Aussieamps
EXPIRED: Holton Zero Five Zero Introductory Offer!
Sounds like competitive pricing. Will have to keep an eye out this year when I'm ready to upgrade.
Thank you
Will be looking forward to it and possibly having a listen.:thumb:
Don't Joe, you will want to change brands :P
@Cafad...the recognised Integrated addict...
Will be lining up...of that I am sure...
I'm already in line, the line just doesn't know it yet.
On 20/01/2018 at 8:27 PM, Aussieamps said:
Hi @Mungbean66
I am currently developing the stand alone pre-amp, from this the integrated will be completed, ETA would be around March 2018.
Price range between $2500-3900 depending on options.
Do you know how much the stand alone pre will cost yet? Also, what are the main differences to the Geisler pre?
https://www.stereo.net.au/forums/topic/103617-new-preamplifier-ugrade/
Hi @Mike13
The Holton 101 Preamp will approximate cost $3.5K
It will be a fully balanced high bandwidth ultra low THD+N topology preamp capable of accepting XLR as well as RCA inputs 3 selectable inputs in total
and Balanced XLR and RCA outputs.
The volume control on this will be a Gold Point 24 position stepped attentuator; manual control only on this unit.
RCA Record buffered loop outputs and HT Bypass capable on the 3rd selectable input.
12v trigger output to remotely control power on/off on the Holton power amplifiers.
It will also have high grade headphone amplifier with 6.35mm output on the front panel.
All coupling input and output capacitors will be audio grade Metalised polypropylene or MKP
The chassis for the preamp will fully CNC machined anodised 10mm front and back panels;
To match the current range of Holton power amplifiers, such as the Holton Five-Zero-Zero power amplifier
Expected dimensions will be 400mm Wide x 80mm High x 300mm Deep and approximate net weight 5kg+
Thanks for the detail. Is there a way to try your products outside of Tassie?
 (BTW I see the HT bypass will help with my laziness problem)
Bloody hell Anthony, looks like you'll be getting more of my money; although I don't begrudge you a single cent; love your work!!! [emoji106]
@Mike13
Currently there is no dealers of Holton Audio products in Melbourne, however there are a number of customers that might be willing to
let you audition their Holton gear.
Edited by Aussieamps
2 hours ago, Aussieamps said:
@Mike13
Ok no worries. I keep buying stuff without trying it in my system. I’ll keep an eye out for when your pre is ready.
Hi Guys
Thought you would like an update on the preamp and integrated amplifier.
Currently I am buried in the design of the stand alone pre-amp, which is moving ahead very well.
Between getting prototype panels machined and developing new technology to handle the functions within the preamp PCB design of main board and front panel electronics it all takes quite a lot of time. :)
The integrated amplifier will have all the good stuff from the stane alone preamp once it has been developed.
Here is some photos of the prototype front and back panels.
Just trying out some different components for the panels, the volume knob is a custom machined out of solid aluminium and designed to fit
to the Goldpoint Stepped attentuator.
The front panel switch and headphones jack shown are just tryouts they will not be used they will have proximity switch input selection and power on/off.
No doubt that you've been very busy Anthony!
Are you considering offering a neutrik powercon or similar locking power connector instead of the standard IEC?
Are you concurrently working on a remote volume unit? I think many people, myself included, would be happy to have remote volume even if there were no manual volume adjustment; removing motor noise and circuitry, but from the other direction?
Will you also offer semi-custom options, eg no headphone jack on this model?
I'm sure whatever you come up with will be stellar, regardless! [emoji4]
Hi Steve
You have raised some interesting points?
yes i do like the powercon connectors, i tried introducing those quite a number of years ago in my power amplifiers. No body wanted them because they wanted to be able to use their very expensive snake oil jug kettle cords.
i would love to be able to use  powercon
but i suspect mans love affair with the IEC connector has not ended?
The remote control is in the works for sure.
It is really hard to come to the fact that there is no such thing as a perfect volume control and yet it is the one component in the audio chain the can have the most profound effect on sound quality in almost every way.
The goal for this preamp is to use the best analog volume control without breaking the bank. Remote volume control for the most part are full of compromise.
It is really hard to come up with a remote controlled volume that doesn’t cause some problem a long the way or just plain sounds dreadful or has those annoying clicking and popping relays as you adjust the level up and down.
One of the best volume controls i used in a Smart Dac i help to produce was done in the digital domain, basically and practically perfect IMHO.
but it requires a real nicely designed DAC
with some processing power behind it to do it right.?
Regarding the headphone jack i would be happy to leave it out if it suited everybody.
just one less thing i have to add?
But i suspect it might be on the same level as the IEC connector.
some feedback would be good?
