EXPIRED: Holton Zero Five Zero Introductory Offer!
Just now, Aussieamps said:
It it is important to remember that the existing 050 power amplifier is a very high performance amp at a budget price.
The original brief for the SE is to take the original design and make it into an integrated amplifier and keep it minimalist in its approach; again to keep cost down.
I think this needs to be pointed out again. The 050 is obviously a great design from the get go and if it ain't broke................
The whole idea is to make it into an integrated amplifier to widen the appeal,but keeping it relatively minimalist is the best way to retain the essence of the original design and keep things affordable for most people
  • Replies 297
Popular Posts
Hi Guys   Thought you would like an update on the preamp and integrated amplifier.   Currently I am buried in the design of the stand alone pre-amp, which is moving ahead very well
With respect, I disagree entirely I think it is pretty well established that this will be kept as simple as possible and I have not seen any evidence here of people wanting DAC, 12v switching or
Ok This is what can be offered for the Integrated SE Amplifier.     Basic model just with manual volume and electronic 3 input selection, HT Bypass 12 volt trigger remote power on/off,
Posted Images
I've been watching this thread with interest. These Holton amps are beautifully designed as they are. I really hope we don't end up with something that's "designed by a committee"
  • Moderators
you'll end up with the homer mobile... resist the urge @Aussieamps
latest?cb=20090908145331
all things for all people and yet nothing end up bringing something no one wants... :D
theres not hing wrong with a nice high quality power amp.
sure if you can make into an integrated, but then we will want remote control...input switching .... a HT bypass, 12 V triggering inbuilt dacs...then it will be a media streamer...etc etc :D
ps instead of all that could just do  stand alone pre amp.
ps wht would be great to add to the power amp though is twin switchable inputs... people will be able to use this with all pre amps that dont have the ht bypass feature :)
I think it is pretty well established that this will be kept as simple as possible and I have not seen any evidence here of people wanting DAC, 12v switching or media streaming.
The whole idea is to increase its appeal by producing an integrated with the same essential facilities as the 050. I think that far from something nobody wants, it will be something many people will want. Many people don't want a pre/power set up and like the convenience of an integrated and I for one, can't wait to see it produced
  • Administrators
I'm with him ^
I'm with him too ^^.
We need to see what's the best no frills integrated amp we (i.e. Anthony) can build for under $2k. We should discuss things like power output, number and types of input, etc. No unnecessary ad ons like DAC/streamer/phono stage, etc. This is an integrated amp only. Otherwise this idea will never become a reality as we will all want too many different things.
Maybe in the future Anthony and Clay can get together and build a true all in one amp/dac/streamer thingy.
@Aussieamps
The 100wpc 050 is $1990
The SNA special edition would add 3 RCA inputs, HQ volume control, remote, ht bypass, larger case, orange led, etc.
Is it realistic to expect you to produce this for under $2000?
most certainly you can always make improvements and make it drive 1 Ohm loads continuously if you really want to, but all of this comes at a price.
i am certainly open also to a "no cost object design" on another thread if others are interested :)
OK...lets do it...
Design brief for 2 x monos...
Design brief for 1 x iintegrated...
How do we progress...
Just now, Rob181 said:
OK...lets do it...
We have progressed quote a lot on the integrated. Possibly to the point where there is a consensus about its design and features. Very high quality simplicity are the key descriptors.
52 minutes ago, Rob181 said:
OK...lets do it...
2 monos? Just buy a pair of the existing 050 amps.  :)
That what I thought Chris, but I didn't post it because I thought I had missed something that was obvious to everyone but myself:)
3 minutes ago, Cardiiiii said:
Ah can the zero five zero be used in a mono config? What's the power output in mono config?
Yes the zero five zero can be used in bridged mono mode
the 50 watt version in mono bridge mode produces 160 watts into 8 ohms
the 100 watt version produces around 300 watts into 8 ohms.
3 hours ago, custom_made said:
@Aussieamps
No it is not realistic, there will be another tier of electronics
which will require its own separate PCB and quality components.:)
Thanks. I didn't think it so either.. and this is before your labour and expertise costs.
I think people should temper their expectations in regards to price, as it wouldn't be fair to Anthony.
The 100w 050 already exists in the $2000 price bracket and from all accounts, it's worth every dollar. If you guys want to turn it into an integrated, you'd probably have to consider that as the starting point.
Edited by custom_made
What if we were to make these amps in batches, would that reduce the cost a little? In batches of 10 or 25, people pay upfront? With the features we've discussed so far, what sort of price are we looking at?
A couple more build photos
Not a lot of room in there other than what is there already :)
Photo is of the front of Amp and what lurks behind the decorative milled anodised fascia
Photo was taken before all the heat shrinks were applied to the high volts mains connectors. It was a mock up for testing the 35 x 35v  225va Transformer
Also depicted is the 30v Harbuch Transformer.
To me after building Holton 050 amps (for self consumption purposes) would suggest that a separate matching case pre amplifier with  a volume pot, inputs and outputs be considered + maybe a very high end Holton Designed DAC as well.:love:party
The only thing that I see of real benefit to the existing 050 design is input and output connectors on the 050 back panel to facilitate parallel connection of amplifier inputs for mono configuration, rather than Y connectors however if an active arrangement fed via DSP this wouldn't be required.
