Owen Y
Our DIY Ultrasonic Record Cleaner
On 2017-5-19 at 11:27 PM, tesla13BMW said:
Only thing I noted is that the spindle seemed to move out from the motor drive so will do some adjusting of the bearing holder height to see if I can stop this.
@tesla13BMW - giving this further thought, be sure that the shaft is level, by adjusting bearing plate height.
Or even have the bearing end a touch higher.
Cheers, Owen
http://darklanternforowen.wordpress.com/
Hi Owen
I was going to do some adjusting but found the motor alternated its direction of rotation with each turn on / off cycle.  So if I have it rotating clockwise when looking from the bearing side it is naturally pushing back toward the motor.  I've had no further issue.
Cheers, Chris.
Been following this thread for a while with interest.
Information on RCM in this thread is gold :love
Edited by Guest
This looks like a good place in Aus to purchase Triton x-100 LR, $45.00 for 500ml http://www.ssapl.com.au/product-group/2969/category/392 still very expensive. Waiting to hear back from these guys that Owen uses Triton X 100, $49.85 for 1 L, http://www.conservationsupplies.co.nz/product/triton-x100-cle01/ regarding postage to Australia, will keep you all updated :thumb:
Total cost for 1L Triton X including postage to Aus. is  NZ $64.65 so it`s great value and Jeanette was excellent to deal with I hope this helps   :love
Edited by myskylab
Does anyone have a suggestion for a filter that will attach to the tap on the ultrasonic tank everyones using?
Doesn't need to pump, just something simple for draining the cleaning solution back into the bottle after use.
Thanks in advance!
31 minutes ago, Leinster Lad said:
coffee filter paper in a funnel should work a treat :thumb:
Ha I was thinking that! are the coffee filters fine enough to filter everything out though?
maybe something like this https://www.bunnings.com.au/stefani-chrome-on-tap-water-purifying-system_p5091498
Not sure it'd fit, or that there'd be enough pressure to force the water through though.. comes out at a dribble..
Edited by jack_b
Not sure on the actual specific particle size that they will trap, but very finely ground espresso grounds are mighty fine, and they seem to trap those. Could always double or triple the layers of paper.
Either way, it would be a pretty cheep and simple exercise to test it.  It will however be a slow process, as the fluid would only drip thru.
Edited by Leinster Lad
I really wouldn't bother with filtering after use. Just discard and replace. Unless using an alcohol component, the cost of the water and surfactant really is minimal, considering the amount of lps cleaned per batch.
I do see a possible benefit from filtering during use but not convinced yet.
Coffee paper filters are 10-20 micron I believe, so may be useful for removing larger bits of debris, dirt.
But as said, the detergent eventually depletes.
On ?3?/?27?/?2017 at 6:20 PM, Owen Y said:
A bit more info:
Fluid mix:
For starters, I'm using a water + Triton X-100 detergent/surfactant concentrate.  (I haven't checked if this is avail downunder, mine came from USA via a pal).
Drying:
So far, in our low 20's C summer weather, using a water + detergent/surfactant mix, then air-drying is fast. (20-30 min?)
Plain water doesn't film over the vinyl & takes much longer to dry. .I have a vacuum RCM but have not bothered using it for drying after US cleaning.
Right now, I'm using just carbon-filtered (drinking) water.
Static:
Vinyl is a poor conductor but water is a good conductor, so simply rinsing will reduce static. Wiping a record, is not such a good thing, if you want to avoid static-electricity.  And I believe that it is good to use a non-ionic, neutral pH detergent for starters, to avoid residual static charge.
(There is also a theory that a thin residual film of detergent left on the vinyl, after cleaning, aids groove tracing - I have to say it certainly sounds that way, signif more dynamic range, more energy..... )
Cheers, Owen
you can get Triton x 100 on Ebay in Aust.  Just purchased some myself.
how long do you guys have the US on during cleaning process?  I've been doing 15 mins but not sure if that's the right time period
you and I must have had the same thoughts this weekend John....:thumb:
15 mins at 35C with 2 cap fulls of melody mate what i use then a nitty gritty blast with melody mate..:)
Cheers Tase
Hi John,
Would you mind posting a link to this?
I only find international suppliers.
I've been doing 15 minutes too, i use 40º and upwards though. A few records that were in a poor condition have improved with a 30 minute session.
Hi @scuzzii - because of partial immersion & rotation, I consider 15 mins an absolute minimum.
(See my May 4 post.)
If you've got patience, give it 20 mins or even more.
Cheers, Owen
3 hours ago, Edd said:
Hi John,
Hi Edd
looks like I must have grabbed the last one.  I did a search and also clicked on the ebay link.  That seller doesn't have any others
Edited by scuzzii
On 2017-5-16 at 11:26 AM, Owen Y said:
Drying - The surfactant means rapid air drying. But vacuum drying is excellent, if you have a conventional RCM to hand (with clean nozzle/brushes of course). I will experiment with a water rinse beforehand too - I'm not paranoid about water purity, regular carbon-filtered drinking water works fine for me.
Your comments & feedback welcome.
Cheers, Owen
US clean followed by RCM with Melody Mate heavily diluted for the US cleaner then a small amount on the Nitty Gritty RCM trough and the results are excellent....
temp set at 35oC but does jump up when the US cleaner is in operation though..
Tase
Triton X-100:
That's the best price so far, over Oz way.
Hopefully importing is hassle-free, it's only detergent ;)
Cheers, Owen
Guys will this surfactant you're referring to work in other devices, such as the Disco Antistat?
Tim - the 500ml is cheaper than I got on ebay...  as per PM
John
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
    • By gtee
      Item: Record Cleaning Machine
      Price Range: to $1000
      Item Condition: little used
      Am interested in a vacuum type record cleaning machine in really good condition.
      No real preference but prefer a quieter ( ? )  quality machine. Some have suggested a VPI, Okki Nokki Mk2, or the like.
      Please PM me with any offerings
      I am in South Brisbane.
      Thanks.
