denon tuner in the picture is available in a separate listing.
      PLEASE READ
    • By Hilltop Rob
      Item Condition: Very good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Laidley State: Queensland Payment Method: Cash, EFT, PayPal Reason for selling: Not needed Overall in very good condition. Works perfectly.
      No box or remote.
      PLEASE READ
    • By Sonica
      Item: Looking for a good unit in fully working condition.
      Price Range: Negotiable
      Item Condition: Used
    • By Igotmearecord
      Item Condition: used - excellent condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Tura Beach State: New South Wales Payment Method: Paypal F&F, EFT Reason for selling: Not being used. Downsizing and rationalising Further information:
       A classic am/fm tuner from Hitachi and the early '80s. It has their highly regarded FCCS (Field Condition Computer Servo) tuning system which optimises the signal for the best performance. It reviewed very well in Grammophone magazine but I can't locate a copy of the review.
      As seen in the pics, it comes with original and complete packaging, instructions, and antennas, and I have included a basic rca lead with gold-plated plugs to get the new owner going.
      There are some marks/blemishes on the top cover unfortunately but they are not big dings and dents (see the pics).
      This one is silver finish. I have a bronze finish one as well which I am planning to list when I list the matching amplification in case anyone is looking for a matched set.
      Shipping with insurance is easily available with Australia Post at extra cost. I am open to discussing the total price including shipping.
      PLEASE READ
    • By Gramophone
      Item Condition: Very good Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal & Cash Reason for selling: No being used Further information:
      This tuner is exceptional value for money. It is a true hi-fi component, well-build with a clean, bright and open sound. It features dual FM antenna inputs and build-in signal strength meter.
      The tuner is in good working order with very little sign of use. Supplied with original manual.   Photos:
      PLEASE READ
