Owen Y
Our DIY Ultrasonic Record Cleaner
On 28/07/2019 at 5:35 AM, maxpina said:
Finally I managed to clean a bit of vinyl with my new system, the result was excellent look at my video
Thanks !
Very nice set up there maxpina...
Now about that sucking wand...I want one!
How did you build it and what parts did you use please!?! Any links?!?
Of course, @Owen Y, you can publish it on your site, I would very much like it! The box contains the pump that sucks the liquid from the drain into the bottom, sends it into the cartridge with the 10 "high polypropylene filter of 1 micron and then the liquid comes out clean and is reintroduced in the upper part of the ultrasonic tank.The pump has a flow rate of 800 l / h, I carried out tests and with the filtration system it reaches 400 l / h, so the tank contains about 6 liters of liquid so every minute it should filter all the liquid contained in the tank.Here are the links where I made some purchases:
Ultrasonic Tank
Kit for rotation
Rotation motor
filtration pump
Cartridge Filter
Filter
Inner sleeve
Edited by maxpina
2 hours ago, EV Cali said:
Hi @benny
What do you use to power the pump.
Robin
Hi Robin,
I use a 12V powerpack from an old linksys router that i pensioned off. but Any 12Dc wall wart should do the trick, so long as it can deliver the amps the motor pulls.
Thanks chaps.
Tank fluid volume is actually is only around 4.5 L - when I measured it once.
(As @benny mentions.)
@benny - how often & when do you run the fluid filtering?
Or do you run continuously during cleaning?
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
Edited by Owen Y
On 10/08/2019 at 8:47 AM, Owen Y said:
Thanks chaps.
Cheers, Owen
Hi Owen,
Sorry for the delay, i run the filter between cleaning cycles.
I plan to do experiments with doing it once i've taken the records out (ie residual water left on the records contains dirt from the cleaning process)
Vs
Leaving the records in and running the filter for 10 mins or so with the records still rotating (ie effectively rinsing them in 'cleaner' water before removing them from the tank).
Unfortunately being in a 1br unit - US cleaning means i cant listen to music, so i dont clean my records on a daily basis!
If others want to perform the experiment too id be interested to hear their thoughts.
Ben
vs.
My reading on the DIYAudio us cleaning thread suggests that running the pump/filter reduces the effectiveness of the us cleaning action.
Yet, as you say, taking the records out of the tank at the end of the cleaning cycle (with the pump/filter having been turned off) means that the residual water left on the records contains dirt from the cleaning process!  :(
So far, I've been leaving the pump/filter on during record cleaning - however, I shall change to having it off during the actual (10 minute) us cleaning process.  But I like your concept of then having a 'rinse' cycle before taking the records out of the tank - so I'll run it for a further 10 minutes with the pump/filter on:thumb:  This will mean:
a.  the residual water on the records will be clean, when I take them out of the tank, and
b. the water in the tank will be clean ready for the next cleaning cycle.  :)
Edited by andyr
On 18/08/2017 at 10:41 PM, Guest Y B said:
Wow! That's exactly half the of what I am paying now. What's the name of your local chemical supply company?
Since I have already got the Ilfotol, I would just be contended with it and hopefully by the time my Ilfotol finishes the Triton X-100 or Tergitol is easier to obtain. If not, I would just get more Ilfotol as it is so readily available. :)
Hi are you still using the llfotol ?
if so what sort of results are you getting and what ratio are you using please ?
I act in this way: I turn on the ultrasound, I clean the vinyl for 15 minutes at a temperature of 30/35 ° C, then for 3 minutes I turn on the filtering system with the ultrasound system and the rotation motor still on, in this way I performed the cleaning for a good period of time but at the end and 3 minutes are sufficient because with a flow rate of 400 l / min of the pump I can completely filter the contents of the tank for three times!, I think this system is valid, I put the image of the filter at the end of the cycle of about 50 vinyls
Update:
20 min bath in 30deg triton/rodi water (0.1% concentration)
Followed by 10 mins with the filter running with the motor spinning.
Record doctor to vacuum water off disks.
Disks seem to be silent. I guess it boils down to the quality of the vinyl, but it’s cleaned up 30+ year old records to be dead silent.
It will be my workflow for the time being.
Keen to hear others experiences.
Ben
On 31/07/2019 at 2:37 PM, benny said:
Hi @benny
Do you know the exact size of the hose fitting you have fitted in to the tank tap, as I want to purchase one and am not keen to take the tank in to Bunnings to try some.
