Owen Y
Our DIY Ultrasonic Record Cleaner
On 17/11/2019 at 9:14 PM, candyflip said:
I paid $300 for this damn thing (s/hand).
Can't I just get it fixed by someone in the know?.....
Or has this throwaway culture gone so far as there is no-one left to look at machines like this anymore?   :(
@candyflipI agree with your sentiments but  with out the knowledge to be able to repair the Ultrasonic bath yourself , the cost of the labor and parts is likely to  be much more than the baths can be presently purchased for.
Not all the Chinese US baths are the same and I have had mine for three and a half  years ,cleaning thousands of records with only one minor problem, that even with out being a Electrician, I was able to repair my self.
The bath I have are presently selling for $165.99
WWW.EBAY.COM.AU
Ultrasonic cleaning is based on the cavitation effect caused by high frequency ultrasonic wave vibration signals in fluid. 1.3L / 2L / 3L / 6L/10L/15L /22L/30L Digital Heated Ultrasonic Cleaner...
So my recommendation would be to buy another one, so you can start cleaning records again.
Yes you can spend $1800 on a ,perhaps, non Chinese, US bath and if that is what you want to do, go for it,but I do not believe you have to, to still get good results
This is my post relating to the problem with mine
Noticed recently that the ripples on top of the water, in the Ultrasonic bath, were not quite the same and cleaning was a bit off.
I  assumed one or two of the three transducers must of failed. Not too bad considering I have probably cleaned  20 to 30 records a week for the last three years.
Opened up the bottom of the unit to see if replacing the transducers was an option or there was an easily visible fault.
Removing the bottom panel revealed that the transducers were wired in series and one had come un soldered, perhaps through a dry joint and vibrations.
Re soldered the offending joint and it is now as good as new.
Second picture is before soldering, wire just striped back and twisted round tab. 🙂
Edited May 16 by EV Cali
 I am led to believe, by a post on another site,   that the 40kHz bath are presently being sold for a lot less than the cost of their parts, primarily because of the economies of scale, not because 60 kHz or 80kHz baths are actually more expensive to make.
3
Edited by EV Cali
@EV Cali that seems a strange configuration. It appears that two transducers (on the left) are wired in series, but the one on the right is from it's own separate waveform generator.
Edit: OK, probably not so strange, after doing a bit of a google and looking at common drivers and transducers. It looks like maybe one 100W driver supplying two 50W transducers, and a second 50W driver supplying one 50W transducer. Don't know how they sync them though, or even if it is a problem not being synced.
BTW most "electricians" wouldn't have a clue about them LOL, you need an Electronics Technician.
@candyflip in reality, they are a pretty simple circuit. A basic power supply and a square wave generator. So it shouldn't be too difficult for any Electronics Tech to repair. Where the problem comes in, is sourcing replacement parts, and the job hours. I imagine that most would be charging in the vicinity of $100/hour and some more than that. That's one of the reasons I got out of the game, the repair costs started to overtake the replacement cost of a lot of gear that was only worth a few hundred dollars, and make it not economically viable to repair.
Check out your local TV and consume brown goods repair type people, if you still have any in the game. Most have given up nowadays though and only a few diehards seem to hang on.
Edited by bob_m_54
more info
@BoB-M
"@EV Cali that seems a strange configuration. It appears that two transducers (on the left) are wired in series, but the one on the right is from it's own separate waveform generator.
BTW most "electricians" wouldn't have a clue about them LOL, you need an Electronics Technician."
My Trade is a Carpenter and Joiner  but the configuration did appear strange  to me. Two transducers wired in series meant I lost both transducers when the wiring to only one failed.
On the bright side I may not have noticed the difference so soon if only one had.failed
Finally have had the chance to drop the bottom cover off both my dead machines. Ome has destroyed at least 1 if not 2 of the exciters. This can be seen by the epoxy falling out of them and the wires getting hot and fusing the solder joint. The other machine seems to only have fryed a transistor, so I'll attemp a repair on that one and see how things go.
I don't have the skill to make my own so I just brought one from China.
Remember how I turned my US machine up too high and burned it out?
It also did a nice number on one of my test records.  :)  LOL
Does the US clean offer an advantage over a vacuum machine like the new Project vc-e? http://www.clefhifi.com.au/catalog/product_info.php?products_id=4444&gclid=CjwKCAiAluLvBRASEiwAAbX3GSjJGzqIgkmELorXtXxvY5qxpnj7ruBWNTuCDjcHl6rEZGcZxIVD5hoC3YMQAvD_BwE
Are there any pieces of kit still available to purchase?
