Owen Y
Our DIY Ultrasonic Record Cleaner
15 hours ago, Owen Y said:
Hi @balk2117 - which tank have you ordered?
Cheers, Owen
http://darklanternforowen.wordpress.com/
Hi Guys
To those that might be interested, this is the tank that I purchase through eBay thanks to the link provided by EV Cali.  Owen seems to think that this is the correct tank for his template to work -
  • Tank Material: Stainless Steel SUS304
  • Heating Power: 200W
  • Ultrasonic Power: 180W
  • Frequency: 40kHz
  • Power Supply: AC220V 50Hz
  • Tank Capacity: 6 L
  • Time Setting: 1 - 30 minutes (LED Digital Display)
  • Temperature Setting: 0-80 degrees Celsius
  • Transducer Quantity: 3 set
  • Tank Size: 11 3/4 "×6 "×6 " (L x W x H)
  • Ultrasonic Cleaner Size: 14 1/2 "×6 3/4 "×10 3/4" (L x W x H)
This tank certainly appears to be the same as mine & Citroen's.
The product label (on the rear) is different - but the model no. PS-30A is the same.
Except that:
- Be sure to get 220-240vac version (not 110vac).
The key dimensions are:
- The tank top size - mine is 325mm L x 176mm W (12.8" x 6.9") - I see that the given Length dimension is 14.5", which may include the outlet valve.
The tank top length must not be less than 325mm & the tank top width must be 176mm (6.9"), or less.
Cheers, Owen
Edited by Owen Y
Hi all,
Please keep us posted on where you have successfully sourced this cleaner tank from - as there seems to be some variation in listings/sources (as often is the case with online China-manuf products).
Also the out-of-stock situation, that some mention.
Cheers, Owen
This is the ebay link of the one I ordered only last night.
http://www.ebay.com.au/itm/111529951412?ul_noapp=true
In the process of determining they would supply 230V I ended up going direct and obviously saving them the ebay fees.  I used paypal and payed 130AUD delivered to QLD.
Now fingers crossed it arrives and works :unsure:
Appears to be identical to mine and now about $40 cheaper than six months ago!
I also purchased mine from an Australian seller ,as I thought it would then have to comply with Australian standards.
Mine arrived with a mains lead that had a non au plug on it, plus an adaptor.
I just swapped this for a better quality standard AU lead .
Perhaps the better power lead increased its cleaning ability. :)
On 3/31/2017 at 8:36 PM, ABG said:
@Leinster Lad  Some records are inherently noisy.  You can minimise the noise, but you'll never get rid of it.  Some records are produced exceptionally well and will play without a hint of noise.  Most fall somewhere in between.
My experience is that all of them are improved by cleaning in an US cleaner.  The results are significantly improved (and often drastically improved) by running the still wet records fresh out of an US cleaner through a vacuum type RCM.  I tried letting records air dry when I first got my US cleaner - let's face it, it's less work - but now I run them all through my Record Doctor V after a bath.  I reckon the US cleaner loosens the crud, the RCM sucks it away from the grooves.  See if you can borrow one to try for yourself.  I reckon you'll be pleasantly surprised.
That is what I have been saying in a another thread regarding US cleaners.
On 4/26/2017 at 6:59 AM, Owen Y said:
Fully assembled, it looks like this....
(Sorry, the white protective plastic film has not been fully removed from the stainless top plate in this photo ;) )
Cheers, Owen
looks like a professional RCM.
ABG posted:
In response, ST posted:
When I was using the same filter that Andrew uses, my results were the same as his - a vacuum dry with my NG was needed, rather than blow-drying them.
But since replacing the aquarium filter with a 1 micron water filter (& 12v pump), I have found that a vacuum dry doesn't improve things.  So I can go back to blow-drying them 6 at a time.  :thumb:
I have also been advised that the last unit was damaged and there are none available for 30 days. I have been offered a refund which I have asked for and will try the latest link.
7 hours ago, andyr said:
ABG posted:
Andy, I've been giving this some thought and am unsure about your findings.  What your essentially saying is that the cavitation process is removing all of the crud, not just loosening it and your filter is so fine that it's removing all of the suspended particulate matter before you take the records out of your machine.  Even accepting the first point as true (and I'm not 100% convinced it is with dirty records), the filter is going to take some time to actually filter out all of the contaminants from a wash.  I know it's certainly doing its job while the cavitation process is underway - I just wonder how long it takes to thoroughly filter everything.  I suspect that it's probably got time to remove the bulk of the crud which I imagine would be removed fairly early in the cavitation process.  However, there's a nagging feeling that there's got to be some of the particulate matter still suspended in the water that hasn't had time to pass through the filter.  At the end of the day, if you're happy with the results, it probably doesn't matter.  :thumb:
2 hours ago, ABG said:
Andy, I've been giving this some thought and am unsure about your findings.  What your essentially saying is that the cavitation process is removing all of the crud, not just loosening it   Yes!  This is with a 10m of cavitation ... which is just over 3 revolutions, with the motor on my tank.
and your filter is so fine that it's removing all of the suspended particulate matter before you take the records out of your machine.   Yes!