Also go to a 150mm high case so as bigger Transformers can be used as at the moment it's tight, 1mm tight in fact with literally no room for any thing else really
A list of those that would be interested in the Holton 100 Integrated amp would be very helpful.
and once the design is complete and I am ready to do a production run, pre-payment would be very much appreciated. :)
It is hard to exactly know for sure how much it would be at this stage, but a ball park figure would be around $2500.00 + Shipment
Just as an update to this thread, I have had some expressions of interest via PM in purchasing the Holton integrated amplifier when it is released.
I am expecting the development time to be at least 4-5 months which will bring it up to around October-November 2017.
If anyone else is interested please feel free to PM me or publicly post your support; I am not expecting anyone to make a definite commitment, just some expressions of interest.
This will help me with how many I can expect to sell and tool up for when the time comes. :)
That's the spirit guys. I have a very good instinct about this product and I hope there are many more expressions of interest.... or orders even:)
I am interested but may have bought something by then, although I'm not currently rushing.
I would need to hear it first preferably in Sydney.
Being as I've ordered a second 100 watt 050 so I can do the mono block thing I like those numbers.:D
Edited by Hergest
    • By PG2019
      Item Condition: Very Good Shipping Options: Shipping is available at agreed cost. Suburb or Town: SE Suburbs State: Victoria Payment Method: EFT Reason for selling: NLR Further information:
      Selling my Bryston 4BSST2 + MPS2 + BP26, the complete set was brought from Carlton Audio Visual in 2016.  It still has 16 years warranty remaining on the units. Unfortunately, I do not have the original packaging, but can organise shipping.  The units are in very good condition, no remote is included as this was a factory option from Bryston.
      If you have questions please do not hesitate to contact me. Willing to separate, but preference given to those wanting to buy the complete set.
      PLEASE READ
    • By ikwong
      Item Condition: Mint Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Adelaide State: South Australia Payment Method: Paypal + fees, EFT, Cash on Pickup Reason for selling: NLR Further information:
       The Rotel RB-1582 MKII amp (RRP $2799) is in perfect working condition and is pristine in appearance.  The unit was purchased from a local dealer in late 2018. My job roles changed since the purchase and I barely have time with my gears since.
      The unit is extremely well taken care of and was covered with cloth while not in use (I tend to be away from home for weeks!).
      The amp is barely used for 120 hrs in total. So, make sure you allow more burn-in time.
      I have all the original boxes, manuals etc.
      Details:
      Rotel’s largest stereo amplifier at 200 watts per channel provides the massive current to drive the very largest hi-fi systems effortlessly. And like its smaller brother, the RB-1582 MKII has been designed to excel at resolving the subtle details in music as well as supplying the brawn required for extremely dynamic passages. It is able to achieve this difficult dual requirement because of the meticulous attention paid to circuit design and parts selection.
      The RB-1582 MKII ‘s high-end performance begins with an extremely large toroidal transformer combined with a total of 60,000uF storage capacity in special “slit foil” capacitors to provide completely stable power to the output stage. Slit foil capacitors have the ability to charge and discharge extremely quickly, thereby ensuring signal fidelity during orchestral crescendos or repetitive kick-drum impacts, for example. Both left and right channel construction are laid out in a mono block design (after the toroidal transformer) and all grounding is terminated in a star pattern on a copper grounding plate to ensure low signal to noise. The output stage is a discrete design that consists of 10 high current bipolar transistors per channel. Input options consist of both balanced XLR and unbalanced RCA connectors.
      The RB-1582 stereo power amplifier is yet another outstanding example of Rotel’s Balanced Design Concept and will form the heart of a very impressive stereo or home theater system for years to come.
      Specifications:
      Power Configurations: 2 x 200 watts (20Hz-20kHz, <0.03%, 8 Ohms)
      Watts/Channel: 200 watts, all channels driven, 8 ohm load, 20-20kHz
      THD (20-20,000Hz) 8 Ohms, all channels driven: < 0.03%
      IM Distortion: < 0.03%
      Damping Factor (8 Ohms): 1000
      Input Sensitivity / Impedance: 1.5V / 32kOhms
      Frequency Response (+/-1dB): 15-100kHz (+/-1dB)
      S/N Ratio (IHF A): 116dB
      Power Consumption: 550 watts
      Dimensions (W x H x D): 431 x 140 x 406 mm
      Front Panel Height: 3U (5.25”)
      Shipping Weight: 18.5 Kg
      Finish: Silver
    • By alex117
      I am looking to a power amp ( no controls requiring preamp to use) for  3 pairs of  Definitive Technology ceiling speakers for effect (4) and rear center (2)
      (Main R/L/C are Meridian  M60, and pair of M33)
    • By youngjimmy
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Carlingford State: New South Wales Payment Method: EFT, Cash on pickup Reason for selling: no longer needed Further information: 2 x 20 watts RMS into 4 ohms. Sounds much bigger than its spec would suggest. This amp is as new, in original carton, with its under desk mounting bracket
      PLEASE READ
    • By Audiofooled
      Item: Sonance Sonamp 275se Power Amplifier
      Price Range:$100-$150
      Item Condition: New or Used
      Extra Info:  I am looking for a second amp as I want to power separate speakers with a second unit in bridge mode
