Owen Y
Our DIY Ultrasonic Record Cleaner
A pic of one of our kits, from Mike in California.
It's good to have a decent 1" (23-25mm) or so between records, for the ultrasonic cavitation to work nicely & in some cases if I'm really fussy, I'll clean only 2 records a time (with a double spacer between).
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
Edited by Owen Y
Chaps, an update:
Just a note that current price of the kit is A$149 + airparcel postage $15 to most parts of AU.
(Kit is as below.)
You just need to purchase a model PS30A tank from ebay.au & a Gasmate rotisserie motor.
Assembly involves 4 screws + attaching the motor with 3 screws.
Cheers, Owen
Well mine blew up on the weekend.... I'd been testing just how hot I could run a record through it (that was already warped) and see what happened to it. So it was running at 80 degrees + (the max on the dial) and I didn't hear a pop or spark, or smell anything. IT just finished a run and I noticed my cavitators just didn't seem to be....cavitating!  :)   It had gone a bit quiet.... more like a gentle 'ticking' now instead.
I think I broke it!   🙃
80 f'ing degrees, cf!!  WOW!!  :(
Maybe just let it cool down and it will get back to working again?
I know, I know - live dangerously and all that.  ;)
Yeah maybe - ....I'll do it on the weekend, see how I go.
BTW - I've been using filtered water out of our large home Brita-like filter unit, which comes with a built-in tester, and the water filtered out and used in my cavitator is showing Zero parts per million contaminants.  So I reckon whoever said they were doing that earlier on, is probably on the money for effectiveness and cost benefit ratio.
I'm using Kodak Pro Photo-Flo 200 from Vanbar in Victoria (2 x 473ml bottles were under $30, pick-up) and I've barely touched the sides on bottle #1 yet... great stuff to use. 5mls per 2 records in the machine.
Here is the current iteration of my cleaning rig. Was great with just tap water, triton-X, and isopropyl alcohol. Have taken on board others suggestion, and have gone to demineralised water, and put together a filtering line. Running a few second hand mono classical albums and assorted other bits n pieces. Soon we will see how it all works out- will the results go from A to A+?
I'm curious to know, J, why you went for that narrow white pipe?  I will be restricting your water flow, compared to the clear piping from filter to tank.
The white pipes were purely what was suggested by the bloke at the water purifier place where in bought the filter. I had some aquarium tubing in a couple of gauges, but this worked out best with the mix of joiners I had. It is what is used for filtering systems under the sink, and there does not seem to be any limitation of flow in practice- if it was used for the final run back to the tank, I imagine it would hose out with more pressure that I want. I imagine the one micron filter is more of a limitation, though I don’t know. As a side benefit, it looks quite neat. It would have been easier if I had a pump with standard threads, but I was too impatient to wait for eBay, and was going to the pet shop for other reasons, so I made do with the small aquarium pump!
Justin
Edited by Juzbear
Agreed!  :thumb:  IMO the filter is so much of a limitation that you don't want any additional ones!  :lol:
Should be fine - I imagine the duty cycle for an aquarium pump is 24x7?
Well now it's actually working ... you have time to organise v2.0.  :)
Yes, I use a 0.2 micron filter so no aquarium pump for me.
Today I am modifying an old 20 litre water cooler/esky to cycle my water through so that I can keep cleaning records and not have to wait for the water to cool down.  It's bloody warm here in Qld, and it does not take much cleaning to warm up already warm water.
Clean some records >> dump the warm water into the 20l cooler >> start the filter pump >> take a new, cooler usc tank-full of water from the the clean side of the filter >> load-up the next spindle of records >> keep cleaning.  Owen was kind enough to sell me three spindles so I can have two spindles on the drying rack and one in the usc at any one time.
Great concept, acg.  :thumb:  Your filtering action - to remove the dislodged gunk from the cleaning solution - takes place in a separate tank from where the us cleaning is going on.  (As I'm sure you know, 'best practice' says that you shouldn't have the pump running whilst the us vibrators are turned on - as the water flow reduces the effectiveness of the us action - so I currently have to have a 10 min clean cycle followed by a 10 min filter cycle ... so cleaning takes twice as long!  :(
I need to think about following your lead.  :)
Edited by andyr
I have thought about getting another spindle to speed the process a bit- I think that would be the rate limiting step for me, rather than filtering. I usually do a twenty minute cycle, so thought I would do the same, but filter for the last five minutes or so (when I am watching it, otherwise I just do five mins when I get back to it).
How hot do you run your water? Down here, I have to heat it to reach my aim of 40 degrees- it started at 14 today! So no need to cool it in an esky for me.