Even accepting the first point as true (and I'm not 100% convinced it is with dirty records), the filter is going to take some time to actually filter out all of the contaminants from a wash.  True - but my tank holds 8.2l and the pump says it's 10l per minute ... so for 10 minutes, it's going to filter the tank water 12 times!  So I reckon it is feasible all the crud is  coming out.
What you say is certainly valid, Andrew.
I've put my comments in situ, above.
Regards,
Chaps - this topic of water filtration seems detailed enough to deserve its own dedicated thread ;) , however a point about cleaning timing......
Note that, because the record is only partially immersed in the tank fluid at any given time, the total cleaning time for any point on the record surface is only a fraction of the total cleaning time period.  Inner grooves in particular, receive the shortest cleaning - by my calcs, only around 1/7th of the no. of mins/rev x the total mins cleaning time period.
eg. for a 2rpm motor & say a 15min tot. cleaning time, the inner grooves are immersed only for a total of around 1 minute!
The outer grooves are immersed for longer - for the same 2rpm mtr & 15 min cleaning, only for a total of less than 3 minutes.
Apologies if I'm stating the obvious, but a picture may help.....
Cheers, Owen
Edited by Owen Y
Are you sure ?
from what I know both inner and outer grooves are in the fluid exactly the same amount of time, the outer ones just cover more distance during the same time in the fluid.
57 minutes ago, joz said:
Are you sure ?
True, if the spindle centre was at the waterline. But in this case....... I'm still thinking it through :D
Well my first thought was if you think the outer line moves past the inner part of the line sure, but that would mean bending the line.
Now looking at it again I can see what @Owen Y  means and yep it looks right, damm that spindle being of centre:wacko:
Hmmmm, now you got me thinking and I'm not sure I like that:P
Chaps
Assembly - those who are assembling this kit, it is pretty simple with just 4 screws (+ 3 motor screws), but these notes may help:
  1. You should find the following parts - 3 pcs of laser-cut stainless sheet metalwork, a threaded stainless rod with plastic square adapter for the motor drive, 4 red record spacers & a bag containing 2 black 'clamp knobs', 4 stainless button head hex socket screws + spring washers, 1 ball bearing unit.
  2. Strip off the protective plastic from the sheet metal plates.
  3. The large stainless 'baseplate' has 4 protruding nuts under, which should slide under the cleaner tank flange from the short end of the tank - if you have the correct tank.
  4. Attach the 2 upstanding smaller side plates onto the fold-down sides of the main frame, using the 4 screws + washers (align flush the bottom edges of the plates to the baseplate bottom edge) - the correct orientation of the motor plate to the smaller bearing plate is shown in the pic below. (Note, the pic shows a prototype unit & the metalwork has machine marks ;) )
  5. Motor - remove the black attachment plate from the rotisserie motor & use the same 3 screws & spacers to attach the motor to the motor plate (as pic below) - don't overtighten, don't strip the motor plastic threading.
  6. Assemble the record-rod with its clamp knobs & spacers (as pic below) - the little bearing just sits in the cutout in the bearing plate.
Done!
Cheers, Owen
Edited by Owen Y
Thanks Owen for the kit. It left NZ on the 4th of May and I received it on 8th of May in Perth. Very impressive delivery time. The kit was very well packaged. Over the subsequent days my US bath and motor arrived. There initially was a delay in accessing the US bath, however the links posted earlier were useful. I have the impression that some of the adds listing these baths are actually the same company. Communication with them was quick and accurate.
I have just assembled the kit and the bath, Owen has made this very simple with the clear instructions above. At this stage every thing works as it should. I hope be able to use the bath over the next few days and start enjoying its benefits.
Thanks again Owen for the work you have done on this.
I decided to track down the Triton X-100 but there was none in Perth, so I have ordered through Scientific Chemical supplier. Comes in 500ml, I should have enough for the rest of my life! It will take 10 days for it to arrive.
Edited by Edd
Re. Detergent/surfactant I am using Triton X-100. (Pure non-ionic/neutral pH detergent, no additives or perfumes etc),
I am in NZ & I purchased from these people:
http://www.conservationsupplies.co.nz/product/triton-x100-cle01/
In Australia, I googled the following suppliers:
http://www.australianchemicalsuppliers.com/list/search?search=triton
I see that these guys in Oz sell it is 100mLqtys:
https://www.proscitech.com.au/?navaction=show_page&chapter=m&page=6#m035
(I wouldn't put their Ultrasonic Cleaning Agent on records.)
Someone else must sell in AU inmore economical say 500mL or 1L qtys?
Or the Tergitol equivalent.
Cheers, Owen
That's great.
Remember that the 6L tank actually contains around 4.5L of fluid.
So if you use say a 0.5% dilution, that's 22.5mL per tank - so 500mL will do around  22 tankfuls only. ;)
PS. I started using only 0.1% dilution & results are fine with new or near-new records.
Older s/h records looked like they need a bit more detergent and/or more cleaning time.