Hi @crtexcnndrm99
Ultrasonic freq 'cavitation' penetrates deep into fine, deep recesses of objects, like record grooves, dislodging gunk - that brush-scrubbing does not manage to get to.
If wish to add some detergent-surfactant to the water, it helps to 'solubilise' oily or adhered substances like record-pressing release-residues.
This helps rapid air-drying of records, as the water 'films' thinly over the record surface.
Or, ideally, use a record vacuum to vacuum-dry afterwards.
Yes, 'kit' parts are here ready to ship - price is still A$149 + airmail $15.
Assembly is simple, just 4 screws (+ 3 motor screws) - but we provide instructions & some cleaning advice.
You just need to get the tank & rotisserie motor....
I was given this link recently to the PS-30A, 6.5L tank needed:
https://www.ebay.com.au/itm/New-6-5L-Mechanical-Industrial-Ultrasonic-Cleaner-Ultra-Sonic-Wave-Tank-Basket/274098967977?hash=item3fd19255a9:g:LVsAAOSwEP5dnEwr&frcectupt=true
https://www.bunnings.com.au/gasmate-240v-rotisserie-motor_p3180311
https://www.outdoorsdomain.com.au/gasmate-240v-rotisserie-motor/
https://www.ebay.com.au/p/1938162590
More info here - https://darklanternforowen.wordpress.com/2017/05/12/ultrasonic-record-cleaning-pt-2/
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
15 minutes ago, Owen Y said:
Hi @crtexcnndrm99
Cheers, Owen
That sounds excellent. I’d like to purchase a kit then!
Hi @crtexcnndrm99 - excellent, we can have one packed for you within a day or so.
When it's packed ready to ship, we'll Paypal you.
Please PMessage me your postal name & address & email for Paypal.
Cheers, Owen
Cheers, Owen
Sounds great - pm sent!
Someone brought to our attention this ebay.au link for the Ultrasonic Cleaner tank which appears to be the same as what we use & fits our kit:
Price seems good at AU $166.99 for the '6.5L' model. (Model PS-30A)
https://www.ebay.com.au/itm/Digital-Ultrasonic-Cleaner-Stainless-Steel-Heater-Timer-Industrial-Grade-1-3-30L/282539569913?hash=item41c8abb2f9:m:mZod3FFNC6C2NgX0NKn8Ixw&frcectupt=true
Cheers, Owen
Although some users report improved results with heating the fluid, I don't think that there is any need to turn on heating in these US cleaner tanks, the system cleans beautifully without heating, using just the 0.1 -0,5% surfactant/detergent mix.
The ultrasonic action tends to raise the fluid temperature a little anyway (depending on how many records/cycles you run in a session).
I do recommend vacuum-drying if you still have a record vacuum or such.
And either filter of otherwise keep your fluid as refreshed as clean as possible.
Cheers, Owen
Just for info, I have a similar unit that I got from the guy who invented this type of cleaning device. It works well, the cleaning mix is about 80% distilled water 20% pure lab  alcohol and a couple of drops of Kodak koda flow, this works well.
And I have found that to get more use out of this mix before replacing the fluid just float a couple of large Kleenex tissues on top of the fluid when all of the gunk from the records has floated to the top, then carefully slowly remove the tissues and all of the floating gunk will stick to the tissues.
The science says US are barely effective with fluid temperatures less than a fair whack of heat being added (technical terms) ;)
I can quote the papers for you, but a Google search turns up a bit on it.
My understanding is that 5% alcohol is the go - especially if you heat the liquid.  Any higher and you are risking the alcohol igniting.
Quote
That is a great trick!  :thumb:  However, whilst it will certainly remove the scum ... I suspect there is gunk which has fallen to the bottom of the tank - so a filter circuit is required.
Edited by andyr
You need in excess of 40% ABV to ignite. Try it out on your preferred spirits... hic..
Edit: Warning, don't try it with Stroh Rum...
Edited by bob_m_54
Chaps - my experience is that ultrasonic cleaning with a 0.1+% dilution pure, non-ionic, detergent-surfactant mix at ambient temp.  gives excellent sonic results - more balanced tonally (without the slight brightness) than traditional (20%) iso-alcohol-water-surfactant cleaning  & the stylus seems to track better (dynamics are more open at both ends of the freq band) - I suspect that detergent residue may be a factor, not unlike when using Lyra's SPT stylus treatment.