I figure that the relatively slow flow won’t impede the US too much, though I have no evidence to back this up!
From my first post, I was wondering how much “betterer” it could get. I am not sure that the records sound any different, but hopefully all this will streamline the process and reduce the need to manually replace the water.
Don't want it to go over 40C, prefer 35C, but still getting used to the whole system.  Was 37C here yesterday, so it does not take any heating whatsoever for the water to reach 40C and it ain't going to cool quickly on its own with our summer temperatures, hence the additional reservoir of water to spread the heat load.
Still blown up.... not cavitating.
Looks OK inside....no really smoky smells or anything.
Everything seems alright, but I'm useless with electrics.
... and mine just did the dame thing! This is the second of these cheap Chinese tanks I've had die on me, so no more. They have nowhere near enough power to clean even 1 record at a time. When you calculate surface area, you need to allow about 50% more than the surface of both sides of the record due to it being grooved, not flat. These machines are not up to the task, and start to reduce in power from day one. The exciters vibrate themselves to death. Anyone notice what appears to be pumice crumbs appearing under the tank after use? This is the epoxy that holds the exciters together and adhered to the tank. This starts to break up from the vibration, and in the case of my first tank, suffered a short as the exciter self dismantled. That's a 240 vot short in a metal tank!
Hmmm....
Hmmm....
bugger....
Image result for damn
@candyflip  @t_mike
I was not game to go straight with the chinese tank so I purchased one of these.  It is very quiet, is dual frequency, is German made, has an Australian warranty, and fits Owens kit with only a little bit of dremel work on a couple of nuts on the kit.
Edited by acg
1 hour ago, acg said:
@candyflip  @t_mike
Truth be known, this is the sort of money you have to spend for a decent US machine. There certainly is a reason why the purpose made US record cleaners cost as much as they do. Years ago when involved with motor racing, we used to use a small US cleaner for fuel system parts. They were very expensive machines and they worked well. They also had a lot more power than the Chinese tanks on ebay.
@candyflip  @t_mike
Great tank, acg - and 80kHz as well as 40kHz!  :thumb:
I also decided I would pay more for a non-Chinese us tank, a couple of years ago.  I bought a (US-made), 60kHz Sonix-IV tank - which I'm very happy with.
I paid $300 for this damn thing (s/hand).
Can't I just get it fixed by someone in the know?.....
Or has this throwaway culture gone so far as there is no-one left to look at machines like this anymore?   :(
I have limited electronic skills, but pretty good google skills, and it would seem that they can be fixed. You just need someone who has the first set of skills you can outsource to, if you are lacking them yourself! There are plenty of folks on here who may be able to help, though given the price of them via ebay, it may not be worth investing too much time.
Cheers, Justin
Cheers, Justin
That's not helpful at all, and not the reason I posted above.
No Google search is going to specifically direct to an 'Ultrasonic cleaner repairman' in Australia.  :yawn:
Even less so since the culture we have all raced to adopt now means there are very few electronic repair specialists making their services obvious, Google or not.
It's exactly the highlighted part above I was hoping to hear about.
I am disappointed you didn't find it helpful, and that you felt the need to post back saying so- I was certainly not trying to make light of your very valid point about the lack of repairability of many of the electronic items we use currently. I looked firstly to see if people were repairing them- they certainly are, and from looking at the posts, often the repairs sounded easy, in the order of replacing a resistor. I also thought that there may actually be ultrasound repair techs, as our audio part of the world is tiny, compared to the uses in health, computing, etc. I did not find these, but thought the other information may be useful in enlisting the help of the many DIYers on here. As to electronics repair, there are quite a number of places that come up when you google this, if that answers the question better.
I read your post, spent some time thinking about how I might help, did what I could, and posted back to the best of my ability and in good faith.
Justin
Justin
So this is the post where I reflect back on reading the original post without really getting it, responding accordingly which could come across awkwardly, and then getting offended by Candyflip's response. Given I am here for light relief, and enjoying the journey, I hope that nothing I have said offends. @candyflip I am sorry for a bit of an overreaction.
Nothing to see here, move along...
Thanks mate.  🎖️
So, can anyone assist or do I go and talk to some Jaycar employees and nudge them for a 'contact'.
How ridiculous it is that we have got to this state.....  😔
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
    • By gtee
      Item: Record Cleaning Machine
      Price Range: to $1000
      Item Condition: little used
      Am interested in a vacuum type record cleaning machine in really good condition.
      No real preference but prefer a quieter ( ? )  quality machine. Some have suggested a VPI, Okki Nokki Mk2, or the like.
      Please PM me with any offerings
      I am in South Brisbane.
      Thanks.
