Owen Y
Our DIY Ultrasonic Record Cleaner
1 hour ago, RickRycroft said:
I'm having an issue where the records are working their way over away from the motor and sometimes the hand nut coming up against the frame and then it all stops rotating.
The cleaner is on a flat surface and I've tried with different tension when clamping the records and spacers together. The last batch I did last night I tightened it the most I have so far and rather than the bundle of records and spacers working over the whole shaft shifted and fell out of the motor. I have the motor rotating clockwise and the frame isn't moving so the outside of the records are not rubbing on the tank.
It's got me scratching my head. Anyone else had this?
I remember someone else having this issue, caused by a anti-clockwise rotation, rotation must be clockwise, which direction are you using?
Is the bearing nut holding the spindle (at the other end of the motor) moving freely?
Try lowering the motor end, or raising the other end plate.
Thanks for the suggestions. Yes, it's turning clockwise.
I've propped up one side to give a bit of tilt back toward the motor. If that works I'll do as Citroen suggests and lower the motor a bit.
I had this same issue. I just tighten the bejesus out of the nuts and haven't had an issue since. And I mean tight so that there is a heap of pressure on the spacers. Good luck.
Thanks chaps, keep us posted, @RickRycroft.
Good suggestions from @Citroen.
(Sorry, I am out of town travelling presently.)
Cheers, Owen
I think it's the plate the motor is mounted to. It's not quite vertical. I'll bend it a bit and see if that helps.
@RickRycroft, just put some low or medium strength loctite thread locking compound on the nut closest to the motor.  Make sure you screw the nut into the correct position after applying compound.  You'll never have to think about it again.
Thanks acg, that's a good Idea.
I've found that the shaft has comes out of the motor mount sometimes as well. Something is pull the shaft away. What I think was happening when the record stack shifted is that the outside nut rubbed on the frame after the shaft moved out. I might have to put some earplugs in and sit there and watch a session.
Chaps - the main issue, is when for some reason the end bearing unit develops any dirt or friction, the threaded shaft can ‘crawl’ itself out of the motor. Check & keep this bearing unit free-running. (We now rinse out the grease lube in these bearings, if it is too viscous.)
Otherwise, keep things level & be sure that the main frame is centred & does not allow the records to touch the tank ends. (Be sure that the main frame is a firm friction fit into the tank sides - bend the frame edges if necessary to ensure firm fit.)
Install no more than 3 records at a time & run the motor clockwise, as indicated by the arrow on the motor-plate.
As @Citroen says, the 2 side plates must be level/plumb too, but can be adjusted up/down to suit.
We’ve not had to employ any further radical measures 😉
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
Try adding an additional piece of metal on the bearing end which goes straight up above the bearing height. It can be held by the same screws as the bearing bracket. Now cut the threaded rod so it only allows for 2-3mm of end play when fully inserted into the motor. This stops the rod from being able to work it's way out of the motor drive.
Hi @t_mike, can you post a pic of what you mean, as I'm a bit lost by your description? Cheers.
I have found that the record migration issue in my case was when the records touched the right end of the bath (with the motor side to the back). Friction fit alone did not work for me, so I stuck two small silicon buttons under the left end of the steel frame to contact the top of the bath more forcefully. Record migration is no longer an issue for me, assuming I run the motor clockwise (which seems to be its least favourite direction!)
On 25/04/2017 at 10:50 AM, andyr said:
Hi Andrew,
Re. vacuum dry vs. air dry ... and the (good) effect of using a 1-micron filter:
  • this long weekend, I finally got my 1 micron filter working (with a 12v DC pump), with my Sonix IV US tank.
  • first, I listened to an LP which had been cleaned using the (previous) aquarium filter ... but not vacuumed dry.
  • then I re-cleaned it with the 1-micron filter in circuit ... then blow-dried it.
  • result - quieter!  :thumb:
  • I then re-washed it in the US tank for a couple of minutes - and then used my NG to vacuum it dry.
  • result - no quieter:party
So AFAIAC, using the 1-micron filter takes out all the crap which was in suspension in the water - which was previously resting in the bottom of the grooves with the liquid ... so was still there when the liquid dried (unless I vacuumed it out) and which caused the LP to be noisy.
Removing this crap in suspension results in a quiet record - so the 1-micron filter is doing a much better job than the aquarium filter.  So I no longer need to vacuum dry each side.  :thumb:
So my US cleaning setup consists of the following:
Unfortunately, I sourced these from Amazon - which I hate with a passion, as they don't offer any way of getting in touch with them to ask questions - but I know you can search eBay for the same pump.
Plus the following items from www.ultrasonic records.com:
  • 2 spindles with spacers (to take 6 LPs) and a gear wheel.  One spacer for the LPs in the US tank, the 2nd for LPs which are being blow-dried.
  • a frame with a slow-rotation motor, to hold the spindle at just the right height above the US tank.
  • a "Blower Cube" - a box with a powerful fan (and a lid) to blow-dry the LPs.  Unfortunately, this is not 100% effective, as supplied - I had to fit a slow-rev motor to turn the LPs in the airstream ... and I think it would be good to rig up some ceramic resistors in the base of the Cube, to provide a warming effect on the airstream.
So it's not a budget setup - but I believe it cleans just as well - if not better than - the commercial "all-in-one" units and I get to clean 6 LPs at a time.  :D
And my liquid mixture is: 7.8l of distilled water / 400ml of 99% IPA / 8ml of Ilfotrol.
@andyrI wanted to ask you if the pump you used is self-priming and if it works even not immersed in water, because from the rules on amazon it seems that it only works submerged.
Thank you
Thank you
No problem, Max.  :)
Not sure what 'self priming' means - all I know is:
  • the pump sits on the tiled (spare) bathroom floor - not immersed in water.
  • and it pumps the fluid just fine.
What I have found since I made that post, though, is:
  1. having a flow of water into the us tank is not a good idea whilst the tank is switched on (it reduces the effect of the us cleaning action).  So better to run the filter after a cleaning cycle, to remove all the detritus knocked out of the grooves, into solution.
  2. the pump I bought does not have a high duty cycle - so I need to run it for, say, 10 mins filtering and then switch it off during the 10 mins us cleaning.
3 minutes ago, andyr said:
Nessun problema, Max.  :)
Non sono sicuro di cosa significa "autoadescante": tutto quello che so è:
  • la pompa si trova sul pavimento del bagno piastrellato (di riserva) - non immerso nell'acqua.
  • e pompa il fluido alla perfezione.
Quello che ho trovato da quando ho fatto quel post, però, è:
  1. avere un flusso d'acqua nel serbatoio us non è una buona idea mentre il serbatoio è acceso (riduce l'effetto dell'azione di pulizia degli Stati Uniti). Quindi è meglio far funzionare il filtro dopo un ciclo di pulizia, per rimuovere tutti i detriti buttati fuori dalle scanalature, in soluzione.
  2. la pompa che ho acquistato non ha un ciclo di lavoro elevato - quindi ho bisogno di eseguirlo per, diciamo, filtraggio di 10 minuti e poi spegnerlo durante i 10 minuti di pulizia.
So @andyr  if I understand correctly you could not do continuous filtration, but stop the ultrasound and filter.
At this point it might be interesting to proceed with a further washing after filtering the liquid, thus having a very clean wash of discs in clean water, obtaining a disk that would not have on the surface of the dirty residue and could be left to dry in the air being sure you have removed everything, what do you say?
Max
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