Depending on season, anything from 18-35deg C works very well.
I clean also new vinyl, to remove stamper-release residue before playing. This gives consistently good sonic improvements.
Cheers, Owen
If you run a 5% IPA mix at 35 degrees, does the alcohol evaporate ?
Mr Relish
Mr Relish
Naturally!  :)  So:
  • that's probably a good reason to start with a higher %, and
  • you keep having to top it up.
Mr Relish
Yes it does, but not at a rate that will produce flammable levels, at moderate temperatures. That's why you should always ad a nip of brandy, when topping up your port barrel, even though it is ethanol.
See how drinking can be such an educational activity? hic..
Edited by bob_m_54
I am getting ready to give this a go.
Do the labels ever get wet? I am not very keen on that.
Is the authoritative process for both precious/collectables and market scores posted somewhere? eg do you use revirginiser/glue or purely the US cleaner? Do you wipe them with something special or how do you dry them? How long do you bath them for?
Any other equipment needed?
I haven' read all of this topic, but one comment I will make is that while mechanical processes can remove surface gunk and dust, it can never restore a played vinyl record to its original, pristine condition. This is because the stylus exerts so much pressure on the record at its point that it liquifies the vinyl. So the vinyl becomes a liquid then solidifies again once the stylus has passed. This allows 2 things to occur:
  1. microscopic distortion in the groove as it melts and re-hardens,
  2. foreign matter that is present in the groove to fuse to the vinyl while it is in a temporary liquid state.
No cleaning process can correct for these.
    • By Demondes
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Hawthorn State: Victoria Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: Looking to upgrade and automate the RCM process Further information:  I have had the Kirmuss since August 2018 (locally bought in Melbourne, 1st owner), probably have done around 400-500 records in this time.  I also bought a Record Doctor v5 at the time to vacuum dry the records that came off the Kirmuss wet.  I found this way worked very well and you could clean a batch of 30-50 records (dependent on water cleanliness) in a few hours  You can clean 2x12 Inch records on the Kirmuss move those to the Record Doctor for vacuum dry and then lay the records out on lint free cloth for up to 1 hour to dry before putting into clean inner sleeves.
      The RRP of a new Kirmuss (same model) is now $2800
      Most original items are included, including the cloth, mat, plastic drain pipe, camel hair brush, instructions, a couple of extra cleaning pads, power cord
      Used consumable items originally included:
      1) The included cleaning fluid is included but is 90% gone but it really is not required (used for extra pre-clean).  In the Kirmuss I used a combination of Distilled Water, Isopropyl Alchohol and Kodak Photo Flo 200
      2) Stylus cleaning liquid that i never used, but it is missing
      3) a record cleaning brush supplied is not included
      Record Doctor v5
      Selling both together as the Record Doctor is basically a giveaway to use in line with Kirmuss
      includes brush, use guide and a full bottle of record cleaner
      Note the 2nd last photo, shows the plastic liner on one section is loose from MDF in top left corner.  Some glue would stick that back down
      Kirmuss is the original double boxes and the Record Doctor comes in the original single box with foam support
    • By evil c
      Item Condition: Very good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Glen Waverley State: Victoria Payment Method: Paypal, EFT, Cash on pick up. Reason for selling: NLR Further information:
      Knosti Record cleaning machine, fantastic unit and very good for restoring vinyl .
      Bought a few years ago from Audio Trends.
      Supplied with full 1Lt bottle of record cleaning liquid
      Not only is it remarkably good at cleaning your LPs but it's quick and easy to use and there's none of the noise and palaver associated with more elaborate alternatives. It's by far the cheapest wet cleaner on the market and to be frank, it's as effective as any other." Hi Fi Choice
      "The results were visually impressive. All visible finger marks and dirt had been removed leaving a satisfyingly glossy surface. Before and after playings proved that this system does a good job. Surface noise was drastically reduced and clarity improved to a surprising extent." Hi Fi News
      "We can't recommend this gadget too highly." AV Review
      Revive Your Vinyl Collection. Record Washing Machine. Helps Minimise Static. Removes Dirt & Dries Residue Free. Does Not Require Power. Easy To Use. Very Economical. Replacement 1 Litre Refills available. Made In Germany.
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