Robin
4 hours ago, EV Cali said:
Hi @benny
Robin
Hi robin,
i bought mine from Reece, I can’t remember the exact size I think it was 1/2” to 10mm hose barb.
Sorry im not much more help
Hi Robin,
I have just purchased all the brass fittings I needed today - you should be able to get most of them from Bunnings, or on websites like plumbingsales.com.au
If you have a PS-30A tank they are 10mm.
Chris.
22 minutes ago, patrol42td said:
Hi Robin,
Chris.
Hey Chris - just noticed the Oracle Delphi in your pic,
Is that your table?
Hi Guys,
Got my kit put together this weekend and picked up my Pro-Ject vac cleaner as well.
Was using Illfoto and alcohol pretty happy with the results but I will order some Triton to compare.
I'm thinking of using  silicone to stick the top frame to the tank I imagine it will lessen the noise from vibration and stop it sliding forward ,has anyone tried this?
Thanks Owen and Andyr for all your advice so far , much appreciated.
Pic of my setup below
On 14/07/2019 at 9:37 PM, andyr said:
I buy 5l containers of distilled water from Autobarn.  Maybe $13 a pop?
Hi Andy,
I get mine from Bunnings its about $4.00 for 5l
Edited by SteveOscar
24 minutes ago, SteveOscar said:
Hi Andy,
Thanks, Steve.  Pedantic as I am ... can you tell me what type of 'distilled water ' is it?  (I believe there's a. steam and b. membrane? (And steam is preferred.))
1b629f78-5478-48e8-97fb-545f5b2f7c86.pngHi @andyr
Bunning's is Steam distilled but you get 10L for $12.99 at Auto barn, rather than 5L for $4 at Bunning's so not a great deal of difference in price.
https://www.autobarn.com.au/refresh-industrial-steam-distilled-water-10l
I have now installed a 1 micron filter system and started using distilled water ,on the basis that it is better than tap water ,I can use it for an extended period and it is cheap.
Thank you, EV!  :thumb:
I totes agree with using distilled water in place of tap water! :)  And, yes, a 1 micron filter is a necessity, IMO!  :lol:
BTW, in case you haven't read how to suck eggs, AIUI the cleaning cycle should be:
  1. pour in the water - plus whatever else you use in the cleaning mixture.
  2. turn on the us tank for 10 mins, to 'de-gas'.
  3. maybe turn on the heater (if you have one), to get the water to 35 deg C.
  4. put the spindle of LPs into the us tank.
  5. rotate - I do this for 10 mins.
  6. turn on the filter and turn off the us transducers for a. a rinse cycle and b. to clean the water, for 10 mins.
  7. repeat 4-6 with your next batch of records!
Im an ex marine aquarist - so I instead have my own 4 stage reverse osmosis deionising water filter with inline TDS meters and such.
It goes through a micro sediment filter, an activated carbon filter, a reverse osmosis membrane, then deionising resin. Can theoretically get water as pure as/ more pure than distilled water.
And you can make it anytime you wish... Downside is the filter costs about $350 to buy.
But a thought incase you guys dont want to goto the hardware store everytime.
Just a couple of pics of the Ultrasonic machine cleaning 7" 45 singles.
Drop the side plates a few mm., add a little fluid.
Cheers, Owen
Edited by Owen Y
@Owen Y Which adapter should be used for 45 rpm?
2 hours ago, Owen Y said:
Ciao @maxpina  - quei singoli da 7 "sopra, sono piccoli dischi, non è necessario alcun adattatore.
Saluti, Owen
Blog di Lanterna Oscura - http://darklanternforowen.wordpress.com/
But this type of vinyl has a hole much bigger than 33 rpm!
Hi Max
You will need to get some record centers ,if your singles have the larger holes.
https://www.ebay.com.au/itm/10-Pack-45RPM-Adaptors-Spider-Inserts-for-7-Vinyl-Records-Jukebox-NonSlip/273471287518?hash=item3fac28b0de:g:HuAAAOSwwltboxPj&frcectupt=true
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
    • By gtee
      Item: Record Cleaning Machine
      Price Range: to $1000
      Item Condition: little used
      Am interested in a vacuum type record cleaning machine in really good condition.
      No real preference but prefer a quieter ( ? )  quality machine. Some have suggested a VPI, Okki Nokki Mk2, or the like.
      Please PM me with any offerings
      I am in South Brisbane.
      Thanks.
