Owen Y
Our DIY Ultrasonic Record Cleaner
So finally got around to sending off the extra bottle of Triton to it's rightful owner yesterday(well the missus did) and Aussie Post charged $15.50 for postage. Anyway Jeanette was more than appreciative and reimbursed me straight away with a bit more than it cost so all is well again in the universe.
Thanks Matt!  I think that bottle is destined for my place in Camperdown, thanks for doing this.
Chris
Chris
No problem Chris. Could've just ad easily gone the other way and you would've got two. Good old Aussie Post. Jeanette couldn't believe the cost of postage but was more than happy to have it all sorted. Happy to help out a fellow vinyl spinner.
Sent from my SM-G930F using Tapatalk
I have found a marked difference in using triton x vs some earlier batches i did. Much cleaner / quieter.
Thanks to those on this thread.
Sent from my SM-G925I using Tapatalk
@scuzzi - just for information, what was your previous mix?
Cheers, Owen
http://darklanternforowen.wordpress.com/
Cheers, Owen
Hi Owen
Just distilled water and the iso/alcohol mix listed in the instructions ftom the Poland seller. Ive added triton x to the same mix and the results improved dramatically
Just an update - Jeanette advised they've run out of stock.  Next shipment for them is August, so they are only taking orders from then.
Chaps - thanks to all those patiently waiting for more of these kits, I am pleased to advise that all parts are ready for another batch.
(There was a hitch with the lasercut metalwork, which had to be returned for some addit work.)
My son has been away on work for 3wks but the driveshafts should be assembled this weekend & Paypal requests sent out.
PM me your postal addresses when you can.
Cheers, Owen
Has anyone had any luck ordering Triton X100 from Australian Resellers? There is a few based on a quick google search.
Also at present is the Triton X100 and distilled water still the recommended brew?
I got mine from NZ only took about 10 days
 I think they run out of stock, at last I heard though
Hi Chaps,
Another batch of the kits for the US Cleaner shipped out today,
Assembly is quite easy, but I posted some instructions on page 3 of this thread on 7 May here:
Enjoy! Owen
On 2017-5-4 at 9:04 AM, Owen Y said:
Chaps - this topic of water filtration seems detailed enough to deserve its own dedicated thread ;) , however a point about cleaning timing......
Note that, because the record is only partially immersed in the tank fluid at any given time, the total cleaning time for any point on the record surface is only a fraction of the total cleaning time period.  Inner grooves in particular, receive the shortest cleaning - by my calcs, only around 1/7th of the no. of mins/rev x the total mins cleaning time period.
eg. for a 2rpm motor & say a 15min tot. cleaning time, the inner grooves are immersed only for a total of around 1 minute!
The outer grooves are immersed for longer - for the same 2rpm mtr & 15 min cleaning, only for a total of less than 3 minutes.
Apologies if I'm stating the obvious, but a picture may help.....
Cheers, Owen
Correction:
As @Citroen has pointed out, motor speed is unimportant.
Partial immersion of the record means that:
- Inner grooves are immersed only around 2mins of a 15min cycle.
- Outer grooves are immersed only around 5.5min of a 15min cycle.
Hence, I tend to clean for at least a 25min cycle now.
Cheers, Owen
Edited by Owen Y
Hi @Owen Y just letting you know I got all the bits today.  Got it all set up but haven't tested it out yet. Thanks for all the good coms and advice within this thread. Cheers Matt.
Mine shouldn't be too far away then ,
Will do.
Well the parts arrived from Owen on Wednesday morning  very nicely packaged I must say, so today its time to clean the first batch came out beautifully they are gleaming and dry so quickly a big thanks  @Owen Y5972b4c74decb_URC1.thumb.jpg.c8a855ce23618579f1cb9ca752304c66.jpg
Edited by myskylab
Fingers crossed my Triton X100 arrives before the weekend. I have received my kit and am just waiting for the fluid.
Can you put L'Art Du Son in the mix?
Oh good.
Not familiar with that fluid - but with US cleaning, the US 'cavitation' actions shifts the dirt, the detergent surfactant action (release of surface tension) assists this dirt removal. (And also drying.)  So I guess that any detergent or solvent action should help.  But high concentrations are probably not so essential.
Cheers, Owen
1 hour ago, Owen Y said:
Oh good.
Cheers, Owen
I just remembered reading a post where you mentioned possibly adding an enzymatic cleaner. I believe L'art Du Son may fit the bill, it is generally used with Vacuum RCM's but was wondering if it would be of any benefit in US RCM
Ah yes, some U'Sonic cleaning enthusiasts add an enzymatic cleaner for those difficult to dislodge substances (proteins etc) - I haven't tried any.
So, nothing much different using a US cleaner - it's just ultrasonic action, which gets deeper into the grooves than brush cleaning (IME) & with a minimum of chemicals & if you are concerned, without use of solvents like alcohol, which some say tend to remove plasticisers from the vinyl.  Others (like L'Art Du Son) say that alcohol cleaning results in a unattractive tone.
Cheers, Owen
Cheers, Owen
I found these 2 products that might worth a try as they are reasonably  priced and available in Australia
Whiteley MedizymeLiquid Enzyme Cleaner 500ml $11.50,  MEDIZYME is a specialised enzymatic detergent solution that is capable of removing blood and other protein deposits.
Whiteley Sonidet Ultrasonic Detergent 5L $25.71, Sonidet is a highly active Neutral liquid detergent specifically designed for both machine and manual cleaning operations in the medical field. It is manufactured in a plant licensed by the Therapeutic Goods Administration. Sonidet is odourless, non-staining and is a safe detergent for the removal of hospital and surgical soils. Diluted solutions of Sonidet are colourless
I'm not a chemist but check the datasheets - fairly neutral pH, non-ionic - sounds good. (Sonidet).
Check for other additives - eg. Sodium Nitrite 'corrosion inhibitor'.
Also - the Sonidet can mix directly with water (they recommend 1:200/0.5%) which means that it is probably pre-diluted, not 100% concentrate detergent/surfactant. So maybe just consider the cost comparison against buying 100% concentrate of say Triton X100 or similar.
Cheers, Owen
Edited by Owen Y
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
    • By gtee
      Item: Record Cleaning Machine
      Price Range: to $1000
      Item Condition: little used
      Am interested in a vacuum type record cleaning machine in really good condition.
      No real preference but prefer a quieter ( ? )  quality machine. Some have suggested a VPI, Okki Nokki Mk2, or the like.
      Please PM me with any offerings
      I am in South Brisbane.
      Thanks.