Cheers Anthony
I actually don't mind the idea of the powercon connector, but is it that easy to buy power cables with them installed ? I have never personally seen one in a shop. Even a quick google search turned up very little in the way of complete cables with that connector. Perhaps that implies it may be "nice" if that cable is supplied with the amp ?? (even if you add the cost to the RRP or perhaps make it an option, ie $50-$75.00 etc.)
Remote volume for me in the integrated is mandatory - as problematic as that sounds from what you have said above - I really hope to own one of your amps one day and love integrated's - but without this feature it is not a proposition for me.
The headphone jack is not important for me, it would be nice, but not if it increases the cost significantly or compromises performance in other areas. Separate headphone amps are in abundance..
Thanks Ray
I really appreciate your feedback.
The Powercon connector is a really good device, but its not viable to offer it as an option as the cost of getting two different rear panels machined
is hard to justify given that only a few might want this option.
Good point about the headphone option though, might be a case for leaving it out of the pre-amp.
Also noted on the remote control, this will be included in the integrated amplifier.
44 minutes ago, Aussieamps said:
Thanks Ray
Gday Anthony,
Thanks for the quick update. I wasn't suggesting have the powercon as an option vs. IEC on the back of the amp - rather POWERCON is the power cable connector, the option is that they either get a powercon cable from you (ie thus the $50 increased cost) when they buy the amp or buy their own from elsewhere.
Hope that makes sense. I can see others balking though, and it revolves around your point of the desire to use after market power cables.
4 minutes ago, Ray H said:
Gday Anthony,
no worries mate, thanks for that. :)
Not trying to be a pain, but this thread is really interesting, but located in the wrong place. Could it possibly be moved by a moderator into the correct location? Maybe the Holton thread? Or the two channel amplifier topic?
Anyway, great reading! I look forward to more details about the Pre, as I am now decided on my quest to build a hi end, Australian made system!
Hi Everyone
I have started a new thread in the Holton Precision Audio forum for all those interested in the up and coming Holton 101 Pre-Amplifier.
I planned to show the build and design journey of this unit, I think you will find this interesting.
Here is the link.
I will also start a new thread for the Holton Integrated Amplifier as well.
So please come and visit the new threads at the Holton Precision Audio Forum and please register your interest by clicking on the Follow button.
That way you will get notified of any updates within the thread.
Hi Everyone
For those that might have missed the previous update on the Holton 101 preamplifier.
Here is a link to the new Holton preamplifier page.:)
This advertisement has been withdrawn or the offer has expired.
    • By SBM
      Hello everyone,
      Good day can any one recommend a good budget power conditioner.
      Thank you.
    • By rockwell
      Item: Plinius SA201 Stereo Power Amplifier
      Price: $1200
      Item Condition: Used
      Reason for selling: Have upgraded my power amplifier to mono blocks and need to save space, and keep the peace at home.
      Extra Info: For sale is my well cared for Plinius SA201 stereo power amplifier in the silver finish. I have been the first owner since circa 2006. I can't see any noticeable scratches or marks, so the curvaceous casework has stood up well over time. But alas I have felt the need to upgrade after many years good service, and when the opportunity arose I purchased a pair of mono blocks.
      This amp is rated at 225 watts per channel into 8 ohms. Both channels driven from 20Hz to 20kHz at less than 0.2% total harmonic distortion.
      Current Output: 40A short duration per module. Fuse protected.
      Hum and Noise: 90dB  below rated output 20Hz to 20kHz unweighted.
      Gain: 32dB.
      Input Impedance: 47k ohms
      Dimensions: Height 170mm, Width 445mm, Depth 453mm, Weight 25kg
      Here's one review to give a general feel for the amp:
      https://www.dagogo.com/plinius-tautoro-preamplifier-sa-201-stereo-power-amplifier-review/
      I've been using this amp with PS Audio products - the Directstream player, DAC and the BHK preamp.
      You could describe the sounds as smooth and coherent. Spatial performance is excellent with an expansive soundstage. There is plenty of detail, presented in  natural fashion without being in your face.
      I have the original Plinius double-box packaging for transportation. The amp weighs 25kg so local pickup is preferred.
    • By Max Headroom
      Item: NAD C 275BEE Stereo Power Amplifier - does not include Integrated in picture, see my other sale
      Price: $600
      Item Condition: Perfect
      Reason for selling: Looking at upgrading to NAD Master Series
      Extra Info: This stereo amplifier is a proverbial iron fist in a velvet glove.
      If you can never have enough power, match this brilliant power amp with the matching integrated, and switch them both to bridged mode, sit back and revel in the awesome scale and control that this amp has. This amp has performance that simply must be heard to be fully appreciated.