Cheers, Owen
Edited by Owen Y
  • Recently Browsing   1 member
    • By betty boop
      folks, considering an ultrasonic record cleaner... of the more affordable variety... I am not planning to spend on one costing the same as a turntable.
      And with more than my own share of home projects going on and plenty on the to do list no interest to be dong anything DIY in this regard.
      So what are folks experience with Affordable ultrasonic record cleaning machines of the non DIY variety ...
      theres this nobsound one on amazon - any thoughts or experience ?
      nobsound on amazon
      dont want to get one and find a waste of cash ? last thing world needs is more land fill
      any good experiences with anything out there (non DIY - please and affordable)
    • By Goatboy
      Item: Okki Nokki MKI  MKII RCM (White)
      Price: $520
      Item Condition: Excellent
      Reason for selling: NLR
      EDIT: This is a MKII and not a MK1, as I first thought. This means it is manufactured in China (not Germany) and has a plastic instead of metal wand. Apologies for any confusion caused !
      For sale is a MK II Okki Nokki record cleaner, purchased in 2014 from Krispy Audio. Included in the sale are wands for 12” and 7” records, a clamp, and dust cover. The cover and 7” wand are additional purchases and retail for $115 and $75 respectively, and the 7" wand is unused. The dust cover is a must IMO, as keeping dust from a RCM is pretty important !
      The unit has seen mild to moderate use, and there are months where it’s barely used.
      For anyone not familiar with the Okki Nokki, it is a wet - vacuum cleaning system, and works by first agitating debris from the record as it rotates via a brush placed along the grooves. After a few rotations (the unit has forward and reverse) the wand vacuums the liquid away, leaving you with a clean and hopefully crackle and pop - free record. It can’t perform miracles and fix a record retrieved from a dumpster, but for gunk, mould, fingerprints etc... it does a good job.  And with the debris and detritus new records come with, it’s a good idea to clean everything, not just 2nd hand purchases. Your needle will thank you.
      A few months after I received the unit, it had an issue with the vacuum cleaner which was easily fixed by a fuse replacement and was a common problem with this model. It has been trouble - free ever since.
      The original brush is long gone, so you’ll need to grab something suitable. There are plenty of options, and of course you’ll need to arm yourself with a record cleaning concoction.
      I’ll also throw in a back - up set of spare velvet strips, which attach to the 12” wand and should be changed about every 50 records.
      Shipping is possible as I have the box for the unit, however I don’t have one for the dust cover and so preference is given to local pick-up.
    • By Paul-H
      Item: RCM Sensor 2 Phono stage + Kuzma Stabi-S Turntable (with PS2 speed controller) + Stogi-S Tonearm + Lyra Delos Cart
      Price:
      RCM SENSOR 2 = $3800  - SOLD (TT still available)
      KUZMA STABI-S TT + STOGI-S tonearm + PS2 Upgraded Power supply + LYRA DELOS MC Cartridge = $6750
      (comes with free perspex dust cover, as per photos)
      Package Deal: $10K (RRP for this setup is approx 15K. Please note I prefer to sell this whole package COMPLETE)
      Item Condition: 9.5/10
      Reason for selling: Have purchased a new car and need funds for that.
      Payment Method: Cash on Pickup or Bank Deposit. Paypal is my last preference and you will need to pay an extra 3%.
      Preference given to local pickup VIC buyers.
      I can send interstate at buyers expense, but very much prefer not to because of risk of damage.
      Extra Info: I bought these last year from Sonic Purity in May 2018, so this gear is approx 1 year old.
      The sale is somewhat regrettable, however I have other priorities now.
      The RCM Sensor 2 phono stage is magic and extracts every detail from the Cartridge while giving strong bass.
      (Has Furutech Connections, and external latest power supply)
      There are many reviews online about the phono stage and many who have heard it will confirm its high reputation.
      It has a multitude of loading and gain options.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2
      The Kuzma Turntable is equally amazing in sound and build quality.
      Latest 2018 30mm thick platter!
      https://sonicpurity.com.au/store/turntables/kuzma-stabi-s
      It has the upgraded power supply which means you don't need to change pulleys etc to change the speed.
      The speed controller has a digital display.
      It comes with Stogi-S tonearm, and LYRA DELOS cartridge. (has had little use, but is run in. I honestly don't know the hours)
      Those who know this cartridge can tell you that its super detailed in the high frequencies and still has gorgeous midrange and strong bass.
      Cartridge azimuth has been painstakingly set up by Rom at Sonic purity, using computer software.
      I look after my equipment with a lot of care and live in a smoke free / pet free home.
      Auditions are welcome at my home only for SERIOUS BUYERS.
      Upon sale I always make donations to SNA.
      Thanks for watching.
      Paul.
      Happy Easter to all.
    • By gtee
      Item: Record Cleaning Machine
      Price Range: to $1000
      Item Condition: little used
      Am interested in a vacuum type record cleaning machine in really good condition.
      No real preference but prefer a quieter ( ? )  quality machine. Some have suggested a VPI, Okki Nokki Mk2, or the like.
      Please PM me with any offerings
      I am in South Brisbane.
      Thanks.