      This integrated has lots of trickle down technology from the NAD Masters Series M3 Amplifier. These include application of Bjørn Erik Edvardsen’s Distortion Canceling Circuit in the output stage and BEE Clamp in the power supply, with distortion and noise reduced down to unprecedented levels.
      The C275BEE is the same Power Amplifier circuitry as used in the C375BEE Integrated Stereo Amplifier and can be connected to form a truly prodigious combination. As a two-channel amplifier, the possibilities are numerous. Experience room-filling sound with impressive musical detail and transparency. The NAD C275BEE features a sophisticated design and beefy construction to bring out the best in all your music from the lowest, wall-shaking pedal notes of a pipe organ to the delicate reverberation of a solo acoustic guitar.
      What HiFi loved this amp: "If you're looking for a powerful but subtle amplifier, then the NAD C275BEE power amp, paired with the matching C165BEE preamp does the trick"... "A likeable brute of an amplifier. For those who want plenty of sonic muscle without having to sacrifice subtlety too much.
      https://nadelectronics.com/product/c-275bee-stereo-power-amplifier/
      This amp will drive just about any load down to 2ohm, and can hit 800w at 8ohm in bridged mode.
      2 x 150W Continuous Power into 4 Ohms and 8 Ohms
      250W, 410W, 600W IHF Dynamic power into 8, 4 and 2 Ohms, respectively
      PowerDrive™ circuit
      Holmgren Toroidal Power transformer
      All discrete circuitry
      Class A Voltage Stages
      BEE Anti-saturation Clamp
      Copper bus bars
      Short signal path from input to output
      All sockets Gold-plated
      Soft Clipping™
      This amp has run beautifully without a hitch, and works incredible well with the matching C 375BEE integrated that I'm selling - the power amp in the integrated is meant to be the same as this standalone power amp.
      I have a box that I received the amp in, so it will be packed well, but I don't have the original packaging.
    • By leqt1969
      Item:  Roksan Caspian M1 Power Amplifier
      Price: $750.00 ONO
      Item Condition: Excellent used condition
      Reason for selling: NLR
      Extra Info: Advertised on behalf of a friend in Sydney. This is in excellent used condition.
      Caspian M series-1 Power Amplifier Spec
      Input Impedance: 38 kΩ
      Input Sensitivity: 700mV RMS
      Signal Inputs: Left & Right channels
      Signal Outputs: Chain Output L & R Channels
      Power Outputs: Loudspeaker, L & R
      Output Power:> 85 Watts continuous, into 8ohm; both channels driven; 120 Watts continuous, into 4ohm; both channels driven
      Power Supply: 330VA Ultra Low Noise Toroidal Transformer
      Current Output: 50 Amps Peak to Peak
      Damping Factor: & gt; 140 (8ohm)
      Frequency response: -3dB, <1Hz -> 100kHz
      Gain: 30.7dB
      Harmonic Distortion: <0.003% 1 kHz - 8 ohm <0.003% 1 kHz - 4 ohm Signal to Noise Ratio:>116dB (ref 70W, 8ohm)
      Dimension: 432 x 330 x 70 (W x D x H) mm 432 x 330 x 85 (including feet)
      Weight: 10 Kg
    • By Goatboy
      Item: Exposure 3010 Stereo Power Amplifier
      Price: $680   $500
      Item Condition: Very Good - functions perfectly / minor cosmetic wear
      Having one last crack at moving this on. I think this is a great amp for the asking price.
      I bought this power amplifier from the forums in 2017. Its main use is HT duties, as well as spinning 10 hours or so of vinyl each week. The amp has performed flawlessly and presents as warm and emotive, ie. the Exposure house sound. The amp is rated at 100w / channel into 8 Ohms, and has the capability to run as a mono amp, as well as the option to biwire.
      Note: the amp only takes banana plugs.
      Cosmetically, there are minor blemishes and some light scratches on the top of the unit.
      I have the original box, and happy to post.
      https://www.exposurehifi.com/images/quickstart/3010_Power_Amplifier_QS_Manual_web.pdf
      Specs:
      Power Output (Stereo): 100 Watts per channel at 1KHz into 8 Ohms
      Power output (bridged mono): 110 Watts at 1KHz into 8 Ohms
      Input Impedance: 18K ohms
      Frequency Response: 20Hz - 20 KHz ±0.5dB
      Total Harmonic Distortion: <0.015% at rated output ref 1 KHz
      Signal to noise: >100 dB ref rated output
      Channel Separation: >60dB, 20Hz - 20KHz
      Mains Supply: 110/120V or 220/240V, 50/60Hz (factory set)
      Power Consumption: <350VA, 8 ohm load both channels driven
      Dimensions (H x W x D): 115mmx440mmx300mm
      Net Weight (unpacked): 11kg
      Gross Weight (packed): 13kg
